700,339
Link-Belt Excavator 130X4 Engine DTC Information
Brand: Link-Belt
Type of Machine: Excavator
Type of Manual: Engine DTC Information, Connector Location Harness
Model: Link-Belt 130X4 Excavator
130X4 Connector Location Cab Main Harness.pdf
130X4 Connector Location Engine Harness.pdf
130X4 Connector Location Main Frame Harness.pdf
130X4 Connector Location Monitor Harness (With FVM).pdf
130X4 Connector Location Monitor Harness (Without FVM).pdf
130X4 DTC 7000 Pressure Sensor P1 Abnormality.pdf
130X4 DTC 7001 Pressure Sensor P2 Abnormality.pdf
130X4 DTC 7002 Pressure Sensor N1 Abnormality.pdf
130X4 DTC 7003 Pressure Sensor N2 Abnormality.pdf
130X4 DTC 7007 Pressure Sensor Arm Cylinder Rod Abnormality.pdf
130X4 DTC 7021 Pressure Sensor Swing Pilot Abnormality.pdf
130X4 DTC 7023 Pressure Sensor Arm-in Pilot Abnormality.pdf
130X4 DTC 7041 Temperature Sensor Hydraulic Oil Abnormality.pdf
130X4 DTC 7065 Pressure Sensor Boom-up Pilot Abnormality.pdf
130X4 DTC 7067 Pressure Sensor Bucket-in Pilot Abnormality.pdf
130X4 DTC 7068 Pressure Sensor Boom-down Pilot Abnormality.pdf
130X4 DTC 7069 Pressure Sensor Arm-out Pilot Abnormality.pdf
130X4 DTC 7070 Pressure Sensor Bucket-out Pilot Abnormality.pdf
130X4 DTC 7071 Pressure Sensor Travel Right Pilot Abnormality.pdf
130X4 DTC 7072 Pressure Sensor Travel Left Pilot Abnormality.pdf
130X4 DTC 7074 Pressure Sensor 1st Option Pilot (Common-Front pedal) Abnormality.pdf
130X4 DTC 7075 Pressure Sensor Arm Cylinder Bottom Abnormality.pdf
130X4 DTC 7078 Pressure Sensor 1st Option Pilot (Rear pedal) Abnormality.pdf
130X4 DTC 7202 Pressure Boost Solenoid Abnormality.pdf
130X4 DTC 7203 Travel Alarm Buzzer Abnormality.pdf
130X4 DTC 7212 Gate Lock Solenoid Abnormality.pdf
130X4 DTC 7247 Boom 2-down Pilot Proportional Valve Abnormality.pdf
130X4 DTC 7249 Bucket-in Pilot Proportional Valve Abnormality.pdf
130X4 DTC 7270 Tilting 1 Proportional Valve Abnormality.pdf
130X4 DTC 7271 Tilting 2 Proportional Valve Abnormality.pdf
130X4 DTC 7400 7401 Water Temperature Overheating.pdf
130X4 DTC 7404 Oil Temperature Overheating.pdf
130X4 DTC 7405 7406 Boost Temperature Overheating.pdf
130X4 DTC 7420 Alternator Power Generation Failure.pdf
130X4 DTC 7422 Engine Oil Pressure Decrease.pdf
130X4 DTC 7424 Return Filter Clogging.pdf
130X4 DTC 7427 Fuel Filter Clogging 2.pdf
130X4 DTC 7618 DCU Communication Abnormality.pdf
130X4 DTC P2BAA SCR System Abnormality (IND, purge prohibited).pdf
130X4 DTC P20A2 Reverting Valve And GND Short-Circuit.pdf
130X4 DTC P20AC Urea Solution Temperature (S-M) Sensor Abnormality.pdf
130X4 DTC P20B1 Coolant Control Valve And Disconnection.pdf
130X4 DTC P20B3 Coolant Control Valve And GND Short-Circuit.pdf
130X4 DTC P20B4 Coolant Control Valve +B Short-circuit.pdf
130X4 DTC P20C9 SCR System Abnormality (IND).pdf
130X4 DTC P20E8 Urea Injection Pressure And Low Pressure Abnormality.pdf
130X4 DTC P20E9 Urea Injection High Pressure Abnormality (1250 KPa or more).pdf
130X4 DTC P20FE Urea Injection Pressure And Low Pressure Abnormality.pdf
130X4 DTC P060B Read Predefined Test Voltage Value - Read Converted A-D Value.pdf
130X4 DTC P062F DCU EEPROM Abnormality.pdf
130X4 DTC P0102 Airflow Sensor Abnormality (Low voltage abnormality).pdf
130X4 DTC P0103 Airflow Sensor Abnormality (High voltage abnormality).pdf
130X4 DTC P0112 Intake Air Temperature Sensor Abnormality (Low voltage abnormality).pdf
130X4 DTC P205D Urea Solution Temperature (tank) Sensor Error (Disconnection).pdf
130X4 DTC P206A Urea Quality Sensor Reset Error.pdf
130X4 DTC P206C Urea Quality Sensor Short-circuit - Urea Solution Temperature Sensor Short-circuit.pdf
130X4 DTC P206D Urea Quality Sensor Disconnection - Urea Solution Temperature Sensor Disconnection.pdf
130X4 DTC P207F Quality of Urea Solution Is Too Low.pdf
130X4 DTC P207F Urea Quality Abnormality.pdf
130X4 DTC P208A Supply Module Disconnection.pdf
130X4 DTC P208B Supply Module Pump Motor Comparison Between Target Speed And Actual Speed.pdf
130X4 DTC P208C Supply Module GND Short-Circuit.pdf
130X4 DTC P208D Supply Module +B Short-Circuit.pdf
130X4 DTC P208E Dosing Valve Sticking.pdf
130X4 DTC P0237 Boost Pressure Sensor Abnormality (Low voltage abnormality).pdf
130X4 DTC P0238 Boost Pressure Sensor Abnormality (High voltage abnormality).pdf
130X4 DTC P242B Validity Diagnosis of SCR Temperature Sensor Against DOC Outlet Temperature Sensor.pdf
130X4 DTC P242C SCR Inlet Temperature Sensor Low Voltage Abnormality.pdf
130X4 DTC P242D SCR Inlet Temperature Sensor And High Voltage Abnormality.pdf
130X4 DTC P0401 EGR Flow Abnormality.pdf
130X4 DTC P0404 EGR Valve Control Abnormality.pdf
130X4 DTC P0409 EGR Position Sensor Abnormality (Brushless type).pdf
130X4 DTC P0607 Functional Failure of DCU Involving No Operation.pdf
130X4 DTC P2049 Dosing Module +B Short-circuit.pdf
130X4 DTC P2201 NOx Sensor Validity Diagnosis Of Concentration Value.pdf
130X4 DTC P2206 NOx Sensor Disconnection.pdf
130X4 DTC P2207 NOx Sensor Short-circuit.pdf
130X4 DTC U0002 DCU-ECM Communication Error.pdf
130X4 DTC U010E ISO-CAN DCU Communication Abnormality.pdf
130X4 DTC U029D Communication Error Between DCU and NOx Sensor J1939CAN Bus Off.pdf
130X4 DTC U0100 ISO-CAN Bus Off.pdf
