Link-Belt Excavator 240X2-EX Parts Manual
- Download this document, you need 8625 Gallons
Brand: Link-Belt
Type of Machine: Excavator
Model: Link-Belt 240X2-EX Excavator
Number of Pages: 1063 Pages
Grouser Shoes 3-Bar (600mm) Sealed_ 007
Grouser Shoes 3-Bar (700mm) (Sealed)_ 007
Grouser Shoes 3-Bar (800mm) (Sealed)_ 007
Lower Under Cover_ 001
Center Guard_ 004
Track Guard (Triple)_ 004
Center Joint_ 003
Recoil Springs_ 003
Recoil Springs_ 004
Traction Equipment_ 004
Lower Frame_ 008
Lower Frame_ 002
Traction Motor Line_ 002
Upper Roller_ 010
Take-Up Roller_ 004
Take-Up Rollers_ 001
Lower Rollers_ 005
Lower Rollers_ 001
Counterweight_ 004
Upper Under Covers_ 000
Upper Under Covers_ 002
Turntable Bearing_ 005
Revolving Frame_ 003
Revolving Frame_ 009
Revolving Frame_ 001
Revolving Frame_ 001 (1)
Revolving Equipment_ 008
Engine (Isuzu 4hk1-Xyss02)_ 006
Engine (Isuzu 4hk1-Xyss02)_ 005
Engine (Isuzu 4hk1-Xyss02)_ 003
Engine (Isuzu 4hk1-Xyss02)_ 004
Muffler (Standard)_ 002
Radiator (Standard)_ 013
Air Cleaner (W_Element)_ 007
Fuel Tank_ 007
Fuel Lines_ 010
Fuel Lines_ 004
Single Pedal Control_ 001
Service Valve Control (Rh)_ 000
Service Valve Control (L)_ 000
Joystick Control_ 009
Drain Lines_ 001
Bucket & Arm Lines_ 001
Bucket & Arm Lines_ 000
Pilot Pressure & Return Lines_ 008
Pilot Pressure & Return Lines_ 009
Boom Lines_ 001
Boom Lines_ 001 (1)
Sump Tank_ 010
Sump Tank_ 002
Return & Oil Cooler Lines_ 003
Control Valve_ 005
Control Valve_ 004
Service Valve_ 000
Pilot Control Lines (Standard)_ 006
Pilot Control Lines (W_ Selector Valve)_ 004
Pilot Control Lines (Hbcv)_ 001
Plugs & Hardware_ 006
Plugs & Hardware_ 003
Plugs & Hardware_ 003 (1)
Wire Harness & Hydraulic Hardware_ 002
Plug Group (Fuel Tank)_ 000
Wire Harness & Hydraulic Hardware_ 003
Wire Harness & Hydraulic Hardware_ 003 (1)
Wire Harness & Hydraulic Hardware_ 005
Wire Harness & Hydraulic Hardware_ 005 (1)
Wire Harness & Hydraulic Hardware_ 002 (1)
Single Acting Circuit_ 001
Single Acting Circuit S_V_ 000
Double Acting Circuit S_V_ 000
Multi-Purpose + 3-Way Valve_ 003
Multi-Purpose + 3-Way Valve S_V_ 002
Hydraulic Pump_ 004
Hydraulic Pump (2nd)_ 007
Second W_Acting Circuit_ 003
Second W_Acting Circuit S_V_ 002
Floor Mat_ 000
Floor Mat (W_Service Valve)_ 000
Floor Mat_ 000 (1)
Pressure Lines_ 001
Suction Lines_ 003
Swing Lines_ 002
Traction Lines_ 002
Cab Guard (Fops Level 2) Lbx_ 001
Cab Front Guard (Mesh) (Lower)_ 000
Cab Front Guard (Mesh) (Upper)_ 001
Cab Front Guard (Opg Level 1)_ 003
Cab Front Guard (Opg Level 2)_ 001
Vandal Guard_ 001
Operator's Cab Lbx (Polyca)_ 000
Operator's Cab Lbx (Polyca)_ 001
Operators Cab Lbx Polycarbonate - Hatch_ 009
House_ 003
House_ 006
House_ 005
House_ 005 (1)
House_ 005 (2)
Console Box & Seat_ 001
Console Box & Seat (Air-Suspension)_ 009
Manual Holder Cable_ 000
Rain Deflector_ 001
Decals_ 005
Decals_ 001
Decals (Spanish Labels)_ 001
Decals (Spanish Labels)_ 001 (1)
Label (Pedal Controls W_Rh Service Valve)_ 001
Operator Label_ 001
Label (Knob Controls W_Rh Aux)_ 002
Label (Knob Controls W_Rh & Lh Aux)_ 001
Label (Aux Controls)_ 001
Decal (Inside Of Cab) (English)_ 006
Label (Knob Controls W_Lh Aux)_ 001
Labels (Pedal Controls W_Rh Serv Vlv) (Spanish)_ 000
Label (Std Pedal Controls) (Spanish)_ 000
Label (Knob Controls W_Rh Aux) (Spanish)_ 000
Label (Knob Controls W_Lh Aux) (Spanish)_ 000
Label (Knob Controls W_Rh & Lh Aux) (Spanish)_ 000
Label (Pedal W_Rh Srv Vlv;Lh & Rh Aux) (Spanish)_ 000
Decal (Cab Labels) (Spanish)_ 002
Rearview Mirrors_ 002
Spare Parts Kit_ 002
Spare Parts Kit (Eng & Safety Manuals & Filters)_ 000
Spare Parts Kit (Eng & Sfty Man & Filters) Span_ 000
Tools_ 004
Operator Labels (Iso)_ 002
Labels (Operator Controls)_ 000
Operators Label_ 000
Labels (Inside Cab) (Spanish)_ 000
Label (Selector Adjustment) (Spanish)_ 000
Label (Operation Pattern) (Spanish)_ 000
Label_ 008
Am_Fm Radio High Band_ 005
Air Conditioner (Cab)_ 009
Air Conditioner (Cab)_ 001
Air Conditioner (Frame)_ 008
Working Lights (Boom And House)_ 000
Working Light (Upper Cab)_ 000
Working Light (Cab W_Front Guard)_ 001
Working Light_ 001
Working Light_ 001 (1)
Back-Up Alarm_ 004
Back-Up Alarm_ 000
Window Washer_ 002
Window Washer_ 001
Cover_ 000
Controller_ 001
Controller_ 002
Controller_ 011
Dc-Dc Converter (12v-10a)_ 001
Stand Rear_ 001
Pressure Switch_ 000
Press Switch (Indicator)_ 001
Indicator Sensor_ 001
Electric Parts & Wire Harness (Frame)_ 010
Electric Parts & Wire Harness (Cab)_ 010
Electric Parts & Wire Harness (Cab)_ 008
Electric Parts & Wire Harness (Cab)_ 004
Electric Parts & Wire Harness (Frame)_ 004
Electric Parts & Wire Harness (Frame)_ 004 (1)
Batteries_ 001
Batteries_ 000
Horn_ 002
Fuel Feed Pump_ 003
Arm (Standard)(3.0m 9'-10_)(W_1st Aux Bar Bases)_ 002
Arm (Std)(3.0m 9'-10_) (W_Aux-2nd Opt.Bar Bases)_ 001
Arm (Std Hd) (3.0m 9'-10_) (W_1st Aux Bar Bases)_ 003
Arm (Std Hd)(3.0m)9'10_(W_Aux-2nd Opt Bar Bases)_ 003
Arm (Long) 3.5m 11'-6_ (W_1st Aux Bar Bases)_ 001
Arm (Long) 3.5m 11'-6_ (W_Aux-2nd Opt.Bar Bases)_ 000
Arm (Long) 3.5m 11'-6_ (W_Aux-2nd Opt.Bar Bases)_ 000 (1)
Arm (Long) 3.5m 11'-6_ (W_1st Aux Bar Bases)_ 001 (1)
Arm (Long) 3.5m 11'-6_ (W_Aux-2nd Opt.Bar Bases)_ 001
Arm (Long) 3.5m 11'-6_ (W_Aux-2nd Opt.Bar Bases)_ 001 (1)
Arm (Short Hd) 2.5m 8'-2_(W_1st Aux Bar Bases)_ 001
Arm(Short Hd)2.5m 8'-2_(W_Aux-2nd Opt.Bar Bases)_ 001
Boom (Back-Hoe) 5.85m 19'-2__ 006
Boom (Back-Hoe) 5.85m 19'-2__ 006 (1)
Boom (Back-Hoe Hd) 5.85m 19'-2__ 005
Boom (Back-Hoe Hd) 5.85m 19'-2__ 005 (1)
Boom (Back-Hoe) 5.85m 19'-2__ 004
Boom (Back-Hoe Hd) 5.85m 19'-2__ 004
Bucket Linkage (Standard)_ 001
Bucket Linkage (Std) (Em3)_ 001
Bucket Linkage (Build-Up)_ 001
Bucket Linkage (Build-Up)_ 001 (1)
Option Lines (Bar Base) (Std Arm)_ 002
Option Line (Bar Base) (Boom Back-Hoe)_ 000
Option Lines (Bar Base) (Short Arm)_ 001
Option Lines (Bar Base) (Long Arm)_ 001
Arm Cylinder Lines_ 004
Arm Cylinder Line (Hbcv)_ 004
Grease Lines_ 001
Bucket Cylinder Line (Arm Std) All Ems Bushing_ 005
Bucket Cylinder Line (Arm Short) All Ems Bushing_ 004
Bucket Cylinder Line (Arm Long)_ 005
Boom Cylinder Lines (Ems)_ 001
Boom Cylinder Lines (Hbcv) (5.85m) (19'2_)_ 003
Boom Cylinder Lines (Std) (5.85m) (19'2_)_ 001
Second Opt Aux Lines (Std Arm) (3.0m) (9'10_)_ 004
Second Opt Aux Lines (Short Arm) (2.5m) (8'2_)_ 003
Second Option Line (Arm Long)_ 000
Second Opt Aux Lines (Long Arm) (3.52) (11'7_)_ 001
Clamp - 9'-8_ (2.94m) Boom (W_1st Aux Bar Bases)_ 003
Clamp - 18'-8_ (5.70m) Boom (Aux Hyd Lines)_ 001
Clamps (Boom) (Aux & 2nd Option Hydraulic Lines)_ 002
Clamps (Std Arm)_ 000
Clamps (Std Arm)(9'8_)(W_Aux-2nd Opt. Bar Bases)_ 000
Clamp - (Hbcv)_ 003
Clamps (Short Arm) (Hd)_ 000
Clamps (Short Arm) (W_Aux-2nd Opt. Bar Bases)_ 000
Clamp (Boom Hbcv) (Aux Hyd Lines)_ 000
Clamp (Boom Hbcv) (W_Aux-2nd Opt.Bar Bases)_ 002
Clamp (Boom) (W_2nd Opt.Bar Bases)_ 003
Clamp (Boom Hbcv) (W_2nd Opt.Bar Bases)_ 003
Clamps (Short Arm) (2.5m) (8'2_) (2nd Opt Lines)_ 001
Clamps (Std Arm) (9'10_) (2nd Opt Lines)_ 001
Clamps (Lng Arm) (3.52m) (11'7_) (Option 1 & 2)_ 000
Plug Bolts (Short Arm)_ 001
Clamps (Short Arm)_ 001
Clamps (Long Arm) (3.52m) (11'7_) (Option 2)_ 001
Hydraulic Pump (Std) (Part# Kbj10510)_ 004
Hydraulic Pump (Pto) (Part# Kbj12360)_ 002
Gear Pump (Part# Krj10300)_ 002
Gear Pump (Part# Krj34770)_ 001
Traction Motor (Part# Kba10290)_ 002
Traction Motor (Part# Kba12640)_ 003
Traction Motor (Part# Kba14020 )_ 000
Traction Motor (Part# Kba14420 )_ 000
Swing Motor (Part# Kbc10020)_ 006
Swing Motor (Part# Kbc10012)_ 000
Swing Motor (Part# Kbc10010)_ 000
Boom Cylinder (Part# Kbv10980 )_ 001
Boom Cylinder (Bushing) (Ems) (Part# Kbv25220)_ 004
Boom Cylinder (Bushing) (Ems) (Part# Kbv25230)_ 004
Boom Cylinder Rh (All Ems Bushing) Hbcv (Part# Kbv25240 )_ 003
Boom Cylinder Lh (All Ems Bushing) Hbcv (Part# Kbv25250)_ 003
Boom Cylinder (Part# Kbv11000 )_ 001
Arm Cylinder (Std) (Part# Kbv11020)_ 003
Arm Cylinder (Hbcv) (Part# Kbv11100)_ 003
Bucket Cylinder (Part# Kbv24080)_ 003
Bucket Cylinder (Part# Kbv11040)_ 001
Control Valve (Part# Krj10310)_ 001
Control Valve (Part# Kbj10390)_ 002
Control Valve (Part# Kbj12020)_ 002
Control Valve (Part# Kbj10391)_ 002
Control Valve (Part# Kbj12021)_ 002
Control Valve (Part# Kbj10392)_ 002
Control Valve (Part# Kbj10394)_ 001
Control Valve (Part# Kbj10393)_ 001
Control Valve (Part# Kbj12022)_ 001
Control Valve (Part# Kbj12023)_ 002
Control Valve (Add-On Option 2) (Part# Krj10331)_ 000
Solenoid Valve (Part# Khj14000)_ 001
Solenoid Valve (Part# Khj14520)_ 001
Solenoid Valve (Part# Khj14780)_ 001
Solenoid Valve (Part# Krj3557)_ 001
Solenoid Valve (Part# Khj0659)_ 001
Remote Control Valve (Part# Krj5803)_ 000
Remote Control Valve (Part# Khj13290)_ 001
Remote Control Valve (Part# Khj10450)_ 000
Remote Control Valve (Part# Khj19270)_ 002
Remote Control Valve (Joystick) (Part# Khj13291)_ 001
Remote Control Valve (Part# Khj13292)_ 001
Remote Control Valve (Part# Khj19271)_ 001
Selector Valve (Part# Khj12080)_ 001
Stop Valve (Part# Khv10430)_ 001
Stop Valve (Part# Khv10440)_ 001
Stop Valve (Part# Khv13530)_ 000
Stop Valve (Part# Khv10670)_ 000
Stop Valve (Part# Khv10690)_ 000
Direction Valve (Part# Khj10420)_ 001
Shut-Off Valve (Part# Khj10410)_ 002
Cushion Valve (Part# Khj1399)_ 001
Cushion Valve (Pilot Control Lines) (Part# Kbj12430)_ 000
Cushion Valve (Part# Kbj12431)_ 001
Cushion Valve (Part# Kbj12432)_ 000
Relief Valve (Part# Khj15050)_ 002
Holding Valve (Part# Krv11110 )_ 001
Holding Valve (Part# Krv11120)_ 000
Holding Valve (Part# Ksv17260)_ 000
Fuel Prefilter (Part# Khh12020)_ 001
Fuel Pre-Filter (Part# Khh16390)_ 001
Fuel Filter (Part# Khh10550)_ 000
Radiator (Part# Kbh10800)_ 001
Radiator (Part# Kbh10801 )_ 000
Reduction Gears (Part# Kbc10030)_ 001
Reduction Gears (Part# Kbc10032)_ 000
Engine Gasket Kit_ 000
Cylinder Head Cover_ 000
Cylinder Head_ 000
Cylinder Block_ 000
Oil Pan And Level Gauge_ 000
Camshaft And Valve_ 000
Crankshaft_ 000
Timing Gear Case And Flywheel Housing_ 000
Inlet Manifold_ 000
Exhaust Manifold_ 000
Ventilation System_ 000
Water Pump And Corrosion Resistor_ 000
Thermostat And Housing_ 000
Engine Water Piping_ 000
Fan And Fan Belt_ 000
Turbocharger System_ 000
Fuel Injection System_ 000
Fuel Filter And Bracket_ 000
Fuel Pump And Pipe_ 000
Oil Cooler And Oil Filter_ 000
Oil Pump And Oil Strainer_ 000
Engine Oil And Vacuum Piping_ 000
Emission Piping_ 000
Engine Electrical Control Parts_ 000
Starter_ 000
Generator_ 000
Injection Pump Miscellaneous Parts_ 000
Radiator_ 000
Side Cover To Trans Case_ 000
Wiring Harness And Fuse_ 000
Wiring Harness Fixing Parts_ 000
Electrical Control And Other Parts_ 000
Brand: Link-Belt
Center Guard_ 004
Center Joint_ 003
Recoil Springs_ 003
Recoil Springs_ 004
Lower Frame_ 008
Lower Frame_ 002
Upper Roller_ 010
Take-Up Roller_ 004
Lower Rollers_ 005
Lower Rollers_ 001
Counterweight_ 004
Fuel Tank_ 007
Fuel Lines_ 010
Fuel Lines_ 004
Drain Lines_ 001
Boom Lines_ 001
Boom Lines_ 001 (1)
Sump Tank_ 010
Sump Tank_ 002
Control Valve_ 005
Control Valve_ 004
Service Valve_ 000
Hydraulic Pump_ 004
Floor Mat_ 000
Floor Mat_ 000 (1)
Pressure Lines_ 001
Suction Lines_ 003
Swing Lines_ 002
Traction Lines_ 002
Vandal Guard_ 001
House_ 003
House_ 006
House_ 005
House_ 005 (1)
House_ 005 (2)
Rain Deflector_ 001
Decals_ 005
Decals_ 001
Operator Label_ 001
Tools_ 004
Label_ 008
Working Light_ 001
Back-Up Alarm_ 004
Back-Up Alarm_ 000
Window Washer_ 002
Window Washer_ 001
Cover_ 000
Controller_ 001
Controller_ 002
Controller_ 011
Stand Rear_ 001
Batteries_ 001
Batteries_ 000
Horn_ 002
Fuel Feed Pump_ 003
Grease Lines_ 001
Clamp - (Hbcv)_ 003
Cylinder Head_ 000
Cylinder Block_ 000
Crankshaft_ 000
Inlet Manifold_ 000
Starter_ 000
Generator_ 000
Radiator_ 000
- Linkbelt LS108C Parts, Operation Maintenance and Load Chart Manuals
- Linkbelt Greer BBTM-508/BB-509 ANTI TWO-BLOCK ALARM SYSTEM – HYDRAULIC CRANE SYSTEM LAYOUT
- Link Belt 350X3 Excavator Schematic Service Manual
- Linkbet LS 118 Operator's Manual
- Link Belt 145X3 Hydraulic Excavators Operator's Manual
- Link Belt 3400 Quantum Excavator Schematic Shop Manual
- Link Belt HTC86100 Operator's Manual
- Link Belt RTC80130 Parts Manual
- Linkbelt RTC-8065 II Operator's Manual (Spanish)
- Link Belt 2800 Quantum Excavator Shop Manual
- Link Belt RTC-80130 II Operator's Manual
- Linkbelt LS 98 Operator's Manual
- Link Belt 210X2-EX Excavators Parts Manual
- MicroGuard 404 Trouble Shooting Manual
- Linkbelt LS-278 Rated Capacity Limiter Operators Manual
