7,392
Link-Belt Excavator 130LX 160LX Operator Manual
Brand: Link-Belt
Type of Machine: Excavator
Model: Link-Belt 130LX 160LX Excavator
Engine: Isuzu BB-4BG1T Engine
Number of Pages: 228 Pages
130 LX - 160 LX Excavators
To The Owner
Right,Left,Front And Rear Of Machine
Identification Numbers
Type, Serial Number And Year Of Manufacture
Machine Components
Safety Rules
Utility Safety
Personal Safety
Before Operation
Machine Operation
Burn Prevention
Fire Extinguisher
Fire Or Explosion Prevention
Maintenance
Safety Area
Parking The Machine
Before Using The
Hydraulic Breaker (Optional)
Using The Hydraulic Breaker (Optional)
Maintenance And Adjustments
Hand Signals
Instruments/Controls
Cab Door
Steps And Access Handles
Operator’s Compartment Controls
Right-Hand Control Arm
Left-Hand Control Arm
Systems Display And Control Panel
Anti-Theft Device
Arm And Upperstructure Swing
Left-Hand Control Lever
Boom And Bucket
Right-Hand Control Lever
Optional Control Pattern
Arm And Upperstructure Swing Left-Hand Control Lever
Boom And Bucket Right-Hand Control Lever
130 Lx Blade Option
Heating And Ventilation Or Air Conditioning Controls
Operator’s Seat
Ii
Windshield
Lower Front Window
Rear Window And Emergency Exit
Side Doors
Lifting Eye
Towing Eyes
Hose Burst Check Valves (Optional)
Optional Tool Flow Selector Valve (Optional))
Tool Supply Valves (Optional)
Operating Instructions
Before Operating The Machine
Machine Operation
Break-In Period
Vandal Covers
Starting The Engine
Bringing The Machine Up To Operating Temperature
Engine Operation
Operating The Machine In Cold Weather
Stopping The Engine
Machine Operation
Machine Travel
Handling The Machine
Load Handling
Operating The Machine In Water
Operating On Sloping Ground
Filling The Bucket
Parking The Machine
Towing The Machine
Lowering Attachment In Event Of Failure
Auxiliary Hydraulic (Optional)
Transporting The Machine
130 Lx Long Arm Transport Position
Lubrication
Fluids And Lubricants
Hourmeter
Daily Inspection
Service Intervals
Engine Oil
Environment
Fluid And Lubricant Capacities And Specifications
Grease Points
Greasing The Turntable Teeth
Greasing The Swing Reduction Gear
Fluid Levels
Fuel System
Air Filter
Travel Reduction Gears
Adjustment/Maintenance
Tracks
Radiator And Oil Cooler
Fan And Alternator Drive Belt
Fuel Tank Filter
Inspecting And Cleaning The Machine
Checking For Cylinder Leakage
Plastic And Resin Parts
Replacing A Bucket
Shimming The Bucket
Welding On The Machine
Air Conditioning
Engine Troubleshooting
Hardware Torque Inspection
Torque And Specifications Per Component
Electrical
Fuses
Batteries
Connecting Booster Batteries
Replacing A Bulb
Machine Storage
Preparation For Storage
Specifications
Weights
130 Lx Operating Weight
160 Lx Operating Weight
Weights Of Component Parts
Undercarriage
Safety Devices
Operator’s Cab
Dimensions
130 Lx With 250 M (8ft 2in) Arm
Dimensions
130 Lx With 306 M (10ft 2in) Arm
Dimensions
160 Lx With 270 (8ft 10in)Arm
Dimensions
160 Lx With 310 M (10ft 2 In) Arm
Lifting Capacities
130 Lx And 160 Lx Excavators
130 Lx Lifting Capacities
160 Lx Lifting Capacities
Buckets
Esco
Working Range
Working Range
130 Lx With 306 M (10ft 0in) Arm
Working Range
160 Lx With 27 M (8ft 10in) Arm
Working Range
160 Lx With 310 M (10ft 0in) Arm
Index
