118
6,911
Linde Pallet Stacker Series 172 L14 L16 L14AP L16AP Service Training 3728042401
Brand: Linde
Type of Machine: Pallet Stacker
Type of Manual: Service Training, Wiring Diagram
Model: Linde Series 172 L14 ; L16 ; L14AP ; L16AP Pallet Stacker
Part Number: 3728042401
Number of Pages: 214 Pages
Drive motor
Technical Data
Description of L14 - L16 motor (1.2 Kw)
Brushes warning lamp (motor 1.2 Kw)
Description of L14AP - L16AP motor (1.5 Kw)
Gearbox
Technical Data
Description
Steering and wheels
Steering L141 L16 (up to serial number 372M 02999)
Steering L141 L16 (from serial number 372M 03000)
Power steering motor (up to serial number 372 L 01002)
Power steering motor (starting from number 372 L 01003)
Drive wheels
Stabiliser wheels L14 - L16
Stabiliser wheel of L14AP - L16AP
Adjustment of the stabiliser wheel height
Load wheels
Operation and brake controls
Tiller articulation
Electrical equipment
Truck operation L14 - L16 without platform
L14 - L16: Status of LDC speed control inputs
L141 L16: LDC speed control adjustments (eprom 1.5)
Location of contactor panel components (up to 372 M 02999)
Location of contactor panel components (starting from 372 M 03000)
Truck operation L14AP- L16AP with platform
L14AP - L16AP: Status of LDC speed control inputs
L14AP / L16AP: LDC speed control adjustments (eprom 1.5)
Location of the platform components
Presenting the LDC speed control
Description of the LDC. (Linde Digital Controller) speed control
Logic circuit feed 1A1
Direction contactors hoist
Tiller in steering position - max. LDC pulses -
Impulse control
Accelerator potentiometer
Speed sensor L14 - L16
Double speed sensors for L14AP - L16AP
Speed controls and adjustments
Security control, back of tiller
Security controls
Speed control temperature controls
Power circuit
Electric braking by reversing the direction of motion
Braking |.b.c
Motor current controls
Current adjustments
Using control units for LDC speed control (eprom 1.5)
Troubleshooting explanations with the LINDE test module box or PC
Electromagnetic brake Y1
Operation
L14 - L16: Electrical steering L.E.S
Description
Steering operation
L14AP - L16AP: Electrical steering LES
Steering description
Steering operation
LES switch unit
The tiller control
The motor—reducer
Adjustment of electrical steering
Pre-setting the potentiometers before assembly
Adjustment procedure
Using control units for L.E.S speed controls
Troubleshooting with the test module unit or PC
List of fault codes and servicing
LSL progressive distribution and initial lift control (up to 372 M 02999)
Description
Hydraulic diagram
L.S.L distribution operation principle
Form height detection
L.S.L card feed
Safety during operation
LLC progressive distribution and initial lift control (starting from 372 M 03000)
Description
Inputs / outputs of LLC controller
Logic circuit feed 2A3
2K11 steering
High lifting pulse control
Initial lift pulse control
Initial lift stop
Action on the tiller back safety
Oil tank level
Contactor 2k11 of motor-pump group
Using control units for LLC speed control
Adjustment of the lift potentiometer
High lifting hoist phases
Hoist flap in neutral position
Pump motor contactor hoist 2K11
Pulse start (minimum speed)
Maximum pulses (maximum speed)
Fork arm carriage stabilisation (contactor fall-back 2K11)
Opening of lowering valve 2Y2
Start of 2Y3 control (low lowering speed)
End of 2Y3 control (high lowering speed)
Reduction in low fork lowering speed
Closing 2Y2 (stop lowering)
Access to LLC proportional lifting controls
IES inbuilt charger CHARIS HF II 24HF 30 (starting from 07/2000)
General information
General conditions for use
Charger electrical data
Load curve
Charger signalling
Guards and safeties
List of faults
Electrical diagrams
L14 - L16 (with LSL and without Ll) up to number 372 M 02999
L14 - L16 (without LSL and without Ll) up to number 372 M 02999
L14 - L16 (with LSL and with Li) up to number 372 M 02999
L14 - L16 (without LSL and with Li) up to number 372 M 02999
L14 - L16 (without LLC and without Ll) starting from number 372 M 03000
L14 - L16 (without LLC and with Li) starting from number 372 M 03000
L14 - L16 (with LLC and without Ll) starting from number 372 M 03000
L14 - L16 (with LLC and with LI) starting from number 372 M 03000
L14AP - L16AP (with LLC and without Ll)
L14AP - L16AP (with LLC and with Li)
Hydraulic unit
L14 - L16 hydraulic unit up to truck no. 372 M 02999
"High lift" pump motor
"Initial lift" pump motor
Control valves
Hydraulic drawing (Isl distribution + initial lift)
Hydraulic drawing (option: traditional distribution with lever)
Pump motor group for L14/L16 with or without booster
Pump motor group for L14l/L16I with or without booster
Operation of the vacuum lift speed amplification (Option: booster)
L14 - L161 L14AP - L16AP hydraulic unit (starting from 372 M 03000)
L14 - L161 L14AP - L16AP hydraulic drawing (starting from 372 M 03000)
LLC (Linde Load Control) distribution component
