Hyundai
86
176,834
Liebherr Telescopic Handler T32-7-1666_3A Service Manual 12263570 2023
Brand: Liebherr
Type of Machine: Telescopic Handler
Model: Liebherr T32-7-1666_3A Telescopic Handler
Order Number: 12263570
Publication Date: 2023
Number of Pages: 1306 Pages
010 Introduction
010.1 Safety instructions​
010.2 Special tools for maintenance and repair work​
010.3 Standards and specifications​
010.4 Conservation guidelines​
010.5 Repair welding​
010.6 Hydraulic symbols​
010.7 Electrical symbols​
010.8 Material weights​
020 Technical data
020.1 Complete machine​
020.2 Drive group​
020.3 Cooling system​
020.4 Working hydraulics​
020.5 Travel hydraulics​
020.6 Hydraulic components​
020.7 Electrical system​
020.8 Travel gear, axles, tyres, drive shafts​
030 Maintenance
030.1 General information on the maintenance and inspection schedule​
030.2 Maintenance and inspection schedule​
030.3 Fill quantities and lubrication chart​
030.4 Lubricants and fuels​
030.5 Maintenance tasks​
030.6 Adjustment checklist​
030.7 Adjustment procedure​
040 Drive group
040.1 Diesel engine​
040.2 Clutch​
050 Cooling system
050.1 Cooling system - Full overview​
050.2 Cooling system - Full overview​
050.3 Cooler arrangement​
050.4 Hydraulic​
060 Working hydraulics
060.1 Working hydraulics - Full overview​
060.2 Gear pump​
060.3 Proportional control valve block​
060.4 Working hydraulic pilot control unit​
060.5 Hydraulic cylinder​
070 Travel hydraulics
070.1 Travel hydraulics - Full overview​
070.2 Travel hydraulics - Full overview​
070.3 Variable displacement pump​
070.4 Variable displacement motors​
080 Hydraulic components
080.1 Hydraulic system - full overview​
080.2 Hydraulic system - Full overview​
080.3 Hydraulic system - Full overview​
080.4 Valves​
080.5 Hydraulic tank​
080.6 Line filter​
090 Steering system
090.1 Steering system - Full overview​
090.2 Steering system - Full overview​
090.3 Steering system Full overview​
090.4 Steering aggregate​
100 Brake system
100.1 Brake system - Full overview​
100.2 Brake system - Full overview​
100.3 Valve block​
100.4 Pressure accumulator​
100.5 Inching brake pedal​
100.6 Multiple disk brake​
110 Electrical system
110.1 Electrical system - Full overview​
110.2 Lighting - Full overview​
110.3 Circuit diagrams​
110.4 Electrical components of operator's cab​
110.5 Electrical components of diesel engine - Full overview (emission stage III-A)​
110.6 Electrical components of diesel engine - Full overview​
110.7 Electrical components of diesel engine - Full overview (emission stage V/Tier 4f)​
110.8 Electrical components of diesel engine - full overview (emission stage V)​
110.9 Electrical components of diesel engine - full overview (emission stage V)​
110.10 Electrical system - Telescope - Full overview​
110.11 Telescope socket, 4-pin​
110.12 Electrical components Compartments​
110.13 Display unit​
110.14 Electrical components of Liebherr telematics unit​
110.15 Electrical components for fuel preheating 12 V​
110.16 Electrical components for fuel preheating 12 V​
110.17 Electrical components of cameras​
110.18 Electrical components of cameras​
110.19 Electrical components of cameras​
130 Travel gear, axles, tyres, drive shafts
130.1 Axles and drive shafts​
130.2 Differential gear​
130.3 Wheel hub with steering axle​
130.4 Gear shaft​
130.5 DMS sensor installation​
130.6 Overload warning device​
140 Steel components Basic machine
140.1 Telescopic boom 7 m (23.0 ft)​
150 Working attachment
150.1 Telescope leak oil line​
160 Operator's cab, heating and air conditioning
160.1 Operator’s platform​
160.2 Operator's cab​
160.3 Heating, ventilation, air conditioning​
170 Lubrication system
170.1 Standard lubrication system - Full overview​
170.2 Manual central lubrication system​
170.3 Automatic central lubrication system​
190 Options
190.1 Cab air pre-filtering​
190.2 Automatic dust discharge​
190.3 Automatic dust discharge​
190.4 Reversible fan drive​
190.5 Ride control​
190.6 Hydraulic trailer brake - 1-line​
190.7 External pressure relief, control circuit 3​
190.8 Electrically reversible control circuit 3​
190.9 Electrically reversible control circuit 3 with external pressure relief​
190.10 Liebherr quick coupler​
190.11 Manitou quick coupler​
190.12 Scorpion quick coupler​
190.13 JCB Q-FIT quick coupler​
190.14 Control circuit 4 switchable from control circuit 3​
190.15 Air brake system - Full overview​
190.16 Air brake system - Full overview​
200 Service codes, diagnosis
200.1 Malfunctions​
200.2 Test and adjustment software​
