7,392
Linde Electric Forklift Series 334 E10 Service Training 3348042411
Brand: Linde
Type of Machine: Electric Forklift
Type of Manual: Service Training
Model: Linde Series 334 E10 Electric Forklift
Part Number: 3348042411
Number of Pages: 150 Pages
Drive - Motor
Travel motor
Checking and changing the carbon brushes
Drive - transmission
Chaning the transmission oil
Lubricating the live ring bearing
Mounting the travel motor to the transmission
Transmission assembly
Vehicle assembly
Steering system
Adjusting the steering chain tension
Control elements
Brake control
Positions of brake cylinder
Adjusting the brake
Purging the brake
Multi function handle
Electrical system
Block diagram E10-01 to 04/97
Digital control 1A1
Location of electrical components
Battery discharge indicator and hour meter
Charger (optional)
Universal Calibration Box UCB 95
Programming
Function Menu PROGRAM
Function Menu TESTER
Function menu SAVE
Function Menu RESTORE
Function Menu ALARM
Function Menu PROGRAM VACC
Function Menu MOTOR DATA
Extended Menus
Battery charging
A2 Logic interface
Fuses
LED‘s LOgic interface
Connectors
Potentiometers
A3 Logic interface
Connectors
Potentiometers
A4 Logic interface
Description of electrical system functions
Switch-on
Bleeding the hydraulic brake
Forward and reverse travel (FWD - RWD)
Lifting
Lowering
Tilting (optional)
Lifting and lowering the driver's platform
Wiring schematic E10 with key switch two stage
Block diagram E10-02103, Br 334
Digital control 131 E10, BR 334
Position of electric components
Battery charge condition gauge and operating hour meter
Battery charger (optional equipment)
Programming
Programming with diagnostic unit UCB 98
Adjustment or alteration of parameters
Display of voltage values, currents, conditions of control signals
Saving complete parameter sets
Transfer of saved parameter sets
Display of error messages
Resetting the parameters to factory setting
Adjustment of multi function lever for travel
Adjustment of motor to control
Adustment of battery charger to battery
Activation of certain options
Adjustment of multi function lever "Lift - Lower"
Diagnostics with PC
Linde interface converter
Installation of the Diagnostic software "test & Setup"
Program Setup
Connection to vehicle
Program start Linde Program selection
Starting the Diagnostic program
The Menus
Main menu "file"
Main menu "utilities"
Main menu "configuration"
Main menu "speciaL"
Electric circuit diagram E10 series 334 -02/03
Hydraulic system
Valve block
Adjustment of pressure relief valve
Pump motor
Hydraulic diagram
Hydraulic functions
Releasing the brake
Lifting
Lowering
Tilting forward
Tilting back
Platform up
Platform Down
Side shift (option)
Function side shift right
Function side shift left
