Link Belt Crane LS-238H Service Manual
Brand: Link Belt
Type of Manual: Service Manual, Hydraulic Diagrams
Model: Link Belt LS-238H Crane
Number of Pages: 410 Pages
SECTION 0 General Serial No.
How To Use This Manual, General Service Instructions, &
Safety Procedures SM00---000---001.00 0001---
Equipment Layout ES00---03---0050.1 000 0001---3052
Equipment Layout ES00---03---0057.0R0S 3053---
SECTION 1 Upper Mechanism
Power Transmission System ES01---01---0065.0 0001---
Front And Rear Drum Shaft Structure And Outline ES01---10---0050.0 0001---
Front And Rear Drum Shaft Maintenance Chart ES01---10---2050.0 0001---
Front And Rear Drum Shaft Disassembly And Reassembly ES01---10---6050.0 0001---
Boom Hoist Drum Shaft Structure And Outline ES01---15---0050.0 0001---
Boom Hoist Drum Shaft Maintenance Chart ES01---15---2050.0 0001---
Boom Hoist Drum Shaft Disassembly And Reassembly ES01---15---6050.0 0001---
Clutch Structure And Outline (1---Cylinder Type) ES01---17---0050.0 0001---
Clutch Maintenance Chart (1---Cylinder Type) ES01---17---2050.0 0001---
Clutch Troubleshooting (1---Cylinder Type) ES01---17---4023.0 0001---
Clutch Disassembly And Reassembly (1---Cylinder Type) ES01---17---6050.0 0001---
Swing Mechanism Maintenance Chart ES01---29---2050.0 0001---
Turntable Bearing Maintenance Chart ES01---30---2030.0 0001---
Turntable Bearing Inspection And Adjustment ES01---30---5050.0 0001---
Power Divider (Pump Splitter) Maintenance Chart ES01---40---2050.0 0001---
Power Divider (Pump Splitter) Disassembly And Reassembly ES01---40---6050.0 0001---
Drum Indicator Troubleshooting (Mechanical Type) ES01---50---4001.0R0S 3053---
SECTION 3 Control System
Front And Rear Drum Maintenance Chart ES03---05---2050.0 0001---3052
Front And Rear Drum Brake Control Maintenance Chart ES03---05---2067.0R0S 3053---
Front And Rear Drum Brakes Control InspectionAnd Adjustment ES03---05---5050.0 0001---3052
Front And Rear Drum Brakes Control InspectionAnd Adjustment ES03---05---5066.0R0S 3053---
Front And Rear Drum Brakes Control Disassembly And Reassembly ES03---05---6050.0 0001---3052
Front And Rear Drum Brakes Control Disassembly And Reassembly ES03---05---6067.0R0S 3053---
Front, Rear & Boom Hoist Drum Lock Pawl Control Maintenance Chart ES03---10---2050.0R0S 0001---
SECTION 4 Hydraulic System
Hydraulic Circuit Outline ES04---01---0067.0 0001---3052
Hydraulic Circuit Outline ES04---01---0071.0R0S 3053---
Hydraulic Circuit Pressure Adjustment ES04---01---5067.0 0001---3052
Hydraulic Circuit Pressure Adjustment ES04---01---5075.0R0S 3053---
SECTION 5 Hydraulic Unit
Variable Pump Structure And Outline ES05---02---0050.0 0001---
Variable Delivery Pump Maintenance Chart ES05---02---2050.0 0001---
Variable Delivery Pump Troubleshooting ES05---02---4009.0 0001---
Gear Pump Troubleshooting (Single Type) ES05---03---4023.0 0001---
Gear Pump Disassembly And Reassembly (Single Type) ES05---03---6023.0 0001---
Gear Pump Troubleshooting (3---Series Type) ES05---03---4050.0 0001---
Gear Pump Disassembly And Reassembly (3---Series Type) ES05---03---6050.0 0001---
Accumulator Structure And Working ES05---05---0009.2 0001---3052
Accumulator Structure And Working ES05---05---0034.0R1S 3053---
Accumulator Inspection And Adjustment ES05---05---5009.1 0001---3052
Accumulator Inspection And Adjustment ES05---05---5031.0R2S 3053---
Accumulator Disassembly And Reassembly ES05---05---6009.2 0001---3052
Accumulator Disassembly And Reassembly ES05---05---6045.0R0S 3053---
Rotating Joint Disassembly And Reassembly ES05---14---6029.1 0001---3052
Rotating Joint Disassembly And Reassembly ES05---14---6029.2R1S 3053---
Brake Booster Function And Operation ES05---16---0011.0 0001---3052
Brake Booster Structure And Working ES05---16---0016.0R1S 3053---
Brake Booster Disassembly And Reassembly ES05---16---6005.0R1S 3053---
Remote Control Valve Structure And Operation ES05---17---0009.1 0001---3052
Remote Control Valve Structure And Operation ES05---17---0029.0R1S 0001---3053
Remote Control Valve Troubleshooting ES05---17---4009.0 0001---3052
Remote Control Valve Troubleshooting ES05---17---4027.0R0S 3053---
Remote Control Valve Disassembly And Reassembly ES05---17---6009.1 0001---3052
Remote Control Valve Disassembly And Reassembly ES05---17---6027.0R0S 3053---
Clutch Cylinder Disassembly And Reassembly (1---Cylinder Type) ES05---18---6050.0 0001---3052
Clutch Cylinder Disassembly And Reassembly (1---Cylinder Type) ES05---18---6074.0R0S 3053---
Automatic Brake Cylinder Disassembly And Reassembly ES05---19---6032.0 0001---
Boom Foot Pin Cylinder Disassembly And Reassembly ES05---27---6050.0 0001---3052
Boom Foot Pin Cylinder Disassembly And Reassembly ES05---27---6051.0R0S 3053---
Line Filter Inspection ES05---30---5061.0 0001---
Line Filter Disassembly And Reassembly ES05---30---6061.0 0001---
Return Filter Inspection ES05---32---5011.0 0001---
Return Filter Disassembly And Reassembly ES05---32---6011.0 0001---
Swing Control Valve Outline And Operation ES05---35---0011.0 0001---3052
Swing Control Valve Structure And Operation ES05---35---0054.0R1S 3053---
Check Block Structure And Outline ES05---49---0011.0 0001---
Backstop Cylinder Disassembly And Reassembly ES05---58---6061.0 0001---3052
Backstop Cylinder Disassembly And Reassembly ES05---58---6061.1R1S 3053---
Counterweight Cylinder Disassembly And Reassembly ES05---59---6050.0 0001---3052
Counterweight Cylinder Disassembly And Reassembly ES05---59---6051.0R0S 3053---
SECTION 13 Electrical System
Electrical Diagram ES13---01---0052.0 0001---3052
Electrical Diagram ES13---01---0058.0R0S 3053---
Electrical System Standardization ES13---01---9032.0 0001---3052
Electrical System Standardization ES13---01---9033.0R0S 3053---
Storage Battery Servicing And Installation ES13---04---5003.0 0001---3052
Storage Battery Servicing And Installation ES13---04---5004.0R0S 3053---
SECTION 14 Tightening Torque Table
Bolt Tightening Torques ES14---02---0001.0 0001---3052
Bolt Tightening Torques ES14---02---0004.0R0S 3053---
Brand: Link Belt
