Link-Belt Excavator 300X3 Service Manual WLSM3006-09LX 2018
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Link-Belt 300X3 Excavator
Engine: Isuzu AL-6HK1X Engine
Part Number: WLSM3006-09LX
Publication Date: 2018
Number of Pages: 1483 Pages
Excavator
Safety
Safety, General Information And Standard Torque Data
Standard Torque Data For Cap Screws And Nuts
A. Lower
Main Equipment Table (300x3)
Main Equipment Structure And Operation Explanation
Port Diagram
Basic Functions
Removal And Installation Of Track
Removal And Installation Of Roller
Removal And Installation Of Drive Sprocket
Removal And Installation Of Take-Up Roller
Assembly And Disassembly Of Take-Up Roller
Removal And Installation Of Grease Cylinder
Assembly And Disassembly Of Grease Cylinder
Removal And Installation Of Center Joint
Assembly And Disassembly Of Center Joint
Removal And Installation Of Travel Motor
Assembly And Disassembly Of Travel Motor
Maintenance Standards
Pressure Measurement And Adjustment Procedures
Drain Volume Measurement Procedures
Air Bleed Procedure
B. C. Swing Unit, Counterweight
Port Diagram
Basic Functions
Removal And Installation Of Swing Unit
Assembly And Disassembly Of Swing Motor
Assembly And Disassembly Of Swing Unit
Assembly And Disassembly Of Swing Reduction Gear
Removal And Installation Of Counterweight
Air Bleed Procedure
H. Engine
Basic Functions
Main Data
Function, Structure, And Operations
Symptom
Functional Inspection
Cautions For Maintenance
Removal And Installation Of Engine Assembly
Removal And Installation Of Fuel Cooler, Engine Intercooler, Radiator, And Oil Cooler
Removal And Installation Of Turbo Charger
Removal And Installation Of Egr Cooler And Egr Valve
Removal And Installation Of Engine Hood
Removal And Installation Of Dpd (Muffler)
Removal And Installation Of Cylinder Head Cover
Removal And Installation Of Cylinder Block
Lubrication System
Removal And Installation Of Exhaust Manifold
Disassembly, Removal And Installation Of Dpd Assembly
Removal And Installation Of Fuel Tank
Removal And Installation Of Fuel Supply Pump
Removal And Installation Of Common Rail Assembly
Removal And Installation Of Injector
Removal And Installation Of Starter Motor
Removal And Installation Of Alternator
Preheating System
Introduction To The Trouble Diagnosis
J. Hydraulic Equipment (Pump, Operation System Valve)
Basic Functions
Port Diagram
Hydraulic Device
Control Valve
5 Stack Solenoid Valve Operation Explanation
Upper Pilot Valve (Remote Control Valve)
Travel Pilot Valve (Remote Control Valve)
Cushion Valve
Pressure Bleeding Operations
Removal And Installation Of Hydraulic Oil Tank
Removal And Installation Of Hydraulic Pump
Removal And Installation Of Pump Coupling
Removal And Installation Of Control Valve
Removal And Installation Of Pilot Blocs
Removal And Installation Of Travel Remote Control Valve
Removal And Installation Of Operation Remote Control Valve
Removal And Installation Of 5 Stack Solenoid
Removal And Installation Of Cushion Valve
Procedures For Assembly And Disassembly Of Hydraulic Pump Main Unit
Pump Main Unit Maintenance Standards
Procedures For Assembly And Disassembly Of Control Valve
Procedures For Assembly And Disassembly Of Operation Remote Control Valve
Procedures For Assembly And Disassembly Of Travel Remote Control Valve
Assembly And Disassembly Of Cushion Valve
Hydraulic Pump Flow Measurement Procedures
Air Bleed Procedure
Hydraulic Equipment Layout
Overall View
J. Explanation Of Hydraulic Circuit And Operations (Standard)
J. Explanation Of Hydraulic Circuit And Operations (Option)
N. Cab
Removal And Installation Of Operator's Seat
Removal And Installation Of Cab Assembly
Removal And Installation Of Wiper
Removal And Installation Of Cab Front Glass
Removal And Installation Of Right-Side Window Glass
Removal And Installation Of Door (Upper) Sash Glass
Window Lock Adjustment Procedures
Tightening Torque
R. Electrical Parts
Electrical And Engine Functions And Service Support
Basic Functions
Battery Disconnect Switch
Reset
Milli-Amp List
Safety
Service Support
Setting
Service Monitor
Computer Explanation
Connection Connector Pin Layout
Sequence Circuit Diagram
Electrical Equipment Layout Diagram
Removal And Installation Of Wiper Controller
Removal And Installation Of Wiper Motor
Removal And Installation Of Monitor
Ecm Replacement Procedure
Removal And Installation Of Ecm
Removal And Installation Of Computer A
Removal And Installation Of Computer B
Air Conditioner Overall Diagram
Assembly And Disassembly Of Unit
Removal And Installation Of Compressor
Removal And Installation Of Condenser
Removal And Installation Of Receiver Dryer
Work Precautions
R. Electrical Connector Wiring Diagram
R. Electrical Parts And Wiring Assembly Diagram
V. Attachments
Removal And Installation Of Bucket Cylinder
Removal And Installation Of Arm Cylinder
Removal And Installation Of Boom Cylinder
Procedures For Operation/Assembly And Disassembly Of Hydraulic Cylinder
Port Diagram
Removal And Installation Of Hbcv
Air Bleed Procedure
Removal And Installation Of Bucket Link
Z. Other
Specifications
Arm Dimension
Main Unit Weight
Bolt Size And Torque Table
Overall View
Work Range Diagram
New Machine Performance Judgment Table
Fluids And Lubricants
Main Unit-Side Diagnostic Trouble Code List
Main Unit-Side Trouble
List Of Special Tools
Brand: Link-Belt
Excavator
Safety
A. Lower
Port Diagram
Basic Functions
Air Bleed Procedure
Port Diagram
Basic Functions
Air Bleed Procedure
H. Engine
Basic Functions
Main Data
Symptom
Lubrication System
Preheating System
Basic Functions
Port Diagram
Hydraulic Device
Control Valve
Cushion Valve
Air Bleed Procedure
Overall View
N. Cab
Tightening Torque
R. Electrical Parts
Basic Functions
Reset
Milli-Amp List
Safety
Service Support
Setting
Service Monitor
Work Precautions
V. Attachments
Port Diagram
Air Bleed Procedure
Z. Other
Specifications
Arm Dimension
Main Unit Weight
Overall View
Work Range Diagram
