Hyundai
86
176,834
Link Belt Crane RTC-8025 II Service Manual
Brand: Link Belt
Model: Link Belt RTC-8025 II Crane
Number of Pages: 717 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 01 RUBBER TIRE LOWER
SM01- 002- 023.00 Front & Rear Axles, Recondition
SM01- 004- 011.00 Front Axle, R & I
SM01- 007- 016.00 Steer Cylinder, Recondition
SM01- 007- 019.00 Steer Cylinder, R & I
SM01- 010- 027.00 Outrigger/Steer Pump, R & I (w/Cummins BT5.9 Engine)
SM01- 010- 028.00 Outrigger/Steer Pump, Recondition (w/Cummins BT5.9 Engine)
SM01- 010- 041.00 Outrigger/Steer Pump, R & I (w/CAT C6.6 Engine)
SM01- 018- 046.00 Transmission, R & I
SM01- 018- 049.00 Transmission, Recondition
SM01- 022- 004.00 U- Joint Installation - Half Round Yokes
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 029- 018.00 Rear Axle & Suspension, R & I
SM01- 030- 010.00 Park Brake Caliper & Actuator, R & I (Generation 1)
SM01- 030- 011.00 Park Brake Caliper & Actuator, Recondition (Generation 1)
SM01- 030- 014.00 Park Brake Caliper, R & I (Generation 2)
SM01- 030- 015.00 Park Brake Caliper, Recondition (Generation 2)
SM01- 030- 020.00 Park Brake Caliper, R & I (Generation 3)
SM01- 030- 021.00 Park Brake Caliper, Recondition (Generation 3)
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional/Steer)
SM01- 043- 032.00 Outrigger Function Control Valve, R & I
SM01- 043- 033.00 Combination Steering Control Valve, R & I
SM01- 043- 034.00 Outrigger Directional Control Valve, R & I (Generation 1)
SM01- 043- 060.00 Outrigger Directional Control Valve, R & I (Generation 2)
SM01- 043- 062.00 Hydro-Gas Suspension Control Valve, R & I
SM01- 044- 018.00 Outrigger Lock Valve Cartridge, R & I
SM01- 045- 014.00 Outrigger Beam Cylinder, Recondition (Gen 1 - Iowa Ind Hyd or Hyd Tech)
SM01- 045- 042.00 Outrigger Beam & Beam Cylinder, R & I
SM01- 045- 054.00 Outrigger Beam Cylinder, Recondition (Gen 2 - Texas Hydraulics)
SM01- 046- 034.00 Jack Cylinder, Recondition
SM01- 046- 035.00 Jack Cylinder, R & I
SM01- 047- 034.00 Relief Valve, Recondition (Outriggers)
SM01- 048- 025.00 Rotating Joint, R & I
SM01- 048- 026.00 Rotating Joint, Recondition
SM01- 050- 017.00 Remote Transmission Oil Cooler, R & I
SM01- 066- 030.00 Battery, R & I (Generation 1 w/Cummins Engine)
SM01- 066- 032.00 Battery, R & I (Generation 2 w/CAT Engine)
SM01- 069- 005.00 Tire & Rim, R & I
SM01- 071- 006.00 Engine Housing, R & I (w/Cummins Engine)
SM01- 071- 015.00 Engine Housing, R & I (w/CAT Engine)
SM01- 075- 015.00 Hydraulic Throttle Control Cylinder, Recondition
SM01- 075- 036.00 Alternator, R & I (Cummins 6BT 5.9- C152
SM01- 075- 037.00 Radiator, R & I
SM01- 075- 038.00 Hydraulic Throttle Control Cylinder, R & I
SM01- 075- 039.00 Starter, R & I (Cummins 6BT 5.9- C152)
SM01- 076- 027.00 Collector Ring, R & I (Generation 1 Tinsley)
SM01- 076- 041.00 Collector Ring, Recondition (Generation 1 Tinsley)
SM01- 076- 064.00 Collector Ring, R & I (2 - U.E.A.)
SM01- 076- 065.00 Collector Ring, Recondition (G2 - U.E.A.)
SM01- 076- 075.00 Collector Ring, Recondition (46 Ring) - G3
SM01- 076- 089.00 Collector Ring, Recon (46 Rings)
SM01- 077- 013.00 Starter, R & I (CAT C6.6 Engine)
SM01- 077- 030.00 Radiator, Charged Air & Hydraulic Oil Cooler, R & I (CAT C6.6)
SM01- 077- 032.00 Alternator, R & I (C6.6 Engine)
SM01- 078- 016.00 Axle Oscillation Lockout Manifold, R & I
SM01- 078- 017.00 Axle Oscillation Cylinder, R & I
SM01- 078- 018.00 Axle Oscillation Cylinder, Recondition
SM01- 078- 019.00 Axle Oscillation Accumulator, R & I
SM01- 078- 020.00 Axle Oscillation Accumulator, Recondition
SM01- 078- 026.00 Axle Oscillation Lockout Valve, R & I
SM01- 078- 027.00 Axle Oscillation Lockout Manifold, Illustrated
SM01- 079- 012.00 Lower Hydraulic Components, R & I (w/Cummins Engine)
SM01- 079- 062.00 Lower Hydraulic Components, R & I (w/CAT Engine)
SM01- 080- 024.00 Pump Disconnect, Recondition
SM01- 080- 037.00 Main Hydraulic Pump, R & I
SM01- 080- 041.00 Pump Disconnect, R & I
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multi Section Gear Type)
SM01- 081- 036.00 Gear Pump/Motor, Recondition (Outrigger/Steer Pump- w/CAT C6.6 Engine)
SM01- 081- 059.00 Main Hydraulic Pump, R & I (w/CAT Engine)
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 068.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 003- 012.00 Counterweight, R & I
AREA 04 VERTICAL SHAFTS
SM04- 005- 017.00 Brake Caliper, Recondition
SM04- 005- 029.00 Swing Brake Caliper, R & I
SM04- 005- 035.00 Swing Brake, Recon.
SM04- 010- 028.00 Swing Speed Reducer, R & I
SM04- 010- 029.00 Swing Speed Reducer, Recondition
SM04- 010- 049.00 Swing Reduction Unit Assy, R & I
SM04- 010- 050.00 Swing Reduction Unit Assy, Recon.
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 018.00 Winch, R & I
SM05- 006- 019.00 Winch, Recondition
SM05- 006- 020.00 Winch Troubleshooting
SM05- 010- 006.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05- 018- 001.00 Winch Roller, Recondition (Steel Roller)
SM05- 018- 004.00 Winch Roller, Recondition (Nylon Roller)
AREA 06 UPPER ENGINE
SM06- 008- 009.00 Throttle Pedal, R & I (Electronic)
SM06- 008- 013.00 Throttle Pedal, Recondition (Hydraulic)
SM06- 008- 014.00 Throttle Pedal, R & I (Hydraulic)
SM06- 024- 025.00 Gauge Audio/Visual Alarms
SM06- 025- 024.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06- 025- 027.00 Diesel Coolant Heater, R & I
SM06- 025- 043.00 Diesel Coolant Heater, R & I
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 098.00 Electrical System Schematic Diagram (Generation 1)
SM06- 047- 102.00 Electrical System Schematic Diagram (Generation 2)
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 000- 125.00 Hydraulic System Schematic Diagram (Generation 1)
SM07- 000- 126.00 Hydraulic System Schematic Diagram (Generation 2)
SM07- 000- 135.00 Hydraulic System Schematic Diagram (Generation 3)
SM07- 001- 023.00 Carrier Brakes Accumulator, R & I
SM07- 001- 024.00 Pilot Control Accumulator, R & I
SM07- 002- 032.00 Relief Valve, Recondition (Air Conditioning)
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 004- 105.00 Upper Hydraulic Components, R & I (Two Winch Plumbing)
SM07- 004- 106.00 Upper Hydraulic Components, R & I (Single Winch Plumbing)
SM07- 006- 073.00 Hydraulic Motor, Recondition (Winch)
SM07- 006- 076.00 Two Speed Valve, Recondition (Winch Motor)
SM07- 006- 079.00 Swing Motor, R & I
SM07- 006- 080.00 Swing Motor, Recondition (Eaton)
SM07- 006- 081.00 Swing Motor, Recondition (Parker Hannifin)
SM07- 006- 082.00 Winch Motor, R & I
SM07- 008- 032.00 Control Valves, Recondition (Gresen V20)
SM07- 008- 037.00 Pressure Reducing Valve, Recondition
SM07- 008- 066.00 Control Valve, Recondition (Gresen V40)
SM07- 008- 067.00 Foot Control Valve, Recon. (Boom Telescope)
SM07- 008- 076.00 Single Axis Control Valves, R & I
SM07- 008- 077.00 Single Axis Control Valves, Recondition (Generation 1)
SM07- 008- 083.00 Upper Hydraulic Components, R & I
SM07- 008- 086.00 Telescope Foot Control Valve, R & I
SM07- 008- 087.00 Winch Counterbalance Valve, R & I
SM07- 008- 088.00 Winch Counterbalance Valve, Recondition
SM07- 008- 108.00 Single Axis Controller Valve, Recondition (Generation 2)
SM07- 008- 114.00 Hydraulic Foot Control Valve, Recon.
SM07- 008- 118.00 Swing Brake Pedal Valve, Recon.
SM07- 008- 131.00 Pilot Oil Supply Valve, Recondition
SM07- 008- 205.00 Dual Axis Controller, R & I (Sales Special)
SM07- 022- 003.00 Steering Control Valve, Recondition
SM07- 022- 004.00 Steering Column, Recondition (O.E. Sales, Inc.)
SM07- 022- 019.00 Steering Column, R & I (O.E. Sales Inc.)
SM07- 022- 020.00 Steering Control Valve, R & I
SM07- 022- 021.00 Steering Control Valve, Recondition (Emergency Steering)
SM07- 022- 031.00 Steering Column, R & I (Douglas Autotech)
SM07- 022- 032.00 Steering Column, Recondition (Douglas Autotech)
SM07- 026- 008.00 Brake Treadle Valve, Recondition
SM07- 026- 009.00 Brake Treadle Valve, R & I
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 001- 048.00 Four Section Boom, R & I (29’- 91.25’ Full Power)
SM17- 001- 049.00 Three Section Boom, Recondition (30’- 78’ Full Power)
SM17- 001- 050.00 Four Section Boom, Recondition (29’- 91.25’ Full Power)
SM17- 001- 051.00 Three Section Boom, R & I (30’- 78’ Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 036.00 Boom Telescope Cylinder, Troubleshooting (Three Section Boom)
SM17- 002- 037.00 Boom Telescope Counterbalance Valve, R & I (Three Section Boom)
SM17- 002- 038.00 Boom Telescope Cylinder, Troubleshooting (Four Section Boom)
SM17- 002- 039.00 Boom Telescope Counterbalance Valve, R & I (Four Section Boom)
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 032.00 Boom Hoist Cylinder, R & I
SM17- 003- 033.00 Boom Hoist Counterbalance Valve, R & I
SM17- 009- 005.00 Four Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 003.00 Reeling Drum, R & I
SM18- 007- 004.00 Reeling Drum, Recondition
SM18- 017- 005.00 Carrier Winch Valve Controller, Recondition
SM18- 017- 007.00 Carrier Winch Control Valve, R & I
SM18- 018- 001.00 Air Conditioning Service Instructions
SM18- 018- 002.00 Air Conditioning Hydraulic Drive Motor, R & I
SM18- 018- 003.00 Air Conditioning Hydraulic Drive Motor, Recondition
SM18- 018- 004.00 Air Conditioning Compressor, Recondition
SM18- 018- 006.00 Air Conditioning Compressor, R & I
SM18- 018- 015.00 A/C Hydraulic Drive Motor, Recon. (Upper)
SM18- 018- 032.00 A/C Compressor, R & I
SM18- 018- 033.00 A/C Hydraulic Drive Motor, R & I
