Link Belt Crane HTC-8670LB Service Manual
Brand: Link Belt
Model: Link Belt HTC-8670LB Crane
Number of Pages: 1008 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01- 001- 005.00 Boom Rest, R & I
SM01- 001- 007.00 Boom Rest Extension, R & I (Generation 1)
SM01- 001- 008.00 Boom Rest Extension, R & I (Generation 2)
SM01- 002- 012.00 Front Axle, Recondition
SM01- 002- 015.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition
SM01- 003- 014.00 Adjusting The Brakes
SM01- 003- 019.00 Automatic Slack Adjusters
SM01- 004- 009.00 Front Axle & Suspension, R & I
SM01- 005- 003.00 Steering Gear, Recondition (Master)
SM01- 005- 004.00 Steering Gear, Recondition (Slave)
SM01- 005- 005.00 Miter Box, R & I
SM01- 005- 010.00 Steering Drive Shafts, Recondition
SM01- 005- 013.00 Steering Column, R & I
SM01- 005- 015.00 Steering Column, Recondition
SM01- 006- 022.00 Steering Gears, R & I
SM01- 006- 023.00 Front Wheel Alignment & Steering Linkage Adjustment
Relief Plunger Adjustment
Axle Stop Adjustment
SM01- 010- 018.00 Power Steering Pump, R & I (Generation 1)
SM01- 010- 019.00 Power Steering Pump, Recondition (Generation 1)
SM01- 010- 028.00 Power Steering Pump, Recondition (Generation 2 - w/Hydraulic Radiator Fan)
SM01- 010- 029.00 Power Steering Pump Priority Valve, Recondition (Gen 2 - w/Hyd Radiator Fan)
SM01- 010- 034.00 Power Steering Pump, R & I (Generation 2 - w/Hydraulic Radiator Fan)
SM01- 016- 001.00 Heater Core, R & I
SM01- 016- 002.00 Heater Core & A/C Coil, R & I
SM01- 017- 008.00 Clutch, R & I And Recondition
SM01- 018- 041.00 Transmission, Recondition (Eaton/Fuller)
SM01- 018- 042.00 Transmission, R & I
SM01- 019- 011.00 Transmission Slave Control, R & I
SM01- 019- 014.00 Transmission Air Shift Control, Recondition
SM01- 019- 020.00 Transmission Shift Cable Adjustment
SM01- 019- 024.00 Transmission Master Control, R & I
SM01- 020- 002.00 Suspended Brake Pedal, Recondition
SM01- 020- 005.00 Suspended Brake Pedal, R & I (Generation 1)
SM01- 020- 008.00 Suspended Brake Pedal, R & I (Generation 2)
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 024- 010.00 Rear Axles, Recondition (Eaton RS520/DS520 Model Series)
SM01- 024- 015.00 Rear Axles, Recondition (Dana R52/D52- 190 Model Series)
SM01- 025- 016.00 Antilock Brake System (ABS EC- 60), Troubleshooting
SM01- 027- 000.00 Pneumatic System Air Line Identification Code
SM01- 027- 026.00 Caging Dual Air Brake Chambers
SM01- 027- 028.00 Front Air Brake Chamber, Recondition (Cam Type Brakes)
SM01- 027- 029.00 Rear Dual Air Brake Chamber, Recondition
SM01- 027- 061.00 Spring Brake Valve, Recondition
SM01- 027- 062.00 Air Dryer, R & I
SM01- 027- 063.00 Air Dryer, Recondition
SM01- 027- 064.00 Air System Components, R & I (Generation 1)
SM01- 027- 086.00 Air System Schematic Diagram (Generation 1)
SM01- 027- 091.00 Front Air Brake Chamber, R & I
SM01- 027- 092.00 Rear Dual Air Brake Chamber, R & I
SM01- 027- 093.00 Air System Components, R & I (Generation 2- w/Rear Air Suspension)
SM01- 027- 094.00 Air System Schematic Diagram (Generation 2- w/Rear Air Suspension)
SM01- 027- 123.00 Air System Components, R & I (Generation 3 - w/Rear Air Suspension)
SM01- 027- 137.00 Air System Components, R & I (Generation 4 - w/ABS)
SM01- 028- 002.00 Rear Wheel Hub & Brake Drum, R & I
SM01- 029- 016.00 Rear Axles & Suspension, R & I (Generation 1)
SM01- 029- 019.00 Rear Axle & Air Suspension, R & I (Generation 2)
SM01- 029- 021.00 Suspension Lift Cylinder, Recondition (Generation 1 - Hydraulic Technologies)
SM01- 029- 022.00 Suspension Lift Cylinder, R & I
SM01- 029- 028.00 Suspension Lift Cylinder, Recondition (Generation 2 - Texas Hydraulics)
SM01- 029- 034.00 Rear Axle & Air Suspension, R & I (Generation 3)
SM01- 039- 002.00 Vacuum Pressure Relief Valve, Recondition
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 039- 004.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 039- 005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01- 043- 010.00 Outrigger Function Valve Stack, R & I
SM01- 043- 018.00 Outrigger Directional Valve, R & I
SM01- 043- 035.00 Four Way Directional Solenoid Valve, Recondition (Fifth Outrigger)
SM01- 044- 007.00 Lock Valve, Recondition (Main Outriggers)
SM01- 044- 008.00 Jack Cylinder Lock Valve, R & I (Main Outriggers)
SM01- 044- 009.00 Jack Cylinder Lock Valve, Recondition (Fifth Outrigger)
SM01- 044- 017.00 Fifth Outrigger Lock Valve, R & I
SM01- 044- 023.00 Outrigger Lock Valve Cartridge, R & I (Jack Cylinder w/Integral Lock Valve)
SM01- 045- 014.00 Outrigger Beam Cylinders, Recondition (Generation 1)
SM01- 045- 025.00 Single Stage Outrigger Beam Cylinder, R & I
SM01- 045- 029.00 Outrigger Beam, Jack & Beam Cylinder, R & I
SM01- 045- 048.00 Bottom Outrigger Beam Cylinder, Recondition (Generation 2)
SM01- 045- 049.00 Top Outrigger Beam Cylinder, Recondition (Generation 2)
SM01- 046- 016.00 Jack Cylinder, Recondition
SM01- 046- 024.00 Fifth Outrigger Jack Cylinder, R & I (Generation 1)
SM01- 046- 028.00 Jack Cylinder, R & I
SM01- 046- 034.00 Jack Cylinder, Recondition (Fifth Outrigger)
SM01- 046- 041.00 Fifth Outrigger Jack Cylinder, R & I (Generation 2)
SM01- 047- 011.00 Relief Valve, Recondition (Outriggers - Generation 1)
SM01- 047- 034.00 Relief Valve, Recondition (Outriggers - Generation 2)
SM01- 048- 015.00 Rotating Joint, R & I (Generation 1)
SM01- 048- 017.00 10- Way Rotating Joint, Recondition (Generation 1)
SM01- 048- 039.00 Rotating Joint, R & I (Generation 2)
SM01- 048- 040.00 8- Way Rotating Joint, Recondition (Generation 2)
SM01- 048- 045.00 Rotating Joint, R & I (Generation 3 - w/Water Swivel))
SM01- 048- 046.00 Rotating Joint, Recondition (Generation 3 - w/Water Swivel)
SM01- 063- 086.00 Starter, R & I (50 & 60 Series Engines)
SM01- 063- 087.00 Alternator, R & I (50 & 60 Series Engines)
SM01- 063- 088.00 Radiator, R & I (Generation 1 - w/Engine Driven Fan)
SM01- 063- 091.00 Radiator Fan Clutch, R & I
SM01- 063- 092.00 Radiator Fan Clutch, Recondition
SM01- 063- 093.00 Torque Limit Switch Check, Adjustment, & Troubleshooting (Generation 1)
SM01- 063- 105.00 Radiator, R & I (Generation 2 - w/Hydraulic Radiator Fan Motor)
SM01- 063- 106.00 Alternator, R & I (Generation 2 - w/o Air Conditioning)
SM01- 063- 107.00 Alternator, R & I (Generation 2 - w/Air Conditioning)
SM01- 063- 108.00 Torque Limit Switch Check, Adjustment, & Troubleshooting (Generation 2)
SM01- 066- 026.00 Battery, R & I
SM01- 069- 009.00 Tires & Rims, R & I
SM01- 071- 003.00 Engine Housing, R & I (Generation 1)
SM01- 071- 004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01- 071- 008.00 Engine Housing, R & I (Generation 2 - w/Hydraulic Radiator Fan Motor)
SM01- 073- 001.00 Electronic Gauge, Troubleshooting (Generation 1 - AMETEK/Dixson)
SM01- 073- 002.00 Electronic Gauge, Troubleshooting (Generation 2 - AMETEK/Dixson)
SM01- 076- 020.00 Collector Ring, R & I (Generation 1)
SM01- 076- 021.00 Collector Ring, Recondition (Generation 1)
SM01- 076- 024.00 Collector Ring, Recondition (Generation 2)
SM01- 076- 029.00 Collector Ring, Recondition (Generation 3)
SM01- 076- 038.00 Collector Ring, Recondition (Generation 4)
SM01- 076- 045.00 Collector Ring, R & I (Generation 2)
SM01- 076- 046.00 Collector Ring, Recondition (Generation 5)
SM01- 079- 003.00 Lower Hydraulic Components, R & I (Generation 1- w/o Rear Air Suspension )
SM01- 079- 015.00 Lower Hydraulic Components, R & I (Generation 2)
SM01- 079- 020.00 Lower Hydraulic Components, R & I (Generation 3)
SM01- 079- 024.00 Lower Hydraulic Components, R & I (Generation 4)
SM01- 079- 026.00 Lower Hydraulic Components, R & I (Generation 5 - w/Hydraulic Radiator Fan)
SM01- 080- 019.00 Pump Drive, Recondition (Funk Mfg)
SM01- 080- 023.00 Pilot Control & Boom Hoist Pumps, R & I
SM01- 080- 029.00 Four Section Pump, R & I (Generation 1 - Main Hydraulic w/Funk Pump Drive)
SM01- 080- 030.00 Pump Drive, R & I (Generation 1 - w/Funk Mfg Pump Drive)
SM01- 080- 031.00 Pump Drive Shaft Assembly, R & I
SM01- 080- 032.00 Pump Drive Shaft Assembly, Recondition
SM01- 080- 045.00 Pump Drive, R & I (Generation 2 - w/Durst Pump Drive)
SM01- 080- 046.00 Pump Drive, Recondition (Generation 2 - Durst)
SM01- 081- 013.00 Pressure Compensating Pump, Recon (Gen 1- Pilot Control & Ctwt Removal)
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multi Section Commercial- Intertech)
SM01- 081- 026.00 Hydraulic Pump, Recondition (One Section, Boom Hoist)
SM01- 081- 027.00 Main Hydraulic Pump, R & I (Generation 2 - w/Durst Pump Drive)
SM01- 081- 028.00 Tandem Hydraulic Pump, Recondition
SM01- 081- 029.00 Radiator Fan Pump, R & I
SM01- 081- 036.00 Radiator Fan Motor, Recondition
SM01- 081- 045.00 Radiator Fan Motor, R & I
SM01- 083- 009.00 Pressure Compensating Pump, Recon (Gen 2- Pilot Control & Ctwt Removal)
SM01- 083- 010.00 Pressure Compensating Pump, R & I (Gen 2 - Pilot Control & Ctwt Removal)
SM01- 085- 002.00 Engine Preheater, R & I
SM01- 085- 004.00 Engine Preheater, Recondition
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 056.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 010- 024.00 Counterweight Removal Cylinder, R & I
SM03- 010- 025.00 Counterweight Removal Cylinder, Recondition
AREA 04 VERTICAL SHAFTS
SM04- 005- 022.00 Swing Brake Assembly, Recondition (Internal Multi Disc Type)
SM04- 005- 023.00 Swing Brake Caliper, Recondition (Hydraulic Application)
SM04- 005- 024.00 Swing Brake, R & I (Caliper Type)
SM04- 005- 025.00 Swing Brake, R & I (Internal Multi Disc Type)
Swing Brake Bleeding Procedure
SM04- 010- 010.00 Swing Speed Reducer, Recondition (w/Caliper Type Swing Brake)
SM04- 010- 023.00 Swing Reduction Unit, R & I
SM04- 010- 024.00 Swing Speed Reducer, Recondition (w/Internal Multi Disc Type Swing Brake)
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 013.00 Winch Assembly, R & I (Generation 1 - w/Braden CH150A, 175A, 185A, CH230)
SM05- 006- 014.00 Winch, Recondition (Generation 1 - w/Braden CH150A, 175A, 185A, CH230)
SM05- 006- 021.00 Winch, Troubleshooting (Generation 1 - w/Braden CH150A, 175A, 185A, CH230)
SM05- 006- 026.00 Winch, Troubleshooting (Generation 2 - w/Braden CH210)
SM05- 006- 027.00 Winch, R & I (Generation 2 - w/Braden CH210 & Rexroth Motor)
SM05- 006- 028.00 Winch, Recondition (Generation 2 - w/Braden CH210)
SM05- 006- 034.00 Winch, R & I (Generation 3 - w/Braden CH210 & Linde Motor)
SM05- 010- 006.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05- 018- 005.00 Winch Roller, Recondition (Steel Roller)
SM05- 018- 006.00 Winch Roller, R & I And Recondition (Nylon Roller)
AREA 06 UPPER ENGINE
SM06- 008- 009.00 Throttle Treadle Assembly, R & I (Electronic)
SM06- 008- 010.00 Throttle Treadle Assembly, Recondition (Electronic)
SM06- 025- 004.00 Diesel Cab Heater, R & I (Generation 1)
SM06- 025- 005.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 1)
SM06- 025- 007.00 Hydraulic Cab Heater, R & I (Floor Mounted)
SM06- 025- 008.00 Hydraulic Cab Heater, Recondition (Floor Mounted)
SM06- 025- 009.00 Hydraulic Heater - Troubleshooting
SM06- 025- 012.00 Hydraulic Cab Heater, R & I (Elevated Mount)
SM06- 025- 014.00 Hydraulic Cab Heater, Recondition (Elevated Mount)
SM06- 025- 017.00 Diesel Cab Heater, R & I (Generation 2)
SM06- 025- 018.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 2)
SM06- 025- 019.00 Operator’s Cab Water Heater, R & I
SM06- 025- 022.00 A/C Coil & Heater Core, Illustrated
SM06- 025- 023.00 Upper Cab Water Heater & A/C Evaporator Coil, R & I
SM06- 025- 024.00 Upper Cab Heater Water Swivel, R & I And Recondition (Rotating Joint)
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 095.00 Electrical System Schematic Diagram (Generation 1)
SM06- 047- 103.00 Electrical System Schematic Diagram (Generation 2)
SM06- 047- 104.00 Electrical System Schematic Diagram (Generation 3)
SM06- 047- 111.00 Electrical System Schematic Diagram (Generation 4)
SM06- 047- 120.00 Electrical System Schematic Diagram (Generation 5)
SM06- 047- 126.00 Electrical System Schematic Diagram (Generation 6)
SM06- 047- 127.00 Electrical System Schematic Diagram (Generation 7)
SM07- 000- 121.00 Hydraulic System Schematic Diagram (Generation 1)
SM07- 000- 140.00 Hydraulic System Schematic Diagram (Generation 2)
SM07- 000- 142.00 Hydraulic System Schematic Diagram (Generation 3 - w/Hydraulic Radiator Fan)
SM07- 001- 025.00 Pilot Control Accumulator, R & I
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 004- 005.00 Upper Hydraulic Components, R & I (Generation 2)
SM07- 004- 008.00 Upper Hydraulic Components, R & I (Generation 3)
SM07- 004- 020.00 Upper Hydraulic Components, R & I (Generation 4)
SM07- 005- 051.00 Hydraulic Heater Gear Pump, R & I
SM07- 005- 052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07- 005- 064.00 Hydraulic Heater Gear Pump, R & I (Upper w/Air Conditioning)
SM07- 006- 034.00 Swing Motor, Recondition
SM07- 006- 052.00 Winch Motor, R & I (Generation 1 - w/Rexroth Motor)
SM07- 006- 056.00 Hydraulic Motor, Recondition - Winch (Rexroth 63 Series)
SM07- 006- 057.00 Swing Motor, R & I (w/Caliper Type Swing Brake)
SM07- 006- 058.00 Hydraulic Heater Motor, Recondition
SM07- 006- 059.00 Hydraulic Motor, Recondition (Oil Cooler)
SM07- 006- 062.00 Swing Motor, R & I (w/Internal Multi Disc Type Swing Brake)
SM07- 006- 063.00 Hydraulic Oil Cooler Motor, R & I
SM07- 006- 064.00 Hydraulic Heater Motor, R & I
SM07- 006- 085.00 Hydraulic Heater Motor, R & I (Upper w/Air Conditioning)
SM07- 006- 095.00 Hydraulic Motor, Recondition - Winch (Linde)
SM07- 006- 101.00 Winch Motor, R & I (Generation 2 - w/Linde Motor)
SM07- 008- 014.00 Winch Counterbalance Valve, Recondition (Generation 1)
SM07- 008- 037.00 Pressure Reducing Valve, Recondition (Generation 1)
SM07- 008- 048.00 Foot Control Valve, R & I (Generation 1 - Boom Telescope)
SM07- 008- 049.00 Winch Counterbalance Valve, R & I (Generation 1)
SM07- 008- 051.00 Boom Hoist Control Valve, Recondition
SM07- 008- 055.00 Controller Valve Assembly, R & I (Dual Axis - Generation 1)
SM07- 008- 056.00 Controller Valve Assembly, Recondition (Comm- Intertech Dual Axis)
SM07- 008- 058.00 Winch Control Valve, Recondition
SM07- 008- 060.00 Control Valve, Recondition (Model V12) - Counterweight Removal Cylinder
SM07- 008- 065.00 Pressure Reducing Valve, Recondition (Generation 2)
SM07- 008- 066.00 Control Valve, Recondition (Model V40)
SM07- 008- 067.00 Foot Control Valve, Recondition (Generation 1 - Boom Telescope)
SM07- 008- 068.00 Upper Hydraulic Components, R & I (Generation 1)
SM07- 008- 076.00 Single Axis Control Valves, R & I (Generation 1)
SM07- 008- 077.00 Single Axis Control Valves, Recondition (Generation 1 - Comm- Intertech)
SM07- 008- 107.00 Controller Valve, Recondition (Monson Dual Axis)
SM07- 008- 108.00 Single Axis Controller Valve, Recondition (Monson)
SM07- 008- 112.00 Pressure Reducing Valve, Recondition (Generation 3)
SM07- 008- 114.00 Boom Telescope Foot Control Valve, Recondition (Generation 2)
SM07- 008- 116.00 Dual Axis Controller Valve, R & I (Generation 2)
SM07- 008- 117.00 Single Axis Controller Valve, R & I (Generation 2)
SM07- 008- 118.00 Swing Brake Pedal Valve, Recondition (Generation 2)
SM07- 008- 120.00 Winch Control Valve, R & I (Generation 2)
SM07- 008- 121.00 Winch Counterbalance Valve, R & I (Generation 2)
SM07- 008- 122.00 Winch Counterbalance Valve, Recondition (Generation 2)
SM07- 008- 138.00 Boom Telescope Foot Pedal Valve, R & I (Generation 2)
SM07- 008- 139.00 Swing Brake Pedal Valve, R & I (Generation 2)
SM07- 029- 002.00 Swing Brake Actuator, Recondition (Generation 1)
SM07- 029- 004.00 Swing Brake Actuator, R & I (Generation 1)
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 001- 042.00 Four Section Boom, Recondition (41’- 127’ Full Power)
SM17- 001- 045.00 Boom, R & I (41’- 127’ Four Section, Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 032.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 033.00 Boom Telescope Counterbalance Valve, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 015.00 Boom Hoist Counterbalance Valve, Recondition (50 Ton)
SM17- 003- 028.00 Boom Hoist Cylinder, R & I
SM17- 003- 030.00 Boom Hoist Counterbalance Valve, R & I
SM17- 003- 031.00 Boom Hoist Counterbalance Valve, Recondition
SM17- 009- 002.00 Five Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 003.00 Reeling Drum, R & I
SM18- 007- 004.00 Reeling Drum, Recondition
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 004.00 Air Conditioning Compressor, Recondition (Carrier & Upper)
SM18- 018- 005.00 Air Conditioning Compressor, R & I (Upper)
SM18- 018- 008.00 Air Conditioning Compressor, R & I (Carrier - Generation 1)
SM18- 018- 011.00 Air Conditioning Compressor, R & I (Carrier - Generation 2)
Brand: Link Belt
