Linde Electric Forklift Series 335-02 E14-02 E20-02 Service Training 3358044601
Brand: Linde
Type of Machine: Electric Forklift Truck
Type of Manual: Service Training, Hydraulic Schematic, Electrical Schematic
Model: Linde Series 335-02 E14-02 ; E20-02 Electric Forklift Truck
Engine: Linde GF116-Q5 Engine
Part Number: 3358044601
Number of Pages: 306 Pages
1 Traction
1.1 Traction motor
1.2 Right hand Traction motor 1M1
1.3 Checking and renewing the traction motor brushes
1.4 Traction motor disassembly
1.5 Checking of the D.C. motor
1.5.1 Visual check
1.5.2 Checking during operation
1.5.3 Winding measurements
1.5.4 Checking on insulation
1.5.5 Reworking the collector
1.5.6 Brush switches
1.5.7 Terminals
1.5.8 Cleaning
1.5.9 Thermal sensor
1.6 Traction motor fan
1.7 Optional speed sensor
1.8 Assembly of drive units
2 Drive gearbox
2.1 Planetary gear GR2E-02
2.1.1 Renewing the radial shaft sealing ring
2.1.2 Oil level check and oil change
2.1.3 DisAssembly and assembly of the traction motor
3 Chassis and bodywork
3.1 Seat switch
3.1.1 Replacement of seat switch
3.2 Operator's cabin
3.2.1 Torsion leaf springs
3.2.1.1 Removing and installing the torsion leaf springs
3.3 Transportation device
4 Steering system
4.1 Close-coupled steering axle E 14, E 16, E 16C
4.1.1 Steering axle removal
4.1.2 Steering axle disassembly and sealing
4.1.3 Steering axle installation
4.2 Combination steering axle E 16P/ E 18P / E 20P
4.2.1 Steering axle removal
4.2.2 Steering cylinder and track rod link
4.2.3 Renewing the steering cylinder seals
4.2.3.1 Steering cylinder (Type Rochlitz)
4.2.3.2 Steering cylinder (Type Weber)
4.2.3.3 Renewing the wheel hub tapered roller bearings and shaft sealing ring
4.2.3.4 Renewing the axle body tapered roller bearings and wipers
4.2.3.5 Installing the steering cylinder and track rod link
4.2.3.6 Steering axle installation
4.3 Servostat
4.3.1 Steering control valve with inductive Sensor
4.4 Renewing of steering position potentiometer
5 Controls
5.1 Travel control
5.1.1 Truck speed controller
5.1.1.1 Adjustment of the pedal stop screws
5.1.2 Single-pedal direction switch
5.2 Braking
5.2.1 Renewing the brake linings
5.2.2 Adjusting the parking brake
5.2.3 Adjusting the foot brake
5.2.4 Renewing the brake fluid
6 Electrical equipment
6.1 Introduction
6.2 Explanation of Functions
6.2.1 Traction drive
6.2.1.1 Motor control
6.2.1.2 Forward direction
6.2.1.3 Reverse direction
6.2.1.4 Free-wheel circuit
6.2.1.5 Regenerative braking
6.2.2 Pump motor
6.3 Power units
6.3.1 General
6.3.2 Power unit A1
6.3.3 Power unit 1A1
6.3.4 Power unit temperature monitoring
6.3.4.1 Power transistors of the traction drive
6.3.4.2 Power transistors of the working hydraulics
6.4 Position of connectors
6.4.1 Trucks with individual controllers
6.4.1.1 E 14 individual controllers
6.4.1.2 E 16 - 20 Individual controllers
6.4.2 Trucks with combination controller
6.4.2.1 E 14 Combination controller
6.4.2.2 E 16 - E 20 combination controller
6.5 Fuses
6.5.1 Trucks with individual controllers
6.5.2 Trucks with combination controller
6.6 Control circuit - individual controllers
6.6.1 Traction controller
6.6.1.1 Power supply
6.6.1.2 Charging of the capacitors in the intermediate circuits
6.6.1.3 Discharging of the capacitors in the intermediate circuits
6.6.1.4 Enabling signal
6.6.1.5 Accelerator
6.6.1.6 Single-pedal switch
6.6.1.7 Steering sensor
6.6.1.8 Hand brake switch
6.6.1.9 Stop pedal switch
6.6.1.10 Switch-controlled speed reduction
6.6.1.11 Relay drivers
6.6.1.12 Motor temperature monitoring
6.6.1.13 Emergency stop microswitch
6.6.1.14 Traction motor speed monitoring
6.6.2 Controller for the working hydraulics
6.6.2.1 Power supply
6.6.2.2 Enabling signal
6.6.2.3 Joystick signals
6.6.2.4 Valve activation
6.6.2.5 Reduction of the lifting speed with low battery charge
6.6.2.6 Reed switch 3S1 of steering control valve
6.7 Control circuit - combination controllers
6.7.1 General
6.7.2 Pin design of connector X13
6.7.3 Function
6.7.3.1 Charging of the capacitors in the intermediate circuit
6.7.3.2 Discharging of the capacitors in the intermediate circuit
6.7.3.3 Enabling signal
6.7.3.4 Power supply to the accelerator and the steering potentiometer
6.7.3.5 Accelerator
6.7.3.6 Single pedal switch
6.7.3.7 Steering sensor
6.7.3.8 Hand brake switch
6.7.3.9 Stop pedal switch
6.7.3.10 Switch-controlled speed reduction
6.6.3.11 Truck coding
6.6.3.12 Relay drivers
6.7.3.13 Motor temperature monitoring
6.7.3.14 Traction motor speed monitoring
6.7.4 Function of the working hydraulics
6.7.4.1 Joystick signals
6.7.4.2 Valve activation
6.7.4.3 Switch-controlled reduction of working speed
6.7.4.4 Reduction of the lifting speed with low battery charge
6.7.4.5 Sensor 3B2 - steering valve
6.8 Software versions Types 335 -02
6.9 Truck diagnosis
6.9.1 Traction windows
6.9.1.1 Status Information
6.9.1.2 Information and fault messages
6.9.1.3 Stored fault numbers
6.9.1.4 Fault memory - operator errors
6.9.1.5 Overall fault memory
6.9.1.6 Clearing the overall fault memory
6.9.1.7 Switch inputs
6.9.1.8 Switch outputs
6.9.1.9 General analog signals
6.9.1.10 Analog signals related to the traction motors
6.9.1.11 Temperature signals
6.9.1.12 Setting of general parameters for the truck
6.9.1.13 Setting of special truck parameters
6.9.1.14 Display of controller information
6.9.1.15 Calibration of accelerator pedal neutral position
6.9.1.16 Calibration of steering end stops and axle type
6.9.2 Fault codes for individual controllers - traction
6.9.2.1 Summary of faults (LDC30C01/LDC30C02)
6.9.2.2 Description of faults - individual controller - traction (LDC30C01/LDC30C02)
6.9.3 Fault codes - combination controller - traction
6.9.3.1 Summary of faults (LDC40C00)
6.9.4 Windows displaying information on the working hydraulics
6.9.4.1 Status information
6.9.4.2 Current information and fault messages
6.9.4.3 Stored fault numbers
6.9.4.4 Overall fault memory
6.9.4.5 Clearing the fault memory
6.9.4.6 Switch inputs
6.9.4.7 Switch outputs
6.9.4.8 Analog signals
6.9.4.9 Analog signals for the working functions
6.9.4.10 Setting of parameters for auxiliary hydraulics
6.9.4.11 Adjustment of parameters for lifting/lowering and tilting
6.9.4.12 Switch-controlled working speeds
6.9.4.13 Adjustment of discharged battery parameter
6.9.4.14 Calibration of joystick 1
6.9.4.15 Calibration of Joystick 2
6.9.4.16 Depressurising the hydraulic system
6.9.4.17 Switch off pump motor - Programmig of axle type
6.9.5 Fault codes - individual controller - working hydraulics (LLC33C00/LLC30C10)
6.9.5.1 Summary of faults
6.9.5.2 Description of faults - individual controller - working hydraulics (LLC30C10)
6.9.6 Fault codes - combination controller - working hydraulics (LDC40C50)
6.9.6.1 Summary of faults
6.9.6.2 Description of faults - combination controller - working hydraulics (LDC40C50)
6.10 Composite instrument
6.10.1 Description
6.10.2 Display messages
6.10.3 Programming of the composite instrument
6.10.4 Battery discharge indicator
6.10.5 Programming of the composite instrument with the diagnostic instrument
6.10.6 Diagnosis of the composite instrument with the Truck Doctor diagnostic software
6.11 Circuit diagrams
6.11.1 Circuit diagram - individual controller
6.11.2 Circuit diagram - combination controller
6.12 Window structure - for the controllers
7 Hydraulic system
7.1 Functional description of the working hydraulics
7.2 Circuit diagram of working hydraulics without pressure accumulator
7.3 Circuit diagram of working hydraulics with pressure accumulator
7.4 Emergency lowering functions of the working hydraulics
7.4.1 Manual tilting of lift mast
7.4.2 Manual lowering of the fork carrier
7.5 Control valve
7.5.1 Functional description of the control valve
7.5.2 Depressurizing of the working hydraulics
7.5.3 Repair work at the valve block
7.5.3.1 Replacing the valve cartridge of safety valve 2Y9
7.5.3.2 Replacing the valve coil of 'tilting/additional hydraulic system 2Y3 to 2Y8'
7.5.3.3 Replacing the valve coil of 'lifting/lowering 2Y1 / 2Y2'
7.5.3.4 Replacing the Tilt brake valve
7.5.3.5 replacing the valve coil of 2Y9
7.5.3.6 Setting the pressure relief valve
7.6 Replacing the micro-filter
7.7 Troubleshooting control valve
8 Mast unit
8.1 Mounting and dismounting the mast
8.2 Right-hand lift cylinder with limit position damping
8.3 Dismounting, mounting the outer lift cylinders
8.4 Dismounting, mounting the center lift cylinder
8.5 Sealing the lift cylinder
8.6 Setting of mast chain
8.7 Setting the roller clearance
8.7.1 Outer, inner and center mast roller clearance
8.7.2 Outer mast clearance at lower part of guide
8.8 Sliders
8.8.1 Dismounting the slider of the standard mast
8.8.2 Dismounting the slider of the
8.8.3 Dismounting the slider of the
8.9 Tilt cylinder
8.9.1 Dismounting the tilt cylinder
8.9.2 Sealing the tilt cylinder
8.9.3 Setting the tilt angle
9 Special equipment
9.1 Electric special equipment
9.2 Voltage transformer
9.3 Fuses
9.4 Working lights and lighting system
9.5 Electric heating unit
9.6 Circuit diagrams
9.6.1 Special equipment switchable by means of key switch
9.6.2 Special equipment
Brand: Linde
1 Traction
1.1 Traction motor
1.5.1 Visual check
1.5.7 Terminals
1.5.8 Cleaning
2 Drive gearbox
3.1 Seat switch
4 Steering system
4.3 Servostat
5 Controls
5.1 Travel control
5.2 Braking
6.1 Introduction
6.2.2 Pump motor
6.3 Power units
6.3.1 General
6.3.2 Power unit A1
6.5 Fuses
6.6.1.5 Accelerator
6.7.1 General
6.7.3 Function
6.7.3.5 Accelerator
6.9 Truck diagnosis
6.10.1 Description
7 Hydraulic system
7.5 Control valve
8 Mast unit
8.8 Sliders
8.9 Tilt cylinder
9 Special equipment
9.3 Fuses
- Linde Forklift Series 393 Service Training
- Linde R14,R16,R20 Service Training Typ 113 Service Training
- Linde R14, R16, R20 Operation Manual
- Linde Reach Stacker 357 Shop Manual
- Linde Forklift Truck H12,16,18,20, D-03,T-03 Service Training
- Linde Stapler H 20 T - 03 / H 25 T - 03 / H 30 T - 03 (351 804 3350 D) Operating Instruction Manual
- Linde E-Stapler E12,15,16 Typ324 Service Training
- Linde Stapler Typ 351 H 20 - 02 / H 25 - 02 / H 30 - 02(351 804 3000 D) Operating Instruction Manual
- ProSeCco Date Time 2018
- Linde Stapler H 35 - 04 / H 40 - 04 / H 45 - 04 / H 45/600 - 04 / H 30 G - 04 / H 35 G - 04(352 804
- Linde E-Stapler E16P Typ 322 Service Training
- Linde Forklift V-Stapler H50D-03EX, H60D-03EX,H70D-03EX, H80D-03EX Service Training
- Linde Lindos Forklift Trucks EPC 2014 Multilanguage
- Linde Stapler E14 -02E16 - 02E16C - 02E18C - 02E16P - 02E18P - 02E20P - 02 Operating Instructions Ma
- Linde E-Stapler E20,25,30 P-Z Typ325 Service Training
