118
6,911
Link-Belt Excavator 135 Spin Ace Tier 3 Shop Manual
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Shop Manual, Hydraulic And Electrical Schematic
Model: Link-Belt 135 Spin Ace Tier 3 Excavator
Engine: Isuzu AJ-4JJ1X Diesel Engine
Number of Pages: 756 Pages
Main Frame Section
Specifications
General
1. Main Data
2. Performance
3. Main Frame Dimensions
4. Engine
5. Cooling System
6. Upper Side Operating System
7. Operating Device
8. Swing Unit
9. Propulsion Lower Frame
10. Bulldozer Blade
Hydraulic Equipment
1. Hydraulic Device
2. Control Valve, Cylinder
Capacities, Filters
1. Coolant And Oil Capacities
2. Hydraulic Oil Filters
3. Fuel Filter
Lifting Capacity
Precautions For Lifting Loads With The Hydraulic Excavator
Lifting Capacities
Overview
Overview (130x2)
1. Standard Arm (2.50 M)
2. Long Arm (3.01 M)
Overview (130x2) [Blade])
Operating Range Diagram
Operating Range Diagram (130x2)
Operating Range Diagram (130x2 [Blade])
Summary Section
Main Equipment Table
Lower Component
1. Drive Unit
2. Pickup Roller
3. Top Roller
4. Bottom Roller
5. Tension Spring
6. Shoe
Upper Component
1. Swing Unit
Engine Related
1. Engine
2. Muffler
3. Air Filter (Dual Element)
4. Radiator
Device Hydraulic
1. Hydraulic Pump
2. Pump P - Q Diagram
Control Related
1. Control Valve
2. Solenoid Valve (4 Pipes)
3. Remote Control Valve (Left/Right, Propulsion Operation)
4. Remote Control Valve Characteristics Diagram
5. Cushion Valve (Thermal Circuit, With Shuttle Valve)
6. Selector Valve (Option)
7. Center Joint
Backhoe Attachment
1. Cylinder
2. Attachments
Equipment Layout Diagram
Main Equipment Layout
Consumable Parts Layout
Standard Machine Options List
Optional Components List
Hydraulic Equipment Section
Hydraulic Equipment Layout
Overview
Pump Chamber Hydraulic Equipment Layout
Hydraulic Equipment Layout Center Section Of The Swing Frame
Hydraulic Equipment Layout On The Left Side Of The Body
Hydraulic Equipment Layout In The Cab
Port Diagram
Pump
1. Hydraulic Pump (Standard Model)
2. Hydraulic Pump (Blade Model)
Valves
1. Control Valve
2. Control Valve (Blade Model)
3. 4-Pipe Solenoid Valve
4. 2-Pipe Solenoid Valve
5. Remote Control Valves (Top, Propel)
6. Cushion Valve
7. 2-Way Selector Valve (Optional For North America)
8. 4-Way Selector Valve (Optional For Export, Europe)
9. Direction Valve/Shut-Off Valve
10. Hbcv (Optional For Export, Europe)
Manifolds
1. Under-Cylinder Manifold Cab
2. Manifold (Accumulator Section)
3. Manifold (Hydraulic Oil Tank Section)
Engines
1. Swing Motor
2. Propulsion Motor
3. Center Joint
Pilot Hose Connection Diagram
T And P Pilot Lines
Pilot Control Line
Pilot Control Line (2-Way Selector Valve) (Optional For North America)
Pilot Control Line (4-Way Selector Valve) (Optional For Export, Europe)
Blade Line
Function List
Function Table
Explanation Of New Features
1. Swing Relief Cut-Off Control
2. Optional Line Flow Adjustment Control
3. General Purpose Circuit One-Touch Switch Control (Hammer  Jaw)
4. Bucket Closing Regenerative Circuit
Theory Of Operation Hydraulic Circuit (Standard Model)
Propulsion Circuit
Low-Speed Propulsion Circuit
High-Speed Propulsion Circuit
Straight-Line Propulsion Circuit (With/Without Hbcv)
Swing Circuit
Swing Relief Cut-Off Control Circuit
Swing Priority Circuit (With/Without Hbcv)
Swing Brake Circuit
Swing Parking Circuit (Lever In Neutral Position)
Swing Parking Circuit (Brake Release)
Swing Parking Circuit (Machine Stop)
Boom Circuit
Boom Lift Circuit (Simple Operation)
Boom Lift Circuit (Simple Operation) (With Hbcv)
Boom Lift Circuit (Boom Lift + Boom Retract) Boom)
(With/Without Hbcv)
Boom Down Regenerative Circuit
Boom Down Regenerative Circuit (With Hbcv)
Boom Down Tilt Prevention Circuit (With/Without Hbcv)
Boom Down Load Holding Valve Circuit (With/Without Hbcv)
Boom Circuit
Boom Extension Circuit (With/Without Hbcv)
Boom Retraction Forced Regenerative Circuit (With/Without Hbcv)
Boom Retraction Load Holding Valve Circuit (With Hbcv)
(Optional For Export)
(Europe)
Arm Retract Load Holding Valve Circuit (Without Hbvc)
Bucket Circuit
Bucket Open Circuit
Bucket Close Regenerative Circuit
Negative Control Circuit
Negative Control Circuit (Bucket Close)
Power Boost Circuit
Arm Retract Power Boost Circuit (With/Without Hbvc)
Propulsion Power Boost Circuit
Other Circuits
Cushion Circuit (Arm Extend Operation)
Cushion Circuit (Arm Extend Interrupted Operation)
Cushion Circuit (Arm Extend  Retract Operation)
Thermal Circuit (Lever In Neutral Position)
Automatic Pressure Boost Circuit (Bucket Closing)
Hydraulic Circuit Operation Theory (Optional)
Optional Circuits
Hammer Circuit (Simple Operation)
Reciprocating Circuit (Hydraulic Fork)
General Purpose Circuit (Hammer Q Control)
General Purpose Circuit (Jaw With 2 Pumps Flow)
Optional Second Circuit (Hydraulic Swing Fork)
Blade Circuit (Blade Lifting Circuit)
Blade Circuit (Blade Lowering Circuit)
Structure And Operation Theory Of Main Equipment
Pump
1. Hydraulic Pump
2. Governor
3. Gear Pump
Motor
1. Travel Motor
2. Swing Motor
Valve
1. Control Valve
2. Operating Theory 4-Pipe Solenoid Valve
3. Overhead Pilot Valve (Remote Control Valve)
4. Propulsion Pilot Valve (Remote Control Valve)
5. Damper Valve
6. Direction Valve (3-Way)
7. Hbcv Check Control Valve (Optional For Export/Europe)
Electrical System Section
Explanation Of New Functions
Working Mode Selector
The Throttle Control And Working Mode Selector Are Linked.
Computer Connection Method
Monitor Changes
Pilot Pressure Switch Changed To Pressure Sensor
Pump Electromagnetic Proportional Valve
1. Power Control Proportional Valve
2. P1 Flow Control Proportional Valve
System Control For Energy Saving
1. Fuel Consumption Reduction Using Transient Load Shedding Control
2. Fuel Consumption Reduction Using Swing Relief Cut-Off Control
Electrical Equipment Layout Diagram
Overview
1. Main Unit Right-Side Layout Diagram (Radiator Chamber)
2. Engine Section Layout Diagram
3. Main Unit Left-Side Layout Diagram (Pump Chamber)
4. Main Unit Center Section Layout Diagram
5. Cab Layout Diagram
6. Surrounding Layout Operator's Seat
Independent Parts Diagram
Main Equipment Structural Diagrams
Connector Pin Connection Diagram
1. Computer A
2. Monitor
Electrical Circuit Diagram
Overview
1. Sequence Circuit Diagram
Block Diagram
1. Computer A
2. Ecm
3. Monitor Screen
4. Air Conditioner
5. Lever Lock
6. Horn
7. Work Light
8. Optional
9. Others
10. Electrical Symbol List
Electrical Connector Wiring Diagram
Harness
1. Main Frame Harness
2. Cab Main Harness
3. Cab Sub-Harness
4. Cab Interior Harness
5. Engine Harness
6. Right Console Harness
7. Left Console Harness
Electrical Symbol List Wiring Harness And Electrical Parts
Main Frame
Explanation Of Functions And Operations
Explanation Of Electrical Functions
Engine Speed Control
1. Throttle Control
2. Idle Control (Auto/One-Touch)
3. Idle Start
4. High Idle Shift
5. Automatic Warm-Up
Engine Start/Stop Control
1. Engine Start/Stop Criterion
2. Power Cut-Off Delay
3. Emergency Engine Stop
4. Neutral Start
Pump Control
1. Work Mode Control
2. Pump Power Boost Control
3. Pump Power Cut-Off Control
Swing
1. Swing Brake
2. Freewheel (Optional For North America)
3. Swing Lock (For Maintenance)
4. Swing Relief Cut-Off
Propulsion
1. Swing Speed Change Propulsion
2. Propulsion Alarm
Control Valve
1. Lever Lock
2. Stall Prevention Solenoid
3. Boost Pressure Control
Monitor Control
1. Bar Graph (Coolant Temperature Gauge, Oil Temperature Gauge, Fuel Gauge)
1. Horn
2. Work Light
3. Windshield Wipers And Washers
4. Dome Bulb
5. Radio Mute
Other
1. Protection
2. Battery Saver Function
3. Alternator Power Generation Detection
4
. Overload Alarm (Optional For Europe)
Options
1. Optional Line Control
2. Optional Line Control
3. Automatic Feed Pump Shutdown
4. Return Filter Clogging Detected
5. Beacon (Optional For Europe)
Service Support
Screen Operation
1. Screen Change
Screen List
1. Chk Screen List (Status Screen)
2. Diag Screen (Troubleshooting)
3. Hr Screen List (Usage Log)
4. Cfg Screen (Setting Change)
5. Cal Screen (Troubleshooting Assistance)
6. Monitor Switch Check Screen (Self-Diagnostic Function)
7. Optional Flow Rate Setting
8. Anti-Theft Protection Setting
9. Model Setting
10. Engine Display Information
Screen Details
1. Display Message List
Trouble Screen
1. Display Diagnostic Trouble Codes
2. Main Unit Diagnostic Trouble Code List
3. Diagnostic Trouble Code (Monitor Display)
4. Sensor Trouble Operation Table
5. Epf (Engine Protection Function)
Engine Section
Engine Overview
Main Data Table (Differences From Model 3)
General Appearance Diagram
Auxiliary Equipment And Sensor Layout (Left)
Auxiliary Equipment And Sensor Layout (Rear)
Engine System Diagram
Fuel System Diagram
Detailed Parts Diagrams
1. Ecm (Engine Control Module)
2. Supply Pump/Scv (Suction Control Valve)
3. Common Rail
4. Common Rail Pressure Sensor/Pressure Limiter
5. Injector
6. Engine Coolant Temperature Sensor
7. Sensor Engine Oil Pressure
8. Camshaft Position Sensor (Cmp Sensor)
9. Crankshaft Position Sensor (Ckp Sensor)
10. Atmospheric Pressure Sensor
11. Intake Air Temperature Sensor
12. Boost Pressure Sensor
13. Boost Temperature Sensor
14. Charge Fuel Pump
15. Egr Cooler
16. Egr Valve
Engine Control Overview
Engine Terms Explanation
Function Explanation Table
Engine Structure Explanation
Exhaust Gas Technology
1. Common Rail System
2. Multi-Stage Fuel Injection (Multiple Injection)
3. Intercooler
4. Egr (Exhaust Gas Recirculation)
Engine Theory Of Operation
General Engine
1. Comparison Of 4bg1t And 4jj1
Fuel Unit
1. Common Rail System Overview
2. Injection Method Change Points (Regulator, Common Rail)
3. Injector Operating Theory
4. Supply Pump Operating Theory
5. Supply Pump Disassembly Diagram
6. Pressure Limiter
7. Maintenance Precautions
Engine Control Explanation
1. Fuel Injection Quantity Correction
2. Initial Q Correction
3. Preheating Control (Qos, Quick Start)
4. Atmospheric Pressure Correction (High Altitude Correction)
5. Superheat Control
6. Boost Temperature Rise Control
7. Engine Oil Pressure Drop Control
8. Starting Control (Coolant Temperature Control)
9. Long Turn Start Control
10. Starting Control For A Smaller Cylinder Count
11. Normal Shutdown (Key Switch In The Off Position)
12. Engine Start/Stop Criteria
Engine Maintenance Standards
Engine Information Display
Monitor Operation Method
Engine Information Copying Method (Q Resistor, Qr Code, Engine Serial Number)
Injector Qr Code Rewriting
When Replacing The Computer
Engine Information Acquisition Timing
Engine Information Reacquisition
Troubleshooting Display
Engine Equipment Table
Compatibility Of Electrical Parts Of The Third Exhaust Gas Accessory (Isuzu Part Number)
Exhaust Gas Regulations
Characteristics Of Materials Subject To Exhaust Gas Regulations
Exhaust Gas Regulation Values
Precautions For The Fuel Used
Fuel Engine And Fuel Filter Maintenance
1. Fuel To Be Added
2. Fuel Filter Maintenance
Air Conditioner Section
Change List
Layout Diagram
General Air Conditioner Diagram
1. Frame
2. Cab
Air Conditioner Circuit Diagram
Control Explanation
1. Air Intake Motor Actuator Control
2. Fan Mode Motor Actuator Control
3. Recirculation/Refresh Switch Motor Actuator Control
4. Fan Ampere Control
5. Compressor Clutch Control
6. Coolmax Control And Hotmax Control
7. Troubleshooting And Post-Troubleshooting Control
Problems
8. Monitor Mode
9. Door Switch Control
10. Indoor Air Filter Clogging Detection Control
Actuator Inspection
Air Intake Motor Actuator Inspection
Recirculation/Fresh Air Motor Actuator Inspection
Mode Motor Actuator Inspection
Self-Diagnostic Function With Panel Display
Trouble Screen And Self-Test Procedure
1. Trouble Screen Position
2. Trouble Screen Explanation
3. Monitor Mode Explanation
Part Function And Ok/Ngo Criteria
Control Panel And Control Unit
Fan Amperage
Relay
Air Intake Actuator
Refresh/Recirculation Actuator
Fan Mode Actuator
Evaporator Sensor
Dual Pressure Switch
Solar Radiation Sensor
New Machine Performance Section
Worksheet Performance Evaluation Check
Performance Evaluation Record Sheet
New Machine Performance Evaluation Standards
Reference Values (130)
Measurement Method And Position Of Main Unit
Engine Speed
Pressure In Each Section
Cylinder Drop Amount
Attachment Speed
Swing Speed
Swing Brake Angle (180°)
Propulsion Speed
Travel Amount
Sprocket Propulsion Speed
Shoe Tension Amount
Ball Bearing Guide Swing Amount And Bucket End Movement Amount
Maintenance Section
Pressure Measurement And Adjustment Procedures
Pressure Measurement Procedures Using The Monitor Screen
1. Pressure Measurement Method
2. Operating Method
Oil Temperature Measurement Procedures Hydraulics Using The Monitor Screen
1. Hydraulic Oil Temperature Measurement Method
2. Operating Method
Procedures For Measuring Pressure Using A Pressure Gauge
1. Preparations
2. Items To Be Prepared
Pressure Measuring Ports
Control Valve
1. Location Of Relief Valves
Preparations For Pressure Measurement
1. Measuring Main Pressure
2. Measuring Pilot Pressure
3. Measuring Negative Control Pressure
Pressure Adjustment
1. Adjusting Main Pressure
2. Adjusting Pilot Pressure
Procedure For Measuring Hydraulic Pump Flow
Procedures For Measuring Flow Using A Flowmeter
1. Preparations
Preparations For Work
Measuring The Flow
Drain Volume Measurement Procedure
Preparations
Propulsion Motor Drain Volume Measurement
Swing Motor Drain Volume Measurement
Air Bleeding Procedure
Propulsion Motor
Swing Motor
Hbcv (For Export, Europe)
1. Boom Cylinder Hbcv
2. Arm Cylinder Hbcv
Procedures For Replacing Consumable Parts
Air Conditioner Belt And Fan Belt Replacement
1. Air Conditioner Belt Replacement
2. Fan Belt Replacement
Main Fuel Filter Replacement
1. Filter Replacement
2. Air Bleeding
Engine Oil Filter And Engine Oil Replacement
1. Engine Oil Replacement
2. Engine Oil Filter Replacement
Radiator Coolant Replacement
Cleaning And Air Filter Replacement
Hydraulic Oil Filter Replacement
1. Return Filter Replacement
2. Intake Filter Replacement
3. Air Breather Element Replacement
4. Pilot Oil Filter Replacement
5. Hydraulic Oil Replacement
Other
1. Coolant Filling
2. Windshield Washer Fluid Filling
Periodic Maintenance Procedures
Maintenance Every 250 Hours
1. Battery Inspection And Replacement
Maintenance After The First 250 Hours For A New Machine/Every 1,000 Hours
Thereafter
1. Swing Reduction Gear Oil Replacement
2. Gear Oil Filling
Replacing The Hydraulic Sealing Fluid In The Flanges At The Bottom Of The Fuel Tank
Size And Torque Chart Bolts
Bolt And Nut Tightening
Tightening Torque Table
Data Section
Main Unit Weight
Divided Weight (Standard Specifications)
Weight Of Independent Parts
Shoe Weight (Per Side)
Arm Weight
Interchangeability
Interchangeability
1. Main Parts Interchangeability Table (130x2)
Accessory Installation Methods
Accessory Dimensions
Paint Colors
Paint Colors
Unit Conversion Ratio
4jj1x
Isuzu 4jj1x
Link-Belt Excavator 130x2 Shop Manual Es_12
Link-Belt Excavator 130x3 Operator Manual 130x3-Om-Lxg-00-Fr_16
130x3-Om-Lxg-00-Fr
Chapitre 1 - À L'intention Du Propriétaire
Manuels Techniques Link-Belt
Chapitre 2 - Composants De L'excavatrice
Composants Du Moteur
Numéros D'identification
Chapitre 3 - Sécurité, Autocollants Et Signaux Manuels
Règles De Sécurité
Zone De Sécurité
Sécurité Concernant Les Services Publics
Précautions À Prendre Par L'opérateur
Autocollants
Signaux Manuels
Chapitre 4 - Instruments Et Commandes
Cabine
Marchepieds Et Barres D'accès
Emplacement Des Commandes Et Accessoires De La Cabine
Siège De L'opérateur
Commandes Du Siège
Bras De Commande Droit
Bras De Commande Gauche
Console Avant
Écran D'affichage De L'ordinateur
Commandes De L'écran De L'ordinateur
Écran D'affichage De Menu
Liste Des Écrans Message
Commande De Chauffage, De Ventilation Et De Climatisation
Sélecteur De Configuration De Commandes
Levier De Commande Gauche De Pivotement Du Bras Et De La Superstructure Dans La Configuration D
Levier De Commande Droit De La Flèche Et Du Godet Dans La Configuration D
Levier De Commande Gauche De Pivotement Du Bras Et De La Superstructure Dans La Configuration C
Levier De Commande Droit De La Flèche Et Du Godet Dans La Configuration C
Commande De Déplacement
Pédale Unique De Déplacement
Fonctionnement De La Lame
Verrouillage De La Porte
Éclairage De La Cabine
Crochet Porte-Manteau
Vitres De Portière De La Cabine
Porte-Gobelet
Plateau De Rangement
Compartiment De Rangement
Boîte À Fusibles
Radio De La Cabine
Pare-Brise
Vitre Avant Inférieure
Évents D'aération
Vitre Arrière
Rétroviseurs
Caméra De Recul
Réservoir De Carburant
Capot Du Moteur
Compartiment De Rangement Avant
Réservoir Du Lave-Glace
Portes Latérales
Point De Remorquage
Œilletons De Levage
Protection Antivandalisme
Protection De La Cabine (Arceau De Sécurité Et Protection Contre La Chute D'objets)
Chapitre 5 - Instructions D'utilisation
Avant D'utiliser L'excavatrice
Utilisation De L'excavatrice
Période De Rodage
Dispositif De Protection Antivol
Démarrage Du Moteur
Montée De L'excavatrice Jusqu'à La Température De Fonctionnement
Fonctionnement Du Moteur
Arrêt Du Moteur
Diffuseur De Particules Diesel
Utilisation De L'excavatrice Par Temps Froid
Utilisation De L'excavatrice Par Temps Chaud
Utilisation De Base
Blocage Du Pivotement
Déplacement De L'excavatrice
Utilisation De L'excavatrice Dans L'eau
Stationnement De L'excavatrice
Utilisation De L'excavatrice Sur Un Sol En Pente
Remorquage De L'excavatrice
Utilisation Du Godet
Manipulation De Charge
Abaissement De L'accessoire En Cas De Panne De L'excavatrice
Circuits Hydrauliques Auxiliaires
Fonctionnement De L'accouplement Rapide De L'excavatrice Hydraulique
Chapitre 6 - Périodicité D'entretien
Compteur Horaire
Inspections Quotidiennes
Écran D'informations Sur La Maintenance
Chapitre 7 - Lubrification, Filtres Et Liquides
Liquides Et Lubrifiants
Tableau De Lubrification
Points De Lubrification
Niveaux Des Liquides
Moteur
Circuit De Refroidissement
Circuit De Carburant
Relâchement De La Pression Dans Le Circuit Hydraulique
Circuit Hydraulique
Purge De L'air Des Composants Hydrauliques
Filtre À Air
Réducteur De Vitesse De Pivotement
Réducteurs De Vitesse De Déplacement
Chapitre 8 - Maintenance Et Réglages
Chenilles
Galets De Chenille Et Roues De Retour
Radiateur Et Refroidisseur D'huile
Courroie De Ventilateur Et D'alternateur
Inspection Et Nettoyage De L'excavatrice
Vérification De L'absence De Fuites Au Niveau Des Vérins
Remplacement D'un Godet
Extincteur (Non Fourni)
Soudage Sur L'excavatrice
Pièces En Plastique Et En Résine
Climatisation
Inspection Des Couples De Serrage De La Boulonnerie
Dépannage Du Moteur
Chapitre 9 - Circuits Électriques
Fusibles
Sectionneur De Batterie
Batterie
Connexion D'une Ou De Deux Batteries D'appoint
Alternateur
Démarreur
Remplacement D'une Ampoule
Chapitre 10 - Instructions De Transport Et D'entreposage
Transport De L'excavatrice
Levage De L'excavatrice
Entreposage De L'excavatrice
Chapitre 11 - Spécifications
Moteur
Circuit Hydraulique
Poids
Châssis De Roulement
Contenance Des Circuits Et Composants
Accessoire
Force De Creusage
Dimensions Hors Tout De L'excavatrice
Plage De Fonctionnement
Capacités Nominales De Levage Iso
Chapitre 12
Index
Chapter 1 - For The Owner
Link-Belt Technical Manuals
Engine Components
Identification Numbers
Chapter 3 - Safety, Decals, And Hand Signals
Safety Rules
Safety Zone
Utility Safety
Operator Precautions
Hand Signals
Steps And Access Bars
Location Of Cab Controls And Accessories
Operator's Seat
Seat Controls
Right Control Arm
Left Control Arm
Front Console
Computer Display Screen
Computer Screen Controls
Menu Display Screen
Message Screen List
Heating, Ventilation, And Air Conditioning Control
Control Configuration Selector
Left Boom And Topside Swing Control Lever In Configuration D
Right-Hand Boom And Bucket Control Lever In Configuration D
Left-Hand Arm And Superstructure Swing Control Lever In Configuration C
Right-Hand Boom And Bucket Control Lever In Configuration C
Travel Control
Single Travel Pedal
Blade Operation
Door Lock
Cab Light
Coat Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Cab Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Mirrors
Backup Camera
Engine Cover
Front Storage Compartment
Windshield Washer Fluid Reservoir
Side Doors
Tow Point
Lifting Eyes
Vandal Protection
Cab Protection (Roll Bar) Safety And Protection Against Falling Objects
Before Using The Excavator
Using The Excavator
Running-In Period
Anti-Theft Protection Device
Starting The Engine
Raising The Excavator To Operating Temperature
Operating The Engine
Stopping The Engine
Diesel Particulate Diffuser
Using The Excavator In Cold Weather
Using The Excavator In Hot Weather
Basic Operation
Swing Lock
Traveling The Excavator
Using The Excavator In Water
Parking The Excavator
Using The Excavator On Sloping Ground
Towing The Excavator
Using The Bucket
Load Handling
Lowering The Attachment In The Event Of An Excavator Breakdown
Auxiliary Hydraulic Systems
Excavator Quick Coupler Operation Hydraulics
Chapter 6 - Maintenance Intervals
Hour Meter
Daily Inspections
Maintenance Information Screen
Fluids And Lubricants
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Relieving Pressure In The Hydraulic System
Bleeding Air From Hydraulic Components
Air Filter
Swing Speed Reducer
Travel Speed Reducers
Tracks
Track Rollers And Return Wheels
Radiator And Oil Cooler
Fan And Alternator Belt
Excavator Inspection And Cleaning
Checking Cylinders For Leaks
Bucket Replacement
Fire Extinguisher (Not Provided)
Welding On The Excavator
Plastic And Resin Parts
Air Conditioning
Inspection Of Bolt Torque
Engine Troubleshooting
Fuses
Battery Disconnect Switch
Battery
Starter
Replacing A Light Bulb
Chapter 10 - Transport And Storage Instructions
Transporting The Excavator
Lifting The Excavator
Storing The Excavator
Chapter 11 - Specifications
Electrical Systems
Weights
Undercarriage
Capacity Of Circuits And Components
Digging Force
Overall Dimensions Of The Excavator
Operating Range
Iso Rated Lifting Capacities
Chapter 12
Index
Isuzu
Am-4jj1x
Chapter 1 - To The Owner
Engine Components
Safety Rules
Safety Area
Utility Safety
Hand Signals
Steps And Access Handles
Position Of The Cab Controls And Accessories
Operator's Seat
Seat Controls
Right Hand Control Arm
Left Hand Control Arm
Front Console
Computer Monitor Display
Computer Monitor Controls
Menu Display Screen
Message Display List
Heating, Ventilation And Air-Conditioning Control
Control Pattern Selector Valve
Arm And Upperstructure Swing Left Hand Control Lever In Pattern D
Boom And Bucket Right Hand Control Lever In Pattern D
Boom And Upperstructure Swing Left Hand Control Lever In Pattern C
Arm And Bucket Right Hand Control Lever In Pattern C
Travel Control
Single Pedal Travel
Blade Operation
Gate Lock
Cab Light
Coat Hanger Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Cab Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rear View Mirrors
Rear View Camera
Engine Hood
Front Strage Box
Windshield Washer Reservoir
Side Doors
Towing Point
Lifting Eyes
Anti-Vandal Cover
Cab Protection (Rops And Fops)
Before Operating The Excavator
Run-In Period
Starting The Engine
Bringing The Excavator Up To Operating Temperature
Engine Operation
Stopping The Engine
Operating The Excavator In Cold Weather
Operating The Excavator In Hot Weather
Basic Operation
Swing Lock
Excavator Travel
Operating The Excavator In Water
Operating The Excavator On Sloping Ground
Operating The Bucket
Load Handling
Lowering The Attachment In The Event Of An Excavator Failure
Auxiliary Hydraulic Circuits
Hydraulic Excavator Quick Coupler Operation
Chapter 6 - Servicing Intervals
Servicing Intervals
Hourmeter
Daily Inspections
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Bleeding Air From The Hydraulic Components
Air Filter
Travel Reduction Gears
Tracks
Inspecting And Cleaning The Excavator
Checking For Cylinder Leakage
Replacing A Bucket
Air Conditioning
Hardware Torque Inspection
Fuses
Battery
Starter Motor
Replacing A Bulb
Chapter 10 - Transportation & Storage Instructions
Excavator Storage
Electrical Systems
Weights
Undercarriage
Capacity Of Systems And Components
Digging Force
Excavator Overall Dimensions
Working Range
Bucket Sizes
Remotecare
Provisional
Chapter 12
Index
Engine Components
Safety Rules
Safety Area
Utility Safety
Hand Signals
Operator's Seat
Seat Controls
Front Console
Menu Display Screen
Travel Control
Single Pedal Travel
Blade Operation
Gate Lock
Cab Light
Coat Hanger Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Cab Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rear View Mirrors
Rear View Camera
Engine Hood
Front Strage Box
Side Doors
Towing Point
Lifting Eyes
Anti-Vandal Cover
Run-In Period
Starting The Engine
Engine Operation
Stopping The Engine
Basic Operation
Swing Lock
Excavator Travel
Load Handling
Servicing Intervals
Hourmeter
Daily Inspections
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Air Filter
Tracks
Replacing A Bucket
Air Conditioning
Fuses
Battery
Starter Motor
Replacing A Bulb
Excavator Storage
Electrical Systems
Weights
Undercarriage
Digging Force
Working Range
Bucket Sizes
Remotecare
Provisional
Chapter 12
Index
Isuzu
Am-4jj1x
Link-Belt Excavator 130x3e Operator Manual 130x3e-D-Om-Es-Lxg-00-Es_19
Capítulo 1 - Para El Propietario
Manuales Técnicos Link-Belt
Capítulo 2 - Componentes De La Excavadora
Componentes Del Motor
Números De Identificación
Capítulo 3 - Seguridad, Etiquetas Y Señales De Mano
Normas De Seguridad
Zona De Seguridad
Seguridad De Servicios Públicos
Precauciones Del Operador
Etiquetas
Señales De Mano
Capítulo 4 - Instrumentos Y Controles
Cabina
Escalones Y Asideros De Acceso
Posición De Controles Y Accesorios De La Cabina
Asiento Del Operador
Controles Del Asiento
Brazo De Control Derecho
Brazo De Control Izquierdo
Consola Delantera
Pantalla De Sistema Y Panel De Control De Funciones
Controles Del Monitor
Pantalla De Menú
Lista De Mensajes En La Pantalla
Control De Calefacción, Ventilación Y Aire Acondicionado
Brazo Y Palanca De Control De Giro A La Izquierda De La Estructura Superior En Configuración D
Palanca De Control Derecha De Pluma Y Cucharón En Configuración D
Brazo Y Palanca De Control De Giro A La Izquierda De La Estructura Superior En Configuración C
Palanca De Control Derecha De Pluma Y Cucharón En Configuración C
Control De Avance
Bloqueo De La Compuerta
Luz De La Cabina
Gancho Para Abrigo
Ventanas De La Puerta De La Cabina
Portavasos
Bandeja De Almacenamiento
Compartimiento De Almacenamiento
Caja De Fusibles
Radio De La Cabina
Parabrisas
Ventana Delantera Inferior
Salidas De Aire
Ventana Trasera
Espejos Retrovisores
Instalación Y Ajuste Del Espejo
Cámara Retrovisora
Tanque De Combustible
Capó Del Motor
Caja De Almacenamiento Delantera
Depósito Del Lavaparabrisas
Puertas Laterales
Punto De Remolque
Argollas De Elevación
Protección De La Cabina (Rops Y Fops)
Capítulo 5 - Instrucciones De Funcionamiento
Antes De Utilizar La Excavadora
Funcionamiento De La Excavadora
Período De Rodaje
Dispositivo De Protección Antirrobo
Arranque Del Motor
Calentamiento De La Excavadora A La Temperatura De Funcionamiento
Funcionamiento Del Motor
Detención Del Motor
Funcionamiento De La Excavadora En Clima Frío
Funcionamiento De La Excavadora En Clima Caluroso
Funcionamiento Básico
Bloqueo De Giro
Avance De La Excavadora
Funcionamiento De La Excavadora En El Agua
Estacionamiento De La Excavadora
Funcionamiento De La Excavadora En Pendientes
Remolque De La Excavadora
Funcionamiento Del Cucharón
Manipulación De Cargas
Descenso Del Accesorio En Caso De Falla De La Excavadora
Circuitos Hidráulicos Auxiliares
Bomba De Alimentación Del Tanque De Combustible (Si Existe)
Capítulo 6 - Intervalos De Mantenimiento
Horómetro
Inspecciones Diarias
Pantalla De Información De Mantenimiento
Capítulo 7 - Lubricación, Filtros Y Fluidos
Fluidos Y Lubricantes
Tabla De Lubricación
Puntos De Lubricación
Niveles De Fluidos
Motor
Sistema De Enfriamiento
Sistema De Combustible
Alivio De La Presión Del Sistema Hidráulico
Sistema Hidráulico
Purga De Aire De Los Componentes Hidráulicos
Filtro De Aire
Engranaje Reductor De Giro
Engranajes Reductores De Propulsión
Capítulo 8 - Mantenimiento Y Ajustes
Orugas
Rodillos Inferiores Y Ruedas Guía
Radiador Y Enfriador De Aceite
Correa Del Ventilador Y Alternador
Inspección Y Limpieza De La Excavadora
Revisión De Fugas En El Cilindro
Sustitución De Un Cucharón
Extinguidor De Incendios (No Incluido)
Soldadura En La Excavadora
Piezas De Plástico Y Resina
Aire Acondicionado
Inspección De Par De Apriete De Tornillería
Localización De Averías En El Motor
Capítulo 9 - Sistemas Eléctricos
Fusibles
Interruptor De Corte De La Batería
Batería
Conexión De Una O Dos Baterías De Refuerzo
Alternador
Motor De Arranque
Sustitución De Una Bombilla
Capítulo 10 - Instrucciones De Transporte Y Almacenamiento
Transporte De La Excavadora
Elevación De La Excavadora
Almacenamiento De La Excavadora
Capítulo 11 - Especificaciones
Motor
Sistemas Eléctricos
Sistema Hidráulico
Pesos
Tren De Rodaje
Capacidad De Sistemas Y Componentes
Accesorio
Fuerza De Excavación
Dimensiones Generales De La Excavadora
Alcance Del Área De Trabajo
Remotecare
Capítulo 12
Índice
Engine Components
Chapter 3 - Safety, Labels, And Hand Signals
Safety Rules
Safety Zone
Utility Safety
Labels
Hand Signals
Steps And Access Grab Bars
Position Of Cab Controls And Attachments
Operator's Seat
Seat Controls
Right Control Arm
Left Control Arm
Front Console
System Display And Function Control Panel
Monitor Controls
Menu Display
List Of Display Messages
Hvac Control
Upperstructure Left Swing Arm And Control Lever In D Configuration
Right Boom And Bucket Control Lever In D Configuration
Arm And Left Upperstructure Swing Control Lever In C Configuration
Right Boom And Bucket Control Lever In C Configuration
Forward Control
Tailgate Lock
Cab Light
Coat Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Cab Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rearview Mirrors
Mirror Installation And Adjustment
Rearview Camera
Engine Hood
Front Storage Box
Side Doors
Towing Point
Lifting Eyes
Cab Guarding (Rops And Fops)
Excavator Operation
Break-In Period
Starting The Engine
Warming Up The Excavator At Operating Temperature
Engine Operation
Stopping The Engine
Basic Operation
Swing Lock
Moving The Excavator Forward
Operating The Excavator On Slopes
Bucket Operation
Load Handling
Fuel Tank Feed Pump (If Equipped)
Hour Meter
Daily Inspections
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Relief Hydraulic System Pressure
Bleeding Hydraulic Components
Air Filter
Propulsion Reduction Gears
Tracks
Track Rollers And Idlers
Fan Belt And Alternator
Cylinder Leak Check
Bucket Replacement
Fire Extinguisher (Not Included)
Excavator Welding
Air Conditioning
Bolt And Nut Torque Inspection
Fuses
Battery Cut-Off Switch
Battery
Starter Motor
Light Bulb Replacement
Electrical Systems
Weights
Undercarriage
Systems And Component Capacity
Digging Force
Overall Excavator Dimensions
Working Area Reach
Remote Care
Chapter 12
Table Of Contents
Isuzu
Gj-4jj1x
Format: Pdf
Language: Spanish
Brand: Link-Belt
Type Of Machine: Excavator
Type Of Manual: Operator Manual
Model: Link-Belt 130x3e Excavator
Engine: Isuzu Gj-4jj1x Engine
Part Number: 130x3e-D-Om-Es-Lxg-00-Es
Publication Date: 2017
Number Of Pages: 193 Pages
Normas De Seguridad
Zona De Seguridad
Etiquetas
Señales De Mano
Cabina
Consola Delantera
Pantalla De Menú
Control De Avance
Luz De La Cabina
Gancho Para Abrigo
Portavasos
Caja De Fusibles
Radio De La Cabina
Parabrisas
Salidas De Aire
Ventana Trasera
Cámara Retrovisora
Capó Del Motor
Puertas Laterales
Punto De Remolque
Período De Rodaje
Arranque Del Motor
Detención Del Motor
Bloqueo De Giro
Horómetro
Niveles De Fluidos
Motor
Sistema Hidráulico
Filtro De Aire
Orugas
Aire Acondicionado
Fusibles
Batería
Alternador
Motor De Arranque
Motor
Sistemas Eléctricos
Sistema Hidráulico
Pesos
Tren De Rodaje
Accesorio
Remotecare
Capítulo 12
Índice
Engine Components
Safety Rules
Safety Zone
Utility Safety
Labels
Hand Signals
Operator's Seat
Seat Controls
Right Control Arm
Left Control Arm
Front Console
Monitor Controls
Menu Display
Hvac Control
Forward Control
Tailgate Lock
Cab Light
Coat Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Cab Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rearview Mirrors
Rearview Camera
Engine Hood
Front Storage Box
Side Doors
Towing Point
Lifting Eyes
Excavator Operation
Break-In Period
Starting The Engine
Engine Operation
Stopping The Engine
Basic Operation
Swing Lock
Bucket Operation
Load Handling
Hour Meter
Daily Inspections
Lubrication Chart
Lubrication Points
Fluid Levels
Fuel System
Air Filter
Tracks
Cylinder Leak Check
Bucket Replacement
Excavator Welding
Air Conditioning
Fuses
Battery
Starter Motor
Electrical Systems
Weights
Undercarriage
Digging Force
Working Area Reach
Remote Care
Chapter 12
Table Of Contents
Link-Belt, Excavator, 130x3e, Operator Manual,
Link-Belt Excavator 130x3e Operator Manual 130x3e-D-Om-Es-Lxg-00-Es 2017
Wlsm1307-00lx-Fr
2017
Excavatrice
Sécurité
Sécurité, Informations Générales Et Couples De Serrage Standard
Couples De Serrage Standard Des Vis Et Des Écrous
A. Inférieur
Tableau De L'équipement Principal
Structure Et Principe De Fonctionnement De L'équipement Principal
Schéma D'orifices
Fonctions De Base
Retrait Et Installation De La Chenille
Retrait Et Installation Des Patins
Retrait Et Installation Du Support De Patin
Retrait Et Installation Du Galet
Retrait Et Installation Du Galet Supérieur
Montage Et De Démontage Du Galet Supérieur
Retrait Et Installation Du Galet Inférieur
Montage Et De Démontage Du Galet Inférieur
Retrait Et Installation De La Roue Dentée D'entraînement
Retrait Et Installation Du Galet Tendeur
Montage Et Démontage Du Galet Tendeur
Retrait Et Installation Du Vérin De Graissage
Montage Et Démontage Des Amortisseurs De Tension
Retrait Et Installation De L'articulation Centrale
Montage Et Démontage De L'articulation Centrale
Retrait Et Installation Du Moteur De Déplacement
Montage Et Démontage Du Moteur De Déplacement (Nabtesco)
Valeurs Standard De Maintenance
Procédures De Mesure Et De Réglage De La Pression
Procédures De Mesure Du Volume De Vidange
Procédure De Purge D'air
B. C. Unité De Pivotement, Contrepoids
Schéma D'orifices
Fonctions De Base
Retrait Et Installation De L'unité De Pivotement
Montage Et Démontage Du Moteur De Pivotement
Montage Et Démontage De L'unité De Pivotement
Retrait Et Installation Du Contrepoids
H. Moteur
Fonctions De Base
Spécifications Principales
Fonction, Structure, Fonctionnement
Fonction, Structure, Fonctionnement (Scr)
Inspection Du Système De Commande Du Scr
Explication Du Fonctionnement Du Scr
Diagnostic Pour Chaque Symptôme
Inspection Fonctionnelle
Retrait Et Installation Du Refroidisseur De Carburant, Refroidisseur D'air De Suralimentation Du Moteur, Radiateur Et Refroidisseur D'huile
Retrait Et Installation Du Turbocompresseur
Retrait Et Installation De La Soupape Egr
Retrait Et Installation Du Refroidisseur Egr
Retrait Et Installation Du Capot Du Moteur
Retrait Et Installation Du Scr
Retrait Et Installation Du Catalyseur Scr
Retrait Et Installation Du Couvercle De Culasse
Retrait Et Installation Du Bloc-Cylindres
Circuit De Lubrification
Système D'induction
Système D'échappement
Aux Système Des Appareils De Contrôle Des Émissions Aux.
Retrait Et Installation Du Collecteur D'échappement
Retrait Et Installation Du Réservoir De Carburant
Retrait Et Installation De La Pompe D'urée
Retrait Et Installation Du Réservoir À Solutions D'urée
Retrait Et Installation De La Pompe D'alimentation En Carburant
Retrait Et Installation De La Rampe Commune
Retrait Et Installation De L'injecteur
Retrait Et Installation Du Vilebrequin
Retrait Et Installation Du Piston Et De La Tringlerie
Retrait Et Installation De L'arbre À Cames
Retrait Et Installation Du Volant Moteur
Retrait Et Installation Du Joint D'huile Avant Du Vilebrequin
Retrait Et Installation Du Joint D'huile Arrière De Vilebrequin
Retrait Et Installation De La Chaîne De Distribution
Retrait Et Installation Du Train D'engrenages De Distribution
Retrait Et Installation Du Carter D'engrenages De Distribution
Retrait Et Installation Du Collecteur D'admission
Retrait Et Installation De L'axe De Culbuteurs
Retrait Et Inspection Du Joint D’huile De La Tige De Soupape Et Du Ressort De Soupape
Retrait Et Installation Du Papillon D'admission
Retrait Et Installation Du Démarreur
Retrait Et Installation De L'alternateur
Retrait Et Installation D'une Bougie De Préchauffage
Retrait Et Installation De La Vanne D'aspiration
Retrait Et Installation Du Filtre À Carburant
Retrait Et Installation Du Clapet De Décharge
Retrait Et Installation De L'élément De Filtre À Carburant
Retrait Et Installation Du Capteur De Température De Carburant
Retrait Et Installation Du Limiteur De Pression
Retrait Et Installation Du Capteur De Pression De Carburant
Retrait Et Installation Du Capteur De Pression Du Filtre À Carburant
Retrait Et Installation Du Capteur De Température Du Liquide De Refroidissement Moteur
Retrait Et Installation Du Capteur De Position Du Vilebrequin
Retrait Et Installation Du Capteur De Position De L'arbre À Cames
Retrait Et Installation Du Capteur De Pression D'huile
Retrait Et Installation Du Capteur De Suralimentation
Retrait Et Installation Du Capteur De Température De Suralimentation
Retrait Et Installation Du Solénoïde De Commande Du Turbocompresseur
Retrait Et Installation Du Capteur De Température Du Collecteur D'admission
Retrait Et Installation Des Capteurs De Débit Massique Et De Température D'air D'admission
Retrait Et Installation Du Capteur De Température De L'échangeur Thermique 1
Procédure D'échantillonnage
Retrait Et Installation Du Capteur De Température Des Gaz D'échappement
Retrait Et Installation Du Capteur De Température Des Gaz Réinjectés 1
Retrait Et Installation Du Capteur De Température Des Gaz Réinjectés 2
Retrait Et Installation Du Capteur De Nox
Retrait Et Installation Du Capteur De Température Des Gaz Réinjectés 3
Retrait Et Installation Du Capteur De Fed
Liste Des Codes D'anomalie Relatifs Au Moteur
Anomalie Côté Moteur
Valeurs De Référence De Données
J. Équipement Hydraulique (Pompe, Vanne De Système De Fonctionnement)
Fonctions De Base
Schéma D'orifices
Pompe Hydraulique
Distributeur
Principe De Fonctionnement De L'électrovanne À 4 Tiroirs Empilables
Distributeur Pilote De Superstructure (Distributeur À Distance)
Distributeur Pilote De Déplacement (Distributeur À Distance)
Vanne À Amortisseur
Sélecteur (Bidirectionnel)
Vanne De Direction (À 3 Voies)
Clapet De Décharge Électromagnétique
Retrait Et Installation Du Réservoir Hydraulique
Retrait Et Installation De La Pompe Hydraulique
Retrait Et Installation Du Distributeur
Retrait Et Installation Du Distributeur À Distance De Déplacement
Retrait Et Installation Du Solénoïde À 4 Tiroirs Empilables
Retrait Et Installation De La Vanne À Amortisseur
Procédures De Montage Et De Démontage De L'unité De Pompe Hydraulique Principale
Valeurs Standard De Maintenance De L'unité De Pompe Principale
Causes De Défaillances, Et Actions
Procédures De Montage Et De Démontage Du Distributeur
Procédures De Montage Et De Démontage Du Distributeur À Distance
Procédures De Montage Et De Démontage Du Distributeur À Distance De Déplacement
Montage Et Démontage De La Vanne À Amortisseur
Procédures De Mesure Du Débit De Pompe Hydraulique
Disposition De L'équipement Hydraulique
Vue Générale
J. Explication Du Circuit Hydraulique Et De Son Fonctionnement (Modèle Standard)
Fonctionnement (Option)
N. Cabine
Retrait Et Installation Du Siège De L'opérateur
Retrait Et Installation De La Cabine
Retrait Et Installation De L'essuie-Glace
Retrait Et Installation De La Vitre Avant De La Cabine
Procédures De Réglage Du Verrouillage De Vitre
Retrait Et Installation De La Main Courante Du Carter
Couple De Serrage
R. Équipement Électrique
Fonctions De Base
Support D'entretien
Brochage Des Connecteurs
Schéma Du Circuit De Séquence
Schéma De Disposition De L'équipement Électrique
Retrait Et Installation Du Système De Commande D'essuie-Glace
Retrait Et Installation Du Moteur D'essuie-Glace
Retrait Et Installation De L'ecm
Retrait Et Installation Du Système De Commande Principal
Retrait Et Installation De L'unité Dcu
Retrait Et Installation De L'écran
Retrait Et Installation De La Caméra De Recul
Retrait Et Installation De La Caméra Latérale (Droite)
Retrait Et Installation De La Caméra Latérale (Gauche)
Retrait Et Installation Du Système De Commande Du Fvm
Comment Paramétrer L'écran De Vue Du Terrain (Fvm)
Schéma Général Du Climatiseur
Retrait Et Installation Du Compresseur
Retrait Et Installation Du Condenseur
Retrait Et Installation Du Réservoir Déshydrateur
Précautions Concernant Le Travail
R. Schéma De Câblage De
Connecteurs Électriques
R. Schéma De Montage
D'équipement Électrique Et
De Câblage
V. Accessoires
Retrait Et Installation Du Vérin De Godet
Retrait Et Installation Du Vérin De Bras
Retrait Et Installation Du Vérin De Flèche
Retrait Et Installation Du Vérin De Lame
Procédures De Fonctionnement/Montage Et Démontage Du Vérin Hydraulique
Clapet Antiretour Contre L'éclatement Des Flexibles
Schéma D'orifices
Retrait Et Installation Du Hbcv
Retrait Et Installation Du Clapet Antiretour Contre L'éclatement Des Flexibles Du Bras
Retrait Et Installation Du Hbcv De La Flèche
Retrait Et Installation Du Godet
Retrait Et Installation De La Tringlerie De Godet
Retrait Et Installation Du Bras
Retrait Et Installation De La Flèche
Retrait Et Installation De La Lame
Z. Autre
Changement Du Type 6
Spécifications (Standard)
Spécifications (Spécifications De Lame)
Spécifications (Spécifications Lc)
Dimensions Du Bras
Poids De L'unité Principale
Tableau De Taille Et De Couple De Serrage Des Boulons
Vue Générale
Schéma De Plage De Fonctionnement
Tableau D'évaluation Des Performances D'une Machine Neuve
Liste Des Codes D'anomalie Concernant L'unité Principale
Anomalie Côté Unité Principale
Liste Des Outils Spéciaux
Couleurs De Peinture
Abréviation
Excavator
Safety
Safety, General Information, And Standard Tightening Torques
Standard Tightening Torques For Screws And Nuts
A. Lower
Main Equipment Structure And Working Principle
Hole Diagram
Basic Functions
Removing And Installing The Track
Removing And Installing The Track Shoes
Removing And Installing The Track Shoe Holder
Removing And Installing The Track Roller
Removing And Installing The Top Roller
Assembling And Disassembling The Top Roller
Removing And Installing The Bottom Roller
Assembling And Disassembling The Bottom Roller
Removing And Installing The Drive Sprocket
Removing And Installing The Idler Pulley
Assembling And Disassembling The Idler Pulley
Removing And Installing The Grease Cylinder
Assembling And Disassembling The Tension Dampers
Removing And Installing The Center Joint
Assembling And Disassembling The Joint Central Unit
Travel Motor Removal And Installation
Travel Motor Assembly And Disassembly (Nabtesco)
Standard Maintenance Values
Drain Volume Measurement Procedures
B. C. Swing Unit, Counterweight
Main Equipment Structure And Operating Principle
Port Diagram
Basic Functions
Swing Unit Removal And Installation
Swing Motor Assembly And Disassembly
Swing Unit Assembly And Disassembly
Counterweight Removal And Installation
H. Motor
Basic Functions
Main Specifications
Function, Structure, Operation
Function, Structure, Operation (Scr)
Inspection Of The Scr Control System
Explanation Of The Operation Of The Scr
Diagnosis For Each Symptom
Functional Inspection
Engine Removal And Installation
Removal And Installation Of The Fuel Cooler, Engine Charge Air Cooler, Radiator, And Oil Cooler
Turbocharger Removal And Installation
Egr Valve Removal And Installation
Egr Cooler Removal And Installation
Engine Cover Removal And Installation
Scr Removal And Installation
Scr Catalyst Removal And Installation
Cylinder Head Cover Removal And Installation
Cylinder Block Removal And Installation
Lubrication System
Induction System
Exhaust System
Aux Emission Control Device System
Exhaust Manifold Removal And Installation
Fuel Tank Removal And Installation
Urea Pump Removal And Installation
Urea Solution Tank Removal And Installation
Fuel Feed Pump Removal And Installation
Common Rail Removal And Installation
Injector Removal And Installation
Crankshaft Removal And Installation
Piston And Linkage Removal And Installation
Camshaft Removal And Installation
Flywheel Removal And Installation
Crankshaft Front Oil Seal Removal And Installation
Crankshaft Rear Oil Seal Removal And Installation
Timing Chain Removal And Installation
Timing Gear Set Removal And Installation
Timing Gear Cover Removal And Installation
Intake Manifold Removal And Installation
Rocker Arm Shaft Removal And Installation
Valve Stem Oil Seal And Valve Spring Removal And Inspection
Removal And Installation Of The Intake Throttle Valve
Removal And Installation Of The Starter Motor
Removal And Installation Of The Alternator
Removal And Installation Of A Glow Plug
Removal And Installation Of The Intake Valve
Removal And Installation Of The Fuel Filter
Removal And Installation Of The Wastegate
Removal And Installation Of The Fuel Filter Element
Removal And Installation Of The Fuel Temperature Sensor
Removal And Installation Of The Pressure Relief Valve
Removal And Installation Of The Fuel Pressure Sensor
Removal And Installation Of The Fuel Filter Pressure Sensor
Removal And Installation Of The Engine Coolant Temperature Sensor
Removal And Installation Of The Crankshaft Position Sensor
Removal And Installation Of The Camshaft Position Sensor
Removal And Installation Of The Oil Pressure Sensor
Removal And Installation Of The Boost Sensor
Removal And Installation Of The Boost Temperature Sensor
Removal And Installation Of The Turbocharger Control Solenoid
Intake Manifold Temperature Sensor Removal And Installation
Mass Flow And Intake Air Temperature Sensor Removal And Installation
Heat Exchanger Temperature Sensor Removal And Installation 1
Sampling Procedure
Exhaust Gas Temperature Sensor Removal And Installation
Recirculation Gas Temperature Sensor Removal And Installation 1
Recirculation Gas Temperature Sensor Removal And Installation 2
Nox Sensor Removal And Installation
Recirculation Gas Temperature Sensor Removal And Installation 3
Edf Sensor Removal And Installation
Engine-Related Trouble Code List
Engine-Side Fault
Data Reference Values
J. Hydraulic Equipment (Pump, Operating System Valve)
Basic Functions
Port Diagram
Control Valve
Operating Principle Of The 4-Spool Stacking Solenoid Valve
Superstructure Pilot Control Valve (Control Valve) Remote)
Pilot Displacement Valve (Remote Displacement Valve)
Damper Valve
Selector Valve (Bidirectional)
Directional Valve (3-Way)
Solenoid Relief Valve
Removal And Installation Of The Hydraulic Reservoir
Removal And Installation Of The Hydraulic Pump
Removal And Installation Of The Displacement Valve
Removal And Installation Of The Remote Displacement Valve
Removal And Installation Of The 4-Spool Stackable Solenoid
Removal And Installation Of The Damper Valve
Installation And Disassembly Procedures For The Main Hydraulic Pump Unit
Standard Maintenance Values For The Main Pump Unit
Causes Of Malfunctions And Actions
Installation And Disassembly Procedures For The Displacement Valve
Installation And Disassembly Procedures For The Remote Displacement Valve
Installation And Disassembly Procedures For The Damper Valve
Hydraulic Pump Flow Measurement Procedures
Sampling Procedure
Overview
J. Explanation Of The Hydraulic Circuit And Its Operation (Standard Model)
Circuit And Its Operation (Optional)
Cabin No.
Removing And Installing The Operator's Seat
Removing And Installing The Cab
Removing And Installing The Windshield Wiper
Removing And Installing The Front Cab Glass
Window Lock Adjustment Procedures
Removing And Installing The Crankcase Handrail
Tightening Torque
R. Electrical Equipment
Basic Functions
Maintenance Support
Connector Pinouts
Removing And Installing The Wiper Control System
Removing And Installing The Wiper Motor
Ecm Removal And Installation
Main Control System Removal And Installation
Dcu Removal And Installation
Display Removal And Installation
Reversing Camera Removal And Installation
Side Camera Removal And Installation (Right)
Side Camera Removal And Installation (Left)
Fvm Control System Removal And Installation
How To Set The Terrain View Monitor (Fvm)
Air Conditioner General Diagram
Compressor Removal And Installation
Condenser Removal And Installation
Dryer Tank Removal And Installation
Working Precautions
R. Electrical Connector Wiring Diagram
R. Electrical Equipment And Wiring Diagram
V. Accessories
Bucket Cylinder Removal And Installation
Arm Cylinder Removal And Installation
Removal And Installation Boom Cylinder
Blade Cylinder Removal And Installation
Hydraulic Cylinder Operating Procedures/Assembly And Disassembly
Hose Burst Check Valve
Port Diagram
Hbcv Removal And Installation
Arm Hose Burst Check Valve Removal And Installation
Boom Hbcv Removal And Installation
Bucket Removal And Installation
Bucket Linkage Removal And Installation
Arm Removal And Installation
Boom Removal And Installation
Blade Removal And Installation
Other
Change From Type 6
Specifications (Standard)
Specifications (Blade Specifications)
Specifications (Lc Specifications)
Arm Dimensions
Main Unit Weight
Bolt Size And Torque Table
Overview
Rating Table Performance Of A New Machine
Link-Belt Excavator 130x4 Service Manual Wlsm1307-00lx-Fr_9
130x4-Om-Lxg-00-Es
Advertencia Según Propuesta De Ley 65 Del Estado De California
Normas De Seguridad
Zona De Seguridad
Etiquetas
Señales De Mano
Cabina
Consola Delantera Derecha
Válvula Selectora De Configuración De Control
Pluma Y Palanca De Control De Giro A La Izquierda De La Estructura Superior En Configuración C
Palanca De Control Derecha De Brazo Y Cucharón En Configuración C
Control De Avance
Avance Del Pedal Único
Funcionamiento De La Cuchilla (Especificación)
Luz De La Cabina
Gancho Para Abrigo
Portavasos
Caja De Fusibles
Radio
Parabrisas
Salidas De Aire
Ventana Trasera
Cámara Retrovisora
Capó Del Motor
Puerta Lateral
Punto De Remolque
Cubierta Antivandálica
Período De Rodaje
Inicio De La Unidad
Arranque Del Motor
Detención Del Motor
Sistema Scr
Regeneración De Scr
Bloqueo De Giro
Interferencia De La Cuchilla (Tipo Hoja)
Bajada Del Accesorio En Caso De Falla De La Excavadora
Operación Del Acoplador Hidráulico Rápido De La Excavadora
Operación Del Accesorio De Frente Largo
Horómetro
Procedimiento De Muestreo
Tabla De Lubricación (Máquina Estándar/ Tipo De Lc)
Tabla De Lubricación (Tipo De Cuchilla)
Niveles De Fluidos
Motor
Sistema Def
Sistema Hidráulico
Filtro De Aire
Orugas
Protección Del Sistema Eléctrico/Electrónico Durante La Carga O Soldadura
Aire Acondicionado
Inspección Del Resorte De Gas
Fusibles
Batería
Alternador
Motor De Arranque
Desmontaje Antes Del Transporte
Motor
Sistemas Eléctricos
Sistema Hidráulico
Pesos
Tren De Rodaje
Accesorio
Capacidades De Elevación - Calificaciones Iso
Tamaños De Cucharón
Remotecare
Declaración Fcc & Ce
Documento
Capítulo 12
Índice
California Proposition 65 Warning
Engine Components
Safety Rules
Safety Zone
Utility Safety
Labels
Hand Signals
Steps And Access Handholds
Position Of Cab Controls And Accessories
Operator's Seat
Seat Controls
Right Control Arm
Left Control Arm
Right Front Console
Control Configuration Selector Valve
Upperstructure Left Swing Control Arm And Lever In Configuration D
Right Boom And Bucket Control Lever In Configuration D
Boom And Lever Upperstructure Left Swing Control Lever In C Configuration
Forward Control
Single Pedal Forward
Blade Operation (Specification)
Tailgate Lock
Cab Light
Coat Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Rearview Mirrors
Rearview Camera
Engine Hood
Front Storage Box
Side Door
Towing Point
Lifting Eyes
Vandal-Proof Cover
Cab Guard (Rops And Fops)
Excavator Operation
Operating Period Break-In
Unit Start-Up
Engine Start-Up
Excavator Warm-Up To Operating Temperature
Engine Operation
Engine Stop
Scr System
Scr Regeneration
Excavator Operation In Cold Weather
Excavator Operation In Hot Weather
Basic Operation
Swing Lock
Blade Interference (Blade Type)
Excavator Forward Operation
Excavator Operation In Water
Excavator Parking
Excavator Operation On Slopes
Excavator Towing
Bucket Operation
Load Handling
Attachment Lowering In The Event Of Excavator Failure
Excavator Hydraulic Quick Coupler Operation
Longface Attachment Operation
Hour Meter
Daily Inspections
Sampling Procedure
Lubrication Table (Standard Machine/Lc Type)
Lubrication Table (Blade Type)
Lubrication Points
Fluid Levels
Fuel System
Def System
Hydraulic System Pressure Relief
Air Filter
Tracks
Cylinder Leak Check
Bucket Replacement
Electrical/Electronic System Protection During Loading Or Welding
Air Conditioning
Gas Spring Inspection
Bolt Tightening Torque Inspection
Fuses
Battery
Starter Motor
Disassembly Before Transport
Electrical Systems
Weights
Undercarriage
Digging Force
Working Area Reach
Bucket Sizes
Remote Care
Fcc & Ce Declaration
Document
Chapter 12
Index
Link-Belt Excavator 130x4 130x4lc 130x4dz Operator Manual 130x4-Om-Lxg-00-Es
Link-Belt Excavator 130x4, 130x4 Lc, 130x4 Dz Operator Manual 130x4-Om-Lxg-00-Fr_13
Chapitre 1 — À L’intention Du Propriétaire
Chapitre 2 — Composants De L’excavatrice
Numéros D’identification
Chapitre 3 — Sécurité, Autocollants Et Signaux Manuels
Règles De Sécurité
Zone De Sécurité
Précautions À Prendre Par L’opérateur
Autocollants
Signaux Manuels
Chapitre 4 — Instruments Et Commandes
Cabine
Marchepieds Et Barres D’accès
Siège De L’opérateur
Commandes Du Siège
Console Avant Droite
Levier De Commande Gauche De Bras Et Pivotement De La Superstructure Dans La Configuration D
Levier De Commande Droit De Flèche Et Godet Dans La Configuration D
Fonctionnement De La Lame (Spécification De Lame)
Porte-Gobelet
Boîte À Fusibles
Radio
Pare-Brise
Évents D’aération
Vitre Arrière
Rétroviseurs
Pose Et Réglage Du Rétroviseur
Caméra De La Vue Arrière
Capot Du Moteur
Porte Latérale
Point De Remorquage
Œilletons De Levage
Protection De La Cabine (Arceau De Sécurité Et Protection Contre La Chute D’objets)
Chapitre 5 — Instructions D’utilisation
Avant D’utiliser L’excavatrice
Utilisation De L’excavatrice
Période De Rodage
Démarrage De La Machine
Démarrage Du Moteur
Montée De L’excavatrice Jusqu’à La Température De Fonctionnement
Arrêt Du Moteur
Système Scr
Scr Re-Gen (Régénération Scr)
Utilisation De L’excavatrice Par Temps Froid
Utilisation De Base
Dégagement De La Lame (Type À Lame)
Utilisation De L’excavatrice Dans L’eau
Stationnement De L’excavatrice
Utilisation De L’excavatrice Sur Un Sol En Pente
Remorquage De L’excavatrice
Abaissement De L’accessoire En Cas De Panne De L’excavatrice
Fonctionnement De L’accouplement Rapide De L’excavatrice Hydraulique
Utilisation De L’accessoire Frontal Long
Chapitre 6 — Périodicité D’entretien
Compteur Horaire
Chapitre 7 — Lubrification, Filtres Et Liquides
Procédure D’échantillonnage
Tableau De Lubrification (Machine Standard/Type Lc)
Tableau De Lubrification (Type De Lame)
Moteur
Système Def
Circuit Hydraulique
Purge De L’air Des Composants Hydrauliques
Filtre À Air
Chapitre 8 — Maintenance Et Réglages
Chenilles
Radiateur Et Refroidisseur D’huile
Courroie De Ventilateur Et D’alternateur
Inspection Et Nettoyage De L’excavatrice
Vérification De L’absence De Fuites Au Niveau Des Vérins
Remplacement D’un Godet
Protection Du Système Électrique / Électronique Pendant La Recharge Ou La Soudure
Climatisation
Inspection Du Ressort À Gaz
Dépannage Du Moteur
Chapitre 9 — Circuits Électriques
Fusibles
Batterie
Connexion D’une Ou De Deux Batteries D’appoint
Alternateur
Démarreur
Remplacement D’une Ampoule
Chapitre 10 — Instructions De Transport Et D’entreposage
Transport De L’excavatrice
Levage De L’excavatrice
Démontage Avant Le Transport
Entreposage De L’excavatrice
Chapitre 11 — Spécifications
Moteur
Circuit Hydraulique
Poids
Accessoire
Force De Creusage
Dimensions Hors Tout De L’excavatrice
Tailles De Godet
Remotecare
Déclaration De Fcc & Ce
Document
Chapitre 12
Index
Chapter 1 — For The Owner
Chapter 2 — Excavator Components
Engine Components
Chapter 3 — Safety, Decals, And Hand Signals
Safety Rules
Safety Zone
Utility Safety
Hand Signals
Chapter 4 — Instruments And Controls
Operator's Seat
Seat Controls
Right Control Arm
Left Control Arm
Right Front Console
Left Arm And Topside Swing Control Lever In Configuration D
Left Arm And Topside Swing Control Lever In Configuration C
Right Boom And Bucket Control Lever In Configuration C
Travel Control
Single Travel Pedal
Blade Operation (Blade Specification)
Door Lock
Cab Light
Coat Hook
Cab Door Windows
Cup Holder
Storage Tray
Storage Compartment
Fuse Box
Radio
Windshield
Lower Front Window
Air Vents
Rear Window
Mirrors
Rearview Camera
Engine Hood
Windshield Washer Fluid Tank
Side Door
Towing Point
Lifting Eyes
Vandal Protection
Cab Protection (Roll Bar And Falling Object Protection)
Chapter 5 — Operating Instructions
Excavator Operation
Break-In Period
Starting The Machine
Starting The Engine
Engine Operation
Stopping The Engine
Scr System
Scr Regeneration
Basic Operation
Swing Lock
Blade Release (Blade Type)
Excavator Travel
Excavator Parking
Excavator Operation On Sloping Ground
Bucket Operation
Load Handling
Auxiliary Hydraulics
Attachment Operation Long Front End
Chapter 6 — Maintenance Interval
Hour Meter
Daily Inspections
Chapter 7 — Lubrication, Filters, And Fluids
Sampling Procedure
Lubrication Chart (Standard Machine/Lc Type)
Lubrication Chart (Blade Type)
Lubrication Points
Fluid Levels
Fuel System
Def System
Air Filter
Swing Speed Reducer
Chapter 8 — Maintenance And Adjustments
Tracks
Checking For Cylinder Leaks
Bucket Replacement
Electrical/Electronic System Protection During Recharging Or Welding
Air Conditioning
Chapter 9 — Electrical Systems
Fuses
Battery
Starter
Chapter 10 — Transport And Storage Instructions
Chapter 11 — Specifications
Electrical Systems
Weight
Undercarriage
Circuit And Component Capacity
Digging Force
Working Range Operation
Bucket Sizes
Remote Care
Document
Chapter 12
Index
130x4-Om-Lxg-00-Fr
2016
Isuzu
Ar-4jj1x
2019
Isuzu
Ar-4jj1x
1112
0. About This Shop Manual
1. Service Manual
2. Specification Add-On Items
3. Performances
4. Troubleshooting (Not Published Yet)
5. Disassembling And Maintenance Instructions For The Main Body
6. Disassembling And Maintenance Instructions For Major Parts
7. Disassembling And Maintenance Instructions For Major Hydraulic Components
8. Instructions For Installation Of Options (Separate Volume)
Sh125x-3
Isuzu, Bb-4bg1t
Sh125xu-3
Sh135x-3
Sh125x-3 Sh125xu-3 Sh135x-3
Link-Belt Excavator 135 Spin Ace Shop Manual_15
1207
2008
Capítulo 1
Información General
Capítulo 2
Capítulo 3
Capítulo 4
Instrucciones De Operación
Capítulo 5
Capítulo 6
Capítulo 7
Sistema Eléctrico
Capítulo 8
Especificaciones
Capítulo 9
Índice
Chapter 1
Chapter 2
Chapter 3
Chapter 4
Chapter 5
Chapter 6
Chapter 7
Chapter 8
Specifications
Chapter 9
Table Of Contents
Link-Belt Excavator 135 Spin Ace Tier 3 Operator Manual Es
4jj1x
Chapitre 1
Chapitre 2
Chapitre 3
Chapitre 4
Chapitre 5
Chapitre 6
Chapitre 7
Circuit Électrique
Chapitre 8
Spécifications
Chapitre 9
Index
Chapter 1
Chapter 2
Chapter 3
Chapter 4
Chapter 5
Chapter 6
Chapter 7
Chapter 8
Specifications
Chapter 9
Index
Isuzu
Ai-4jj1x
Hydraulic And Electrical Schematic
Main Body
Specifications
Overall
1. Main Data
2. Performance
3. Main Body Dimensions
4. Engine
5. Cooling System
6. Upper Side Work System
7. Operating Device
8. Swing Units
9. Travel Lower Body
Hydraulic Equipment
1. Hydraulic Device
2. Control Valve, Cylinder
Capacities, Filters
1. Coolant And Oil Capacities
2. Hydraulic Oil Filters
3. Fuel Filter
Lifting Capacity
Precautions For Lifting Loads With The Hydraulic Excavator
Lifting Capacities
Overall View
Overall View (135) (Mono Boom Spec.)
1. Standard Arm (2.39 M)
2. Long Arm (2.85 M)
Overall View (135) (Mono Boom Spec. With Dozer Blade)
Work Range Diagram
Work Range Diagram (135) (Mono Boom Spec.)
Work Range Diagram (135) (Mono Boom Spec. With Dozer Blade)
Optional Components
Optional Components
Major Equipment Specifications
Equipment Configuration
Overall
Operator’s Cab
Lower Mechanism
Lower Assembly Diagram (Overall)
Lower Assembly Diagram (Overall) (With Dozer Blade)
Lower Component
1. Travel Unit
2. Take-Up Roller
3. Upper-Roller
4. Lower-Roller
5. Recoil Spring
6. Shoes
Upper Component
1. Swing Unit
Engine-Related
1. Engine
2. Muffler
3. Air Cleaner (Double Element)
4. Radiator
Hydraulic Device
1. Hydraulic Pump
Control-Related
1. Control Valve
2. Solenoid Valve (5 Stack)
3. Remote Control Valve (Left / Right, Travel Operations)
4. Remote Control Valve Characteristic Diagram
5. Cushion Valve (Heat Circuit, With Shuttle Valve)
6. Selector Valve (Option)
7. Center Joint
8. Solenoid Valve
Backhoe Attachment
1. Cylinder
2. Attachments
Sump Tank
Hydraulic Section
Hydraulic Pump Operational Description
Structure And Operation Principle
Attached Drawing 1.
Pump Development Diagram
Attached Drawing 2.
Pump Structure Drawing
Control Valve Operation
When All Spools Are In Neutral Position
1. Neutral Passage
2. Signal Passage
Independent Operations
1. Travel Spool Changeover
2. Extra Spool Changeover
3. Swing Spool Changeover
4. Bucket Spool Changeover
5. Boom Spool Changeover
6. Arm Spool Changeover
7. Parallel Throttle For Arm
8. Neutral Cut Spool Changeover (Extra Combination)
9. Blade Spool Changeover
10. Relief Valve
Compound Operation
1. Travel Compound Operation
2. Anti-Drift Valve
Swing Unit
Swing Motor
Mechanical Brake
Make-Up Valve
1. Explanation Of Operation When Relief Valve Is Pressurized
2. Explanation Of Operation When Relief Valve Is Depressurized
Swing Relief Valve
Anti-Reverse Valve
Swing Reduction Gears
Problems And Remedies
Structural Drawings
Main Equipment Structure And Operation Explanation
Motor
1. Travel Motor
Hydraulic Circuit Section
Port Locations
Control Valve (Mono Boom)
Control Valve (Mono Boom With Blade)
Control Valve (Offset Boom With Blade) (Option For Europe)
Pilot Hose Connection Diagrams
Pilot P & T Line
Pilot Control Line
Functional Description
List Of Functions
Control Valve Configuration Table
Overview
Travel Circuits
High Speed Travel Circuit
Low Speed Travel Circuit
Straight Travel Circuit (Simultaneous Operation Of Travel Forward And Boom-Up)
Swing Circuits
Swing Parking Circuit (Independent Operation Of Swing)
Swing Priority Variable Throttle Circuit
Arm Circuits
Arm-In / Arm-Out 2-Speed Circuit
Arm-In Load Holding Valve Circuit
Arm-In Forced Regenerative Circuit
Boom Circuits
Boom-Up 2-Speed Circuit
Boom-Down Load Holding Valve Circuit
Boom-Down Regenerative Circuit
Boom-Down Windage Prevention Circuit
Option Circuits
Breaker And Crusher Circuit (2-Speed Confluence Crusher Circuit)
Breaker And Crusher Circuit (Option Line Holding Valve)
Breaker And Crusher Circuit (Breaker Circuit)
Secondary Option Shuttle Circuit
Electric Circuits Section
Wiring Diagrams
Electrical Components And Wiring For Upper Frame (Frame)
Electrical Components And Wiring For Cab
Air Conditioner
Electrical Components And Wiring For Upper Frame (Engine)
Electrical Components And Wiring For Upper Frame (Battery)
Electrical Components And Wiring For Upper Frame (Pump)
Harness Diagrams
Upper Frame
Frame Wiring Main Harness
Inside Cab
Cab Wiring Main Harness
Monitor Display
1. Monitor Switch Panel
2. List Of Functions
Engine Control
1. Engine Start-Up Control
2. Throttle Control
3. One-Touch Idling
Monitor Output Control
1. 2-Speed Travel
2. Swing Brake
3. Travel Alarm
4. Working Light
5. Windshield Wiper / Washer
6. Power Cut Delay
Monitor Display Control
1. Overheat Warning
2. Engine Oil Pressue Warning
3. Low Fuel Warning
4. Battery Charge Warning
5. Auto Preheat
6. Idle Up
7. Faulty Electrical System At Engine
Service Support
Screen Operations
1. Screen Shift
Screen Display List
1. Chk (Status Display) Screen List
2. Diag (Trouble Diagnosis) Screen
3. Hr (Usage Log) Screen List
4. Cfg (Setting Change) Screen
5. Cal (Troubleshooting Support) Screen
6. Check The Monitor Switch (Self-Diagnosis Function)
7. Model Setting
8. Engine Screen Information
Screen Display Details
1. Message Display List
Trouble Display
1. Diagnostic Trouble Code Display
5. Epf (Engine Protection Feature)
Connection Connector Pin Layout
1. Computer A
2. Monitor
Overall View
Block Diagram
1. Computer A
2. Ecm
3. Monitor Display
4. Air Conditioner
5. Lever Lock
6. Horn
7. Others
8. Electrical Symbol List
Maintenance Section
Measuring Adjusting Pressure
Measuring Pressure
1. Basic Conditions
2. Pressure Settings
3. Ports For Measuring Pressure
4. Preparation For Measuring Pressure
5. Measuring Pressure
Pressure Adjustment
1. Pressure Adjusting Points
Compatibility
List Of Common Features And Compatibility Of Major Parts
Attachment Installation Methods
Attachment Dimensions For Mono Boom
Attachment Dimensions For Offset Boom (Option For Europe)
Section 2 Shop Manual
Safety
Introduction
Introduction
Using Technical Information
Symbols
Precautions For Use
Tightening Torque
Tightening Bolts And Nuts
Retightening Torque Table
Numerical Conversion Table
This Section Describes Unit Notation For Numerical Values.
Specifications
Overall
Operator’s Cab
Major Equipment Table
Lower Mechanism
Lower Component
1. Travel Unit
2. Take-Up Roller
3. Upper-Roller
4. Lower-Roller
5. Recoil Spring
6. Shoes
Upper Component
1. Swing Unit
Engine-Related
1. Engine
2. Muffler
4. Radiator
Hydraulic Device
1. Hydraulic Pump
Control-Related
1. Control Valve
7. Center Joint
8. Solenoid Valve
Backhoe Attachment
1. Cylinder
2. Attachments
Sump Tank
Fuel / Lubricants And Filters
Fuel / Lubricants For Different Ambient Temperature Settings
Fuel / Oil
Antifreeze
Genuine Parts And Elements
Engine Fuel And Maintenance Of Fuel Filters
1. Fuel To Be Applied
2. Maintenance Of Fuel Filters
Disposable Items
Grease / Oil And Elements Replacement (Mono Boom Spec. )
Grease / Oil And Elements Replacement (Mono Boom Spec. With Dozer Blade)
Replacement Intervals For Hydraulic Oil And Filters When Using Breaker
Inspection And Maintenance When Using The Breaker: We Recommend Having The Hydraulic Oil
Checked By Specialists (Sampling)
Performances
Lifting Capacity
Lifting Capacities
Hydraulic Pump Control Curve
P-Q Line Diagram Of Hydraulic Pump
Disassembling And Maintenance Instructions For Main Body
Process Block Diagram For Lower Equipment
Lower Mechanism
Track Shoe
1. Disassembly
2. Assembly
3. Track Link Changing Procedure
Travel Unit
1. Precautions When Assembling
2. Disassembly
3. Assembling
Recoil Spring Assembly
1. Disassembly
2. Assembly
Upper Roller
1. Disassembly
2. Assembly
Lower Roller
1. Disassembly
2. Assembly
Rotating Joint
1. Disassembly
2. Assembly
Upper Mechanism
Swing Unit
Control Valve
Operator’s Cab
1. Removal
2. Installation
1. Removal
2. Installation
Boom Cylinder Removal And Installation
1. Removal
2. Installation
Take-Up Roller
Disassembling And Assembling Instructions
1. Component Diagram
2. Tools And Jigs
3. Disassembling Instructions
4. Assembling Instructions
Assembly Drawings
Upper Roller
2. Tools And Jigs
Assembly Drawings
Lower Roller
2. Tools And Jigs
Assembly Drawings
Grease Cylinder
2. Tools And Jigs
Assembly Drawings
Rotating Joint
2. Tools And Jigs
Assembly Drawings
Air Conditioner
Disassembling The Case
1. Removing The Switch Box:
2. Removing The Upper Case:
Replacing The Blower Motor
Replacing The Evaporator
Replacing The Expansion Valve
Replacing The Heater Core
Replacing The Motor Actuator
Check Sheet
1. Drive Sprocket
2. Take-Up Roller
3. Upper Roller
4. Lower Roller
5. Track Shoe (Grouser Shoe)
6. Attachment (Backhoe)
7. Attachments (Offset Boom)
8. Blade
Inspection Gauges
1. For Drive Sprocket
2. For Take-Up Roller
3. For Upper Roller
4. For Lower Roller (External)
List Of Shims For Adjusting Attachment Gaps
List Of Shims For Adjusting Attachment Gaps (For Boom Foot)
Hydraulic Pump Maintenance
1. Pump Main Body-Disassembling And Assembling Instructions
2. Pump Main Body-Maintenance Standards
3. Troubleshooting
4. Attached Diagram And Chart
5. Cross-Sectional View Of Pump
Pto Unit Maintenance
1. Tools
2. Disassembly Procedure
3. Assembly Procedure
1. Standards For Replacing Worn Parts
2. Tightening Torque
3. Attached Diagram 1 Pto Unit Breakdown Diagram
4. Attached Diagram 2 Pto Unit Assembly Cross-Section Diagram
Gear Pump Handling
1. Structure And Function
2. Assembly Drawing
Regulator Handling
1. Description
2. Description Of Operation
3. Adjusting The Regulator
4. Troubleshooting
5. Attachements
Regulator Maintenance
1. Disassembling Precautions
2. Tools
4. Reassembling Instructions
5. Cross-Sectional View Of Regulator (Front)
6. Cross-Sectional View Of Regulator (Rear)
Travel Unit
Service Outline
1. Tools
3. Weight
Disassembly
1. Preparations
2. General Suggestion At Work
3. Disassembly Procedure
Service Criteria
1. Replace All Seals
2. Maintenance Criteria For Wearing Parts
Assembly
1. Preparations
2. General Precautions
3. Assembling Procedure
Performance Confirmation Test
Exploded Diagram Of Reduction Gear
Exploded Diagram Of Hydraulic Motor
Travel Motor Internal Structure Diagram
Travel Motor Part Table
Swing Unit
Hydraulic Motor
1. Structural View Of Motor
2. Troubleshooting
3. Disassembly And Assembly
4. Maintenance Instructions
Reduction Gears
1. Introduction
2. Structure
3. Handling Precautions
4. Troubleshooting
5. Instructions For Maintenance
6. Outline Drawing
7. Sectional Assembly Drawing
Control Valve
Disassembly
1. Disassembly Precautions
Cleaning
Inspection
Assembly
1. Subassemblies
2. Assembling The Control Valves
Relief Valves
1. Instructions For Disassembling And Assembling The Main Body Main Relief Valv
2. Instructions For Disassembling And Assembling The Add-On Main Relief Valves
3. Instructions For Disassembling And Assembling The Overload Relief Valves
4. Negative Control Relief Valves (55, Total 2 Locations)
5. Adjusting The Relief Valves
Installation
Operation
Troubleshooting
Control Valve In General
Relief Valve
Hydraulic System In General
Parts List
Reference Diagram 1/3
Reference Diagram 2/3
Reference Diagram 3/3
Service Parts
1. Reference No. 2: Spool Assembly
2. Reference No. 3: Spool Assembly
3. Reference No. 4: Spool Assembly
4. Reference No. 5: Spool Assembly
5. Reference No. 6: Spool Assembly
6. Reference No. 7: Spool Assembly
7. Reference No. 8: Spool Assembly
8. Reference No. 9: Spool Assembly
9. Reference No. 10: Spool Assembly
10. Reference No. 80: Spool Assembly
11. Reference No. 20: Plug Assembly
12. Reference No. 29: Spacer Assembly
13. Reference No. 30: Anti-Drift Valve Assembly
14. Reference No. 52: Spool Assembly
15. Reference No. 64: Relief Valve Kit
16. Reference No. 61: Spool Outlet Section
17. Reference No. 78: Inlet Section Assembly
18. Reference No. 80: Spool Section Assembly
Cylinder
Structural Drawings
1. Boom Cylinder (Right Side) (For Mono Boom Spec.)
2. Boom Cylinder (Left Side) (For Mono Boom Spec.)
3. Bucket Cylinder (For Mono Boom Spec.)
Structural Drawings
1. Arm Cylinder (For Mono Boom Spec.)
Structural Drawings
1. Blade Cylinder (Right/Left) (For Mono Boom Spec. With Dozer Blade)
1. Description Of Functions
2. Maintenance/Inspection And Servicing
3. Error Diagnosis
4. Storage Standards
5. Instructions For Disassembling And Assembling
Special Jigs For Repair
1. Dimensions Of Tools
2. Handling The Jigs For Cylinder Repair
Safety Information
1. Notes For These Instructions
2. Safety Precautions
3. Exemption From Liability
For Operation Use
1. Description
2. Specifications
3. Structure
4. Functions
5. Operation
6. Maintenance Procedures
7. Troubleshooting
Cross-Sectional View Of Pilot Valve Assembly
Cross-Sectional And Detailed Views Of Special Jig Assembly
For Travel Use
1. Description
2. Specifications
3. Actuation
4. Maintenance Procedures
5. Troubleshooting
6. Cross-Sectional View Of The Assembly
Exemption Clause
1. Description
2. Specifications
3. Actuation
5. Troubleshooting
Solenoid Valve (3 Stack)
Assembly Drawing
Theory Of Operation
Maintenance
1. Assembling And Disassembling Precautions
2. Assembling And Disassembling A Solenoid Operated Directional Valve
3. Maintenance Standards
4. Troubleshooting
Safety Precautions
Cushion Valve
1. Assembly Drawing
2. System Drawing
3. Operational Description
