Hyundai
86
176,834
Liebherr Telescopic Handler T441 T441 Service Manual And Diagram
Brand: Liebherr
Type of Machine: Telescopic Handler
Model: Liebherr T441 T441 Telescopic Handler
Engine: CD 4045 HF 287 (Tier 3 -Stage 3-A)
Number of Pages: 850 Pages
1 General
1.1 Foreword and explanations​
1.2 Safety guidelines​
1.3 Charts​
1.4 Conservation guidelines​
1.5 Material weights​
2 Tools and work instructions
2.1 Special tools​
2.2 Repair welding​
2.3 Installation guidelines​
3 Technical data and Maintenance
3.1 Technical data​
3.2 Maintenance and inspection schedule​
3.3 Maintenance and inspection guidelines​
3.4 Adjustment checklist​
3.5 Inspection and adjustment tasks​
4 Engine
4.1 Data page​
4.2 Fan and cylinder arrangement​
4.3 Installation kit Liebherr- Diesel particle filter​
4.4 Installation and check list for Diesel particle filter​
5 Coupling, splitterbox
5.1 Data page​
5.2 Coupling​
5.3 Splitterbox​
6 Travel hydraulic
6.1 Data page​
6.2 Design​
6.3 Function​
6.4 Repair work and troubleshooting​
6.5 Component arrangement​
7 Working hydraulic
7.1 Data page​
7.2 Design​
7.3 Function​
7.4 Repair work and troubleshooting​
7.5 Component arrangement​
8 Steering hydraulic
8.1 Data page​
8.2 Design​
8.3 Function​
8.4 Repair work and troubleshooting​
8.5 Component arrangement​
9 Brake hydraulic
9.1 Data page​
9.2 Design​
9.3 Function​
9.4 Repair work and troubleshooting​
9.5 Component arrangement​
10 Hydraulic components
10.1 Variable displacement pump – Travel hydraulic​
10.2 Variable displacement motor – Travel hydraulic​
10.3 Regulating pump – Working hydraulic​
10.4 Fixed displacement pump​
10.5 Gear motor – Fan drive​
10.6 Steering aggregate​
10.7 Proportional control valve block​
10.8 S / W control valve block​
10.9 Brake cylinder​
10.10 Valves​
10.11 Hydraulic cylinder​
11 Electrical system – Diagrams and components
11.1 Component description​
11.2 Function list​
11.3 Fuses and notes​
11.4 Circuit diagram​
11.5 Component arrangement​
11.6 Control lever​
11.7 Calibration of electronic load display​
11.8 DMS Sensor Installation​
12 Electrical system - Descriptions
12.1 Diagnostics Software Travel Hydraulic LinDiag​
12.2 Software for Working hydraulic control Bodem​
12.2 Software for Working hydraulic control BODAS​
12.3 Service Code List​
12.4 Software PDL – Diesel particle filter​
13 Axles/ tires and gear shafts
13.1 Data page​
13.2 Design of axles and gear shafts​
13.3 Disk brake​
13.4 Differential​
13.5 Wheel hub with steering axle​
13.6 Gear shafts​
14 Main frame - Installations
14.1 Level regulation​
14.2 Stabilizers / Side offset​
14.3 Cooler arrangement​
14.4 Engine mount​
14.5 Battery installation​
15 Tank arrangements
15.1 Hydraulic tank​
15.2 Fuel tank​
16 Operator’s cab, heater, air conditioning system
16.1 Operator’s cab​
16.2 Heater with blower​
16.3 Air conditioning system​
17 Telescopic boom
17.1. Design and function​
17.2 Repair instructions​
17.3 Hose replacement in telescope​
18 Working attachment
18.1. Tool coupler​
18.2 Forklift​
18.3 Bucket​
18.4 Aerial work platform​
19 Special Installations
19.1 Industrial control​
19.2 Rear axle oscillation lock​
19.4 Quick coupler​
19.5 Reversible fan​
19.6 Towing hitch device​
19.7 Telescope - Leak oil line​
20 Additional documentation
6.3 Schematic Travel hydraulic​
7.3 Schematic Working hydraulic​
8.3 Schematic Steering hydraulic​
9.3 Schematic Brake hydraulic​
11.4 Schematic Circuit diagram​
14.1 Schematic Level regulation​
14.2 Schematic Stabilizers and side offset​
18.4 Schematic Aerial work platform​
19.1 Schematic Industrial control​
