Link Belt Crane HTC-8640 Service Manual
Brand: Link Belt
Model: Link Belt HTC-8640 Crane
Number of Pages: 1542 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 How To Use This Manual, General Service Instructions And Safety Procedures
AREA 01 RUBBER TIRE LOWER
SM01- 001- 006.00 Boom Rest, R & I
SM01- 001- 007.00 Boom Rest Extension, R & I
SM01- 001- 008.00 Boom Rest Extension, R & I
SM01- 002- 012.00 Front Axle, Recondition
SM01- 002- 015.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition
SM01- 003- 014.00 Adjusting The Brakes
SM01- 003- 019.00 Automatic Slack Adjusters
SM01- 004- 013.00 Front Axle & Suspension, R & I
SM01- 005- 003.00 Steering Gear, Recondition - Master
SM01- 005- 004.00 Slave Steering Gear, Recon
SM01- 005- 005.00 Steering Miter Boxes, R & I
SM01- 005- 013.00 Steering Column, R & I
SM01- 005- 015.00 Steering Column, Recondition
SM01- 005- 017.00 Steering Bevel Gear Drive, Recondition (Remote Steering)
SM01- 005- 022.00 Master Steering Gear, R & I
SM01- 005- 023.00 Steering Gears, Recondition (“M” Series)
SM01- 005- 024.00 Slave Steering Gear, R & I
SM01- 005- 025.00 Slave Steering Gear, Recondition (92 Series)
SM01- 005- 026.00 Steering Miter Box, R & I (w/o Remote Steering)
SM01- 005- 027.00 Troubleshooting Steering Gears (“M” Series)
SM01- 005- 028.00 Steering Bevel Gear Drive, R & I (Remote Steering)
SM01- 005- 031.00 Steering Bevel Gear Drive, R & I
SM01- 005- 034.00 Steering Column, R & I
SM01- 005- 035.00 Steering Column, Recon.
SM01- 005- 037.00 Steering Gears, Recon.
SM01- 006- 024.00 Front Wheel Alignment & Steering Linkage Adjustment
Relief Plunger Adjustment
Axle Stop Adjustment
SM01- 006- 034.00 Steering Gears, R & I
SM01- 006- 035.00 Front Wheel Alignment & Steer Linkage Adjustment
SM01- 006- 040.00 Steering Gears, R & I
SM01- 006- 041.00 Front Wheel Alignment & Steer Linkage Adjustment
SM01- 010- 025.00 Power Steering Pump, Recon.
SM01- 010- 028.00 Fifth Outrigger/Steer Pump, Recondition
SM01- 010- 029.00 Power Steering Pump Priority Valve, Recondition
SM01- 010- 030.00 Power Steering Pump, R & I
SM01- 010- 035.00 Power Steering Pump, R & I
SM01- 010- 038.00 Power Steering Pump, R & I
SM01- 010- 039.00 Power Steering Pump, Recon.
SM01- 016- 001.00 Heater, R & I
SM01- 016- 002.00 Heater & A/C Coil, R & I
SM01- 017- 008.00 Clutch, R & I And Recondition
SM01- 018- 028.00 Transmission, Recondition (Manual)
Transmission Air System
Transmission Shift Controls, Recondition
SM01- 018- 050.00 Transmission, R & I (Cummins w/Eaton Manual)
SM01- 018- 051.00 Transmission, R & I (Cummins w/Allison Automatic)
SM01- 019- 014.00 Transmission Air Shift Control, Recondition
SM01- 019- 024.00 Transmission Master Control, R & I
SM01- 019- 026.00 Transmission Slave Control, R & I
SM01- 019- 027.00 Transmission Slave Control, Recondition
SM01- 019- 028.00 Transmission Shift Cable Adjustment
SM01- 019- 029.00 Automatic Transmission Oil Cooler, R & I
SM01- 019- 030.00 Oil Cooler Fan Motor, R & I (Automatic Transmission)
SM01- 019- 031.00 Oil Cooler Fan Motor, Recondition (Automatic Transmission)
SM01- 019- 034.00 Transmission Shift Control, R & I
SM01- 020- 002.00 Suspended Brake Pedal, Recondition
SM01- 020- 005.00 Suspended Brake Pedal, R & I
SM01- 020- 008.00 Suspended Brake Pedal, R & I
SM01- 020- 011.00 Suspended Brake Pedal Valve, R & I
SM01- 021- 004.00 Auxiliary Transmission, R & I
SM01- 021- 007.00 Auxiliary Transmission, Recondition
SM01- 022- 004.00 U- Joint Installation - Half Round Yokes
SM01- 022- 005.00 U- Joint Installation - Full Round Yokes
SM01- 024- 010.00 Rear Axles, Recondition (Eaton RS460/DS460 Model Series)
SM01- 024- 011.00 Rear Axles, Recondition (Eaton RP460/DP460 Model Series)
SM01- 024- 012.00 Rear Axles, Recondition (Eaton RS450/DS450 Model Series)
SM01- 024- 015.00 Rear Axles, Recondition
SM01- 025- 015.00 Anti- lock Braking System, Troubleshooting (EC- 30)
SM01- 025- 016.00 Anti- lock Braking System, Troubleshooting (ABS EC- 60)
SM01- 027- 000.00 Pneumatic System Air Line Identification Code
SM01- 027- 026.00 Caging Dual Air Brake Chambers
SM01- 027- 028.00 Front Air Brake Chamber, Recondition (Cam Type Brakes)
SM01- 027- 029.00 Rear Dual Air Brake Chamber, Recondition
SM01- 027- 061.00 Spring Brake Valve, Recondition
SM01- 027- 062.00 Air Dryer, R & I
SM01- 027- 063.00 Air Dryer, Recondition
SM01- 027- 088.00 Air System Components, R & I (Generation 1)
SM01- 027- 089.00 Air System Schematic Diagram - Cummins w/Manual Transmission (Gen 1)
SM01- 027- 090.00 Air System Schematic Diagram - Cummins w/Automatic Transmission (Gen 1)
SM01- 027- 091.00 Front Air Brake Chamber, R & I (w/Auto Slack Adjusters)
SM01- 027- 092.00 Rear Dual Air Brake Chamber, R & I (w/Auto Slack Adjusters)
SM01- 027- 112.00 Air System Components, R & I (Generation 2)
SM01- 027- 113.00 Air System Schematic Diagram - Cummins w/Manual Transmission (Gen 2)
SM01- 027- 114.00 Air System Schematic Diagram - Cummins w/Automatic Transmission (Gen 2)
SM01- 027- 115.00 Air System Components, R & I (w/Upper Remote Steering)
SM01- 027- 127.00 Air System Components, R & I
SM01- 027- 129.00 Air System Components, R & I
SM01- 027- 130.00 Air System Components, R & I
SM01- 027- 134.00 Air System Components, R & I
SM01- 027- 139.00 Air System Components, R & I
SM01- 027- 145.00 Air System Components, R & I (HTC- Model)
SM01- 027- 150.00 Air System Components, R & I (Rear Lift Axle)
SM01- 028- 002.00 Rear Wheel Hub & Brake Drum, R & I
SM01- 029- 019.00 Rear Axle & Air Suspension, R & I
SM01- 029- 020.00 Suspension Lift Cylinder, R & I
SM01- 029- 021.00 Suspension Lift Cylinder, Recondition (Generation 1 - Hydraulic Technologies)
SM01- 029- 026.00 Rear Axles And Suspension, R & I
SM01- 029- 027.00 Suspension Lift Cylinder, R & I
SM01- 029- 028.00 Suspension Lift Cylinder, Recondition (Generation 2 - Texas Hydraulics)
SM01- 029- 029.00 Rear Axles And Suspension, R & I
SM01- 029- 031.00 Axle Lift Manifold Illustrated
SM01- 038- 039.00 Outrigger Solenoid Valve Stacks, R & I (Function)
SM01- 039- 002.00 Vacuum Pressure Relief Valve, Recondition
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 039- 004.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 039- 005.00 Hydraulic Reservoir Filter Assembly, Recondition
SM01- 039- 008.00 Hydraulic Reservoir Filter Assembly, R & I
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional/Remote Steering)
SM01- 043- 035.00 Four Way Directional Solenoid Valve, Recondition
SM01- 043- 036.00 Outrigger Directional Control Valve, R & I
SM01- 043- 045.00 Outrigger Directional Control Valve, R & I
SM01- 043- 046.00 Outrigger Function Control Valve, R & I
SM01- 043- 047.00 Fifth Outrigger Directional Control Valve, R & I
SM01- 044- 009.00 Jack Cylinder Lock Valve, Recondition (Bumper Outrigger)
SM01- 044- 018.00 Outrigger Lock Valve Cartridge, R & I
SM01- 044- 019.00 Fifth Outrigger Lock Valve, R & I
SM01- 044- 023.00 Outrigger Lock Valve Cartridge, R & I (5th O.R. Integral)
SM01- 044- 027.00 Outrigger Lock Valve Cartridge, R & I And Recon.
SM01- 045- 014.00 Outrigger Beam Cylinder, Recondition (Gen 1 - Iowa Ind Hyd or Hyd Tech)
SM01- 045- 043.00 Outrigger Beam & Beam Cylinder, R & I
SM01- 045- 050.00 Outrigger Beam Cylinder, Recon.
SM01- 045- 054.00 Outrigger Beam Cylinder, Recondition (Gen 2 - Texas Hydraulics)
SM01- 045- 056.00 Outrigger Beam And Beam Cylinder, R & I
SM01- 046- 034.00 Jack Cylinder, Recondition (Main & Fifth Outrigger)
SM01- 046- 035.00 Jack Cylinder, R & I
SM01- 046- 036.00 Fifth Outrigger Jack Cylinder, R & I
SM01- 046- 044.00 Jack Cylinder, R & I
SM01- 046- 045.00 5th Outrigger Jack Cylinder, R & I
SM01- 047- 011.00 Relief Valve, Recondition
SM01- 047- 029.00 Manifold Block Illustrated
SM01- 047- 030.00 Manifold Block Illustrated
SM01- 047- 034.00 Relief Valve, Recondition
SM01- 047- 035.00 Pick & Carry Manifold Block, Illustrated
SM01- 047- 038.00 Pick & Carry Manifold Block, Illustrated
SM01- 047- 048.00 P & C Manifold Block, Illustrated
SM01- 048- 023.00 Rotating Joint, R & I (Rectangular Collector Ring Cover)
SM01- 048- 026.00 Rotating Joint, Recondition
SM01- 048- 027.00 Rotating Joint, R & I (Round Collector Ring Cover)
SM01- 048- 037.00 Rotating Joint, R & I
SM01- 048- 038.00 Rotating Joint, Recon.
SM01- 050- 007.00 Transmission Oil Cooler, R & I
SM01- 050- 008.00 Transmission Oil Bypass Valve, R & I
SM01- 050- 009.00 Transmission Oil Bypass Valve, Recon.
SM01- 050- 012.00 Oil Cooler Fan Motor, R & I (Hydraulic Oil Cooler)
SM01- 050- 013.00 Hydraulic Oil Cooler, R & I
SM01- 053- 001.00 Remote Steer Motor, R & I
SM01- 053- 002.00 Remote Steer Motor, Recondition
SM01- 053- 003.00 Remote Steer Motor, R & I
SM01- 066- 024.00 Battery, R & I
SM01- 069- 009.00 Tires & Rims, R & I
SM01- 069- 016.00 Tire & Rim Inspection & Maintenance
SM01- 071- 004.00 Repair Of Components Made Of Fibrous Composite Materials
SM01- 071- 007.00 Engine Housing, R & I
SM01- 071- 008.00 Outrigger Lock Valve Cartridge, R & I
SM01- 071- 013.00 Engine Housing, R & I
SM01- 073- 001.00 Electronic Gauge, Troubleshooting (Interlink)
SM01- 073- 002.00 Electronic Gauges, Troubleshooting
SM01- 075- 040.00 Radiator, R & I
SM01- 075- 041.00 Alternator, R & I
SM01- 075- 042.00 Starter, R & I
SM01- 075- 043.00 Radiator Fan Clutch, R & I
Radiator Fan Clutch, Troubleshooting
SM01- 075- 044.00 Radiator Fan Clutch, Recondition
SM01- 076- 025.00 Collector Ring, R & I (Rectangular Cover)
SM01- 076- 028.00 Collector Ring, Recondition (Rectangular Cover)
SM01- 076- 030.00 Collector Ring, Recondition (Round Cover)
SM01- 076- 039.00 Collector Ring, R & I (Round Cover)
SM01- 076- 042.00 Collector Ring, R & I
SM01- 076- 043.00 Collector Ring, Recon.
SM01- 076- 044.00 Collector Ring, Recon.
SM01- 076- 052.00 Collector Ring, Recon (With Air Swivel)
SM01- 076- 053.00 Collector Ring, Recon. (38 Rings W/Air Swivel)
SM01- 076- 056.00 Collector Ring, Recon. (43 Rings W/Air Swivel)
SM01- 076- 059.00 Collector Ring, Recon. (32 Rings)
SM01- 076- 063.00 Collector Ring, Recon. (34 Rings)
SM01- 076- 073.00 Collector Ring, R & I
SM01- 077- 008.00 Starter, R & I (CAT C10/C11)
SM01- 077- 009.00 Alternator, R & I (CAT C10)
SM01- 077- 010.00 Radiator, R & I
SM01- 077- 011.00 Alternator, R & I (CAT C11)
SM01- 077- 012.00 Radiator, R & I
SM01- 077- 023.00 Alternator, R & I
SM01- 077- 036.00 Radiator & Changed Air Cooler, R & I (G2)
SM01- 079- 013.00 Lower Hydraulic Components, R & I
SM01- 079- 035.00 Lower Hydraulic Components, R & I
SM01- 079- 036.00 Lower Hydraulic Components, R & I
SM01- 079- 049.00 Lower Hydraulic Components, R & I (Suction, Pressure, & Return Lines)
SM01- 079- 080.00 Lower Hydraulic Components, R & I (Suction, Pressure, & Return Lines)
SM01- 080- 008.00 Pump Disconnect, Recondition
SM01- 080- 042.00 Pump Disconnect, R & I
SM01- 080- 043.00 Main Hydraulic Pump, R & I
SM01- 081- 014.00 Hydraulic Pump, Recondition (Multi Section Commercial- Intertech)
SM01- 081- 036.00 Radiator Fan Motor, Recon.
SM01- 081- 037.00 Hydraulic Pump, Recon. (Multiple Section Aluminum)
SM01- 081- 038.00 Hydraulic Pump, R & I (Tandem 4 Section)
SM01- 081- 039.00 Hydraulic Pump, R & I (Pick & Carry 2 Section)
SM01- 081- 040.00 Hydraulic Pump, R & I (Tandem 4 Section)
SM01- 081- 041.00 Hydraulic Pump, R & I (Pick & Carry 2 Section)
SM01- 081- 042.00 Radiator Fan Motor, R & I
SM01- 081- 043.00 Radiator Fan Motor, R & I
SM01- 081- 046.00 Hydraulic Gear Pump/Motor, Recon. - Aluminum (Radiator Fan Motor)
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 067.00 Upper Revolving Frame & Turntable Bearing, R & I
SM03- 001- 072.00 Upper Revolving Frame & Turntable Bearting, R & I
SM03- 003- 013.00 Main Counterweight, R & I
SM03- 003- 016.00 Fixed Counterweight, R & I
SM03- 010- 025.00 Counterweight Removal Cylinder, Recon.
SM03- 010- 037.00 Counterweight Removal Cylinder, R & I
SM03- 010- 038.00 Counterweight Removal Control Valve, R & I
AREA 04 VERTICAL SHAFTS
SM04- 005- 022.00 Swing Brake Assembly, Recondition
SM04- 010- 026.00 Swing Reduction Unit, R & I
SM04- 010- 027.00 Swing Speed Reducer, Recondition
SM04- 010- 032.00 Swing Reduction Unit & Brake, R & I
SM04- 010- 033.00 Swing Reduction Unit W/Brake, Recon.
AREA 05 HORIZONTAL SHAFTS
SM05- 006- 018.00 Winch, R & I (Generation 1 - w/Remote Drum Rotation Indicator)
SM05- 006- 019.00 Winch, Recondition
SM05- 006- 020.00 Winch Troubleshooting
SM05- 006- 031.00 Winch, R & I
SM05- 006- 032.00 Winch, R & I (Generation 2 - w/Drum Rotation Indicator Integral to Winch Motor)
SM05- 006- 039.00 Winch Assy, R & I
SM05- 010- 006.00 Drum Rotation Indicator, R & I And Troubleshooting
SM05- 018- 001.00 Winch Roller, Recondition (Steel Roller)
SM05- 018- 004.00 Winch Roller, Recondition (Nylon Roller)
AREA 06 UPPER ENGINE
SM06- 008- 009.00 Throttle Treadle Assembly, R & I
SM06- 008- 010.00 Throttle Treadle Assembly, Recondition
SM06- 025- 004.00 Diesel Cab Heater, R & I (Generation 1)
SM06- 025- 005.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 1)
SM06- 025- 007.00 Hydraulic Cab Heater, R & I
SM06- 025- 008.00 Hydraulic Cab Heater, Recondition
SM06- 025- 009.00 Hydraulic Heater - Troubleshooting
SM06- 025- 017.00 Diesel Cab Heater, R & I (Generation 2)
SM06- 025- 018.00 Diesel Cab Heater, Recondition & Troubleshooting (Generation 2)
SM06- 025- 019.00 Operator’s Cab Water Heater, R & I
SM06- 025- 022.00 A/C Coil And Heater Core, Illustrated
SM06- 025- 023.00 Upper Cab A/C Coil & Heater Core, R & I
SM06- 025- 024.00 Upper Cab Heater Water Swivel, R & I & Recon.
SM06- 025- 026.00 Diesel Coolant Heater, Troubleshooting & Recon.
SM06- 025- 029.00 Diesel Coolant Heater, R & I
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 105.00 Electrical System Schematic Diagram (Generation 1)
SM06- 047- 106.00 Electrical System Schematic Diagram (Generation 2)
SM06- 047- 109.00 Electrical System Schematic Diagram (Generation 3)
SM07- 000- 000.00 Hydraulic Schematic Diagram Symbol Legend
SM07- 000- 127.00 Hydraulic System Schematic Diagram
SM07- 001- 024.00 Pilot Control Accumulator, R & I
SM07- 001- 027.00 Pilot Control Accumulator, R & I
SM07- 002- 032.00 Relief Valve, Recon. (Upper A/C)
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 004- 007.00 Upper Hydraulic Components, R & I
SM07- 004- 009.00 Upper Hydraulic Components, R & I
SM07- 004- 042.00 Upper Hydraulic Components, R & I (Upper Frame)
SM07- 004- 043.00 Upper Hydraulic Components, R & I (Two Winch Plumbing)
SM07- 004- 044.00 Upper Hydraulic Components, R & I (Single Winch Plumbing)
SM07- 004- 047.00 Upper Hydraulic Components, R & I (Single Winch Plumbing With Linde Motor)
SM07- 004- 048.00 Upper Hydraulic Components, R & I (Two Winch Plumbing With Linde Motor)
SM07- 004- 079.00 Upper Hydraulic Components, R & I (Cab Floor)
SM07- 005- 052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07- 005- 061.00 Hydraulic Heater Gear Pump, R & I (Upper w/o A/C)
SM07- 005- 062.00 Hydraulic Heater Gear Pump, R & I (Upper w/Air Conditioning)
SM07- 006- 034.00 Swing Motor, Recondition
SM07- 006- 050.00 Winch Motor, R & I (Generation 1 - w/Remote Drum Rotation Indicator)
SM07- 006- 056.00 Hydraulic Motor, Recondition - Winch (Rexroth 63 Series)
SM07- 006- 059.00 Hydraulic Motor, Recondition (Hydraulic Heater)
SM07- 006- 075.00 Swing Motor & Brake, R & I
SM07- 006- 078.00 Hydraulic Heater Motor, R & I (Upper w/o A/C)
SM07- 006- 083.00 Hydraulic Heater Motor, R & I (Upper w/Air Conditioning)
SM07- 006- 095.00 Winch Motor, Recon. (Linde)
SM07- 006- 098.00 Winch Motor, R & I (Generation 2 - w/Drum Rotation Indicator Integral to Motor)
SM07- 006- 099.00 Swing Motor, R & I
SM07- 008- 014.00 Winch Counterbalance Valve, Recondition
SM07- 008- 032.00 Control Valves, Recon. (Gresen V20)
SM07- 008- 048.00 Foot Control Valve, R & I (Boom Telescope)
SM07- 008- 055.00 Controller Valve Assembly, R & I
SM07- 008- 056.00 Controller Valve Assembly, Recondition (Comm- Intertech)
SM07- 008- 066.00 Control Valve, Recondition (Gresen V40)
SM07- 008- 067.00 Foot Control Valve, Recondition (Boom Telescope)
SM07- 008- 076.00 Single Axis Control Valves, R & I
SM07- 008- 077.00 Single Axis Control Valves, Recondition (Comm- Intertech)
SM07- 008- 081.00 Control Valve, Recondition (Gresen V56)
SM07- 008- 089.00 Upper Hydraulic Components, R & I
SM07- 008- 090.00 Winch Counterbalance Valve, R & I
SM07- 008- 107.00 Controller Valve, Recondition (Monson)
SM07- 008- 108.00 Single Axis Controller Valve, Recondition (Monson)
SM07- 008- 109.00 Telescope/Swing Control Valve, R & I
SM07- 008- 110.00 Boom Hoist Control Valve, R & I
SM07- 008- 111.00 Winch Control Valve, R & I
SM07- 008- 113.00 Boom Telescope Foot Control Valve, R & I
SM07- 008- 114.00 Boom Telescope Foot Control Valve, Recon.
SM07- 008- 115.00 Swing Brake Pedal Valve, R & I
SM07- 008- 116.00 Dual Axis Controller Valve, R & I
SM07- 008- 117.00 Sing Axis Controller Valve, R & I
SM07- 008- 118.00 Swing Brake Pedal Valve, Recon.
SM07- 008- 122.00 Winch Counterbalance Valve, Recon.
SM07- 008- 127.00 Winch Control Valve, Recon.
SM07- 008- 129.00 Hydraulic Control Valves, Recon. (Parker VG20)
SM07- 008- 131.00 Pilot Oil Supply Valve, Recondition
SM07- 008- 158.00 Telescope/Swing Control Valve, R & I
SM07- 008- 159.00 Boom Hoist Control Valve, R & I
SM07- 008- 160.00 Winch Counterbalance Valve, R & I (W/Linde Motor)
SM07- 026- 003.00 Brake Treadle Valve, Recondition (Air)
SM07- 026- 005.00 Brake Treadle Valve, R & I (Remote Steering)
SM07- 026- 013.00 Brake Treadle valve, R & I
SM07- 029- 002.00 Swing Brake Actuator, Recondition
SM07- 029- 004.00 Swing Brake Actuator, R & I
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 14 CAB & HOUSE ASSEMBLY
SM14- 001- 006.00 Repair Of Components Made Of Fibrous Composite Materials
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 001- 047.00 Four Section Boom, Recondition (33’- 105’ Full Power)
SM17- 001- 052.00 Four Section Boom, R & I (33’- 105’ Full Power)
SM17- 001- 055.00 Four Section Boom, Recon. (35.5’- 110’ Full Power)
SM17- 002- 022.00 Boom Telescope Cylinder, Recondition
SM17- 002- 026.00 Boom Telescope Cylinder Troubleshooting
SM17- 002- 027.00 Boom Telescope Counterbalance Valve, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 014.00 Boom Hoist Counterbalance Valve, R & I (Block Mounted)
SM17- 003- 015.00 Boom Hoist Counterbalance Valve, Recondition (Block Mounted)
SM17- 003- 021.00 Boom Hoist Cylinder, R & I
SM17- 003- 034.00 Boom Hoist Cylinder, R & I (w/Integral Counterbalance Valve)
SM17- 003- 035.00 Boom Hoist Counterbalance Valves, R & I (Case Mounted)
SM17- 009- 006.00 Four Sheave Head Machinery, Recondition
AREA 18 SPECIAL ATTACHMENTS
SM18- 000- 003.00 Crane System Schematics
SM18- 007- 003.00 Reeling Drum, R & I
SM18- 007- 004.00 Reeling Drum, Recondition
SM18- 018- 001.00 Air Conditioning Service Precautions
SM18- 018- 002.00 Air Conditioning Hydraulic Drive Motor, R & I (Upper)
SM18- 018- 003.00 Air Conditioning Hydraulic Drive Motor, Recondition (Upper)
SM18- 018- 004.00 Air Conditioning Compressor, Recondition (Carrier & Upper)
SM18- 018- 006.00 Air Conditioning Compressor, R & I (Upper)
SM18- 018- 007.00 Air Conditioning Compressor, R & I (Carrier)
SM18- 018- 012.00 Air Conditioning Compressor, R & I (Carrier)
SM18- 018- 013.00 Air Conditioning Compressor, R & I (Upper)
SM18- 018- 014.00 Air Conditioning Hydraulic Drive Motor, R & I (Upper)
SM18- 018- 015.00 Air Conditioning Hydraulic Drive Motor, Recon.
SM18- 018- 016.00 Air Conditioning Compressor, R & I (Carrier CAT C- 11)
SM18- 018- 017.00 Air Conditioning Compressor, R & I (Carrier)
Brand: Link Belt
