Link Belt Crane LS-98 Service Manual
Brand: Link Belt
Model: Link Belt LS-98 Crane
Number of Pages: 268 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 02 CRAWLER LOWER
SM02- 000- 003.00 Lower Frame - General
SM02- 002- 006.00 Traction Shaft (88/98 Standard & Long Wide Models)
SM02- 002- 012.00 Traction Shaft (98A, 98LC, 108B Models)
SM02- 003- 004.00 Tread Sprocket (98LC, 108B Models)
SM02- 003- 005.00 Tread Sprocket (88/98 Long Model)
SM02- 003- 009.00 Tread Sprocket (88/98 Standard & Long Wide Models)
SM02- 004- 002.00 Idler Roller
SM02- 005- 003.00 Track Carrier Rollers
SM02- 005- 004.00 Track Roller
SM02- 005- 007.00 Track Roller (Westrac)
SM02- 006- 002.00 Steering Mechanism
SM02- 008- 001.00 Side Frame Cylinder (108B Model)
SM02- 008- 001.01 Side Frame Cylinder (108B Model)
SM02- 010- 005.00 Rotating Joint
SM02- 010- 022.00 Hydraulic System Cleaning Procedure
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 031.00 Undecking Machine
SM03- 004- 005.00 Conical Roller Assembly
SM03- 005- 002.00 Gear Case Lube System
SM03- 006- 002.00 Swing Lock Control
SM03- 007- 002.00 Low Gantry Assembly
SM03- 008- 002.00 Retractable Gantry Assembly
SM03- 009- 001.00 Hydraulic Retractable Gantry
SM03- 010- 015.00 Hydraulic Counterweight Removal
AREA 04 VERTICAL SHAFTS
SM04- 000- 006.00 Vertical Shaft Assembly - General
SM04- 001- 011.00 Vertical Travel Shaft
SM04- 002- 007.00 Vertical Center Drive Shaft
SM04- 002- 008.00 Swing Center Drive Shaft
SM04- 003- 015.00 Vertical Swing Shaft
SM04- 004- 003.00 Swing Brake Shaft
SM04- 005- 011.00 Swing Brake Assembly
SM04- 005- 012.00 Swing Brake Controls
SM04- 006- 005.00 Swing & Travel Shifters
AREA 05 HORIZONTAL SHAFTS
SM05- 000- 008.00 Horizontal Shafts General
SM05- 001- 002.00 Independent Travel Reverse Shaft
SM05- 001- 003.00 Independent Swing Reverse Shaft
SM05- 002- 005.00 Reduction Shaft
SM05- 003- 003.00 Front Drum Shaft
SM05- 003- 005.00 Front & Rear Drum Brakes
SM05- 004- 001.00 Rear Drum Shaft
SM05- 004- 002.00 Auxiliary Rear Drum Brake
SM05- 005- 001.00 Third Drum Shaft Assembly
SM05- 005- 002.00 Third Drum Brake
SM05- 005- 009.00 Field Installation Of Third Drum
SM05- 006- 002.00 Two Speed Drums
SM05- 007- 001.00 Two Speed Planetary
SM05- 007- 002.00 Planetary Brake
SM05- 008- 001.00 Boom Hoist Shaft - Independent Swing
SM05- 008- 002.00 Boom Hoist Shaft
SM05- 008- 003.00 Boom Hoist Brake
SM05- 009- 002.00 Clutches - General
SM05- 009- 004.00 Clutch Assembly (Front, Rear, & Boom Hoist Drum)
SM05- 009- 005.00 Third Drum Clutch
SM05- 009- 009.00 Clutch Rotating Joint
AREA 06 UPPER ENGINE
SM06- 022- 003.00 GM Engine Wiring
SM06- 024- 017.00 Cummins Engine Wiring
SM06- 024- 018.00 Cummins Engine Wiring - Elevated Cab
SM06- 024- 019.00 Caterpillar Engine Wiring
SM06- 024- 020.00 Caterpillar Engine Wiring - Elevated Cab
SM06- 039- 007.00 Chain Case Assembly
SM07- 000- 005.00 S- o- M System - General
SM07- 000- 006.00 Troubleshooting Charts
SM07- 001- 001.00 Unloading Valve
SM07- 001- 002.00 Accumulator
SM07- 001- 004.00 External Check Valve
SM07- 001- 005.00 Relief Valve
SM07- 001- 008.00 S- o- M Filter
SM07- 005- 006.00 S- o- M Pump
SM07- 005- 010.00 Hydraulic Pump (Hydraulic Bucket)
SM07- 005- 011.00 Pump Drive (Hydraulic Bucket)
SM07- 008- 004.00 Control Valve (Hydraulic Bucket)
SM07- 012- 002.00 Control Valves & Stand
AREA 08 ANGLE BOOM, & JIB
SM08- 001- 001.00 Repairing Damaged Angle Booms & Jibs
SM09- 001- 002.00 Repairing DamagedTubular Booms, Flys, & Jibs
SM09- 002- 004.00 Hydraulic Boom Live Mast
AREA 10 TAGLINE WINDER
SM10- 001- 001.00 Tagline Winder
SM10- 001- 002.00 Tag & Magnet Reel
AREA 13 TRENCH HOE ATTACHMENT
SM13- 000- 002.00 Operation & Maintenance (Hydraulic Bucket)
SM13- 001- 004.00 Trench Hoe - General (Hydraulic Bucket)
SM13- 007- 005.00 Bucket Cylinder (Hydraulic Bucket)
SM13- 007- 006.00 Fixed Pitch Brace (Hydraulic Bucket)
SM13- 007- 008.00 Bucket Cylinder (Hydraulic Bucket)
AREA 18 SPECIAL ATTACHMENTS
Brand: Link Belt
