118
6,911
Linde Electric Forklift Series 334-03 E10-03 Service Training 3348044701
Brand: Linde
Type of Machine: Electric Forklift Truck
Type of Manual: Service Training, Electrical Schematic, Hydraulics Schematic
Model: Linde Series 334-03 E10-03 Electric Forklift Truck
From F2 X334 N....
Part Number: 3348044701
Number of Pages: 110 Pages
1 Drive Motor
1.1 Traction motor
1.1.1 Checking and replacing of carbon brushes
2 Drive gearbox
2.1 Changing of gearbox oil
2.2 Regreasing of the turntable bearing
2.3 Gearbox setup
2.4 Motor pinion
2.4.1 Dismounting of motor pinion
2.4.2 Mounting of motor pinion
2.5 Mounting of traction motor to the gearbox
2.6 Replacement of the drive unit
3 Truck setup
3.1 Tightening torques
4 Steering system
4.1 Setting of the steering chain tension
4.2 Replacement of potentiometer of the steering position indicator
5 Operating elements
5.1 Brake actuation
5.1.1 Brake cylinder positions
5.1.2 Setting of the brake
5.1.3 Bleeding of the brake
5.2 Multi-function lever (MFL)
5.2.1 Mounting of the MFL
5.2.2 Basic calibration of the MFL p.c. board
6 Electrical system
6.1 Introduction
6.2 Survey of the electrical system
6.3 Control current fuses
6.4 Connector location
6.5 Digital controller 1A1
6.5.1 Connectors of the digital controller
6.5.2 Power section of the digital controller
6.5.3 Connection of revolving light and/or acoustic warning
6.5.4 Mounting of the controller
6.6 Truck diagnosis
6.6.1 Controller data and current faults
6.6.2 Fault memory
6.6.3 Measured values
6.6.4 Adjustments
6.6.4.1 Truck parameter
6.6.4.2 Battery type
6.6.4.3 Hour meter function etc.
6.6.4.4 Calibration of the joystick handle (multi-function lever) - traction
6.6.4.5 Calibration of the joystick handle (multi-function lever) - lift
6.6.5 Store parameter
6.6.6 Load parameter
6.6.7 Loading default settings
6.7 Battery discharge indicator and operating hour counter
6.8 Battery charger (special equipment)
6.9 Circuit diagram
7 Hydraulic system
7.1 Valve block
7.1.1 Setting of the pressure relief valve
7.2 Pump motor
7.3 Hydraulic functions
7.3.1 Brake release
7.3.2 Brake released
7.3.3 De-activation of the brake
7.3.4 Lifting
7.3.5 Lowering
7.3.6 Forward tilting
7.3.7 Backward tilting
7.3.8 Side shift right
7.3.9 Side shift left
7.3.10 Steering right
7.3.11 Steering left
7.3.12 platform lowering
7.3.13 Platform lifting
7.4 Oil level switch in the hydraulic reservoir
7.5 Hydraulic diagram
