Hyundai
86
176,834
Link Belt Crane LS-418 Service Manual
Brand: Link Belt
Model: Link Belt LS-418 Crane
Number of Pages: 284 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 02 CRAWLER LOWER
SM02- 000- 001.00 Lower Frame - General
SM02- 002- 001.00 Traction Shaft - Inner
SM02- 002- 002.00 Traction Shaft - Outer (518 Model)
SM02- 002- 003.00 Traction Shaft - Outer (418 Model)
SM02- 003- 001.00 Tread Sprocket
SM02- 004- 001.00 Idler Roller
SM02- 005- 001.00 Track Roller
SM02- 005- 002.00 Track Carrier Roller
SM02- 006- 001.00 Steering Mechanism
SM02- 010- 001.00 Rotating Joint - Independent Swing
SM02- 010- 002.00 Rotating Joint
SM02- 010- 003.00 Rotating Joint - Two Piece (518 Model)
SM02- 010- 004.00 Rotating Joint - Independent Swing (Early)
SM02- 010- 006.00 Rotating Joint - Two Piece (418 Model)
SM02- 010- 022.00 Hydraulic System Cleaning Procedure
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 003.00 Turntable Bearing
SM03- 001- 004.00 Ring Gear Replacement
SM03- 001- 009.00 Undecking - w/Two Piece Rotating Joint (408- 418 Models)
SM03- 004- 001.00 Conical Rollers (408- 418 Models)
SM03- 006- 001.00 Swing Lock
SM03- 015- 001.00 Pressure Limited Counterweight Remover
SM03- 015- 002.00 Pressure Limited Counterweight Remover
AREA 04 VERTICAL SHAFTS
SM04- 000- 002.00 Vertical Shafts - General
SM04- 001- 001.00 Independent Travel Shaft (408, 418 Models)
SM04- 001- 002.00 Independent Travel Shaft (418A,518 Models)
SM04- 001- 005.00 Non- Independent Travel Shaft
SM04- 001- 007.00 Independent Travel Shaft
SM04- 002- 001.00 Center Drive Shaft
SM04- 003- 002.00 Swing Shaft
SM04- 005- 001.00 Swing Brake & Controls
SM04- 006- 001.00 Standard Boom Hoist Circuitry
SM04- 006- 002.00 Swing- Travel Shifter
SM04- 009- 001.00 Independent Boom Hoist Center Shaft
SM04- 009- 002.00 Independent Boom Hoist Vertical Shaft
SM04- 009- 003.00 Standard Boom Hoist Idler Shaft
SM04- 009- 003.00 Boom Hoist Vertical Shaft
SM04- 009- 004.00 Boom Hoist Brake (408, 418 Models)
SM04- 009- 005.00 Boom Hoist Brake (418A, 518 Models)
SM04- 009- 006.00 Boom Hoist Pawl
AREA 05 HORIZONTAL SHAFTS
SM05- 000- 002.00 Horizontal Shafts - General
SM05- 001- 001.00 Independent Travel Reverse Shaft
SM05- 001- 004.00 Reverse Shaft
SM05- 002- 006.00 Reduction Shaft
SM05- 003- 006.00 Front Drum Shaft
SM05- 003- 007.00 Rear Drum Shaft
SM05- 005- 003.00 Third Drum Shaft
SM05- 006- 001.00 Two Speed Drums
SM05- 007- 001.00 Two Speed Planetary
SM05- 007- 007.00 Two Speed Planetary Brake
SM05- 008- 004.00 Boom Hoist Reverse Shaft
SM05- 008- 005.00 Boom Hoist Gear Case
SM05- 008- 010.00 Boom Hoist Gear Case (Wide Gear)
SM05- 009- 002.00 Clutches - General
SM05- 009- 003.00 Clutches (30” & 37”)
SM05- 009- 004.00 Clutches (Independent Travel)
SM05- 009- 005.00 Clutches (Independent Boom Hoist)
SM05- 009- 007.00 Clutches (Bladder)
SM05- 009- 009.00 Rotating Joint
SM05- 012- 001.00 Front & Rear Drum Brake
SM05- 012- 002.00 Third Drum Brake
SM05- 012- 027.00 Auxiliary Rear Drum Brake
SM05- 013- 001.00 Left Hand Drive (Without Clutch)
SM05- 013- 002.00 Left Hand Driver (With Clutch)
SM05- 013- 003.00 Right Hand Drum Driver (Early)
SM05- 013- 004.00 Right Hand Drum Driver
SM05- 013- 005.00 Right Hand Drum Driver (Later)
AREA 06 UPPER ENGINE
SM06- 016- 002.00 Twin Disc Clutch
SM06- 017- 001.00 Clutch & Control Adjustment
SM06- 018- 001.00 Chain Case Pump
SM06- 024- 001.00 Caterpillar Engine Wiring
SM06- 024- 002.00 GM 6030 Engine Wiring
SM06- 024- 003.00 Cummins Engine Wiring
SM06- 024- 004.00 GM 8V- 71 Engine Wiring
SM06- 039- 001.00 Chain Case
SM07- 000- 005.00 S- o- M System - General
SM07- 000- 006.00 S- o- M Troubleshooting
SM07- 001- 001.00 Unloading Valve
SM07- 001- 002.00 Accumulator
SM07- 001- 004.00 External Check Valve
SM07- 001- 005.00 Relief Valve
SM07- 001- 008.00 S- o- M Filter
SM07- 005- 006.00 S- o- M Pump
SM07- 012- 001.00 Control Valves & Bank
AREA 08 ANGLE BOOM & JIB
SM08- 001- 001.00 Repairing Damaged Angle Booms & Jibs
SM09- 001- 002.00 Repairing DamagedTubular Booms, Flys, & Jibs
AREA 10 TAGLINE WINDER
SM10- 001- 001.00 Tagline Winder
AREA 18 SPECIAL ATTACHMENTS
