Link Belt Crane TCC-1100XP Service Manual
Brand: Link Belt
Model: Link Belt TCC-1100XP Crane
Number of Pages: 608 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions, And Safety Procedures
AREA 02 CRAWLER LOWER
SM02- 001- 004.00 Track, R & I
SM02- 001- 005.00 Axle & Axle Extend Cylinder, R & I
SM02- 004- 017.00 Take–Up Roller, Recon.
SM02- 004- 018.00 Take–Up Roller, R & I
SM02- 005- 019.00 Track Rollers, R & I
SM02- 007- 008.00 Track Adjustment Cylinder, R & I
SM02- 007- 009.00 Track Adjustment Cylinder, Recon.
SM02- 008- 006.00 Axle Extend/Retract Cylinder Assy, Recon.
SM02- 010- 034.00 Rotating Joint, R & I
SM02- 010- 035.00 Rotating Joint, Recon.
SM02- 010- 036.00 Collector Ring, R & I
SM02- 010- 037.00 Collector Ring, Recon. (8–Ring)
SM02- 010- 038.00 Lower Hydraulic Components, R & I
SM02- 011- 020.00 Hydraulic Travel Drive With Motor, R & I
SM02- 011- 021.00 Hydraulic Travel Drive With Motor, Recon.
SM02- 014- 013.00 Hydraulic Jack Cylinders, R & I
SM02- 014- 014.00 Hydraulic Jack Cylinders, Recon.
SM02- 014- 015.00 Control Valve Assy, Recon.
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 080.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 010- 068.00 Counterweight Removal Cylinders, R & I
SM03- 010- 069.00 Counterweight Removal Cylinder, Recon.
AREA 04 VERTICAL SHAFTS
SM04- 005- 035.00 Swing Brake, Recon.
SM04- 010- 027.00 Swing Speed Reducer, Recon.
SM04- 010- 045.00 Swing Reduction Unit And Brake, R & I
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 026.00 Winch, Troubleshooting
SM05- 006- 028.00 Winch, Recon.
SM05- 006- 045.00 Winch Assembly, R & I
SM05- 006- 048.00 Winch, Troubleshooting
SM05- 006- 049.00 Winch, Recon.
SM05- 018- 006.00 Winch Roller, R & I And Recon.
AREA 06 UPPER ENGINE
SM06- 008- 017.00 Throttle Pedal, R & I
SM06- 013- 017.00 Starter, R & I
SM06- 013- 018.00 Alternator, R & I
SM06- 013- 019.00 Radiator & Charged Air Cooler, R & I
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recon.
SM06- 025- 032.00 Operator’s Cab A/C Coil & Heater Core, R & I
SM06- 025- 033.00 Operator’s Cab A/C Coil & Heater Core, Illustrated
SM06- 025- 035.00 Diesel Coolant Heater, R & I
SM06- 029- 006.00 Battery, R & I
SM06- 029- 010.00 Battery, R & I
SM06- 047- 000.00 Electrical System Wire Identification Code
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 001- 028.00 Hydraulic System Cleaning Procedure
SM07- 002- 028.00 Relief Valve, Recon.
SM07- 003- 006.00 Solenoid Valves, General Recon.
SM07- 003- 013.00 Pilot Kickout Valve, Recon. (Generation 1)
SM07- 003- 018.00 Pilot Kickout Valve, Recon. (Generation 2)
SM07- 004- 098.00 Upper Hydraulic Components, R & I (Upper Frame)
SM07- 004- 099.00 Upper Hydraulic Components, R & I (Generation 1 - Cab Plumbing)
SM07- 004- 100.00 Upper Hydraulic Components, R & I (Generation 1 - Two Winch Plumbing)
SM07- 004- 115.00 Upper Hydraulic Components, R & I (Generation 2 - Two Winch Plumbing)
SM07- 004- 116.00 Upper Hydraulic Components, R & I (Generation 2 - Cab Plumbing)
SM07- 004- 117.00 Upper Hydraulic Components, R & I
SM07- 005- 083.00 Hydraulic Gear Pump, Recon.
SM07- 005- 107.00 2- Section Gear Pump, R & I
SM07- 005- 109.00 Regulated Pump, R & I
SM07- 005- 110.00 Regulated Pump, Recon.
SM07- 005- 115.00 2- Section Gear Pump, Recon.
SM07- 006- 081.00 Swing Motor, Recon.
SM07- 006- 095.00 Winch Motor, Recon.
SM07- 006- 127.00 Winch Motor, R & I
SM07- 006- 131.00 Swing Motor, R & I
SM07- 008- 101.00 Control Valve, Recon (Swing)
SM07- 008- 107.00 Dual Axis Controller Valve, Recon.
SM07- 008- 114.00 Hydraulic Foot Control Valve, Recon.
SM07- 008- 118.00 Swing Brake Pedal Valve, Recon.
SM07- 008- 122.00 Winch Counterbalance Valve, Recon.
SM07- 008- 180.00 Single Axis Controller Valve, Recon.
SM07- 008- 181.00 Winch Counterbalance Valve, R & I
SM07- 008- 191.00 Dual Axis Controller Valve, R & I
SM07- 008- 192.00 Single Axis Controller Valve, R & I
SM07- 008- 193.00 Foot Pedal Control Valves, R & I
SM07- 008- 195.00 Counterweight Removal Control Valve, Recon.
SM07- 008- 203.00 Main Control Valve, R & I (Travel, BH, Tele, Winch)
SM07- 008- 204.00 Main Control Valve, Recon.
SM07- 008- 211.00 Main Control Valve, R & I
SM07- 008- 212.00 Main Function Control Valve Assy, Recon.
SM07- 008- 217.00 Telescope Control Valve, Recon.
SM07- 011- 002.00 Hydraulic Reservoir Filter Assy, R & I
SM07- 011- 003.00 Hydraulic Reservoir Filter Assy, Recon.
SM07- 014- 005.00 Oil Cooler Hydraulic Fan Motor, Recon.
SM07- 014- 013.00 Hydraulic Oil Cooler Assembly, R & I
SM07- 014- 014.00 Hydraulic Oil Cooler Fan Motor, R & I
SM09- 001- 002.00 Tubular Boom, Fly, & Jib Repair
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Components Made Of Fibrous Comp Materials
SM14- 001- 011.00 Upper Cab Tilt Cylinder, R & I
SM14- 001- 012.00 Upper Cab Tilt Cylinder, Recon.
SM14- 001- 013.00 Cab Tilt Cylinder, Recon.
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 053.00 Hydraulic Boom Inspection - Formed Sections
SM17- 001- 060.00 Boom Wear Shoe Replacement (40- 150’ Full Power)
SM17- 001- 086.00 Five Section Boom, Recon. (40’- 150’ Full Power)
SM17- 001- 088.00 5 Section Boom Assy, R & I. (40- 150’ Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recon.
SM17- 002- 047.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 048.00 Boom Telescope Counterbalance Valve, R & I
SM17- 002- 062.00 Boom Telescope Mechanism, Recon.
SM17- 002- 119.00 Hose Reel, R & I (65 ft)
SM17- 002- 124.00 Hose Reel, Recon. (65 ft)
SM17- 002- 125.00 Hose Reel, Recon. (33 ft)
SM17- 003- 013.00 Boom Hoist Cylinder, Recon.
SM17- 003- 051.00 Boom Hoist Cylinder, R & I
SM17- 003- 052.00 Boom Hoist Counterbalance Valve, R & I
SM17- 009- 014.00 6 Sheave Head Machinery, Recon.
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 002.00 Gear, Shaft, Bearing, Housing Inspection
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 016.00 Reeling Drum, Troubleshooting & Recon.
SM18- 007- 020.00 Reeling Drum, R & I
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 004.00 Air Conditioning Compressor, Recon.
SM18- 018- 029.00 Air Conditioning Compressor, R & I
Brand: Link Belt
