Hyundai
58
135,269
Link Belt Crane TCC-750XP Service Manual
Brand: Link Belt
Model: Link Belt TCC-750XP Crane
Number of Pages: 694 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions, And Safety Procedures
AREA 02 CRAWLER LOWER
SM02- 001- 003.00 Lower Frame Counterweight, R & I
SM02- 001- 004.00 Track, R & I
SM02- 001- 006.00 Side Frames, R & I
SM02- 003- 032.00 Track Planetary Drive Unit, R & I
SM02- 003- 033.00 Track Planetary Drive Unit, Recondition
SM02- 003- 034.00 Track Drive Sprocket, R & I
SM02- 004- 016.00 Take- Up Roller, R & I
SM02- 004- 017.00 Take- Up Roller, Recondition
SM02- 005- 017.00 Sealed Track Roller, R & I
SM02- 005- 018.00 Sealed Track Roller, Recondition
SM02- 007- 006.00 Track Adjustment Cylinder, R & I
SM02- 007- 007.00 Track Adjustment Cylinder, Recondition
SM02- 008- 004.00 Side Frame Extend Cylinder, R & I
SM02- 008- 005.00 Side Frame Extend Cylinder, Recondition
SM02- 010- 030.00 Lower Hydraulic Components, R & I
SM02- 010- 031.00 Rotating Joint, R & I
SM02- 010- 032.00 Rotating Joint, Recondition (8- Way)
SM02- 011- 014.00 Travel Motor, Recon.
SM02- 011- 018.00 Travel Motor, R & I
SM02- 011- 019.00 Travel Motor, Recondition
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 078.00 Upper Revolving Frame And Turntable Bearing, R & I
SM03- 010- 052.00 Counterweight Removal Cylinder, R & I
SM03- 010- 056.00 Counterweight Removal Cylinder, Recondition (G1)
SM03- 010- 057.00 Counterweight Removal Solenoid Control Valve, R & I
SM03- 010- 058.00 Counterweight Removal Solenoid Control Valve, Recondition
SM03- 010- 067.00 Counterweight Removal Cylinder, Recondition (G2)
AREA 04 VERTICAL SHAFTS
SM04- 005- 035.00 Swing Brake, Recondition (Ausco)
SM04- 005- 036.00 Swing Brake, R & I
SM04- 010- 035.00 Swing Reduction Unit, Recondition
SM04- 010- 042.00 Swing Reduction Unit, R & I
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 026.00 Winch, Troubleshooting (G1 - w/Braden CH210)
SM05- 006- 028.00 Winch, Recondition (G1 - w/Braden CH210)
SM05- 006- 045.00 Winch Assy, R & I
SM05- 018- 006.00 Winch Roller, R & I And Recondition
AREA 06 UPPER ENGINE
SM06- 001- 007.00 Radiator & Charged Air Cooler, R & I
SM06- 001- 008.00 Radiator Fan Motor, R & I
SM06- 001- 011.00 Starter, R & I (CAT C6.6 Tier 3)
SM06- 001- 012.00 Alternator, R & I (CAT C6.6 Tier 3)
SM06- 008- 017.00 Throttle Pedal, R & I (Electronic)
SM06- 013- 023.00 Radiator & Charged Air Cooler, R & I
SM06- 013- 024.00 Radiator Fan Motor, R & I
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06- 025- 032.00 Operator’s Cab A/C Coil And Heater Core, R & I
SM06- 025- 033.00 Operator’s Cab A/C Coil And Heater Core, Illustrated
SM06- 025- 036.00 Diesel Coolant Heater, R & I
SM06- 029- 004.00 Battery, R & I
SM06- 047- 000.00 Electrical System Wire Identification Code
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 001- 028.00 Hydraulic System Cleaning Procedure
SM07- 001- 035.00 Pilot Control Accumulator, R & I (100psi)
SM07- 002- 028.00 Relief Valve, Recondition
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 003- 007.00 Four Way Solenoid Valve, Recondition
SM07- 003- 012.00 Pilot Kickout Valve, Recondition (G1)
SM07- 003- 013.00 Pilot Kickout Valve, Recondition (G2)
SM07- 004- 073.00 Upper Hydraulic Components, R & I (Generation 1 - Cab Plumbing)
SM07- 004- 075.00 Upper Hydraulic Components, R & I (Generation 1 - Single Winch Plumbing)
SM07- 004- 076.00 Upper Hydraulic Components, R & I (2 Winch Plumb)
SM07- 004- 077.00 Upper Hydraulic Components, R & I (Generation 1 - Upper Frame)
SM07- 004- 078.00 Upper Hydraulic Components, R & I (Generation 2 - Cab Plumbing)
SM07- 004- 108.00 Upper Hydraulic Components, R & I (Generation 3 - Cab Plumbing)
SM07- 004- 109.00 Upper Hydraulic Components, R & I (Two Winch Plumbing)
SM07- 004- 118.00 Upper Hydraulic Components, R & I (Generation 2 - Single Winch Plumbing)
SM07- 004- 130.00 Upper Hydraulic Components, R & I (Generation 2 - Upper Frame)
SM07- 004- 131.00 Upper Hydraulic Components, R & I (Generation 4 - Cab Plumbing)
SM07- 005- 072.00 Hydraulic Gear Pump, Recondition (Com- Inter Multiple Section)
SM07- 005- 090.00 3- Section Hydraulic Gear Pump, R & I
SM07- 005- 091.00 Regulated Piston Pump & Flex Coupling, R & I
SM07- 005- 092.00 Regulated Hydraulic Piston Pump, Recondition
SM07- 006- 034.00 Swing Motor, Recondition (Von Ruden)
SM07- 006- 095.00 Winch Motor, Recondition (Linde)
SM07- 006- 123.00 Hydraulic Gear Pump/Motor, Recondition (PGP/PGM600 Series)
SM07- 006- 127.00 Winch Motor, R & I
SM07- 006- 128.00 Swing Motor, R & I
SM07- 008- 032.00 Control Valves, Recondition (Gresen V20)
SM07- 008- 107.00 Dual Axis Controller Valve, Recondition
SM07- 008- 114.00 Foot Pedal Control Valve, Recondition (Travel/Boom Telescope)
SM07- 008- 118.00 Swing Brake Pedal Valve, Recondition
SM07- 008- 122.00 Winch Counterbalance Valve, Recondition
SM07- 008- 180.00 Single Axis Controller Valve, Recondition
SM07- 008- 181.00 Winch Counterbalance Valve, R & I
SM07- 008- 183.00 Swing Brake Pedal Control Valve, R & I
SM07- 008- 186.00 Pressure Reducing Valve, Recondition (Pilot Pressure)
SM07- 008- 187.00 Control Valve Block, R & I (Travel, BH, Tele, Winch)
SM07- 008- 188.00 Control Valve Block, Recondition (Linde VW18000 Series)
SM07- 008- 189.00 Swing Control Valve, R & I
SM07- 008- 190.00 Flow Divider Valve, Recondition (Telescope)
SM07- 008- 191.00 Dual Axis Controller Valve, R & I
SM07- 008- 192.00 Single Axis Controller Valve, R & I
SM07- 008- 193.00 Foot Pedal Control Valves, R & I
SM07- 008- 195.00 Counterweight Removal Control Valve, Recondition
SM07- 008- 210.00 Main Function Control Valve Assy, Recon.
SM07- 011- 002.00 Hydraulic Reservoir Filter Assy, R & I
SM07- 011- 003.00 Hydraulic Reservoir Filter Assy, Recondition
SM07- 014- 005.00 Oil Cooler Hydraulic Fan Motor, Recondition (Parker 500 Series)
SM07- 014- 008.00 Hydraulic Oil Cooler Assy, R & I
SM07- 014- 009.00 Hydraulic Oil Cooler Fan Motor, R & I
SM09- 001- 002.00 Tubular Boom, Fly, & Jib Repair
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Comps Made Of Fibrous Comp Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 053.00 Hydraulic Boom Inspection - Formed Sections
SM17- 001- 075.00 Four Section Boom, R & I (38.6- 115.6’ Full Power)
SM17- 001- 076.00 Four Section Boom, Recondition (38.6- 115.6’ Full Power)
SM17- 001- 090.00 Four Section Boom, Recondition
SM17- 001- 096.00 Four Section Boom, Recondition (38.6’- 115.6’ Boom)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 060.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 061.00 Boom Telescope Counterbalance Valve, R & I
SM17- 002- 062.00 Boom Telescope Mechanism, Recondition
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 039.00 Boom Hoist Cylinder, R & I
SM17- 003- 040.00 Boom Hoist Counterbalance Valve, R & I - G1
SM17- 003- 055.00 Boom Hoist Counterbalance Valve, R & I - G2
SM17- 009- 004.00 Five Sheave Boom Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 002.00 Gear, Shaft, Bearing, & Housing Inspection
SM18- 000- 003.00 Crane Systems Schematics
SM18- 007- 004.00 Reeling Drum, Recondition (Greer)
SM18- 007- 010.00 Reeling Drum, R & I
SM18- 007- 016.00 Reeling Drum, Troubleshooting & Recondition (Hirschmann LWG511)
SM18- 007- 017.00 Reeling Drum, R & I (CE Models)
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 004.00 Air Conditioning Compressor, Recondition
SM18- 018- 023.00 Air Conditioning Compressor, R & I (CAT C6.6 Tier 3)
SM18- 022- 001.00 Auger Store Cylinder, R & I
SM18- 022- 002.00 Auger Store Cylinder, Recondition
SM18- 022- 003.00 Manifold Assembly, Recondition (Latching/Storage Cylinder)
SM18- 022- 004.00 Manifold Assembly, Recondition (Auger Control)
SM18- 022- 005.00 Auger Plumbing Illustrated
