118
6,911
Linde IC-Engined Truck Series 354 H100 H120 H136 H140 H150 H160 Service Training 3548044601
Brand: Linde
Type of Machine: IC-Engined Truck
Type of Manual: Service Training, Hydraulic Circuit Diagram, Electrical Circuit Diagram
Model: Linde Series 354 H100 ; H120 ; H136 ; H140 ; H150 ; H160 IC-Engined Truck
Engine:
Perkins 1006.6 E NA (Naturally Aspirated) Engine
Perkins 1006.6 TE (Turbocharged) Engine
Part Number: 3548044601
Number of Pages: 227 Pages
1.1 Diesel Engine To 11197
1.1.3 Explanation Of The Engine Number
1.1.4 Adjusting The Valve Clearance
1.1.8 Removing And Installing The Fuel Injection Pump
1.1.8.2 Mechanical Cold Start Timing Advance Unit (Ksb)
1.2 Diesel Engine H 1001120114011501160
1.2.1 Engine Specifications
1.2.6 Installing The Intake Manifold
1.2.8 Engine Timing And Tightening Torques
1.2.9.2 Removing And Installing The Injection Nozzle Clamping Nut Type...
1.2.10 Removing And Installing The Fuel Injection Pump, Pin Type
1.2.11 Mechanical Cold Start Timing Advance Unit (Ksb)
2 Hydrodynamic Transmission And Drive Axle
2.1 Hydrodynamic Travel Drive
2.2 Full View Of Power Shift Transmission 18000 And 20000 Series
2.3.4 Pressure Check Points On Power Shift Transmission
2.3.5 Inspection And Replacement Of Components.
4 Series 310 Steering Axle
4.3 Installing And Adjusting The Swivel Pin
4.7 Removing And Installing The Steering Cylinder
4.8 Hydraulic Steering Unit
5. Air Braking System
5.1 Air Braking System Circuit Diagram
5.2 Description Of The Air Braking System
5.3 Designation Of Ports On Air Brake Equipment Acc. To Din 74 254
5.5 Pressure Relief Valve
4.5.6.11 Unloader Valve Assembly
5.7 Single Check Valve
5.9 Low Air Warning Switch
5.10 Changeover Valve
5.15 Pneumatic Servo Valves (Pilot Valves) To 04196
5.15.1 Ergonomic Andle Valve (Joystick) From 05196
6 Electrical System
6.1 Electric Circuit Wiring Diagram Up To 4196
6.2 Electric Circuit Wiring Diagram From 5196 To 01101
6.3 Electric Circuit Wiring Diagram From 01101 Including Changes At 11101
6.3 Relay And Fuse Box With Cable Connections To 01101
6.3.1 Relay And Fuse Box With Cable Connections From 01101
6.4 Electronic Gearchange System
6.5 Joystick Control, From 05196
Circuit Diagram H 1001120113611501160, Type 354, To 4196
7.1 Hydraulic Circuit Diagrams
7.2 Supply And Return Line Layout
7.3 Line Layout For Working Hydraulics - Control Valves - Tandem Pump
7.4 Hydraulic Tandem Pump
7.5 Load Sensing Valve - Priority Valve
7.6 Hydraulic Control Valves
7.9 Anti-Stall Cylinder - To 09199
7.11 Safe Lowering Valve
7.12 Pressure Relief Valve Settings - Working Hydraulics
8.2 Auxiliary Hydraulics Line Layout
8.3 Mast Type 171, 172 To 01101
Fitted With Universal Carriage With Roller Mounted Fork Carriers And
8.4 Mast Unit Adjustment
9 Options And Accessories.
9.1 Climate Control - Operation
9.1.2 Servicing And Troubleshootlng
9.1.3 Component Replacement
9.4 Data Logger - Davis Derby Type
9.4.1 Data Logger— Davis Derby Type, Description And Function
9.4.4 Installation Procedure.
9.4.5 Installation Of The Trucklog Datalogger Ev 16 System
9.4.6 Installation Procedure.
9.4.8 Using The Psion Workabout
9.7 Load Weighing System
10.1 354 Series Differentiating Characteristics
10.2 General Torques For Series 354 Trucks
