Liebherr Telescopic Handler T60-9-1709_3AS Service Manual 12261273 2023
- Download this document, you need 8625 Gallons
Brand: Liebherr
Type of Machine: Telescopic Handler
Model: Liebherr T60-9-1709_3AS Telescopic Handler
Order Number: 12261273
Publication Date: 2023
Number of Pages: 1712 Pages
010 Introduction
Brand: Liebherr
010 Introduction
010.1 Safety instructions
010.2 Special tools for maintenance and repair work
010.3 Standards and specifications
010.4 Conservation guidelines
010.5 Repair welding
010.6 Hydraulic symbols
010.7 Electrical symbols
010.8 Material weights
020 Technical data020.1 Complete machine
020.2 Drive group
020.3 Cooling system
020.4 Working hydraulics
020.5 Travel hydraulics
020.6 Hydraulic components
020.7 Electrical system
020.8 Travel gear, axles, tyres, drive shafts
020.9 Steel components Basic machine
030 Maintenance030.1 General information on the maintenance and inspection schedule
030.2 Maintenance and inspection schedule
030.3 Fill quantities and lubrication chart
030.4 Lubricants and fuels
030.5 Maintenance tasks
030.6 Adjustment checklist
030.7 Adjustment procedure
040 Drive group040.1 Diesel engine
040.2 Clutch
050 Cooling system050.1 Cooling system - Full overview
050.2 Cooling system - Full overview
060 Working hydraulics060.1 Working hydraulics - Full overview
060.2 Working hydraulics - Full overview
060.3 Working hydraulics - Full overview
060.4 Regulating pump
060.5 Proportional control valve block
060.6 Working hydraulic pilot control unit
070 Travel hydraulics070.1 Travel hydraulics - Full overview
070.2 Travel hydraulics - Full overview
070.3 Variable displacement pump
070.4 Variable displacement motors
080 Hydraulic components080.1 Hydraulic system - Full overview
080.2 Hydraulic system - Full overview
080.3 Hydraulic system - Full overview
080.4 Valves
080.5 Hydraulic tank
090 Steering system090.1 Steering system - Full overview
090.2 Steering system - Full overview
090.3 Steering system - Full overview
090.4 Priority valve
090.5 Steering aggregate
100 Brake system100.1 Brake system - Full overview
100.2 Brake system - Full overview
100.3 Inching brake pedal
110 Electrical system110.1 Electrical system - Full overview
110.2 Electrical system - Full overview
110.3 Electrical system - Full overview
110.4 Lighting - Full overview
110.5 Circuit diagrams
110.6 Electrical components of operator's cab
110.7 Electrical components of diesel engine - Full overview (emission stage III-A)
110.8 Electrical components of diesel engine - Full overview (emission stage III-A)
110.9 Electrical components of diesel engine - Full overview (emission stage V/tier 4f)
110.10 Electrical system - Telescope - Full overview
110.11 Telescope socket, 4-pin
110.12 Electrical components of automatic retraction of telescope
110.13 Electrical components of automatic bucket repositioning
110.14 Electrical components Compartments
110.15 Display unit
110.16 Option package 2 - Full overview
110.17 Option package 2 - Full overview
110.18 Option package 2 - Full overview
110.19 Electrical components of Liebherr telematics unit
110.20 CAN communication
110.21 Electrical components for fuel preheating 12 V
110.22 Electrical components of cameras
110.23 Electrical components of cameras
110.24 Electrical components of cameras
130 Travel gear, axles, tyres, drive shafts130.1 Axles and drive shafts
130.2 Multiple disc brake
130.3 Differential gear
130.4 Wheel hub and steering axle
130.5 Drive shaft
130.6 DMS sensor installation
130.7 Overload warning device
140 Steel components Basic machine140.1 Telescopic boom 9 m (29.5 ft)
160 Operator's cab, heating and air conditioning160.1 Operator’s platform
160.2 Operator's cab
160.3 Heating, ventilation, air conditioning
170 Lubrication system170.1 Standard lubrication system - Full overview
170.2 Manual central lubrication system
170.3 Automatic central lubrication system
190 Options190.1 Automatic dust discharge (option)
190.2 Reversible fan drive
190.3 Reversible fan drive
190.4 4x4 shut-off
190.5 4x4 shut-off
190.6 Ride control
190.7 Ride control
190.8 Ride control
190.9 Emergency down
190.10 Emergency down
190.11 Hydraulic trailer brake - 2-line
190.12 Hydraulic trailer brake - 2-line
190.13 Hydraulic trailer brake - 2-line
190.14 Electrically reversible control circuit 3
190.15 Electrically reversible control circuit 3
190.16 Electrically reversible control circuit 3
190.17 High flow control circuit 3
190.18 High flow control circuit 3
190.19 High flow control circuit 3
190.20 Control circuit 3 leak oil line
190.21 Control circuit 3 leak oil line
190.22 Control circuit 3 leak oil line
190.23 Liebherr quick coupler
190.24 Liebherr quick coupler
190.25 Liebherr quick coupler
190.26 Manitou quick coupler
190.27 Manitou quick coupler
190.28 Manitou quick coupler
190.29 Scorpion quick coupler
190.30 Scorpion quick coupler
190.31 Scorpion quick coupler
190.32 JCB Q-FIT quick coupler
190.33 JCB Q-FIT quick coupler
190.34 JCB Q-FIT quick coupler
190.35 Control circuit 4 tipper connection
190.36 Control circuit 4 tipper connection
190.37 Control circuit 4 tipper connection
190.38 Tipper and rear hydraulics control circuit 4
190.39 Tipper and rear hydraulics control circuit 4
190.40 Tipper and rear hydraulics control circuit 4
190.41 Trailer coupling, tipper and rear hydraulics control circuit 4
190.42 Trailer coupling, tipper and rear hydraulics control circuit 4
190.43 Trailer coupling, tipper and rear hydraulics control circuit 4
190.44 Rear axle pendulum lock
190.45 Rear axle pendulum lock
190.46 Rear axle pendulum lock
190.47 Air brake system - Full overview
190.48 Working hydraulics fine control (option)
190.49 Function
200 Service codes, diagnosis200.1 Malfunctions
200.2 Test and adjustment software
- Liebherr Diesel Engines 904-926 Service Manual
- Liebherr Software Diagnostic Without Dongle
- LIEBHERR R900 R902 R912 R922 R932 R942 Service Repair Manual
- LIEBHERR excavator A900 , R900 - A944 , R944 service manual
- Liebherr Excavator R952 R952HD R962 R972 R982 Service Manual and Diagram
- Liebherr New Engine CR and PLD Technical Information
- Liebherr Wheel Loader L544 L564 L574 WorkShop Service Manual
- Liebherr R996 Service Manual Hydraulic Excavator
- Liebherr Diesel Engine D846 A7 Maintenance Manual
- Liebherr R944C Hydraulic Excavator Shop Manual
- Liebherr Crawler Dozer PR 776-1296 Service Manual 2015
- Wheel Loader Liebherr L524 - L534 - L538 - Service manual
- Liebherr ZF Transmission Workshop Manual
- Wheel Loader Liebherr L550-L586 2plus2 - Service manual
- Liebherr Mobile Excavator A902 Parts Catalog
