Hyundai
86
176,834
Link Belt Crane HTC-850 Service Manual
Brand: Link Belt
Model: Link Belt HTC-850 Crane
Number of Pages: 1012 Pages
AREA 00 GENERAL INFORMATION
SM00- 000- 000.00 Service Manual General Usage & Instructions
AREA 01 RUBBER TIRE LOWER
SM01- 002- 012.00 Front Axle, Recondition (Eaton EFA Series)
SM01- 002- 013.00 Front Wheel & Brake Drum, R & I
SM01- 003- 010.00 Brakes, Recondition (Eaton EB & ES Type)
SM01- 003- 013.00 Brakes, Recondition (Rockwell “Q” Series)
SM01- 003- 014.00 Adjusting The Brakes (Eaton EB,ES & Rockwell “P,Q,T” Series)
SM01- 005- 003.00 Steering Gear, Recondition (Master)
SM01- 005- 004.00 Steering Gear, Recondition (Slave)
SM01- 005- 006.00 Miter Box, Recondition
SM01- 005- 015.00 Steering Column, Recondition
SM01- 006- 006.00 Steering Gear, R & I
SM01- 006- 007.00 Front Wheel Alignment & Steer Linkage Adjustment
Axle Stop Adjustment
SM01- 010- 007.00 Steer Pump, Recondition
SM01- 018- 026.00 Transmission, Recondition
SM01- 019- 010.00 Transmission Master Control, R & I
SM01- 019- 011.00 Transmission Slave Control, R & I
SM01- 019- 012.00 Transmission Shift Cable Adjustment - Manual
SM01- 019- 014.00 Transmission Air Shift Control, Recondition
SM01- 022- 004.00 U- Joint Installation - Half Round Yokes
SM01- 024- 005.00 Rear- Rear Axle, Recondition (Rockwell RR- 23- 160)
SM01- 024- 009.00 Front- Rear Axle, Recondition (Rockwell RD- 23- 160)
SM01- 024- 010.00 Rear Axles, Recondition (Eaton RS460/DS460 Model Series)
SM01- 025- 008.00 Brakes, Recondition (Rockwell “P,Q & T Series”)
SM01- 027- 009.00 Air Dryer, Recondition
SM01- 027- 010.00 Air Throttle Control Cylinder, Recondition
SM01- 027- 026.00 Caging Dual Air Brake Chambers
SM01- 027- 027.00 Air Brake Chamber, R & I
SM01- 027- 028.00 Front Air Brake Chamber, Recondition
SM01- 027- 029.00 Rear Dual Air Brake Chamber, Recondition
SM01- 027- 033.00 Throttle Pedal, Recondition
SM01- 027- 036.00 Air System Schematic
SM01- 027- 037.00 Air System Schematic - Two- Speed Winch
SM01- 027- 061.00 Spring Brake Valve, Recondition
SM01- 028- 001.00 Rear Wheel & Brake Drum, R & I
SM01- 039- 002.00 Vacuum Pressure Relief Valve, Recondition
SM01- 039- 003.00 Hydraulic System Cleaning Procedure
SM01- 043- 001.00 Solenoid Valves, General Recondition
SM01- 043- 003.00 Outrigger Solenoid Valve Stack, Recondition (Function)
SM01- 043- 004.00 Four Way Solenoid Valve, Recondition (Outrigger Directional)
SM01- 043- 024.00 Throttle Lock Solenoid Valve, Recondition
SM01- 044- 008.00 Jack Cylinder Lock Valve, R & I
SM01- 044- 009.00 Jack Cylinder Lock Valve, Recondition
SM01- 045- 007.00 Outrigger Beam Cylinder, Recondition
SM01- 046- 012.00 Jack Cylinder, Recondition (Main & Fifth Outrigger)
SM01- 046- 015.00 Jack Cylinder, R & I
SM01- 047- 002.00 Flow Divider, Recondition
SM01- 047- 006.00 Relief Valve, Recondition
SM01- 048- 009.00 Rotating Joint, Recondition
SM01- 069- 003.00 Rims & Tires, R & I - Dual Rear
SM01- 069- 004.00 Rim & Tire, R & I - Front
SM01- 075- 027.00 Alternator, R & I (Cummins 6CT8.3C)
SM01- 075- 030.00 Starter, R & I (Cummins 6 CTA 8.3 Engine)
SM01- 076- 007.00 Collector Ring, Recondition
SM01- 076- 013.00 Collector Ring, Recondition
SM01- 080- 014.00 Pump Disconnect, R & I
Jaw Clutch Clearance Adjustment
SM01- 080- 015.00 Pump Disconnect, Recondition
SM01- 081- 010.00 Main Hydraulic Pump With Free- Fall, Recondition
SM01- 081- 011.00 Main Hydraulic Pump Without Free- Fall, Recondition
SM01- 083- 002.00 Pressure Compensating Pump, Recondition
SM01- 085- 002.00 Engine Preheater, R & I
SM01- 085- 004.00 Engine Preheater, Recondition
AREA 03 UPPER REVOLVING FRAME
SM03- 001- 047.00 Upper Frame & Turntable Bearing, R & I
SM03- 003- 005.00 Counterweight, R & I
AREA 04 VERTICAL SHAFTS
SM04- 005- 017.00 Brake Caliper, Recondition
SM04- 010- 010.00 Swing Speed Reducer, Recondition
SM04- 010- 011.00 Swing Speed Reducer, R & I
360 Degree Swing Lock Adjustment
Swing Brake Adjustment
AREA 05 HORIZONTAL SHAFTS
SM05- 004- 008.00 Hoist Drum & Shaft Without Free- Fall, R & I
SM05- 004- 011.00 Hoist Motor, Brake & Planetary, R & I (Air Shift Two- Speed Valve)
SM05- 004- 012.00 Hoist Drum & Shaft With Free- Fall, R & I
SM05- 004- 014.00 New Style Hoist Brake Retrofit
SM05- 006- 008.00 Hoist Motor, Brake & Planetary, R & I (Hydraulic Shift Two Speed Valve)
SM05- 006- 009.00 Winch Drum & Shaft Without Free- Fall, R & I
SM05- 006- 010.00 Winch Drum & Shaft With Free- Fall, R & I
SM05- 009- 016.00 Free- Fall Hoist Rotating Joint, R & I
Free- Fall Hoist Rotating Joint, Recondition
SM05- 009- 017.00 Free- Fall Hoist Clutch Cylinder, Recondition
SM05- 009- 018.00 Free- Fall Hoist Clutch Cylinder, R & I
SM05- 009- 019.00 Free- Fall Hoist Clutch Shoes, R & I
Clutch Lining Burn In Procedure
SM05- 009- 020.00 Free- Fall Hoist Clutch Shoe Adjustment
SM05- 009- 021.00 Free- Fall Hoist Clutch Shoes, Recondition
SM05- 009- 022.00 Free- Fall System Test Procedure
SM05- 012- 033.00 Automatic Hoist Brake, Recondition
SM05- 012- 035.00 Free- Fall Hoist Brake Cylinder, Recondition
SM05- 012- 036.00 Free- Fall Hoist Band Brake, R & I
Brake Lining “Burn In” Procedure
SM05- 012- 037.00 Free- Fall Hoist Band Brake Adjustment
SM05- 012- 038.00 Free- Fall Hoist Brake Cylinder, R & I
Brake Actuator Spring, R & I
SM05- 012- 039.00 Free- Fall Hoist Brake Bands, Recondition
AREA 06 UPPER ENGINE
SM06- 008- 004.00 Treadle Valve, Recondition
SM06- 024- 023.00 Audio/Visual Warning System Calibration
SM06- 025- 002.00 Diesel Cab Heater, Recondition
SM06- 025- 003.00 Propane Heater, Recondition
SM06- 025- 007.00 Hydraulic Cab Heater, R & I
SM06- 025- 008.00 Hydraulic Cab Heater, Recondition
SM06- 025- 009.00 Hydraulic Heater - Troubleshooting
SM06- 047- 000.00 Electrical System Wire Identification Code
SM06- 047- 043.00 Electrical Schematic
SM07- 000- 085.00 Hydraulic System Schematic Diagram
SM07- 001- 019.00 Free- Fall Accumulator, R & I
Charging The Accumulator
SM07- 002- 028.00 Relief Valve, Recondition (Hydraulic Heater)
SM07- 003- 006.00 Solenoid Valves, General Recondition
SM07- 005- 051.00 Hydraulic Heater Gear Pump, R & I
SM07- 005- 052.00 Hydraulic Gear Pump Assembly, Recondition (Hydraulic Heater)
SM07- 006- 010.00 Two- Speed Hoist Valve, R & I (Air Shift)
SM07- 006- 011.00 Hoist Motor, Recondition (w/Separate Two- Speed Valve)
SM07- 006- 014.00 Hoist Counterbalance Valve, R & I (w/Air Shift Two- Speed)
SM07- 006- 034.00 Swing Motor, Recondition
SM07- 006- 040.00 Hoist Motor, Recondition (w/Integral Two- Speed Valve)
SM07- 006- 061.00 Hydraulic Motor, Recondition (Hydraulic Heater)
SM07- 008- 012.00 Control Valves, Recondition (Gresen V42)
SM07- 008- 014.00 Winch Counterbalance Valve, Recondition (w/Hydraulic Shift Two- Speed)
SM07- 008- 022.00 Free- Fall Press Sequence Valve, Recondition
SM07- 008- 023.00 Control Valves, Recondition (Gresen V70)
SM07- 008- 024.00 Hoist Counterbalance Valve, Recondition (w/Air Shift Two- Speed)
SM07- 008- 026.00 Two- Speed Hoist Valve, Recondition (Air Shift)
SM07- 008- 030.00 Free- Fall Pressure Sequence Valve, R & I
SM07- 008- 080.00 Winch Counterbalance Valve, R & I (w/Hydraulic Shift Two- Speed)
SM09- 001- 002.00 Repairing Damaged Tubular Booms, Flys, & Jibs
AREA 17 HYDRAULIC CRANE ATTACHMENT
SM17- 001- 014.00 Boom, R & I
SM17- 001- 015.00 Four Section Boom, Recondition
Manual Section Only, R & I
Manual Section & Bottom Cylinder, R & I
Retrieval Bracket Adjustment
Hose Wheel Hose Replacement
Hose Wheel Cable Replacement
SM17- 001- 036.00 Hydraulic Boom Inspection
SM17- 002- 009.00 Telescope Counterbalance Valve, Recondition
SM17- 002- 014.00 Boom Telescope Cylinder, Recondition
SM17- 002- 025.00 Boom Telescope Cylinder, Recondition
SM17- 003- 010.00 Boom Hoist Cylinders, R & I
SM17- 003- 013.00 Boom Hoist Cylinder, Recondition
SM17- 003- 015.00 Boom Hoist Counterbalance Valve, Recondition
SM17- 003- 016.00 Boom Hoist Counterbalance Valve, R & I
AREA 18 SPECIAL ATTACHMENTS
SM18- 001- 009.00 Boom Length/Angle Indicator Adjustment (Generation 1)
SM18- 001- 011.00 Boom Angle Indicator Adjustment
SM18- 001- 012.00 Boom Length/Angle Indicator Adjustment (Generation 2)
SM18- 007- 001.00 Reeling Drum, R & I
SM18- 007- 002.00 Reeling Drum, Recondition
SM18- 018- 001.00 Air Conditioning Service Instructions
