Hyundai
86
176,834
Link Belt Crane HTC-8640XP SL Service Manual
Brand: Link Belt
Type of Manual: Service Manual, Electric Diagrams
Model: Link Belt HTC-8640XP SL Crane
Number of Pages: 1048 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions, And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01- 001- 006.00 Boom Rest, R & I
SM01- 001- 008.00 Boom Rest Extension, R & I
SM01- 002- 012.00 Front Axle, Recondition
SM01- 002- 015.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition
SM01- 003- 014.00 Adjusting The Brakes
SM01- 003- 019.00 Automatic Slack Adjusters
SM01- 004- 013.00 Front Axle & Air Suspension, R & I
SM01- 005- 005.00 Steering Miter Boxes, R & I
SM01- 005- 027.00 Troubleshooting Sheppard Steering Gears
SM01- 005- 034.00 Steering Column, R & I
SM01- 005- 035.00 Steering Column, Recondition
SM01- 005- 037.00 Steering Gears, Recondition
SM01- 006- 040.00 Steering Gears, R & I
SM01- 006- 041.00 Front Wheel Alignment & Steer Linkage Adjustment
SM01- 010- 039.00 Power Steer Pump With Priority Valve, Recondition (Cummins QSM Tier 3 Engine)
SM01- 010- 044.00 Power Steering Pump, R & I (Cummins QSM Tier 3 375 HP Engine)
SM01- 016- 002.00 Heater Core & A/C Coil, R & I
SM01- 018- 057.00 Transmission, Recondition
SM01- 018- 062.00 Transmission And Clutch, R & I (Cummins QSM Tier 3 Engine)
SM01- 019- 034.00 Transmission Shift Control, R & I
SM01- 020- 002.00 Suspended Brake Pedal, Recondition
SM01- 020- 011.00 Suspended Brake Pedal Valve, R & I
SM01- 022- 004.00 U- Joint Installation (Square Flange)
SM01- 022- 005.00 U- Joint Installation (Round Flange)
SM01- 024- 015.00 Rear Axles, Recondition
SM01- 025- 016.00 Antilock Brake System, Troubleshooting (ABS EC- 60)
SM01- 027- 000.00 Pneumatic System Air Line Identification Code
SM01- 027- 026.00 Caging Dual Air Brake Chambers
SM01- 027- 028.00 Front Air Brake Chamber, Recondition
SM01- 027- 029.00 Rear Dual Air Brake Chamber, Recondition
SM01- 027- 062.00 Air Dryer, R & I
SM01- 027- 063.00 Air Dryer, Recondition
SM01- 027- 091.00 Front Air Brake Chamber, R & I
SM01- 027- 092.00 Rear Dual Air Brake Chamber, R & I
SM01- 027- 145.00 Air System Components, R & I
SM01- 027- 150.00 Air System Components, R & I (Rear Lift Axle)
SM01- 028- 002.00 Rear Wheel Hub & Brake Drum, R & I
SM01- 029- 027.00 Suspension Lift Cylinder, R & I
SM01- 029- 028.00 Suspension Lift Cylinder, Recondition
SM01- 029- 029.00 Rear Axles And Air Suspension, R & I
SM01- 029- 031.00 Axle Lift Manifold Illustrated
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 039- 005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01- 039- 008.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01- 043- 045.00 Outrigger Directional Control Valve, R & I
SM01- 043- 046.00 Outrigger Function Control Valve, R & I
SM01- 043- 047.00 Fifth Outrigger Directional Control Valve, R & I
SM01- 044- 023.00 Fifth Outrigger Lock Valve Cartridge, R & I
SM01- 044- 027.00 Outrigger Lock Valve Cartridge, R & I And Recondition
SM01- 045- 050.00 Outrigger Beam Cylinder, Recondition
SM01- 045- 056.00 Outrigger Beam And Beam Cylinder, R & I
SM01- 045- 073.00 Outrigger Beam Cylinder Assy, Recondition
SM01- 046- 034.00 Jack Cylinder, Recondition (Main & Fifth Outrigger)
SM01- 046- 044.00 Jack Cylinder, R & I
SM01- 046- 045.00 Fifth Outrigger Jack Cylinder, R & I
SM01- 047- 038.00 Pick & Carry Manifold Block, Illustrated (G2)
SM01- 047- 048.00 Pick & Carry Manifold Block, Illustrated (G2)
SM01- 048- 037.00 Rotating Joint, R & I
SM01- 048- 038.00 Rotating Joint, Recondition
SM01- 050- 007.00 Transmission Oil Cooler, R & I (Boom Trailer)
SM01- 050- 008.00 Transmission Oil Bypass Valve, R & I (Boom Trailer)
SM01- 050- 009.00 Transmission Oil Bypass Valve, Recondition (Boom Trailer)
SM01- 066- 024.00 Battery, R & I
SM01- 069- 009.00 Tires & Rims, R & I
SM01- 069- 016.00 Tire & Rim,Inspection & Maintenance (Aluminum Disc Rims & Tubeless Tires)
SM01- 071- 004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01- 071- 013.00 Engine Housing, R & I
SM01- 071- 024.00 Engine Housing, R & I (G2)
SM01- 073- 002.00 Electronic Gauge, Troubleshooting
SM01- 075- 053.00 Starter, R & I (Cummins QSM Tier 3 375 HP Engine)
SM01- 075- 054.00 Alternator, R & I (Cummins QSM Tier 3 375 HP Engine)
SM01- 075- 055.00 Radiator, Charged Air & Hydraulic Oil Cooler, R & I (Cummins QSM Tier 3 Engine)
SM01- 076- 042.00 Collector Ring, R & I
SM01- 076- 068.00 Collector Ring, Recondition (37 Rings)
SM01- 076- 084.00 Collector Ring, Recondition (w/Cummins Engine & Pulse 35 Rings)
SM01- 076- 088.00 Heavy Duty Collector Ring Assy, Recon
SM01- 076- 098.00 Collector Ring, Recondition - 37 Rings
SM01- 079- 072.00 Lower Hydraulic Components, R & I (Suction, Pressure, & Return Lines)
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multiple Section Gear Type)
SM01- 081- 040.00 Hydraulic Pump, R & I- Tandem Four Section
SM01- 081- 043.00 Radiator Fan Motor, R & I (w/CAT C13 Engine)
SM01- 081- 046.00 Hydraulic Gear/Pump Motor, Recondition- PGM 620 Series (Radiator Fan)
SM01- 081- 051.00 Hydraulic Pump, R & I (Outriggers/Pick & Carry)
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 072.00 Upper Revolving Frame And Turntable Bearing, R & I
SM03- 003- 016.00 Fixed Counterweight, R & I
SM03- 010- 025.00 Counterweight Removal Cylinder, Recondition
SM03- 010- 037.00 Counterweight Removal Cylinder, R & I
SM03- 010- 038.00 Counterweight Removal Control Valve, R & I - G1
SM03- 010- 077.00 Counterweight Removal Control Valve, R & I - G2
AREA 04 VERTICAL SHAFTS
SM04- 010- 032.00 Swing Reduction Unit And Brake, R & I
SM04- 010- 033.00 Swing Reduction Unit And Brake, Recondition
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 019.00 Winch, Recondition
SM05- 006- 020.00 Winch Troubleshooting
SM05- 006- 039.00 Winch Assembly, R & I
SM05- 018- 004.00 Winch Roller, Recondition
AREA 06 UPPER ENGINE
SM06- 008- 009.00 Throttle Treadle Assembly, R & I
SM06- 025- 019.00 Operator’s Cab Water Heater, R & I
SM06- 025- 022.00 A/C Coil And Heater Core, Illustrated
SM06- 025- 023.00 Upper Cab Water Heater & A/C Evaporator Coil, R & I
SM06- 025- 024.00 Upper Cab Heater Water Swivel, R & I And Recondition
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recondition
SM06- 025- 029.00 Diesel Coolant Heater, R & I
SM06- 025- 037.00 Operator’s Cab Water Heater, R & I
SM06- 047- 000.00 Electrical System Wire Identification Code
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 001- 027.00 Pilot Control Accumulator, R & I
SM07- 002- 032.00 Relief Valve, Recondition (Upper Air Conditioning And/Or Telescope)
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 004- 042.00 Upper Hydraulic Components, R & I- Upper Frame
SM07- 004- 047.00 Upper Hydraulic Components, R & I- Single Winch Plumbing
SM07- 004- 048.00 Upper Hydraulic Components, R & I- Two Winch Plumbing
SM07- 004- 079.00 Upper Hydraulic Components, R & I (Cab Floor)
SM07- 006- 034.00 Swing Motor, Recondition
SM07- 006- 095.00 Winch Motor, Recondition
SM07- 006- 099.00 Swing Motor, R & I
SM07- 006- 114.00 Winch Motor, R & I
SM07- 008- 032.00 Control Valves, Recondition (Counterweight Removal)
SM07- 008- 107.00 Dual Axis Controller Valve, Recondition
SM07- 008- 108.00 Single Axis Controller Valve, Recondition
SM07- 008- 111.00 Winch Control Valve, R & I
SM07- 008- 113.00 Boom Telescope Foot Control Valve, R & I
SM07- 008- 114.00 Boom Telescope Foot Pedal, Recondition
SM07- 008- 115.00 Swing Brake Pedal Valve, R & I
SM07- 008- 116.00 Dual Axis Controller Valve, R & I
SM07- 008- 117.00 Single Axis Controller Valve, R & I
SM07- 008- 118.00 Swing Brake Pedal Valve, Recondition
SM07- 008- 122.00 Winch Counterbalance Valve, Recondition
SM07- 008- 127.00 Winch Control Valve, Recondition
SM07- 008- 129.00 Hydraulic Control Valve, Recondition (Boom Hoist/Telescope/Swing)
SM07- 008- 131.00 Pilot Oil Supply Valve, Recondition
SM07- 008- 158.00 Telescope/Swing Control Valve, R & I
SM07- 008- 159.00 Boom Hoist Control Valve, R & I
SM07- 008- 160.00 Winch Counterbalance Valve, R & I
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 036.00 Hydraulic Boom Inspection- Diamond Embossed
SM17- 001- 054.00 Four Section Boom, R & I (35.5’- 110’ Full Power)
SM17- 001- 055.00 Four Section Boom, Recondition (35.5’- 110’ Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 026.00 Boom Telescope Cylinder, Troubleshooting
SM17- 002- 027.00 Boom Telescope Counterbalance Valve, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 034.00 Boom Hoist Cylinder, R & I
SM17- 003- 035.00 Boom Hoist Counterbalance Valves, R & I
SM17- 009- 006.00 Four Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 003.00 Reeling Drum, R & I
SM18- 007- 004.00 Reeling Drum, Recondition
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 004.00 Air Conditioning Compressor, Recondition (Carrier And Upper)
SM18- 018- 013.00 Air Conditioning Compressor, R & I (Upper)
SM18- 018- 014.00 Air Conditioning Hydraulic Drive Motor, R & I (Upper)
SM18- 018- 015.00 Air Conditioning Hydraulic Drive Motor, Recondition (Upper)
SM18- 018- 026.00 Air Conditioning Compressor, R & I - Cummins Engine (Carrier)
