118
6,911
Linde IC-Engined Forklift Series 351 H20T-02 H25T-02 Service Training 3518042411
Brand: Linde
Type of Machine: IC-Engined Forklift
Type of Manual: Service Training, Hydraulic Circuit Diagram
Model: Linde Series 351 H20T-02 ; H25T-02 IC-Engined Forklift
Engine: Renault F3R 262 Engine
Part Number: 3518042411
Number of Pages: 70 Pages
2.8 Icvengined trucks H 20/35 T—02, type 351
2.8.1 Engine
2.8.1.1 Engine specifications
2.8.1.2 Explanation of engine serial number
2.8.1.3 Valve clearance check and adjustment
2.8.1.3.1 Shim renewal
2.8.1.4 Engine timing
2.8.1.5 Toothed belt removal and installation
2.8.1.5.1 Removal
2.8.1.5.2 Installation
2.8.1.6 Timing gear renewal
2.8.1.6.1 Camshaft sprocket
2.8.1.6.2 Intermediate shaft sprocket
2.8.1.6.3 Crankshaft sprocket
2.8.1.7 Cylinder head
2.8.1.7.1 Removal
2.8.1.7.2 Cleaning
2.8.1.7.3 Sealing face check
2.8.1.7.4 Cylinder head installation
2.8.1.7.5 Tightening the cylinder head bolts
2.8.1.8 Radial seal removal
2.8.1.8.1 Camshaft seals
2.8.1.8.2 Crankshaft seals
2.8.1.8.3 Intermediate shaft seal
2.8.1.9 Electronic ignition system
2.8.1.9.1 Description
2.8.1.9.2 Method of operation
2.8.1.9.3 Functional schematic
2.8.1.9.4 Electronic control unit
2.8.1.9.5 Ignition characteristic map
2.8.1.9.6 Ignition distrfiiutor
2.8.1.9.7 Ignition cables and spark plugs
2.8.1.9.8 Ignition point
2.8.1.9.9 Troubleshooting
2.8.1.10 Special tools
2.8.2 Hydrostatic travel drive
2.8.2.1 Schematic diagram of drive unit
2.8.2.2 Specifications for compact axle type AK 30-01
2.8.2.3 Hydraulic circuit diagram
2.8.2.4 Hydraulic remote control
2.8.3 Circuit diagram
2.8.4 LPG system
2.8.4.1 Schematic
2.8.4.2 Types of operation
2.8.4.3 Operation of vaporiser
2.8.4.4 Operation of mixer
2.8.4.5 LPG Mixer
2.8.5 Electronic speed control
2.8.5.1 Checks and adjustments
2.8.5.1.1 Speed adjustment
2.8.5.1.2 Desired value sender
2.8.5.1.3 Actual value sender
2.8.5.2 Troubleshooting
2.8.5.2.1 Electronic speed control
