118
6,911
Linde IC Engined Forklift Series 353 H50D To H80T-03 Service Training 3538042401
Brand: Linde
Type of Machine: IC Engined Forklift
Type of Manual: Service Training, Hydraulic Circuit Diagram, Electrical Circuit Diagram
Model: Linde Series 353 IC Engined Forklift
H50D ; H60D ; H70D ; H80D ; H50T ; H60T ; H70T ; H80T
H50D-02 ; H60D-02 ; H70D-02 ; H80D-02 ; H50T-02 ; H60T-02
H70T-02 ; H80T-02 ; H50D-03 ; H60D-03 ; H70D-03 ; H80D-03
H50T-03 ; H60T-03 ; H70T-03 ; H80T-03
Engine: Deutz BF6M 1012 E Engine
Part Number: 3538042401
Number of Pages: 282 Pages
4 lC-engined fork truck H 50160170180, Type 353
4.1 Engine drive
4.1.1 Engine model BF6M 1012 E
4.1.1.1 Engine specifications
4.1.1.1.1 Explanation of the engine number
4.1.1.2 Changing and tightening the drivebelt
4.1.1.3 Adjusting valve clearance
4.1.1.4 Adjusting the injection valve
4.1.1.5 Checking the compression pressure
4.1.1.6 Cylinder head
4.1.1.7 Adjusting the begin of delivery
4.1.8 Special tools
4.1.2 Engine model BF6M 2012
4.1.2.1 Overview of engine components
4.1.2.2 Engine specifications
4.1.2.2.1 Explanation of the engine number
4.1.2.3 Replacement of V-ripped belt
4.1.2.4 Adjusting valve clearance
4.1.2.5 Checking and adjusting leak-fuel-free injection nozzles
4.1.2.6 Thermostat
4.1.2.7 Checking the compression pressure
4.1.2.8 Cylinder head
4.1.2.9 Injection pump
4.1.2.9.1 Adjusting the begin of delivery
4.1.2.9.2 Replacement of the injection pump
4.1.2.10 Heater flange
4.1.2.11 Special tools
4.2 Transmission
4.2.1 Hydrostatic transmission
4.2.1.1 Schematic diagram of the drive
4.2.1.2 Transmission specifications
4.2.1.3 Hydraulic circuit diagram
4.2.2 Operation of the hydrostatic transmission
4.2.2.1 Travel control unit P
4.1 Engine drive
4.1.8 Special tools
4.1.2.6 Thermostat
4.2 Transmission
4.3 Chassis
4.3.1 Overhead guard - torsion mounting
4.3.1.1 Work on the overhead guard
4.4 Steering system
4.4.1 Power steering circuit diagram
4.4.2 Series 304 steering axle
4.4.2.1 Description
4.4.3 Steering axle removal
4.4.3.1 Steering axle installation
4.4.4 Steering axle repairs
4.4.4.1 Renewing the wheel bearings
4.4.4.2 Steering knuckle removal and installation
4.4.4.3 Steering cylinder removal and installation
4.4.4.4 Replacing the steering cylinder seals
4.4.4.5 Steering stop adjustment
4.5 Controls
4.5.1 Accelerator and brake pedal adjustment
4.5.2 Speed control
4.5.2.1 Speed control up to 10195
4.5.2.2 Speed control from 11195
4.5.3 Medium wheel speed
4.5.4 Start of drive wheel rotation
4.5.5 Brake shaft stop screws
4.5.6 Symmetry of the travel control
4.5.6.1 Drive wheel start of rotation
4.5.6.2 Engine speed increase
4.5.7 Pressure difference Ap
4.5.8 Modification of engine acceleration
4.6 Electrical system
4.6.1 Wiring diagram
4.6.2 Wiring diagram for options
4.6.3 Wiring diagram, 353 -02
4.6.4 Wiring diagram for options, 353 -02
4.6.5 Wiring diagram, 353 -03 Diesel
4.6.6 Wiring diagram for options, 353 -03
4.3 Chassis
4.4 Steering system
4.4.2.1 Description
4.5 Controls
4.5.2 Speed control
4.9.3 Propellant gas system
4.9.3.1 Diagram
4.9.3.2 Functional description of the propellant gas system
4.9.4 Inspections and adjustments
4.9.4.1 Ignition system
4.9.4.2 Installation of the engine speed control system
4.9.4.3 Inspection of the engine speed control system
4.9.4.4 Adjustment of the propellant gas mixers
