Link-belt Crane RTC-8050 II J6K4-4251 Service Manual Wiring Diagram
Brand: Link-belt
Type of Manual: Service Manual, Wiring Diagram
Model: Link-belt RTC-8050 II, RTC-8050XP II Crane
Serial Number: J6K4-4251
Number of Pages: 721 Pages
Service Manual
AREA 00 GENERAL INFORMATION
SM00-000-000.00 How To Use This Manual, General Service Instructions, And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01-002-023.00 Front & Rear Axles, Recondition
SM01-004-010.00 Front Axle, R & I
SM01-007-012.00 Steer Cylinder, Recondition
SM01-007-018.00 Steer Cylinder, R & I
SM01-010-002.00 Steering Pump, Recondition
SM01-010-026.00 Power Steering Pump, R & I
SM01-018-047.00 Transmission, R & I (Funk)
SM01-018-048.00 Transmission, Recondition (Funk)
SM01-018-059.00 Transmission, R & I (Spicer)
SM01-018-060.00 Transmission, Recondition (Spicer)
SM01-019-025.00 Transmission Control Unit Diagnostic Manual (Funk Transmission)
SM01-022-004.00 U-Joint Installation -Half Round Yokes
SM01-022-005.00 U-Joint Installation -Full Round Yokes
SM01-029-017.00 Rear Axle & Suspension, R & I
SM01-039-002.00 Vacuum Pressure Relief Valve, Recondition
SM01-039-003.00 Hydraulic System Cleaning Procedure
SM01-039-004.00 Hydraulic Reservoir Filter Assembly, R & I
SM01-039-005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01-039-009.00 Hydraulic Reservoir Filter Assembly, R & I
SM01-043-001.00 Solenoid Valves, General Recondition
SM01-043-003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01-043-004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01-043-029.00 Combination Steering Control Valve, R & I
SM01-043-030.00 Combination Steering Control Valve, Recondition
SM01-043-031.00 Outrigger Directional Control Valve, R & I (Generation 1)
SM01-043-032.00 Outrigger Function Control Valve, R & I
SM01-043-056.00 Outrigger Directional Control Valve, R & I (Generation 2)
SM01-043-062.00 Hydro-Gas Suspension Control Valve, R & I
SM01-044-018.00 Outrigger Lock Valve Cartridge, R & I
SM01-045-014.00 Outrigger Beam Cylinder, Recondition (Generation 1 -Hydraulic Technologies)
SM01-045-044.00 Outrigger Beam & Beam Cylinder, R & I
SM01-045-050.00 Outrigger Beam Cylinder, Recondition (Generation 2 -Texas Hydraulics)
SM01-046-034.00 Jack Cylinder, Recondition
SM01-046-035.00 Jack Cylinder, R & I
SM01-047-034.00 Relief Valve, Recondition
SM01-048-028.00 Rotating Joint, R & I
SM01-048-029.00 Rotating Joint, Recondition
SM01-050-014.00 Remote Transmission Oil Cooler, R & I
SM01-050-025.00 Hydraulic Oil
SM01-066-027.00 Battery, R & I (Generation 1)
SM01-066-031.00 Battery, R & I (Generation 2)
SM01-066-038.00 Battery, R & I (Generation 3)
SM01-066-039.00 Battery, R & I (Generation 3)
SM01-069-005.00 Tire & Rim, R & I
SM01-071-014.00 Engine Housing, R & I (CAT Engine)
SM01-075-015.00 Hydraulic Throttle Control Cylinder, Recondition (Cummins 6BT5.9 Engine)
SM01-075-045.00 Radiator & Transmission/Hydraulic Oil Coolers, R & I (Cummins 6BT5.9 Engine)
SM01-075-046.00 Hydraulic Throttle Control Cylinder, R & I (Cummins 6BT5.9 Engine)
SM01-075-047.00 Starter, R & I (Cummins 6BT5.9 Engine)
SM01-075-048.00 Alternator, R & I (Cummins 6BT5.9 Engine)
SM01-075-075.00 Starter, R & I
SM01-075-076.00 Starter, R & I
SM01-075-079.00 Radiator, CAC, TOC, & Surge Tank, R & I
SM01-075-080.00 Starter, R & I
SM01-075-081.00 Alternator, R & I
SM01-075-085.00 Alternator, R & I
SM01-076-031.00 Collector Ring, R & I
SM01-076-032.00 Collector Ring, Recondition (Generation 1 -46 Ring)
SM01-076-047.00 Collector Ring, Recondition (Generation 2 -43 Ring)
SM01-076-055.00 Collector Ring, Recondition (Generation 3 -47 Ring)
SM01-076-072.00 Collector Ring, Recondition (Generation 4 -50 Ring)
SM01-076-075.00 Collector Ring, Recondition (46 Ring)
SM01-076-076.00 Collector Ring, Recondition (38 Ring)
SM01-076-086.00 Collector Ring, Recondition (Generation 5 -50 Ring)
SM01-076-092.00 Collector Ring, Recondition (53 Ring)
SM01-076-099.00 Collector Ring, Recondition (Generation 6 -55 Ring)
SM01-077-019.00 Starter, R & I (CAT C6.6 Engine)
SM01-077-020.00 Alternator, R & I (C6.6 Engine)
SM01-077-025.00 Radiator & Charged Air & Hydraulic Oil Coolers, R & I (C6.6 Engine)
SM01-078-016.00 Axle Oscillation Lockout Manifold, R & I (Hydro-Gas Suspension)
SM01-078-017.00 Axle Oscillation Cylinder, R & I
SM01-078-018.00 Axle Oscillation Cylinder, Recondition
SM01-078-019.00 Axle Oscillation Accumulator, R & I (Hydro-Gas Suspension)
SM01-078-020.00 Axle Oscillation Accumulator, Recondition (Hydro-Gas Suspension)
SM01-078-027.00 Axle Oscillation Lockout Manifold, Illustrated
SM01-078-032.00 Axle Oscillation Lockout Valve, R & I
SM01-079-011.00 Lower Hydraulic Components, R & I (Suction, Pressure, & Return-Gen 1)
SM01-079-055.00 Lower Hydraulic Components, R & I (Suction, Pressure, & Return-Gen 2)
SM01-079-056.00 Lower Hydraulic Components, R & I (O.R., Steering, & Axle Oscillation-Gen 2)
SM01-079-084.00 Lower Hydraulic Components, R & I (O.R., Steering, & Axle Oscillation-Gen 3)
SM01-080-008.00 Pump Disconnect, Recondition (Spicer Transmission)
SM01-080-044.00 Main Hydraulic Pump, R & I-Cummins Engine
SM01-080-049.00 Pump Disconnect, R & I (Spicer Transmission)
SM01-081-009.00 Hydraulic Pump, Recondition (Tele/Swing/O.R.’s/Steer/Brakes)
SM01-081-014.00 Hydraulic Pump, Recondition (Cummins-Main or CAT-Boom Hoist & Winch)
SM01-081-049.00 2-Section Hydraulic Pump, R & I-CAT Engine (Boom Hoist & Winch)
SM01-081-050.00 2-Section Hydraulic Pump, R & I-CAT Engine (Tele/Swing/O.R.’s/Steer/Brakes)
AREA 03 UPPER REVOLVING FRAME
SM03-001-070.00 Upper Revolving Frame And Turntable Bearing, R & I
SM03-003-014.00 Main Counterweight, R & I
AREA 04 VERTICAL SHAFTS
SM04-005-022.00 Swing Brake Assembly, Recondition (Generation 1 -Mico)
SM04-005-031.00 Swing Brake, R & I (Generation 3 -Ausco)
SM04-005-035.00 Swing Brake, Recondition (Generation 3 -Ausco)
SM04-010-026.00 Swing Reduction Unit, R & I (Generation 1 & 3)
SM04-010-027.00 Swing Speed Reducer, Recondition (Generation 1 & 3)
SM04-010-032.00 Swing Reduction Unit And Brake, R & I (Generation 2 -w/Integral Brake)
SM04-010-033.00 Swing Reduction Unit And Brake, Recondition (Generation 2 -w/Integral Brake)
AREA 05 HORIZONTAL SHAFTS
SM05-006-021.00 Winch, Troubleshooting (Generation 1 -Braden CH150A, 175A, 185A, CH230)
SM05-006-022.00 Winch, Recondition (Generation 1 -Braden CH150A, 175A, 185A, CH230)
SM05-006-023.00 Winch, R & I (Generation 1 -Braden CH150A, 175A, 185A, CH230)
SM05-006-025.00 Winch, Recondition (Generation 2 -Braden CH210)
SM05-006-026.00 Winch, Troubleshooting (Generation 2 -Braden CH210)
SM05-006-029.00 Winch, R & I (Generation 2 -Braden CH210)
SM05-018-002.00 Winch Roller, Recondition (Steel Roller)
SM05-018-003.00 Winch Roller, Recondition (Nylon Roller)
AREA 06 UPPER ENGINE
SM06-008-009.00 Throttle Treadle, R & I (Electronic)
SM06-008-012.00 Throttle Pedal, R & I (Hydraulic)
SM06-008-013.00 Throttle Pedal, Recondition (Hydraulic)
SM06-025-020.00 Operator’s Cab Heater Core, R & I (w/o Air Conditioning)
SM06-025-021.00 Operator’s Cab A/C Coil & Heater Core, R & I (w/Air Conditioning)
SM06-025-022.00 A/C Coil And Heater Core, Illustrated
SM06-025-024.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06-025-026.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06-025-029.00 Diesel Coolant Heater, R & I
SM06-025-039.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06-025-041.00 Diesel Coolant Heater, R & I
SM06-025-042.00 Operator’s Cab Heater Core, R & I (w/o Air Conditioning)
SM06-047-000.00 Electrical System Wire Identification Code
SM06-047-113.00 Electrical System Schematic Diagram
SM07-000-000.00 Hydraulic Schematic Diagram Symbol Legend
SM07-000-136.00 Hydraulic System Schematic Diagram
SM07-001-018.00 Piston Type Accumulator, Recondition
SM07-001-023.00 Carrier Brakes Accumulator, R & I
SM07-001-024.00 Pilot Control Accumulator, R & I
SM07-003-006.00 Solenoid Valves, General Recondition
SM07-004-011.00 Upper Hydraulic Components, R & I (Upper Frame -Generation 2)
SM07-004-039.00 Upper Hydraulic Components, R & I (Upper Frame -Generation 3)
SM07-004-040.00 Upper Hydraulic Components, R & I (Two Winch Plumbing -Generation 1)
SM07-004-041.00 Upper Hydraulic Components, R & I (Single Winch Plumbing)
SM07-004-061.00 Upper Hydraulic Components, R & I (Upper Frame -Generation 4)
SM07-004-133.00 Upper Hydraulic Components, R & I (Two Winch Plumbing -Generation 2)
SM07-004-134.00 Upper Hydraulic Components, R & I (Single Winch Plumbing -G2)
SM07-006-034.00 Swing Motor, Recondition (Generation 1 -Von Ruden)
SM07-006-073.00 Hydraulic Motor, Recondition (Winch)
SM07-006-075.00 Swing Motor & Brake, R & I (Generation 1 -w/o Pressure Reducing Valve)
SM07-006-076.00 Two Speed Valve, Recondition (Winch Motor)
SM07-006-077.00 Winch Motor, R & I (Generation 1 -CH185A w/o Pressure Reducing Valve)
SM07-006-081.00 Swing Motor, Recondition (Generation 2 -Parker)
SM07-006-086.00 Winch Motor, R & I (Generation 2 -CH185A w/Pressure Reducing Valve)
SM07-006-096.00 Winch Motor, R & I (Generation 3 -CH210)
SM07-006-100.00 Swing Motor, R & I (Generation 2 -Parker)
SM07-008-014.00 Winch Counterbalance Valve, Recondition
SM07-008-037.00 Pressure Reducing Valve, Recondition (Winch Or Swing Circuit)
SM07-008-048.00 Foot Control Valve, R & I (Generation 1 -Boom Telescope)
SM07-008-055.00 Controller Valve Assembly, R & I
SM07-008-056.00 Controller Valve Assembly, Recondition (Comm-Intertech)
SM07-008-063.00 Priority Flow Control Valve Assembly, Recondition
SM07-008-066.00 Control Valve, Recondition (Gresen V40)
SM07-008-067.00 Foot Control Valve, Recondition (Generation 1 -Boom Telescope)
SM07-008-076.00 Single Axis Control Valves, R & I
SM07-008-077.00 Single Axis Control Valves, Recondition (Comm-Intertech)
SM07-008-079.00 Upper Hydraulic Components, R & I (Upper Frame -Generation 1)
SM07-008-081.00 Control Valve, Recondition (Winch -Gresen V56)
SM07-008-091.00 Winch Counterbalance Valve, R & I (Winch w/o Pressure Reducing Valve)
SM07-008-092.00 Winch Pressure Reducing Valve, R & I
SM07-008-096.00 Winch Counterbalance Valve, R & I (Winch w/Pressure Reducing Valve)
SM07-008-107.00 Controller Valve, Recondition (Monson)
SM07-008-108.00 Single Axis Controller Valve, Recondition (Monson)
SM07-008-111.00 Winch Control Valve, R & I (Generation 1)
SM07-008-113.00 Boom Telescope Foot Control Valve, R & I (Gen 2 -Boom Telescope)
SM07-008-114.00 Boom Telescope Foot Control Valve, Recondition (Gen 2 -Boom Telescope)
SM07-008-118.00 Swing Brake Pedal Control Valve, Recondition
SM07-008-119.00 Pressure Reducing Valve, R & I (Steering)
SM07-008-127.00 Winch Control Valve, Recondition (Generation 2 -Parker VP170)
SM07-008-129.00 Hydraulic Control Valves, Recondition-Swing/Tele/Boom Hoist (Parker VG20)
SM07-008-131.00 Pilot Oil Supply Valve, Recondition
SM07-008-137.00 Swing Brake Pedal Valve, R & I
SM07-008-142.00 Accumulator Charging Valve, Recondition
SM07-008-146.00 Accumulator Charging Valve, R & I
SM07-008-157.00 Winch Control Valve, R & I (Generation 2)
SM07-008-190.00 Flow Divider Valve, Recon.
SM07-018-001.00 Hydraulic System Tube Fittings
SM07-022-003.00 Steering Control Valve, Recondition (Generation 1 -Eaton Series 12)
SM07-022-011.00 Steering Column, R & I (Generation 1 -John Deere Column)
SM07-022-012.00 Steering Column, Recondition (John Deere)
SM07-022-013.00 Power Steering Control Valve, R & I (Generation 1 -w/John Deere Column)
SM07-022-018.00 Emergency Steer Accumulator, R & I
SM07-022-022.00 Steering Control Valve, Recondition (Generation 2 -Eaton Series 10)
SM07-022-023.00 Steering Control Valve, R & I (Generation 2 -w/RR-TCI Column)
SM07-022-025.00 Steering Column, R & I (Generation 2 -RR-TCI Column)
SM07-022-027.00 Priority Flow Control Valve, R & I (Emergency Steering)
SM07-026-008.00 Brake Treadle Valve, Recondition
SM07-026-010.00 Brake Treadle Valve, R & I
SM07-029-001.00 Swing Brake Actuator, R & I
SM07-029-002.00 Swing Brake Actuator, Recondition
SM09-001-002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 14 CAB & HOUSE ASSEMBLY
SM14-001-006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17-001-036.00 Hydraulic Boom Inspection
SM17-001-054.00 Four Section Boom, R & I
SM17-001-055.00 Four Section Boom, Recondition (35.5’-110’ Full Power)
SM17-002-022.00 Boom Telescope Cylinder, Recondition
SM17-002-026.00 Boom Telescope Cylinder, Troubleshooting
SM17-002-027.00 Boom Telescope Counterbalance Valve, R & I
SM17-003-013.00 Boom Hoist Cylinder, Recondition
SM17-003-034.00 Boom Hoist Cylinder, R & I
SM17-003-035.00 Boom Hoist Counterbalance Valves, R & I
SM17-009-006.00 Four Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18-000-001.00 Capscrew Torques
SM18-000-002.00 Bearing, Gear, Shaft, & Housing Inspection
SM18-000-003.00 Crane System Schematics
SM18-007-004.00 Reeling Drum, Recondition
SM18-007-016.00 Reeling Drum, Troubleshooting & Recon.
SM18-007-030.00 Reeling Drum, R & I
SM18-017-005.00 Carrier Winch Valve Controller, Recondition
SM18-017-007.00 Carrier Winch Control Valve, R & I
SM18-018-001.00 Air Conditioning Service Precautions
SM18-018-002.00 Air Conditioning Hydraulic Drive Motor, R & I (Generation 1)
SM18-018-003.00 Air Conditioning Hydraulic Drive Motor, Recondition (Generation 1)
SM18-018-004.00 Air Conditioning Compressor, Recondition
SM18-018-006.00 Air Conditioning Compressor, R & I (Generation 1)
SM18-018-013.00 Air Conditioning Compressor, R & I (Generation 2)
SM18-018-014.00 Air Conditioning Hydraulic Drive Motor, R & I (Generation 2)
SM18-018-015.00 Air Conditioning Hydraulic Drive Motor, Recondition (Generation 2)Hydraulic Schematic J6J0303S
Electrical Diagram J6R0098S
Brand: Link-belt
Service Manual
