Linde Electric Forklift Series 336 E25 E30 Service Training 3368042491
Brand: Linde
Type of Machine: Electric Forklift Truck
Type of Manual: Service Training
Model: Linde Series 336 E25 ; E30 Electric Forklift Truck
Part Number: 3368042491
Number of Pages: 164 Pages
0 General
0.1 Instructions
0.2 Explosion protection measures on the vehicle
0.2.1 Battery
0.2.2 Electric installation
0.2.3 Tyres / Driver's seat
0.2.4 Dashboard
0.2.5 Instruments
0.2.6 Fork arms
0.3 Tests for explosion protected industrial trucks acc. to Elex-V as per PTB
0.4 Tests of explosion protected installations at three year intervals
0.5 Screw torque for pressure proofed housing covers
0.6 Special tools
1 Drive motor
1.1 Drive motor 80 V
1.1.1 Technical data
1.1.2 General
1.1.3 Inspection and replacement of carbon brushes in drive motors
1.1.4 Cleaning the drive motors
2 Drive - transmission
2.1 Disassembling the drive axle
2.2 Removal and assembly of the motor at the wheel drive unit
2.3 Assembling the drive axle
2.4 Replacing the speed sensor on the drive motor
3 Vehicle design
3.1 Driver's seat
3.1.1 Checking the leakage resistance of the driver's seat
3.1.2 Seat switch explosion protected
3.1.3 Removing and installing the seat switch
4 Steering system and wheels
4.1 Servostat
4.2 Curve sensors
4.2.1 Adjusting the curve sensors
4.2.2 Removing and installing a curve sensor
4.3 Drive wheels
4.3.1 Checking the leakage resistance of the drive wheels
5 Control elements
5.1 Travel control
5.1.1 Accelerator Sensor
5.1.2 Checking the output signals of the accelerator sensor in the intrinsically safe circuit
5.1.3 Removing and installing the accelerator sensor
5.2 Brake control
5.2.1 Renew the brake Pads
5.2.2 Adjusting the foot brake
5.2.3 Adjusting the hand brake
6 Electrical system
6.1 Pressure resistant fully enclosed housing
6.1.1 Maintenance on pressure resistant housings
6.1.2 Control housing
6.1.3 Pressure resistant housing for Exciter resistor 1R2 (Up to 10.96)
6.1.4 Pressure resistant housing for voltage transformer
6.2 Checking the sealing function of PG-fittings
6.3 Checking condition and tight fit of electric cables
6.4 Checking the insulation resistance of the electrical system
6.5 Intrinsically safe electric circuits
6.5.1 Buffer amplifier, function and description
6.5.2 Internal circuit diagram of a buffer amplifier
6.5.3 Checking the function of the buffer amplifiers
6.5.4 Replacing the buffer amplifier
6.6 Function and description of the Zener barrier
6.6.1 Terminal designation on the Zener barrier
6.6.2 Internal circuit diagram of the Zener barrier
6.6.3 Checking the internal resistance of the Zener barriers
6.6.4 General function of the Zener diodes
6.6.5 Checking the output signals in the intrinsically safe circuit
6.7 Power supply
6.7.1 Monitoring unit 1V1 and release signal
6.8 Insulation monitoring 3V3 (Option)
6.8.1 Insulation monitoring (3V3) fault detection
6.8.2 Insulation monitoring 3V3 after 94/9 EG (ATEX 100)
6.8.3 Checking the insulation monitoring 3V3
6.8.4 Insulation monitoring 3V3 fault detection
6.9 Circuit diagrams up to 08/97
6.9.1 Main electric circuit for driving, lifting
6.9.2 Electric control circuit for driving
6.9.3 Intrinsically safe circuit - buffer amplifier and Zener barriers
6.9.4 Intrinsically safe circuit - carbon brush wear indicator
6.9.6 Auxiliary electrics - lighting and working head lights
6.9.7 Terminal strip X1 - not intrinsically safe circuits (up to 08/97)
6.9.8 Terminal strip X2 intrinsically safe circuits (up to 08/97)
6.10 Electric diagrams from 09/97
6.10.1 Main electric circuit for driving, lifting
6.10.2 Electric control circuit for driving
6.10.3 Intrinsically safe circuit - buffer amplifiers and Zener barriers
6.10.4 Intrinsically safe circuit - carbon brush wear indicator
6.10.5 Carbon brush monitoring
6.10.6 Auxiliary electrics - lighting and working head lights
6.10.7 Terminal strip X1 - Not intrinsically safe circuits (From 09/97)
6.10.8 Terminal strip X2 intrinsically safe circuits (from 09/97)
6.11 Circuit diagrams from 7/98
6.11.2 Electric control circuit for driving
6.11.3 Intrinsically safe circuit - buffer amplifiers and Zener barriers
6.11.4 Intrinsically safe circuit - carbon brush wear indicator
6.11.5 Carbon brush monitoring
6.11.6 Auxiliary electrics - lighting and working head lights
6.11.7 Terminal strip X1 - not intrinsically safe circuits (from 07/98 w/o Atex)
6.11.8 Terminal strip X2 intrinsically safe circuits (from 07/98)
6.12 Circuit diagrams from 08/98 (94/9 EG)
6.12.1 Main electric circuit for driving, lifting
6.12.2 Electric control circuit for driving
6.12.3 Intrinsically safe circuit - Buffer amplifier and Zener barriers
6.12.4 Intrinsically safe circuit - Carbon brush wear indicator
6.12.5 Carbon brush monitoring
6.12.6 Auxiliary electrics - lighting and working head lights
6.12.7 Terminal strip X1 - Not intrinsically safe circuits (from 08/98 ATEX)
6.12.8 Terminal strip X2 intrinsically safe circuit (from 08/98 ATEX)
6.13 Illustration of components in pressure resistant housings
6.13.1 Pressure resistant control housing
6.14 Pressure resistant transformer housing
7 Hydraulic system
7.1 General
7.2 Pump motor
7.2.1 Technical Data
7.2.2 Removing and installing the pump motor
7.2.3 Changing the carbon brushes in the pump motor
7.2.4 Disassembly of the hydraulic pump
7.2.5 Speed sensor for Pump motor (2B8)
7.3 Displacement transducer
Brand: Linde
0 General
0.1 Instructions
0.2.1 Battery
0.2.4 Dashboard
0.2.5 Instruments
0.2.6 Fork arms
0.6 Special tools
1 Drive motor
1.1.2 General
3 Vehicle design
3.1 Driver's seat
4.1 Servostat
4.2 Curve sensors
4.3 Drive wheels
5 Control elements
5.1 Travel control
5.2 Brake control
6 Electrical system
6.7 Power supply
7 Hydraulic system
7.1 General
7.2 Pump motor
- Linde Forklift Series 393 Service Training
- Linde R14,R16,R20 Service Training Typ 113 Service Training
- Linde R14, R16, R20 Operation Manual
- Linde Reach Stacker 357 Shop Manual
- Linde Forklift Truck H12,16,18,20, D-03,T-03 Service Training
- Linde Stapler H 20 T - 03 / H 25 T - 03 / H 30 T - 03 (351 804 3350 D) Operating Instruction Manual
- Linde E-Stapler E12,15,16 Typ324 Service Training
- Linde Stapler Typ 351 H 20 - 02 / H 25 - 02 / H 30 - 02(351 804 3000 D) Operating Instruction Manual
- ProSeCco Date Time 2018
- Linde Stapler H 35 - 04 / H 40 - 04 / H 45 - 04 / H 45/600 - 04 / H 30 G - 04 / H 35 G - 04(352 804
- Linde E-Stapler E16P Typ 322 Service Training
- Linde Forklift V-Stapler H50D-03EX, H60D-03EX,H70D-03EX, H80D-03EX Service Training
- Linde Lindos Forklift Trucks EPC 2014 Multilanguage
- Linde Stapler E14 -02E16 - 02E16C - 02E18C - 02E16P - 02E18P - 02E20P - 02 Operating Instructions Ma
- Linde E-Stapler E20,25,30 P-Z Typ325 Service Training
