Hyundai
86
176,834
Link Belt Crane TC-138 Service Manual
Brand: Link Belt
Model: Link Belt TC-138 Crane
Number of Pages: 158 Pages
AREA 00 GENERAL INFORMATION
SM00---000---000.00 Service Manual General Usage & Instructions
AREA 03 UPPER REVOLVING FRAME
SM03---001---007.00 Undecking Machine
SM03---006---006.00 Swing Lock
SM03---010---004.00 Counterweight Remover System
SM03---010---005.00 Counterweight Remover Cylinder
SM03---010---006.00 Hydraulic Cylinder, Recondition (Counterweight Removal)
AREA 04 VERTICAL SHAFTS
SM04---003---007.00 Vertical Swing Shaft
AREA 05 HORIZONTAL SHAFTS
SM05---000---007.00 Horizontal Shafts --- General
SM05---001---012.00 Reverse Shaft
SM05---002---009.00 Reduction Shaft
SM05---003---011.00 Front Or Rear Drum Shaft
SM05---005---005.00 Third Drum Shaft
SM05---007---001.00 Two Speed Planetary
SM05---007---002.00 Planetary Brake, R & I And Adjustment
SM05---008---014.00 Boom Hoist Shaft
SM05---008---017.00 Boom Hoist Pawl
SM05---009---002.00 Clutches --- General
SM05---009---004.00 Clutch Assemblies
SM05---009---009.00 Rotating Joint, R & I And Recondition
SM05---012---007.00 Front & Rear Drum Brakes
SM05---012---008.00 Third Drum Brake (Mechanical)
SM05---012---009.00 Third Drum Brake (Hydraulic)
SM05---012---010.00 Boom Hoist Brake
SM05---014---002.00 Swing Brake
AREA 06 UPPER ENGINE
SM06---016---002.00 Twin Disc Clutch (2 Disc)
SM06---018---001.00 Chain Case Pump
SM06---022---006.00 GM Engine Wiring
SM06---029---001.00 Storage Battery
SM06---034---001.00 Cummins Engine Wiring
SM06---039---004.00 Chain Case
SM07---000---005.00 S---o---M System --- General
SM07---000---006.00 S---o---M Troubleshooting
SM07---001---001.00 Unloading Valve
SM07---001---002.00 Accumulator
SM07---001---004.00 External Check Valve
SM07---001---005.00 Relief Valve
SM07---001---008.00 S---o---M Filter
SM07---003---006.00 Solenoid Valves, General Recondition
SM07---005---006.00 S---o---M Pump
SM07---012---001.00 Control Valves & Stand
SM07---018---001.00 Hydraulic System Tube Fittings
AREA 08 ANGLE BOOM & JIB
SM08---001---001.00 Repairing Damaged Angle Booms And Jibs
SM09---001---002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
SM09---002---001.00 Live Mast Cylinder (Early Models)
SM09---002---002.00 Live Mast Cylinder (Later Models)
AREA 18 SPECIAL ATTACHMENTS
SM18---000---001.00 Capscrew Torques
SM18---000---002.00 Bearing, Gear, Shaft, & Housing Inspection
