Hyundai
86
176,834
Liebherr Telescopic Handler TL432-1483 7 13335 Service Manual 93517079
Brand: Liebherr
Type of Machine: Telescopic Handler
Model: Liebherr TL432-1483 7 13335 Telescopic Handler
Engine: TCD 3.6 L4 (Tier 4i - Stage III-B)
Order Number: 93517079
Publication Date: 2017
Number of Pages: 634 Pages
010 Introduction
010.1 Safety guidelines​
010.2 Special tools for maintenance and repair work​
010.3 Standards and specifications​
010.4 Conservation guidelines​
010.5 Repair welding​
010.6 Hydraulic symbols​
010.7 Electrical symbols​
010.8 Material weights​
020 Technical data
020.1 Overall machine​
020.2 Drive group​
020.3 Cooling system​
020.4 Working hydraulic​
020.5 Travel hydraulic​
020.6 Hydraulic components​
020.7 Electrical system​
020.8 Axles, tires, gear shafts, travel gear​
020.9 Steel components Basic machine​
020.10 Working attachments​
030 Maintenance
030.1 Maintenance and inspection schedule​
030.2 Fill quantities, lubrication schedule​
030.3 Lubricants and fuels​
030.4 Maintenance tasks​
030.5 Testing and adjustment checklist​
030.6 Check and adjustment tasks​
040 Drive group
040.1 Diesel engine​
040.2 Clutch​
050 Cooling system
050.1 Cooling system - Full overview​
050.2 Cooler arrangement​
060 Working hydraulic
060.1 Working hydraulics - Full overview​
060.2 Proportional control valve block​
060.3 Pilot control Working hydraulic​
060.4 Lowering brake valve​
060.5 Hydraulic cylinder​
060.6 Pressure relief Y76​
070 Travel hydraulic
070.1 Travel hydraulics - Full overview​
080 Hydraulic components
080.1 Axial piston variable displacement pump​
080.2 Variable displacement motors - Full overview​
080.3 Double gear pump​
080.4 Gear motor – fan drive​
080.5 Valves​
080.6 Hydraulic tank​
090 Steering system
090.1 Steering system - Full overview​
090.2 Priority valve​
090.3 Steering aggregate​
090.4 Steering cylinder​
100 Brake system
100.1 Brake system - Full overview​
100.2 Valve block​
100.3 Pressure accumulator​
100.4 Inching brake pedal​
100.5 Multiple disk brake​
110 Electrical system
110.1 Electrical system - Full overview​
110.2 Lighting system​
110.3 Circuit diagrams​
110.4 Electrical system - operator’s cab​
130 Axles, tires, gear shafts, travel gear
130.1 Axles and gear shafts​
130.2 Multiple disk brake​
130.3 Differential gear​
130.4 Wheel hub with steering axle​
130.5 Gear shaft​
130.6 DMS sensor​
130.7 Load torque display​
130.8 Tires​
140 Steel components Basic machine
140.1 Counterweight​
150 Working attachments
150.1 Tool holder​
150.2 Fork carrier​
150.3 Hitch​
150.4 Locking unit​
160 Driver's cab, heater, climate control system
160.1 Operator’s platform​
160.2 Operator's cab​
160.3 Heater, ventilation, air conditioning system​
200 Service codes, Diagnostics
200.1 Malfunctions​
200.2 Testing and adjustment software​
