118
6,911
Linde Forklift E386-02 E12 to E20 Electrical Hydraulic Diagrams 3868013601 2019
Brand: Linde
Type of Machine: Forklift
Type of Manual: Electrical Diagrams, Hydraulic Diagrams
Model: Linde E386-02 E12-02, E14-02, E15-02, E16-02, E18-02, E20-02 Forklift
Serial Number: 0214
Part Number: 3868013601
Publication Date: 2019
Number of Pages: 199 Pages
5 Circuit Diagrams From 01/2019
5.1 Wiring Diagram
Basic Equipment, Sheet 01
Basic Equipment, Sheet 02
Basic Equipment, Sheet 03
Basic Equipment, Sheet 04
Special Equipment, Sheet 01 − Voltage Transformer/Heating System
Special Equipment, Sheet 02 − Screen Heating For Front Windscreen Wiper/Rear Window Wiper/Roof Panel Wiper
Special Equipment, Sheet 03 − Voltage Transformer/Socket/Radio/Seat Heater
Special Equipment, Sheet 04 − Standard/Higher Lighting
Special Equipment, Sheet 05 − Working Spotlights/Rotating Beacon/Flashing Beacon/Bluespot
Special Equipment, Sheet 06 − Hazard Warning Lights For Reverse Travel
Special Equipment, Sheet 07 – Battery Carrier
Special Equipment, Sheet 08 − Seat Belt Buckle Monitoring System/Camera System
Special Equipment, Sheet 09 – Depressurisation/Mast Positioning/Third Auxiliary Hydraulics With Third Joystick
Special Equipment, Sheet 10 — Battery Recognition/LithiumIon Battery/Radio Transmission Unit (Cdx10) For Operating Hours And Error Codes/Cdx
20 Connection With Deviation Permission/Hoop Guard/Reduction In Driving Speed Via A Radar Sensor (Speedassist)
Special Equipment, Sheet 11 – Integrated Charger 24 V/100 A // 48 V/65 A
Special Equipment, Sheet 12 – Battery Charging Via The Rear
Special Equipment, Sheet 13 — Cdx20 Connection Unit With Deviation Permission/Access System Connect: (LFM)/Radio Transmission (Cdx20) For
Special Equipment, Sheet 14 – Assistance System Linde Safety Pilot (Lsp) & LoadDependant Assistance System (Load Weight Indicator "Plus")
Special Equipment, Sheet 15 — Interface For Additional Systems (LFI)/External Management System
Special Equipment, Sheet 16 − Voltage Transformer With Delayed SwitchOn For LithiumIon Trucks
Special Equipment, Sheet 17 − Led Light Stripe
Special Equipment, Sheet 18 – 48V/120A Integrated Charger
Special Equipment, Sheet 19 — Reducing The Driving Speed Via Linde Safety Guard
Special Equipment Sheet 20 − 48V/170A Integrated Charger For LithiumIon Battery
Special Equipment Sheet 21 − 48V/170A Integrated Charger For LeadAcid Battery
5.2 Hydraulic Circuit Diagram
4 Circuit Diagrams From 12/2017 To 12/2018
4.1 Wiring Diagram
Special Equipment, Sheet 09 – Depressurisation/Mast Positioning/Third Auxiliary Hydraulics With Third Joystickspecial Equipment, Sheet 10 – Battery Recognition/LithiumIon Battery/Radio Transmission Unit (Cdx10) For Operating Hours And Error
Codes/Reduction In Driving Speed Via A Radar Sensor (Speedassist)
Special Equipment, Sheet 13 – Access System Connect: (LFM)/Radio Transmission (Cdx20) For Operating Hours And Error Codes
Special Equipment, Sheet 15 – Interface For Additional Systems (LFI)
4.2 Hydraulic Circuit Diagram
3 Circuit Diagrams From 08/2016 To 11/2017
3.1 Wiring Diagram
Special Equipment Sheet 01 − Voltage Transformer/Heating System
Special Equipment Sheet 02 − Screen Heating, Rear Window Wiper/Front Windscreen Wiper/Roof Panel Wiper
Special Equipment, Sheet 05 − Working Spotlight/Rotating Beacon/Flashing Beacon/Bluespot/Switchable Reversing Signal
Special Equipment, Sheet 09 − Depressurisation / Mast Positioning / 3rd Auxiliary Hydraulics
Special Equipment, Sheet 10 − LithiumIon Battery/Hour Meter
Special Equipment, Sheet 11 − Integrated Charger
Special Equipment, Sheet 12 − Battery Charging At The Rear
Special Equipment, Sheet 13 − LFM (Fde + Load Sensor + Gprs Unit)
Special Equipment, Sheet 14 − Axle Load Sensor/Load Pressure Sensor/Lift Height Sensor/Rotary Push Button/Lti Display
Special Equipment, Sheet 15 − LFI (Linde Functional Interface)
3.2 Hydraulic Circuit Diagram
2 Circuit Diagrams From 01/2016 To 07/2016
2.1 Wiring Diagram
Special Equipment, Sheet 09 − Depressurisation/Mast Positioning/3rd Auxiliary Hydraulics
Special Equipment, Sheet 11 − Integrated Chargerspecial Equipment, Sheet 12 − Battery Charging At The Rear
2.2 Hydraulic Circuit Diagram
Hydraulic Circuit Diagram For Basic Truck
1 Circuit Diagrams From 10/2013 To 12/2015
1.1 Wiring Diagram
Basic Equipment Sheet 01
Basic Equipment Sheet 02
Basic Equipment Sheet 03
Basic Equipment Sheet 04
Special Equipment Sheet 03 − Voltage Transformer/Socket/Radio/Seat Heater
Special Equipment Sheet 04 − Standard/Higher Lighting
Special Equipment Sheet 05 − Working Spotlight/Rotating Beacon/Flashing Beacon/Bluespot/Switchable Reversing Signal
Special Equipment Sheet 06 − Hazard Warning Lights For Reverse Travel
Special Equipment Sheet 07 − Battery Carrier
Special Equipment Sheet 08 – Seat Belt Buckle Monitoring System/Camera System
Special Equipment Sheet 09 Depressurisation/Mast Positioning/3rd Auxiliary Hydraulics
Special Equipment Sheet 11 − Integrated Charger
Special Equipment Sheet 12 − Rear Battery Charger
Special Equipment Sheet 13 − LFM (Fde + Load Sensor + Gprs Unit)
Special Equipment Sheet 14 − Axle Load Sensor/Load Pressure Sensor/Lift Height Sensor/Rotary Push Button/Lsp Display
Special Equipment Sheet 15 − LFI (Linde Functional Interface)
1.2 Hydraulic Circuit Diagram
