Link Belt Crane RTC-8040 II Service Manual
Brand: Link Belt
Model: Link Belt RTC-8040 II Crane
Number of Pages: 1061 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions, And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01- 002- 023.00 Front & Rear Axles, Recondition
SM01- 004- 010.00 Front Axle, R & I
SM01- 007- 012.00 Steer Cylinder, Recondition - 4.00 inch (10.2cm) Diameter Case
SM01- 007- 017.00 Steer Cylinder, Recondition - 4.50 inch (11.4cm) Diameter Case
SM01- 007- 018.00 Steer Cylinder, R & I
SM01- 010- 002.00 Steering Pump, Recondition
SM01- 010- 026.00 Power Steering Pump, R & I
SM01- 018- 047.00 Transmission, R & I
SM01- 018- 048.00 Transmission, Recondition
SM01- 019- 025.00 Transmission Control Unit Diagnostic Manual
SM01- 022- 004.00 U- Joint Installation - Half Round Yokes
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 029- 017.00 Rear Axle & Suspension, R & I
SM01- 039- 002.00 Vacuum Pressure Relief Valve, Recondition
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 039- 004.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 039- 005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional/Steer)
SM01- 043- 029.00 Combination Steering Control Valve, R & I
SM01- 043- 030.00 Combination Steering Control Valve, Recondition
SM01- 043- 031.00 Outrigger Directional Control Valve, R & I
SM01- 043- 032.00 Outrigger Function Control Valve, R & I
SM01- 043- 062.00 Hydro- Gas Suspension Control Valve, R & I
SM01- 044- 018.00 Outrigger Lock Valve Cartridge, R & I
SM01- 045- 014.00 Outrigger Beam Cylinder, Recondition (Generation 1 - Hydraulic Technologies)
SM01- 045- 041.00 Outrigger Beam & Beam Cylinder, R & I
SM01- 045- 050.00 Outrigger Beam Cylinder, Recondition (Generation 2 - Texas Hydraulics)
SM01- 046- 034.00 Jack Cylinder, Recondition
SM01- 046- 035.00 Jack Cylinder, R & I
SM01- 047- 034.00 Relief Valve, Recondition
SM01- 048- 023.00 Rotating Joint, R & I (Rectangular Collector Ring Cover)
SM01- 048- 024.00 Rotating Joint, Recondition
SM01- 048- 028.00 Rotating Joint, R & I (Round Collector Ring Cover)
SM01- 048- 029.00 Rotating Joint, Recondition
SM01- 066- 027.00 Battery, R & I
SM01- 069- 005.00 Tire & Rim, R & I
SM01- 071- 005.00 Engine Hood, R & I
SM01- 075- 015.00 Hydraulic Throttle Control Cylinder, Recondition
SM01- 075- 032.00 Radiator & Transmission/Hydraulic Oil Coolers, R & I
SM01- 075- 033.00 Alternator, R & I
SM01- 075- 034.00 Starter, R & I
SM01- 075- 035.00 Hydraulic Throttle Control Cylinder, R & I
SM01- 076- 025.00 Collector Ring, R & I (Generation 1)
SM01- 076- 026.00 Collector Ring, Recondition (Generation 1 - 45 Ring)
SM01- 076- 031.00 Collector Ring, R & I (Generation 2)
SM01- 076- 032.00 Collector Ring, Recondition (Generation 2 - 46 Ring)
SM01- 076- 047.00 Collector Ring, R & I (Generation 3 - 43 Ring)
SM01- 078- 016.00 Axle Oscillation Lockout Manifold, R & I (Hydro- Gas Suspension)
SM01- 078- 017.00 Axle Oscillation Cylinder, R & I
SM01- 078- 018.00 Axle Oscillation Cylinder, Recondition
SM01- 078- 019.00 Axle Oscillation Accumulator, R & I (Hydro- Gas Suspension
SM01- 078- 020.00 Axle Oscillation Accumulator, Recondition (Hydro- Gas Suspension)
SM01- 078- 027.00 Axle Oscillation Lockout Manifold, Illustrated
SM01- 079- 011.00 Lower Hydraulic Components, R & I
SM01- 080- 036.00 Main Hydraulic Pump, R & I
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multi Section Commercial- Intertech)
SM01- 085- 004.00 Engine Preheater, Recondition
SM01- 085- 006.00 Engine Preheater, R & I (Propane)
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 067.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 003- 010.00 Main Counterweight, R & I (One Piece Counterweight)
SM03- 003- 011.00 Main Counterweight, R & I (Three Piece Counterweight)
AREA 04 VERTICAL SHAFTS
SM04- 005- 022.00 Swing Brake Assembly, Recondition
SM04- 010- 026.00 Swing Reduction Unit, R & I (Generation 1)
SM04- 010- 027.00 Swing Speed Reducer, Recondition (Generation 1)
SM04- 010- 032.00 Swing Reduction Unit And Brake, R & I (Generation 2 - w/Integral Brake)
SM04- 010- 033.00 Swing Reduction Unit And Brake, Recondition (Generation 2 - w/Integral Brake)
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 021.00 Winch, Troubleshooting (Generation 1 - Braden CH150A, 175A, 185A, CH230)
SM05- 006- 022.00 Winch, Recondition (Generation 1 - Braden CH150A, 175A, 185A, CH230)
SM05- 006- 023.00 Winch, R & I (Generation 1 - Braden CH150A, 175A, 185A, CH230)
SM05- 006- 025.00 Winch, Recondition (Generation 2 - Braden CH210)
SM05- 006- 026.00 Winch, Troubleshooting (Generation 2 - Braden CH210)
SM05- 006- 029.00 Winch, R & I (Generation 2 - Braden CH210)
SM05- 010- 007.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05- 018- 002.00 Winch Roller, Recondition (Steel Roller)
SM05- 018- 003.00 Winch Roller, Recondition (Nylon Roller)
AREA 06 UPPER ENGINE
SM06- 008- 012.00 Throttle Pedal, R & I
SM06- 008- 013.00 Throttle Pedal, Recondition
SM06- 025- 004.00 Diesel Cab Heater, R & I (Generation 1)
SM06- 025- 005.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 1)
SM06- 025- 007.00 Hydraulic Cab Heater, R & I
SM06- 025- 008.00 Hydraulic Cab Heater, Recondition
SM06- 025- 009.00 Hydraulic Heater - Troubleshooting
SM06- 025- 017.00 Diesel Cab Heater, R & I (Generation 2)
SM06- 025- 018.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 2)
SM06- 025- 020.00 Operator’s Cab Heater Core, R & I (w/o Air Conditioning)
SM06- 025- 021.00 Operator’s Cab A/C Coil & Heater Core, R & I (w/Air Conditioning)
SM06- 025- 022.00 A/C Coil And Heater Core, Illustrated
SM06- 025- 024.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 096.00 Electrical System Schematic Diagram (Generation 1)
SM06- 047- 097.00 Electrical System Schematic Diagram (Generation 2)
SM06- 047- 107.00 Electrical System Schematic Diagram (Generation 3)
SM06- 047- 108.00 Electrical System Schematic Diagram (Generation 4)
SM07- 000- 122.00 Hydraulic System Schematic Diagram (Generation 1)
SM07- 000- 123.00 Hydraulic System Schematic Diagram (Generation 2)
SM07- 000- 124.00 Hydraulic System Schematic Diagram (Generation 3)
SM07- 001- 018.00 Piston Type Accumulator, Recondition
SM07- 001- 023.00 Carrier Brakes Accumulator, R & I
SM07- 001- 024.00 Pilot Control Accumulator, R & I
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 004- 011.00 Upper Hydraulic Components, R & I (Upper Frame - Generation 2)
SM07- 004- 039.00 Upper Hydraulic Components, R & I (Upper Frame - Generation 3)
SM07- 004- 040.00 Upper Hydraulic Components, R & I (Two Winch Plumbing)
SM07- 004- 041.00 Upper Hydraulic Components, R & I (Single Winch Plumbing)
SM07- 005- 052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07- 005- 061.00 Hydraulic Heater Gear Pump, R & I
SM07- 006- 034.00 Swing Motor, Recondition (Generation 1 - Von Ruden)
SM07- 006- 059.00 Hydraulic Motor, Recondition (Hydraulic Heater)
SM07- 006- 073.00 Hydraulic Motor, Recondition (Winch)
SM07- 006- 075.00 Swing Motor & Brake, R & I (Generation 1 - w/o Pressure Reducing Valve)
SM07- 006- 076.00 Two Speed Valve, Recondition (Winch Motor)
SM07- 006- 077.00 Winch Motor, R & I (Generation 1 - CH185A w/o Pressure Reducing Valve)
SM07- 006- 078.00 Hydraulic Heater Motor, R & I
SM07- 006- 081.00 Swing Motor, Recondition (Generation 2 - Parker)
SM07- 006- 086.00 Winch Motor, R & I (Generation 2 - CH185A w/Pressure Reducing Valve)
SM07- 006- 096.00 Winch Motor, R & I (Generation 3 - CH210)
SM07- 006- 100.00 Swing Motor, R & I (Generation 2 - Parker)
SM07- 008- 014.00 Winch Counterbalance Valve, Recondition
SM07- 008- 037.00 Pressure Reducing Valve, Recondition (Winch Or Swing Circuit)
SM07- 008- 048.00 Foot Control Valve, R & I (Generation 1 - Boom Telescope)
SM07- 008- 055.00 Controller Valve Assembly, R & I
SM07- 008- 056.00 Controller Valve Assembly, Recondition (Comm- Intertech)
SM07- 008- 063.00 Priority Flow Control Valve Assembly, Recondition
SM07- 008- 066.00 Control Valve, Recondition (Gresen V40)
SM07- 008- 067.00 Foot Control Valve, Recondition (Generation 1 - Boom Telescope)
SM07- 008- 076.00 Single Axis Control Valves, R & I
SM07- 008- 077.00 Single Axis Control Valves, Recondition (Comm- Intertech)
SM07- 008- 079.00 Upper Hydraulic Components, R & I (Upper Frame - Generation 1)
SM07- 008- 081.00 Control Valve, Recondition (Winch - Gresen V56)
SM07- 008- 091.00 Winch Counterbalance Valve, R & I (Cranes w/o Pressure Reducing Valve)
SM07- 008- 092.00 Winch Pressure Reducing Valve, R & I
SM07- 008- 096.00 Winch Counterbalance Valve, R & I (Cranes w/Pressure Reducing Valve)
SM07- 008- 107.00 Controller Valve, Recondition (Monson)
SM07- 008- 108.00 Single Axis Controller Valve, Recondition (Monson)
SM07- 008- 111.00 Winch Control Valve, R & I (Generation 1)
SM07- 008- 113.00 Boom Telescope Foot Control Valve, R & I (Gen 2 - Boom Telescope)
SM07- 008- 114.00 Boom Telescope Foot Control Valve, Recondition (Gen 2 - Boom Telescope)
SM07- 008- 118.00 Swing Brake Pedal Valve, Recondition
SM07- 008- 119.00 Pressure Reducing Valve, R & I (Steering)
SM07- 008- 127.00 Winch Control Valve, Recondition (Generation 2 - Parker VP170)
SM07- 008- 129.00 Hydraulic Control Valves, Recondition (Tele/Swing/Boom Hoist Parker VG20)
SM07- 008- 131.00 Pilot Oil Supply Valve, Recondition
SM07- 008- 137.00 Swing Brake Pedal Valve, R & I
SM07- 008- 142.00 Accumulator Charging Valve, Recondition
SM07- 008- 146.00 Accumulator Charging Valve, R & I
SM07- 008- 157.00 Winch Control Valve, R & I (Generation 2)
SM07- 022- 003.00 Steering Control Valve, Recondition (Generation 1 - Eaton Series 12)
SM07- 022- 011.00 Steering Column, R & I (Generation 1 - John Deere Column)
SM07- 022- 012.00 Steering Column, Recondition (John Deere)
SM07- 022- 013.00 Power Steering Control Valve, R & I (Generation 1 - w/John Deere Column)
SM07- 022- 018.00 Emergency Steer Accumulator, R & I
SM07- 022- 022.00 Steering Control Valve, Recondition (Generation 2 - Eaton Series 10)
SM07- 022- 023.00 Steering Control Valve, R & I (Generation 2 - w/RR- TCI Column)
SM07- 022- 025.00 Steering Column, R & I (Generation 2 - RR- TCI Column)
SM07- 022- 027.00 Priority Flow Control Valve, R & I (Emergency Steering)
SM07- 026- 008.00 Brake Treadle Valve, Recondition
SM07- 026- 010.00 Brake Treadle Valve, R & I
SM07- 029- 001.00 Swing Brake Actuator, R & I
SM07- 029- 002.00 Swing Brake Actuator, Recondition
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 001- 046.00 Four Section Boom, R & I (33’- 105’ Full Power)
SM17- 001- 047.00 Four Section Boom, Recondition (33’- 105’ Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 026.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 027.00 Boom Telescope Counterbalance Valve, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 014.00 Boom Hoist Counterbalance Valve, R & I (Port Block Mounted)
SM17- 003- 015.00 Boom Hoist Counterbalance Valve, Recondition (Port Block Mounted)
SM17- 003- 021.00 Boom Hoist Cylinder, R & I
SM17- 003- 034.00 Boom Hoist Cylinder, R & I (w/Integral Counterbalance Valve)
SM17- 003- 035.00 Boom Hoist Counterbalance Valves, R & I (Case Mounted)
SM17- 009- 006.00 Four Sheave Boom Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 003.00 Reeling Drum, R & I
SM18- 007- 004.00 Reeling Drum, Recondition
SM18- 017- 005.00 Carrier Winch Valve Controller, Recondition
SM18- 017- 007.00 Carrier Winch Control Valve, R & I
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 002.00 Air Conditioning Hydraulic Drive Motor, R & I (Generation 1)
SM18- 018- 003.00 Air Conditioning Hydraulic Drive Motor, Recondition (Generation 1)
SM18- 018- 004.00 Air Conditioning Compressor, Recondition
SM18- 018- 006.00 Air Conditioning Compressor, R & I (Generation 1)
SM18- 018- 013.00 Air Conditioning Compressor, R & I (Generation 2)
SM18- 018- 014.00 Air Conditioning Hydraulic Drive Motor, R & I (Generation 2)
SM18- 018- 015.00 Air Conditioning Hydraulic Drive Motor, Recondition (Generation 2)
Brand: Link Belt
