Link Belt Crane HTC-8665 Service Manual
Brand: Link Belt
Model: Link Belt HTC-8665 Crane
Number of Pages: 1174 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 01 RUBBER TIRE LOWER
SM01- 002- 012.00 Front Axle, Recondition (Eaton EFA Series)
SM01- 002- 015.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition (Eaton EB & ES Type)
SM01- 003- 014.00 Adjusting The Brakes (Eaton EB,ES & Rockwell “P,Q,T” Series)
SM01- 004- 004.00 Front Axles & Suspension, R & I
SM01- 005- 003.00 Steering Gear, Recondition (Master)
SM01- 005- 004.00 Steering Gear, Recondition (Slave)
SM01- 005- 005.00 Miter Box, R & I
SM01- 005- 006.00 Miter Box, Recondition
SM01- 005- 010.00 Steering Drive Shafts, Recondition
SM01- 005- 013.00 Steering Column, R & I
SM01- 005- 015.00 Steering Column, Recondition
SM01- 006- 015.00 Steering Gears, R & I
SM01- 006- 017.00 Front Wheel Alignment & Steering Linkage Adjustment
Relief Plunger Adjustment
Axle Stop Adjustment
SM01- 010- 014.00 Power Steering Pump, R & I
SM01- 010- 015.00 Power Steering Pump, Recondition
SM01- 017- 007.00 Clutch, R & I and Recondition
SM01- 018- 027.00 Transmission, R & I
Clutch Pedal & Linkage Adjustment
SM01- 018- 028.00 Transmission, Recondition (Manual)
Transmission Air System
Transmission Shift Controls, Recondition
SM01- 019- 011.00 Transmission Slave Control, R & I
SM01- 019- 012.00 Transmission Shift Cable Adjustment - Manual
SM01- 019- 014.00 Transmission Air Shift Control, Recondition
SM01- 019- 020.00 Transmission Shift Cable Adjustment
SM01- 020- 002.00 Suspended Brake Pedal, Recondition
SM01- 020- 006.00 Suspended Brake Pedal, R & I
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 024- 005.00 Rear- Rear Axle, Recondition (Rockwell)
SM01- 024- 009.00 Front- Rear Axle, Recondition (Rockwell)
SM01- 025- 008.00 Brakes, Recondition (Rockwell “P,Q & T Series”)
SM01- 027- 009.00 Air Dryer, Recondition
SM01- 027- 010.00 Air Throttle Control Cylinder, Recondition
SM01- 027- 026.00 Caging Dual Air Brake Chambers
SM01- 027- 027.00 Air Brake Chamber, R & I
SM01- 027- 028.00 Front Air Brake Chamber, Recondition
SM01- 027- 029.00 Rear Dual Air Brake Chamber, Recondition
SM01- 027- 032.00 Throttle Pedal, R & I
SM01- 027- 033.00 Throttle Pedal, Recondition
SM01- 027- 044.00 Air Dryer, R & I
SM01- 027- 045.00 Air System Schematic Diagram
SM01- 027- 061.00 Spring Brake Valve, Recondition
SM01- 028- 002.00 Rear Wheel Hub & Brake Drum, R & I
SM01- 029- 010.00 Rear Axles & Suspension, R & I
SM01- 039- 002.00 Vacuum Pressure Relief Valve, Recondition
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01- 043- 008.00 Outrigger Directional Valve, Recondition
SM01- 043- 010.00 Outrigger Function Valve Stack, R & I
SM01- 043- 011.00 Outrigger Directional Valve, R & I
SM01- 043- 012.00 Bumper Outrigger Directional Valve, R & I
SM01- 043- 024.00 Throttle Lock Solenoid Valve, Recondition
SM01- 044- 007.00 Lock Valve, Recondition
SM01- 044- 008.00 Jack Cylinder Lock Valve, R & I
SM01- 044- 009.00 Jack Cylinder Lock Valve, Recondition
SM01- 044- 017.00 Fifth Outrigger Lock Valve, R & I
SM01- 045- 014.00 Outrigger Beam Cylinder, Recondition
SM01- 045- 025.00 Single Stage Outrigger Beam Cylinder, R & I
SM01- 045- 027.00 Dual Stage Beam Cylinder, R & I
SM01- 045- 028.00 Dual Stage Beam Cylinder, Recondition
SM01- 045- 029.00 Outrigger Beam, Jack & Beam Cylinder, R & I
SM01- 046- 016.00 Jack Cylinder, Recondition
SM01- 046- 024.00 Bumper Outrigger Jack Cylinder, R & I
SM01- 046- 025.00 Bumper Outrigger Jack Cylinder, Recondition
SM01- 046- 028.00 Jack Cylinder, R & I
SM01- 047- 006.00 Relief Valve, Recondition
SM01- 047- 011.00 Relief Valve, Recondition
SM01- 048- 015.00 Rotating Joint, R & I
SM01- 048- 017.00 Rotating Joint, Recondition
SM01- 069- 009.00 Tires & Rims, R & I
SM01- 071- 004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01- 075- 020.00 Starter, R & I
SM01- 075- 021.00 Alternator, R & I
SM01- 075- 022.00 Radiator Without Charge Air Cooler, R & I
SM01- 075- 023.00 Radiator With Charge Air Cooler, R & I
SM01- 075- 024.00 Charge Air Cooler, R & I
SM01- 076- 015.00 Collector Ring & Air Swivel, R & I
Air Swivel, Recondition (Installed)
SM01- 076- 016.00 Collector Ring, Recondition
SM01- 080- 019.00 Pump Drive, Recondition
SM01- 080- 023.00 Pilot Control & Boom Hoist Pumps, R & I
SM01- 080- 029.00 Four Section Pump, R & I
SM01- 080- 030.00 Pump Drive, R & I
SM01- 080- 031.00 Pump Drive Shaft Assembly, R & I
SM01- 080- 032.00 Pump Drive Shaft Assembly, Recondition
SM01- 081- 013.00 Pressure Compensating Pump, Recondition (Pilot Control & Ctwt Removal)
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multi Section Commercial- Intertech)
SM01- 081- 026.00 Hydraulic Pump, Recondition (One Section, Boom Hoist)
SM01- 085- 004.00 Engine Preheater, Recondition
SM01- 085- 005.00 Propane Engine Preheater, R & I
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 056.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 010- 024.00 Counterweight Removal Cylinder, R & I
SM03- 010- 025.00 Counterweight Removal Cylinder, Recondition
AREA 04 VERTICAL SHAFTS
SM04- 005- 017.00 Brake Caliper, Recondition (Mechanical Application)
SM04- 005- 022.00 Swing Brake Assembly, Recondition (Wet Disc Type)
SM04- 005- 023.00 Swing Brake Caliper, Recondition (Hydraulic Application)
SM04- 005- 024.00 Swing Brake, R & I (Caliper Type)
SM04- 005- 025.00 Swing Brake, R & I (Wet Disc Type)
Swing Brake Bleeding Procedure
SM04- 010- 010.00 Swing Speed Reducer, Recondition (w/Caliper Type Swing Brake)
SM04- 010- 023.00 Swing Reduction Unit, R & I
SM04- 010- 024.00 Swing Speed Reducer, Recondition (w/Wet Disc Type Swing Brake)
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 013.00 Winch Assembly, R & I
SM05- 006- 014.00 Winch, Recondition
SM05- 006- 021.00 Winch, Troubleshooting
SM05- 010- 006.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05- 018- 005.00 Winch Roller, Recondition
AREA 06 UPPER ENGINE
SM06- 008- 006.00 Upper Treadle Valve, R & I
SM06- 024- 023.00 Audio/Visual Warning System Calibration
SM06- 025- 004.00 Diesel Cab Heater, R & I
SM06- 025- 005.00 Diesel Cab Heater, Recondition & Troubleshooting
SM06- 025- 006.00 11,000 B.T.U. Diesel Cab Heater, Recondition
SM06- 025- 007.00 Hydraulic Cab Heater, R & I
SM06- 025- 008.00 Hydraulic Cab Heater, Recondition
SM06- 025- 009.00 Hydraulic Heater - Troubleshooting
SM06- 025- 010.00 Diesel Cab Heater, Recondition & Troubleshooting
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 074.00 Electrical System Schematic Diagram (Generation 1)
SM06- 047- 075.00 Electrical System Schematic Diagram (Generation 2)
SM06- 047- 076.00 Electrical System Schematic Diagram (Generation 3)
SM07- 000- 109.00 Hydraulic System Schematic Diagram (Generation 1)
SM07- 000- 110.00 Hydraulic System Schematic Diagram (Generation 2)
SM07- 000- 111.00 Hydraulic System Schematic Diagram (Generation 3)
SM07- 000- 112.00 Hydraulic System Schematic Diagram (Generation 4)
SM07- 001- 025.00 Pilot Control Accumulator, R & I
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 005- 051.00 Hydraulic Heater Gear Pump, R & I
SM07- 005- 052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07- 006- 034.00 Swing Motor, Recondition
SM07- 006- 047.00 Hydraulic Motor, Recondition - Winch (Rexroth 60 Series)
SM07- 006- 052.00 Winch Motor, R & I
SM07- 006- 055.00 Hydraulic Motor, Recondition - Winch (VOAC)
SM07- 006- 056.00 Hydraulic Motor, Recondition - Winch (Rexroth 63 Series)
SM07- 006- 057.00 Swing Motor, R & I (w/Caliper Type Swing Brake)
SM07- 006- 058.00 Hydraulic Heater Motor, Recondition
SM07- 006- 059.00 Hydraulic Motor, Recondition (Oil Cooler)
SM07- 006- 062.00 Swing Motor, R & I (w/Wet Disc Type Swing Brake)
SM07- 008- 014.00 Winch Counterbalance Valve, Recondition
SM07- 008- 049.00 Winch Counterbalance Valve, R & I
SM07- 008- 051.00 Boom Hoist Control Valve, Recondition
SM07- 008- 055.00 Controller Valve Assembly, R & I
SM07- 008- 056.00 Controller Valve Assembly, Recondition
SM07- 008- 058.00 Winch Control Valve, Recondition
SM07- 008- 059.00 Swing/Telescope Control Valve Assembly, Recondition
SM07- 008- 060.00 Counterweight Removal Cylinder Control Valve, Recondition
SM07- 008- 065.00 Pressure Reducing Valve, Recondition
SM07- 008- 131.00 Pilot Oil Supply Valve, Recondition
SM07- 029- 002.00 Swing Brake Actuator, Recondition
SM07- 029- 003.00 Swing Brake Actuator, R & I
AREA 09 TUBULAR BOOM
SM09- 001- 002.00 Tubular Boom, Fly, & Jib Repair
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 032.00 Boom, R & I
SM17- 001- 033.00 110’ Four Section Boom, Recondition
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 002- 024.00 Boom Telescope Cylinder, Recondition
SM17- 002- 045.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 046.00 Boom Telescope Counterbalance Valve, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 028.00 Boom Hoist Cylinder, R & I
SM17- 003- 030.00 Boom Hoist Counterbalance Valve, R & I
SM17- 003- 031.00 Boom Hoist Counterbalance Valve, Recondition
SM17- 009- 001.00 Four Sheave Head Machinery, Recondition
SM17- 009- 002.00 Five Sheave Head Machinery, Recondition
SM17- 009- 003.00 Four Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 007- 001.00 Reeling Drum, R & I
SM18- 007- 002.00 Reeling Drum, Recondition
SM18- 018- 001.00 Air Conditioning Service Instructions
Brand: Link Belt
