Link Belt Crane HTT-8675XP II Service Manual
Brand: Link Belt
Model: Link Belt HTT-8675XP II Crane
Number of Pages: 1146 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 01 RUBBER TIRE LOWER
SM01- 001- 006.00 Boom Rest, R & I
SM01- 001- 008.00 Boom Rest Extension, R & I
SM01- 002- 012.00 Front Axle, Recondition
SM01- 002- 015.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition (Front Axles)
SM01- 003- 014.00 Adjusting The Brakes (Front Axles)
SM01- 003- 019.00 Automatic Slack Adjusters (Front Axles)
SM01- 004- 014.00 Front Axle & Air Suspension, R & I
SM01- 005- 027.00 Troubleshooting Sheppard Steering Gears
SM01- 005- 032.00 Steering Miter Boxes, R & I
SM01- 005- 033.00 Steering Gears, R & I
SM01- 005- 034.00 Steering Column, R & I
SM01- 005- 035.00 Steering Column, Recondition
SM01- 005- 037.00 Steering Gears, Recondition
SM01- 006- 030.00 Pressure Reducing Valve, Recondition (Rear Steer Axles)
SM01- 006- 031.00 Rear Wheel Alignment & Axle Stop Adjustment
SM01- 006- 036.00 Front Wheel Alignment & Steer Linkage Adjustment
SM01- 007- 020.00 Rear Axle Steer Cylinder, R & I
SM01- 007- 022.00 Rear Axle Steer Cylinder, Recondition
SM01- 007- 023.00 Rear Axle Steer Locking Cylinder, R & I
SM01- 007- 024.00 Rear Axle Steer Locking Cylinder, Recondition
SM01- 010- 025.00 Power Steering Pump, Recondition (CAT C13 Engine)
SM01- 010- 039.00 Power Steering Pump w/Priority Valve, Recondition (Cummins QSX Tier 3 Engine)
SM01- 010- 042.00 Power Steering Pump, R & I (CAT C13 Engine)
SM01- 010- 043.00 Power Steering Pump, R & I (Cummins QSX Tier 3 Engine)
SM01- 016- 002.00 Heater Core & A/C Coil, R & I
SM01- 018- 056.00 Transmission And Clutch, R & I (CAT C13 Engine)
SM01- 018- 057.00 Transmission, Recondition
SM01- 018- 062.00 Transmission And Clutch, R & I (Cummins QSX Tier 3 Engine)
SM01- 019- 034.00 Transmission Shift Control, R & I
SM01- 020- 002.00 Suspended Brake Pedal, Recondition
SM01- 020- 011.00 Suspended Brake Pedal Valve, R & I
SM01- 022- 004.00 U- Joint Installation - Half Round Yokes
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 024- 013.00 Rear Axles, Recondition
SM01- 025- 011.00 Brakes, Recondition (Rear Steer Axle)
SM01- 025- 016.00 Antilock Brake System, Troubleshooting
SM01- 027- 000.00 Pneumatic System Air Line Identification Code
SM01- 027- 028.00 Front Air Brake Chamber, Recondition
SM01- 027- 054.00 Rear Dual Air Brake Chamber, R & I
SM01- 027- 062.00 Air Dryer, R & I
SM01- 027- 063.00 Air Dryer, Recondition
SM01- 027- 091.00 Front Air Brake Chamber, R & I
SM01- 027- 106.00 Caging Dual Air Brake Chambers
SM01- 027- 117.00 Dual Air Brake Chamber, Recondition
SM01- 027- 147.00 Carrier Air System Components, R & I (G1)
SM01- 027- 149.00 Carrier Air System Components, R & I (G2)
SM01- 027- 150.00 Air System Components, R & I- Rear Lift Axle
SM01- 027- 159.00 Carrier Air System Components, R & I (G3)
SM01- 028- 004.00 Rear Wheel Hub & Brake Drum, R & I
SM01- 029- 027.00 Suspension Lift Cylinder, R & I
SM01- 029- 028.00 Suspension Lift Cylinder, Recondition
SM01- 029- 031.00 Axle Lift Manifold Illustrated
SM01- 029- 032.00 Rear Axles & Air Suspension, R & I
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 039- 005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01- 039- 008.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 4 Way Solenoid Valve, Recondition (Outrigger Directional)
SM01- 043- 045.00 Outrigger Directional Control Valve, R & I
SM01- 043- 047.00 Fifth Outrigger Directional Control Valve, R & I
SM01- 043- 048.00 Outrigger Function Control Valve, R & I
SM01- 044- 023.00 Fifth Outrigger Lock Valve Cartridge, R & I
SM01- 044- 027.00 Outrigger Lock Valve Cartridge, R & I And Recondition (Main Outriggers)
SM01- 045- 048.00 Bottom Outrigger Beam Cylinder, Recondition
SM01- 045- 049.00 Top Outrigger Beam Cylinder, Recondition
SM01- 045- 059.00 Outrigger Beam Assembly, R & I
SM01- 045- 060.00 Outrigger Beam Cylinder, R & I
SM01- 046- 034.00 Jack Cylinder, Recondition (Fifth Outrigger)
SM01- 046- 047.00 Jack Cylinder, R & I (Main Outriggers)
SM01- 046- 048.00 Jack Cylinder, Recondition (Main Outriggers)
SM01- 046- 049.00 Fifth Outrigger Jack Cylinder, R & I
SM01- 047- 011.00 Relief Valve, Recondition (Hydraulic Oil Cooler)
SM01- 047- 038.00 Pick & Carry Manifold Block, Illustrated (G1)
SM01- 047- 048.00 Pick & Carry Manifold Block, Illustrated (G2)
SM01- 048- 044.00 Rotating Joint, Recondition
SM01- 048- 049.00 Rotating Joint, R & I
SM01- 050- 004.00 Hydraulic Oil Cooler Assembly, R & I
SM01- 050- 005.00 Oil Cooler Hydraulic Motor, R & I
SM01- 050- 015.00 Hydraulic Oil Cooler Accumulator, R & I
SM01- 050- 016.00 Oil Cooler Hydraulic Motor, Recondition (Parker)
SM01- 050- 018.00 Hydraulic Oil Cooler Assembly, R & I (G2)
SM01- 066- 024.00 Battery, R & I
SM01- 069- 014.00 Tires & Rims, R & I
SM01- 069- 016.00 Tire & Rim, Inspection & Maintenance (Aluminum Disc Rims & Tubeless Tires)
SM01- 071- 004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01- 071- 013.00 Engine Housing, R & I
SM01- 071- 024.00 Engine Housing, R & I (G2)
SM01- 073- 002.00 Electronic Gauge, Troubleshooting
SM01- 075- 050.00 Starter, R & I (Cummins QSX Tier 3 Engine)
SM01- 075- 051.00 Alternator, R & I (Cummins QSX Tier 3 Engine)
SM01- 075- 052.00 Radiator, Charged Air, & Transmission Oil Cooler, R & I (QSX Tier 3 Engine)
SM01- 076- 058.00 Collector Ring, R & I
SM01- 076- 063.00 Collector Ring, Recondition (34 Rings) - G1
SM01- 076- 068.00 Collector Ring, Recondition (37 Rings) - G2
SM01- 076- 090.00 Collector Ring, Recondition (35 Rings) - G3
SM01- 077- 008.00 Starter, R & I (CAT C13 Engine)
SM01- 077- 021.00 Radiator, Charged Air And Hydraulic Oil Cooler, R & I (CAT C13 Engine)
SM01- 077- 033.00 Alternator, R & I (CAT C13 Engine)
SM01- 079- 046.00 Lower Hydraulic Components, R & I- Rear Steering
SM01- 079- 063.00 Lower Hydraulic Components, R & I- Suction, Pressure, & Return Lines
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multiple Section Gear Type)
SM01- 081- 040.00 Hydraulic Pump, R & I (Tandem Pump)
SM01- 081- 045.00 Radiator Fan Motor, R & I
SM01- 081- 046.00 Hydraulic Gear Pump/Motor, Recondition- PGM620 Series (Radiator Fan)
SM01- 081- 051.00 Hydraulic Pump, R & I (Outriggers/Pick & Carry 2 or 3- Section)
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 075.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 010- 025.00 Counterweight Removal Cylinder, Recondition
SM03- 010- 038.00 Counterweight Removal Control Valve, R & I
SM03- 010- 047.00 Counterweight Removal Cylinder, R & I
AREA 04 VERTICAL SHAFTS
SM04- 010- 033.00 Swing Reduction Unit w/Brake, Recondition
SM04- 010- 038.00 Swing Reduction Unit & Brake, R & I
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 025.00 Winch, Recondition
SM05- 006- 026.00 Winch, Troubleshooting
SM05- 006- 038.00 Winch Assembly, R & I
SM05- 018- 003.00 Winch Roller, Recondition
AREA 06 UPPER ENGINE
SM06- 008- 009.00 Throttle Treadle Assembly, R & I
SM06- 025- 019.00 Operator’s Cab Water Heater, R & I (Without Air Conditioning)
SM06- 025- 022.00 A/C Coil And Heater Core, Illustrated
SM06- 025- 023.00 Upper Cab A/C Coil & Heater Core, R & I
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06- 025- 028.00 Diesel Coolant Heater, R & I
SM06- 025- 030.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06- 047- 000.00 Electrical System Wire Identification Code
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 001- 027.00 Pilot Control Accumulator, R & I
SM07- 002- 033.00 Solenoid/Relief Valve, Recondition (Boom Telescope)
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 003- 011.00 Directional Relief Valve, Recondition (Boom Telescope Cylinder Mechanism)
SM07- 004- 031.00 Upper Hydraulic Components, R & I- Upper Cab Floor
SM07- 004- 033.00 Upper Hydraulic Components, R & I- Two Winch Plumbing
SM07- 004- 038.00 Upper Hydraulic Components, R & I- Single Winch Plumbing
SM07- 004- 060.00 Upper Hydraulic Components, R & I- Upper Frame (G1)
SM07- 004- 089.00 Upper Hydraulic Components, R & I- Upper Frame (G2)
SM07- 006- 034.00 Swing Motor, Recondition (Von Ruden)
SM07- 006- 095.00 Winch Motor, Recondition (Linde)
SM07- 006- 109.00 Winch Motor, R & I
SM07- 006- 124.00 Swing Motor, R & I (w/Needle Valve)
SM07- 008- 032.00 Control Valves, Recondition (Model V20)
SM07- 008- 037.00 Pressure Reducing Valve, Recondition
SM07- 008- 107.00 Dual Axis Controller Valve, Recondition
SM07- 008- 108.00 Single Axis Controller Valve, Recondition
SM07- 008- 112.00 Pressure Reducing Valve, Recondition
SM07- 008- 116.00 Dual Axis Controller Valve, R & I
SM07- 008- 117.00 Single Axis Controller Valve, R & I
SM07- 008- 118.00 Swing Brake Pedal Valve, Recondition
SM07- 008- 122.00 Winch Counterbalance Valve, Recondition
SM07- 008- 132.00 Control Valves, Recondition (Husco 7000 Series)
SM07- 008- 152.00 Winch Counterbalance Valve, R & I
SM07- 008- 153.00 Swing Brake Pedal Valve, R & I
SM07- 008- 154.00 Winch Control Valve, R & I (Single or Double Winch)
SM07- 008- 155.00 Swing Control Valve, R & I
SM07- 008- 156.00 Boom Hoist/Telescope Control Valve, R & I (G1 w/Solenoid Relief)
SM07- 008- 198.00 Boom Hoist/Telescope Control Valve, R & I (G2 w/o Solenoid Relief)
SM07- 010- 006.00 Boom Telescope Electronic Foot Control, R & I
SM09- 001- 002.00 Tubular Boom, Fly, & Jib Repair
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 053.00 Hydraulic Boom Inspection - Formed Sections
SM17- 001- 068.00 Four Section Boom, R & I (G1)
SM17- 001- 069.00 Four Section Boom, Recondition (41- 127’ Latching Boom)
SM17- 001- 083.00 Four Section Latching Boom, R & I (G2)
SM17- 001- 084.00 Four Section Latching Boom, Recondition (R3 Type Boom)
SM17- 002- 054.00 Boom Telescope Counterbalance Valve, R & I
SM17- 002- 055.00 Boom Telescope Cylinder Recondition
SM17- 002- 057.00 Boom Latching Cylinder, Recondition - Hydraulic Technologies (G2)
SM17- 002- 059.00 Telescope Cylinder Length Reel, Recondition
SM17- 002- 066.00 Boom Latching/Pinning Cylinder, R & I
SM17- 002- 068.00 Telescope Cylinder Length Reel, R & I (G1)
SM17- 002- 069.00 Boom Latching/Pinning Cylinder, Recondition - Texas Hyd (G1 & 3)
SM17- 002- 070.00 Latching Boom Telescope System, Troubleshooting
SM17- 002- 071.00 Boom Telescope Cylinder, Calibration
SM17- 002- 088.00 Hose & Cable Reel, Recondition
SM17- 002- 090.00 Boom Telescope Cylinder Mechanism, Recondition (G1)
SM17- 002- 105.00 Boom Pinning Cylinder, R & I (G1)
SM17- 002- 106.00 Boom Pinning Cylinder, Recondition (G1)
SM17- 002- 107.00 Boom Latching Cylinder, R & I (G2)
SM17- 002- 110.00 Boom Telescope Cylinder Mechanism, Recondition (G2)
SM17- 002- 112.00 Latching Boom Telescope System, Troubleshooting (G2)
SM17- 002- 113.00 Latching Boom Telescope System, Calibration (G2)
SM17- 002- 114.00 Hose & Cable Reel, R & I
SM17- 002- 115.00 Telescope Cylinder Length Encoder Reels, R & I (G2)
SM17- 002- 117.00 Pin/Latch Valve, Recondition - (G1)
SM17- 002- 118.00 Pin/Latch Valve, Recondition (G2) - R3 Type Boom
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 039.00 Boom Hoist Cylinder, R & I
SM17- 003- 040.00 Boom Hoist Counterbalance Valve, R & I
SM17- 009- 004.00 Five Sheave Boom Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 002.00 Gear, Shaft, Bearing, & Housing Inspection
SM18- 000- 003.00 Crane Systems Schematics
SM18- 007- 006.00 Reeling Drum, R & I (Greer)
SM18- 007- 007.00 Reeling Drum, Recondition (Greer)
SM18- 007- 016.00 Reeling Drum, Troubleshooting & Recondition (Hirschmann)
SM18- 007- 018.00 Reeling Drum, R & I (Hirschmann)
SM18- 018- 001.00 Air Conditioning Service Instructions
SM18- 018- 004.00 Air Conditioning Compressor, Recondition (Carrier and Upper)
SM18- 018- 013.00 Air Conditioning Compressor, R & I (Upper)
SM18- 018- 014.00 Air Conditioning Hydraulic Drive Motor, R & I (Upper)
SM18- 018- 015.00 Air Conditioning Hydraulic Drive Motor, Recondition (Upper)
SM18- 018- 021.00 Air Conditioning Compressor, R & I (CAT C13 Engine)
SM18- 018- 024.00 Air Conditioning Compressor, R & I (Cummins QSX Tier 3 Carrier Engine)
Brand: Link Belt
