Hyundai
86
176,834
Link Belt Crane HTT-8650XXLB Service Manual
Brand: Link Belt
Model: Link Belt HTT-8650XXLB Crane
Number of Pages: 1424 Pages
AREA 00 GENERAL INFORMATION
SM00---000---000.00 How To Use This Manual, General Service Instructions And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01---001---005.00 Boom Rest, R & I
SM01---001---007.00 Boom Rest Extension, R & I (Generation 1)
SM01---001---008.00 Boom Rest Extension, R & I (Generation 2)
SM01---002---012.00 Front Axle, Recondition
SM01---002---015.00 Front Wheel & Brake Drum, R & I
SM01---003---010.00 Brakes, Recondition (Front)
SM01---003---014.00 Adjusting The Brakes (Front)
SM01---003---019.00 Automatic Slack Adjusters (Front Brakes)
SM01---004---009.00 Front Axle & Suspension, R & I
SM01---005---003.00 Steering Gear, Recondition --- Master
SM01---005---004.00 Steering Gear, Recondition --- Slave
SM01---005---005.00 Steering Miter Boxes, R & I
SM01---005---010.00 Steering Drive Shafts, Recondition
SM01---005---013.00 Steering Column, R & I
SM01---005---015.00 Steering Column, Recondition
SM01---006---022.00 Steering Gears, R & I
SM01---006---023.00 Front Wheel Alignment & Steering Linkage Adjustment
Relief Plunger Adjustment
Axle Stop Adjustment
SM01---006---029.00 Rear Steer Pressure Reducing Valve, R & I (Generation 1)
SM01---006---030.00 Pressure Reducing Valve, Recondition (Rear Steer Axles)
SM01---006---031.00 Rear Wheel Alignment & Axle Stop Adjustment
SM01---006---033.00 Rear Steer Pressure Reducing Valve, R & I (Generation 2)
SM01---007---020.00 Rear Axle Steer Cylinder, R & I
SM01---007---022.00 Rear Axle Steer Cylinder, Recondition
SM01---007---023.00 Rear Axle Steer Locking Cylinder, R & I
SM01---007---024.00 Rear Axle Steer Locking Cylinder, Recondition
SM01---010---018.00 Power Steering Pump, R & I (Generation 1)
SM01---010---019.00 Power Steering Pump, Recondition (Generation 1)
SM01---010---028.00 Power Steering Pump, Recondition (Generation 2 --- w/Hydraulic Radiator Fan)
SM01---010---029.00 Power Steering Pump Priority Valve, Recondition (Gen 2 --- w/Hyd Radiator Fan)
SM01---010---034.00 Power Steering Pump, R & I (Generation 2 --- w/Hydraulic Radiator Fan)
SM01---016---001.00 Heater Core, R & I
SM01---016---002.00 Heater Core & A/C Coil, R & I
SM01---017---008.00 Clutch, R & I And Recondition
SM01---018---041.00 Transmission, Recondition
SM01---018---042.00 Transmission, R & I
SM01---019---011.00 Transmission Slave Control, R & I
SM01---019---014.00 Transmission Air Shift Control, Recondition
SM01---019---020.00 Transmission Shift Cable Adjustment
SM01---019---024.00 Transmission Master Control, R & I
SM01---020---002.00 Suspended Brake Pedal, Recondition
SM01---020---005.00 Suspended Brake Pedal, R & I (Generation 1)
SM01---020---008.00 Suspended Brake Pedal, R & I (Generation 2)
SM01---022---005.00 U---Joint Installation --- Full Round Yokes
SM01---024---013.00 Rear Axles, Recondition
SM01---025---011.00 Brakes, Recondition (Rear)
SM01---027---000.00 Pneumatic System Air Line Identification Code
SM01---027---028.00 Front Air Brake Chamber, Recondition
SM01---027---054.00 Rear, Dual Air Brake Chamber, R & I
SM01---027---061.00 Spring Brake Valve, Recondition
SM01---027---062.00 Air Dryer, R & I
SM01---027---063.00 Air Dryer, Recondition
SM01---027---091.00 Front Air Brake Chamber, R & I
SM01---027---094.00 Air System Schematic Diagram
SM01---027---106.00 Caging Dual Air Brake Chambers
SM01---027---110.00 Air System Components, R & I (Generation 1)
SM01---027---117.00 Dual Air Brake Chamber, Recondition
SM01---027---124.00 Air System Components, R & I (Generation 2)
SM01---028---004.00 Rear Wheel Hub & Brake Drum, R & I
SM01---029---021.00 Suspension Lift Cylinder, Recondition (Generation 1 --- Hydraulic Technologies)
SM01---029---022.00 Suspension Lift Cylinder, R & I
SM01---029---024.00 Rear Axles & Air Suspension, R & I (Generation 1)
SM01---029---028.00 Suspension Lift Cylinder, Recondition (Generation 2 --- Texas Hydraulics)
SM01---029---032.00 Rear Axles & Air Suspension, R & I (Generation 2)
SM01---039---002.00 Vacuum Pressure Relief Valve, Recondition
SM01---039---003.00 Hydraulic System Cleaning Procedure
SM01---039---004.00 Hydraulic Reservoir Filter Assembly, R & I
SM01---039---005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01---043---001.00 Solenoid Valves, General Recondition
SM01---043---003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01---043---004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01---043---010.00 Outrigger Function Valve Stack, R & I
SM01---043---018.00 Outrigger Directional Valve, R & I
SM01---043---035.00 Four Way Directional Solenoid Valve, Recondition
SM01---044---007.00 Lock Valve, Recondition (Main Outriggers)
SM01---044---008.00 Jack Cylinder Lock Valve, R & I (Main Outriggers)
SM01---044---009.00 Jack Cylinder Lock Valve, Recondition (Fifth Outrigger)
SM01---044---017.00 Fifth Outrigger Lock Valve, R & I
SM01---044---023.00 Outrigger Lock Valve Cartridge, R & I (Fifth Outrigger w/Integral Lock Valve)
SM01---045---014.00 Outrigger Beam Cylinders, Recondition (Generation 1)
SM01---045---025.00 Single Stage Outrigger Beam Cylinder, R & I
SM01---045---029.00 Outrigger Beam, Jack & Beam Cylinder, R & I
SM01---045---048.00 Bottom Outrigger Beam Cylinder, Recondition (Generation 2)
SM01---045---049.00 Top Outrigger Beam Cylinder, Recondition (Generation 2)
SM01---046---016.00 Jack Cylinder, Recondition
SM01---046---024.00 Fifth Outrigger Jack Cylinder, R & I (Generation 1)
SM01---046---028.00 Jack Cylinder, R & I
SM01---046---034.00 Jack Cylinder, Recondition (Fifth Outrigger)
SM01---046---041.00 Fifth Outrigger Jack Cylinder, R & I (Generation 2)
SM01---047---034.00 Relief Valve, Recondition (Outriggers)
SM01---048---015.00 Rotating Joint, R & I (Generation 1)
SM01---048---017.00 10---Way Rotating Joint, Recondition (Generation 1)
SM01---048---039.00 Rotating Joint, R & I (Generation 2)
SM01---048---040.00 8---Way Rotating Joint, Recondition (Generation 2)
SM01---048---045.00 Rotating Joint, R & I (Generation 3 --- w/Water Swivel))
SM01---048---046.00 Rotating Joint, Recondition (Generation 3 --- w/Water Swivel)
SM01---063---086.00 Starter, R & I
SM01---063---087.00 Alternator, R & I (Generation 1)
SM01---063---088.00 Radiator, R & I (Generation 1 --- w/Engine Driven Fan)
SM01---063---091.00 Radiator Fan Clutch, R & I
SM01---063---092.00 Radiator Fan Clutch, Recondition
SM01---063---093.00 Torque Limit Switch Check, Adjustment, & Troubleshooting (Generation 1)
SM01---063---105.00 Radiator, R & I (Generation 2 --- w/Hydraulic Radiator Fan Motor)
SM01---063---106.00 Alternator, R & I (Generation 2 --- w/o Air Conditioning)
SM01---063---107.00 Alternator, R & I (Generation 2 --- w/Air Conditioning)
SM01---063---108.00 Torque Limit Switch Check, Adjustment, & Troubleshooting (Generation 2)
SM01---066---026.00 Battery, R & I
SM01---069---014.00 Tire & Rim, R & I
SM01---071---003.00 Engine Housing, R & I (Generation 1)
SM01---071---004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01---071---008.00 Engine Housing, R & I (Generation 2 --- w/Hydraulic Radiator Fan Motor)
SM01---073---001.00 Electronic Gauge, Troubleshooting (Generation 1 --- AMETEK/Dixson)
SM01---073---002.00 Electronic Gauge, Troubleshooting (Generation 2 --- AMETEK/Dixson)
SM01---076---020.00 Collector Ring, R & I (Generation 1)
SM01---076---029.00 Collector Ring, Recondition (Generation 1)
SM01---076---038.00 Collector Ring, Recondition (Generation 2)
SM01---076---045.00 Collector Ring, R & I (Generation 2)
SM01---076---046.00 Collector Ring, Recondition (Generation 3)
SM01---079---020.00 Lower Hydraulic Components, R & I (Generation 1)
SM01---079---024.00 Lower Hydraulic Components, R & I (Generation 2)
SM01---079---026.00 Lower Hydraulic Components, R & I (Generation 3 --- w/Hydraulic Radiator Fan)
SM01---080---019.00 Pump Drive, Recondition (Generation 1 --- Funk Mfg)
SM01---080---023.00 Pilot Control & Boom Hoist Pumps, R & I
SM01---080---029.00 Four Section Pump, R & I --- (Generation 1 --- Main Hydraulic)
SM01---080---030.00 Pump Drive, R & I (Generation 1 --- w/Funk Mfg Pump Drive)
SM01---080---045.00 Pump Drive, R & I (Generation 2 --- w/Durst Pump Drive)
SM01---080---046.00 Pump Drive, Recondition (Generation 2 --- Durst)
SM01---081---013.00 Pressure Compensating Pump, Recon (Gen 1 --- Pilot Control & Ctwt Removal)
SM01---081---014.00 Hydraulic Pump, Recondition (Multi Section Commercial---Intertech)
SM01---081---026.00 Hydraulic Pump, Recondition (One Section, Boom Hoist)
SM01---081---027.00 Main Hydraulic Pump, R & I (Generation 2 --- w/Durst Pump Drive)
SM01---081---028.00 Tandem Hydraulic Pump, Recondition
SM01---081---029.00 Radiator Fan Pump, R & I
SM01---081---036.00 Radiator Fan Motor, Recondition
SM01---081---045.00 Radiator Fan Motor, R & I
SM01---083---009.00 Pressure Compensating Pump, Recon (Gen 2 --- Pilot Control & Ctwt Removal)
SM01---083---010.00 Pressure Compensating Pump, R & I (Gen 2 --- Pilot Control & Ctwt Removal)
AREA 03 UPPER REVOLVING FRAME
SM03---001---056.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03---010---024.00 Counterweight Removal Cylinder, R & I
SM03---010---025.00 Counterweight Removal Cylinder, Recondition
AREA 04 VERTICAL SHAFTS
SM04---005---022.00 Swing Brake Assembly, Recondition
SM04---005---025.00 Swing Brake, R & I
Swing Brake Bleeding Procedure
SM04---010---023.00 Swing Reduction Unit, R & I
SM04---010---024.00 Swing Speed Reducer, Recondition
AREA 05 HORIZONTAL SHAFTS
SM05---006---013.00 Winch Assembly, R & I --- Braden CH150A,175A,185A,230 (Generation 1)
SM05---006---014.00 Winch, Recondition --- Braden CH150A,175A,185A,230 (Generation 1)
SM05---006---021.00 Winch, Troubleshooting --- Braden CH150A,175A,185A,230 (Generation 1)
SM05---006---026.00 Winch, Troubleshooting --- Braden CH210 (Generation 2)
SM05---006---027.00 Winch, R & I --- Braden CH210 (Generation 2)
SM05---006---028.00 Winch, Recondition (Generation 2--- w/Braden CH210 & Rexroth Motor)
SM05---006---034.00 Winch, R & I (Generation 3 --- w/Braden CH210 & Linde Motor)
SM05---010---006.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05---018---006.00 Winch Roller, R & I And Recondition
AREA 06 UPPER ENGINE
SM06---008---009.00 Throttle Treadle Assembly, R & I
SM06---008---010.00 Throttle Treadle Assembly, Recondition
SM06---025---004.00 Diesel Cab Heater, R & I
SM06---025---005.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 1)
SM06---025---009.00 Hydraulic Heater --- Troubleshooting
SM06---025---012.00 Hydraulic Cab Heater, R & I
SM06---025---014.00 Hydraulic Cab Heater, Recondition
SM06---025---017.00 Diesel Cab Heater, R & I (Generation 2)
SM06---025---018.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 2)
SM06---025---019.00 Operator’s Cab Water Heater, R & I (Upper)
SM06---025---022.00 A/C Coil & Heater Core, Illustrated
SM06---025---023.00 Upper Cab Water Heater & A/C Evaporator Coil, R & I
SM06---025---024.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06---047---000.00 Electrical System Wire Identification Code
SM06---047---126.00 Electrical System Schematic Diagram (Generation 1)
SM06---047---127.00 Electrical System Schematic Diagram (Generation 2)
SM07---000---140.00 Hydraulic System Schematic Diagram (Generation 1)
SM07---000---142.00 Hydraulic System Schematic Diagram (Generation 2)
SM07---001---025.00 Pilot Control Accumulator, R & I
SM07---003---006.00 Solenoid Valves, General Recondition
SM07---004---005.00 Upper Hydraulic Components, R & I (Generation 2)
SM07---004---008.00 Upper Hydraulic Components, R & I (Generation 3)
SM07---004---020.00 Upper Hydraulic Components, R & I (Generation 4)
SM07---005---051.00 Hydraulic Heater Gear Pump, R & I
SM07---005---052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07---005---064.00 Hydraulic Heater Gear Pump, R & I (Upper w/Air Conditioning)
SM07---006---034.00 Swing Motor, Recondition
SM07---006---052.00 Winch Motor, R & I (Generation 1 --- w/Rexroth Motor)
SM07---006---056.00 Hydraulic Motor, Recondition (Winch)
SM07---006---058.00 Hydraulic Heater Motor, Recondition
SM07---006---059.00 Hydraulic Motor, Recondition (Oil Cooler & Hydraulic Heater w/AC)
SM07---006---062.00 Swing Motor, R & I
SM07---006---063.00 Hydraulic Oil Cooler Motor, R & I
SM07---006---064.00 Hydraulic Heater Motor, R & I
SM07---006---085.00 Hydraulic Heater Motor, R & I (Upper w/Air Conditioning)
SM07---006---095.00 Hydraulic Motor, Recondition --- Winch (Linde)
SM07---006---101.00 Winch Motor, R & I (Generation 2 --- w/Linde Motor)
SM07---008---014.00 Winch Counterbalance Valve, Recondition (Generation 1)
SM07---008---037.00 Pressure Reducing Valve, Recondition
SM07---008---048.00 Foot Control Valve, R & I (Generation 1 --- Boom Telescope)
SM07---008---049.00 Winch Counterbalance Valve, R & I
SM07---008---051.00 Boom Hoist Control Valve, Recondition
SM07---008---055.00 Controller Valve Assembly, R & I (Dual Axis --- Generation 1)
SM07---008---056.00 Controller Valve Assembly, Recondition (Comm---Intertech Dual Axis)
SM07---008---058.00 Winch Control Valve, Recondition
SM07---008---060.00 Control Valves, Recondition (Model V12) --- Counterweight Removal
SM07---008---065.00 Pressure Reducing Valve, Recondition (Generation 1)
SM07---008---066.00 Control Valve, Recondition (Model V40)
SM07---008---067.00 Foot Control Valve, Recondition (Generation 1 --- Boom Telescope)
SM07---008---068.00 Upper Hydraulic Components, R & I (Generation 1)
SM07---008---076.00 Single Axis Control Valves, R & I (Generation 1)
SM07---008---077.00 Single Axis Control Valves, Recondition (Generation 1 --- Comm---Intertech)
SM07---008---107.00 Controller Valve, Recondition (Monson Dual Axis)
SM07---008---108.00 Single Axis Controller Valve, Recondition (Generation 2 --- Monson)
SM07---008---112.00 Pressure Reducing Valve, Recondition (Generation 2)
SM07---008---114.00 Boom Telescope Foot Control Valve, Recondition (Generation 2)
SM07---008---116.00 Dual Axis Controller Valve, R & I (Generation 2)
SM07---008---117.00 Single Axis Controller Valve, R & I (Generation 2)
SM07---008---118.00 Swing Brake Pedal Valve, Recondition (Generation 2)
SM07---008---120.00 Winch Control Valve, R & I (Generation 2)
SM07---008---121.00 Winch Counterbalance Valve, R & I (Generation 2)
SM07---008---122.00 Winch Counterbalance Valve, Recondition (Generation 2)
SM07---008---138.00 Boom Telescope Foot Pedal Valve, R & I (Generation 2)
SM07---008---139.00 Swing Brake Pedal Valve, R & I (Generation 2)
SM07---018---001.00 Hydraulic System Tube Fittings
SM07---029---002.00 Swing Brake Actuator, Recondition (Generation 1)
SM07---029---004.00 Swing Brake Actuator, R & I (Generation 1)
SM09---001---002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 14 CAB & HOUSE ASSEMBLY
SM14---001---006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17---001---036.00 Hydraulic Boom Inspection --- Diamond Embossed
SM17---001---042.00 Four Section Boom, Recondition
SM17---001---045.00 Boom, R & I
SM17---002---022.00 Boom Telescope Cylinder, Recondition
SM17---002---032.00 Boom Telescope Cylinder, Troubleshooting
SM17---002---033.00 Boom Telescope Counterbalance Valve, R & I
SM17---003---013.00 Boom Hoist Cylinder, Recondition
SM17---003---015.00 Boom Hoist Counterbalance Valve, Recondition (50 Ton)
SM17---003---028.00 Boom Hoist Cylinder, R & I
SM17---003---030.00 Boom Hoist Counterbalance Valve, R & I
SM17---003---031.00 Boom Hoist Counterbalance Valve, Recondition
SM17---009---002.00 Five Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18---000---001.00 Capscrew Torques
SM18---000---002.00 Bearing, Gear, Shaft, & Housing Inspection
SM18---000---003.00 Crane System Schematics
SM18---007---003.00 Reeling Drum, R & I
SM18---007---004.00 Reeling Drum, Recondition
SM18---018---001.00 Air Conditioning Service Precautions
SM18---018---004.00 Air Conditioning Compressor, Recondition (Carrier & Upper)
SM18---018---005.00 Air Conditioning Compressor, R & I (Upper)
SM18---018---008.00 Air Conditioning Compressor, R & I (Carrier --- Generation 1)
SM18---018---011.00 Air Conditioning Compressor, R & I (Carrier --- Generation 2)
