Momed80
103
26,941
Linde Forklift Series 394-02 H40D-02 H45D-02 H50D-02 Operators Manual 3948011501EN
Brand: Linde
Type of Machine: Forklift
Model: Linde Series 394-02 H40D-02, H45D-02, H50D-02 Forklift
Part Number: 3948011501EN
Publication Date: 2013
Number of Pages: 274 Pages
Introduction
Your Forklift Truck
Intended Use
Impermissible Use
Description Of Use And Climatic Conditions
Symbols Used
Technical Description
Truck Operation When Using A Shovel
Receiving The Industrial Truck
Legal Requirements For Placing On The Market
Safety
Safety Guidelines
Residual Risks
Stability
In The Case Of Tip-Over
Handling Consumables
Competent Person
Regulations
Fit Attachments
Fork Carriage Emergency Lowering
Emergency Exit With Attached Rear Window
Overview
Identification Plates
Truck Overview
Operating Devices
Display Unit
Switch Panel
Operation
Service Plan Before Initial Commissioning
Running-In Instructions
Pre-Shift Checks
Standard Equipment
Special Equipment
Working With A Load
Before Exiting The Truck
Loading/Transporting
Maintenance
Inspection And Maintenance Data
Recommendations For Consumables
Inspection And Maintenance Overview
Gearbox
Chassis, Bodywork And Fittings
Chassis Frame
Operating Devices
Electrics
Hydraulics
Load Lift System
Self-Help
Shutting Down
Technical Data
Overview Of Dimensions
Type Sheet H40d-02, As At 01/2013
H45d-02 Type Sheet, As At 01/2013
Type Sheet H50d-02/500, As At 01/2013
Type Sheet H50d-02/600, As At 01/2013
H40d-02 Elevated Driver's Compartment Type Sheet, As At 01/2013
H45d-02 Elevated Driver's Compartment Type Sheet, As At 01/2013
H50d-02/500 Elevated Driver's Compartment Type Sheet, As At 01/2013
H40d-02 Container Type Sheet, As At 01/2013
H45d-02 Container Type Sheet, As At 01/2013
H50d-02/500 Container Type Sheet, As At 01/2013
H50d-02/600 Container Type Sheet, As At 01/2013
Lift Mast Data Type 189
Truck Configuration
Tyre Variants And Rim Sizes
Load Capacity Diagrams
Additional Capacity Rating Plate For Attachments
Noise Emission Values
Vibration Characteristic Values For Bodily Vibrations
Index
