118
6,911
Linde Forklift H391-01 H14D to H20T Electrical Hydraulic Diagrams 391807601 2015
Brand: Linde
Type of Machine: Forklift
Type of Manual: Electrical Diagrams, Hydraulic Diagrams
Model: Linde Series H391-01 Forklift
391-H14D-01 391-H14T-01 391-H16CNG-01 391-H16D-01 391-H16T-01 391-H18CNG-01 391-H18D-01 391-H18T-01 391-H20CNG-01 391-H20D-01 391-H20T-01
Serial Number: 1006
Part Number: 3918076701
Publication Date: 2015
Number of Pages: 827 Pages
4 Circuit Diagrams From 05/2010 (H2x391a00761) To 03/2015 (H2x391f00881)
4.1 Wiring Diagram
CNG Basic Equipment Sheet 1
CNG Basic Equipment Sheet 2
CNG Basic Equipment Sheet 3
Special Equipment Sheet 01 − Working Spotlights, Interior Lighting/Clipboard Lighting
Special Equipment Sheet 02 – Wipers, Seat Heater
Special Equipment Sheet 03 − Heating System, Air Conditioning, Flashing Beacon/Rotating Beacon/Bluespot, Reversing Signal, 12 V Socket
Special Equipment Sheet 04 − Hazard Warning System For Reverse Travel, Truck Deactivation, Lift Mast Positioning
Special Equipment Sheet 05 − Particle Filter, Radio
Special Equipment Sheet 06 – Higher Lighting, Hydraulic Oil Microfilter Indicator, Diesel Filter Water Trap Warning
Special Equipment Sheet 07 − Truck Data Management, Lpg Volume Display, Oil Level Monitoring, Coolant Level Monitoring
Special Equipment Sheet 08 − Third Auxiliary Hydraulics, Exchangeable Particle Filter, Working Spotlights Positions 5, 6
Special Equipment Sheet 09 − Camera System, Centre Rear Brake Light/Tail Light, Rear Window Heating
Special Equipment Sheet 10 – Single Lever Locked, Third Auxiliary Hydraulics Via Switch
Special Equipment Sheet 11 − Lighting, Turn Indicator And Hazard Warning System, Brake Light
4.2 Hydraulic Circuit Diagram
Traction, Working And Steering Hydraulics
3 Circuit Diagrams From 12/2009 (H2x391z02117) To 04/2010 (H2x391a00760)
3.1 Wiring Diagram
Special Equipment Sheet 1 − Working Spotlights, Lighting, Turn Indicator System, Brake Light, Interior Lighting
Special Equipment Sheet 2 – Wipers, Seat Heater
Special Equipment Sheet 3 − Heating System, Air Conditioning, Rotating Beacon, Reversing Signal, 12 V Socket
Special Equipment Sheet 4 − Hazard Warning System For Reverse Travel, Truck Deactivation, Lift Mast Positioning
Special Equipment Sheet 5 − Particulate Filter, Radio
Special Equipment Sheet 6 − Higher Lighting, Hydraulic Oil Microfilter Indicator, Diesel Filter Water Trap Warning
Special Equipment Sheet 7 − Truck Data Management, Lpg Volume Display, Oil Level Monitoring, Coolant Level Monitoring
Special Equipment Sheet 8 − Third Auxiliary Hydraulics, Changing Particle Filter, Working Spotlights Positions 5, 6
Special Equipment Sheet 9 – Camera System, Centre Rear Brake Light/Tail Light, Rear Window Heating
3.2 Hydraulic Circuit Diagram
2 Circuit Diagrams From 06/2009 (H2x391z01260) To 11/2009 (H2x391z02116)
2.1 Wiring Diagram
Special Equipment Sheet 6 − Higher Lighting, Hydraulic Oil Microfilter Indicator, Diesel Filter Water Trap Warningspecial Equipment Sheet 7 − Truck Data Management, Lpg Volume Display, Oil Level Monitoring, Coolant Level Monitoring
2.2 Hydraulic Circuit Diagram
1 Circuit Diagrams From 05/2008 (H2x391w01603) To 05/2009 (H2x391z01259)
1.1 Wiring Diagram
Special Equipment Sheet 2 − Windscreen Wipers, Seat Heater
Special Equipment Sheet 9 − Camera System, Centre Rear Brake Light/Tail Light, Rear Window Heating, CNG Volume Display And Tank ShutOff Valve
1.2 Hydraulic Circuit Diagram
