Liebherr Mobile Crane LTM 1090-011 Z16649 Spare Parts Catalog
Brand: Liebherr
Type of Machine: Mobile Crane
Model: Liebherr LTM 1090-011 Z16649 Mobile Crane
Serial: 016 649
Number of Pages: 1318 Pages
[3] 1410 912932408 - DIESEL ENGINE W.RADIATOR (1/2)
[3] 1410 912932408 - DIESEL ENGINE W.RADIATOR (2/2)
[1] 1410001 927526808 - DIESEL ENGINE, PRE-ASSEMBLED (1/2)​
[1] 1410001 927526808 - DIESEL ENGINE, PRE-ASSEMBLED (2/2)​
[10] 1410013 927737208 - HEAT EXCHANGER, PRE-ASSEMBLED​
[11] 1410011 927518308 - MULTI-FLOW PUMP PRE-ASS.​
[32] 1410032 927655408 - RADIATOR, PRE-ASSEMBLED​
[5] 1411 912945608 - TRANSMISSION INSTALLATION
[1] 1411001 927515308 - TRANSFER CASE, PRE-ASSEMBLED​
[7] 1412 912945708 - INTERMEDIATE GEAR W.SUSPENSION
[1] 1412001 927490108 - INTERMEDIATE GEAR,PRE-ASSEMBLE​
[9] 1415 912950908 - TEST CONNECTION
[11] 1420 912945808 - AXLE 1 WITH SUSPENSION
[1] 1420001 927336708 - AXLE 1, PRE-ASSEMBLED​
[2] 512315708 - HYDRO CYLINDER [SPF]​
[9] 660019408 - PROXIMITY SWITCH​
[13] 1423 912945908 - AXLE 2 WITH SUSPENSION
[1] 1423001 927341408 - AXLE 2, PRE-ASSEMBLED​
[15] 1424 912946008 - AXLE 3 WITH SUSPENSION
[1] 1424001 927345008 - AXLE 3, PRE-ASSEMBLED​
[17] 1421 912946108 - AXLES 4+5 WITH SUSPENSION
[1] 1421001 927494608 - AXLE 4, PRE-ASSEMBLED​
[2] 1421002 927494708 - AXLE 5, PRE-ASSEMBLED​
[3] 512315708 - HYDRO CYLINDER [SPF]​
[10] 660019408 - PROXIMITY SWITCH​
[11] 1421004 927452208 - STEERING LOCKING,PRE-ASSEMBLED​
[19] 1422400 913740408 - TYRES 16.00 R25
[1] 1422401 929760308 - TIRE CPL.16.00 R25 [SPF]​
[21] 1430 912949408 - STEERING MECHANISM
[4] 1430013 924290408 - STEERING LEVER, PRE-ASSEMBLED​
[5] 1430084 927085508 - STEERING LEVER, PRE-ASSEMBLED​
[6] 1430085 927085708 - STEERING LEVER, PRE-ASSEMBLED​
[7] 1430086 927085908 - STEERING LEVER, PRE-ASSEMBLED​
[10] 521121808 - STEERING ROD​
[11] 521129508 - STEERING ROD​
[23] 1432 912949508 - STEERING HYDRAULICS
[2] 511401908 - FLOW CONTROL VALVE​
[3] 510600908 - FLOW RATE INDICATOR​
[5] 511453908 - VALVE BLOCK​
[25] 1450 912927308 - DRIVE SHAFT FITTING
[1] 1450001 927080308 - BEARING ISUPPORT​
[27] 1620 912949608 - FIXING PARTS SLEWING RING
[29] 1632 913067608 - SLIDING BEAM WITH BEARING
[1] 1632001 927814708 - SLIDING BEAM FRONT,PRE-ASSEMB​
[2] 1632002 927814808 - SLIDING BEAM REAR, PRE-ASSEMBL​
[22] 1632080 927954108 - COVERING​
[31] 1640 912949808 - WHEEL CHOCKS WITH HOLDER
[33] 1641 912949908 - SUPPORT PLATES W.FAST.ADD-ON
[1] 1641001 927525608 - SUPPORT PLATE COMPL.​
[35] 1644 912950708 - TRESTLE STRUCTURE BOOM/JIB
[1] 1644001 927532508 - SUPPORT MOUNTING PRE-ASS.​
[37] 1660 912950008 - TOOL BOX ADD-ON
[1] 1660005 924219908 - TOOL BOX​
[39] 1670 912950108 - FUEL TANK FASTENINGS
[1] 1670001 927511408 - FUEL TANK, PRE-ASSEMBLED​
[41] 1671 912950208 - OIL TANK ASSEMBLAGE
[1] 1671001 927528808 - OIL TANK PRE-ASS.​
[43] 1672 913136008 - AIR VESSEL MOUNTING
[1] 502919708 - AIR TANK [SPF]​
[2] 502919808 - AIR TANK​
[45] 1679 912878908 - EXHAUST TAIL PIPE
[47] 1680 912950508 - EXHAUST SYSTEM
[49] 1681 912950608 - AIR FILTER UNIT
[1] 551701608 - COMBI AIR FILTER​
[51] 1683 912075808 - MANEUVERING COUPLING
[1] 520405008 - MANEUVERING COUPLING​
[57] 1750 912951008 - TOOLS AND ACCESSORIES
[1] 1750001 928569808 - MAIN TOOLS​
[3] 607106208 - HAZARD WARNING FLASHER​
[5] 890100408 - FIRE EXTINGUISHER [SPF]​
[29] 790064708 - FILLING AND TESTING FIXTURE​
[59] 1800 912951208 - DRIVER'S CABIN CPL
[1] 1810000 913016908 - DRIVER'S CABIN PRE-ASS.​
[61] 1829 912431308 - TACHOGRAPH
[63] 1830 912951308 - DRIVER'S CABIN CONTROLS
[1] 1830001 927535208 - DASHBOARD CENTER CONSOLE​
[2] 1830002 927535408 - CENTRE CONSOLE INSTRUMENTS​
[4] 1920132 927664008 - ASSEMBLY PLATE PRE-ASS.​
[65] 1859 912951408 - NOISE INSULATION VEHICLE
[67] 1860 913112508 - TIRE COVER PANELLING
[39] 10870752 - FOLDING LADDER [SPF]​
[40] 10870761 - FOLDING LADDER [SPF]​
[69] 1861 912951608 - ENGINE COWLING CPL. (1/2)
[69] 1861 912951608 - ENGINE COWLING CPL. (2/2)
[1] 1861113 927773308 - COVERING PANEL​
[4] 1861131 927401808 - PLATE​
[5] 1861073 928371008 - COVER, CPL.IN FRONT RIGHT​
[6] 1861075 928370908 - COVER, CPL.IN FRONT LEFT​
[7] 1861139 927774208 - SIDE PANEL PRE-ASSEMBLY REAR​
[8] 1861138 927774408 - SIDE PANEL PRE-ASSEMBLY REAR​
[10] 1861045 928371108 - COVER BEHIND​
[73] 1920 912951808 - UNDERCARRIAGE ELEC. SYSTEM
[2] 1920134 927666908 - CABLE LIST ELECTRICAL SYSTEM​
[4] 1920189 927663408 - ELECTRIC FOR DRIVER'S CABIN​
[11] 1915001 921926808 - DOUBLE HORN​
[75] 1932 912951908 - LIGHTING GERMAN
[3] 1932196 927587908 - WIRING LIST FOR LIGHTING​
[5] 1932001 927588008 - LAMP CLAMP CPL.REAR LEFT​
[6] 1932002 927588108 - LAMP CLAMP CPL.REAR RIGHT​
[7] 1932128 925737208 - DISTRIBUTION BOX​
[8] 1932003 927704708 - CLAMP NUMBER PLATE CPL.​
[9] 1932130 925523308 - FLASHING LIGHT IN FRONT LEFT​
[10] 1932131 925523408 - FLASHING LIGHT IN FRONT RIGHT​
[15] 607124208 - FLOODLIGHT​
[77] 1950 912952008 - COMPR.AIR AND BRAKE SYSTEM (1/2)
[77] 1950 912952008 - COMPR.AIR AND BRAKE SYSTEM (2/2)
[2] 1672033 926541708 - AIR DREIER, PRE-ASSEMBLED​
[5] 502991508 - RELAY VALVE​
[6] 502991408 - OVERLOAD VALVE​
[7] 502968108 - OVERFLOW VALVE​
[8] 502922508 - OVERFLOW VALVE​
[10] 502984508 - PRESSURE LIMITING VALVE​
[11] 502659608 - SOLENOID VALVE​
[12] 502612608 - SOLENOID VALVE​
[13] 511442808 - SOLENOID VALVE​
[14] 502986008 - PRESSURE LIMITING VALVE​
[203] 471030708 - FITTING​
[79] 1970 912952108 - HYDRAULIC SUPPORT
[2] 511470508 - SLIDE VALVE BLOCK​
[3] 511470608 - SLIDE VALVE BLOCK​
[5] 511427208 - DIRECTIONAL CONTROL VALVE​
[6] 511464108 - DIRECTIONAL CONTROL VALVE​
[7] 511417608 - PRESSURE LIMITING VALVE​
[81] 1971 912952208 - HYDRAULIC AXLE SUSPENSION
[2] 511433708 - AXLE LOCKING VALVE​
[3] 511452508 - AXLE LOCKING VALVE​
[5] 511433808 - AXLE LOCKING VALVE​
[6] 511435208 - PRESSURE LIMITING VALVE​
[14] 510064608 - BLADDER ACCUMULATOR​
[83] 1982 912952308 - EL.OPERATION OF HYDR. VALVES
[1] 1982067 927667908 - SWITCH BOX LEFT​
[2] 1982069 927668008 - SWITCH BOX RIGHT​
[11] 1982068 927668108 - WIRING LIST FOR SUPPORTS​
[85] 1997 912952408 - HOSE LINES UNDERCARRIAGE
[87] 1998 912952508 - PIPELINES UNDERCARRIAGE
[103] 2102 912952708 - ASSEMBLY PARTS F.SLEWING PLTF.
[12] 2102002 927530808 - BATTERY BOX, PRE-ASSEMBLED​
[105] 2200 913165808 - DRIVE ASSEMBLY
[1] 2210000 913026608 - DRIVE ASSEMBLY, PRE-ASSEMBLED​
[3] 550771408 - AIR FILTER​
[107] 2270 912952908 - FUEL TANK FASTENINGS
[1] 2270001 927538608 - FUEL TANK, PRE-ASSEMBLED​
[109] 2340 912953008 - OIL RESERVOIR, COMPLETE
[8] 510654508 - AERATION FILTER​
[11] 510665008 - RETURN FILTER​
[29] 10475262 - SHUT OFF DEVICE [SPF]​
[111] 2350 912953108 - LUFFING RAM W. PIVOT
[1] 512333808 - LUFFING CYLINDER [SPF]​
[113] 2410 912953208 - ROLLER SLEWING RING
[1] 51922308 591922308 - ROLLER SLEWING RING​
[115] 2420 912077008 - SLEWING GEAR
[1] 500040308 - SWING GEAR [SPF]​
[2] 510228008 - HYDRO MOTOR [SPF]​
[117] 2430 913132708 - ANGLE THREADED BULKHEAD
[1] 724012008 - OPERATION​
[2] 2780300 913150508 - ADDITIONAL ELECTRICS​
[119] 2450 912953408 - MAIN HOIST GEAR
[1] 540046808 - ROPE WINCH [SPF]​
[2] 510232008 - HYDRO MOTOR [SPF]​
[3] 2920200 912788908 - ELECTRIC FOR WINCH 1​
[123] 2500 913044708 - CRANE DRIVER'S CABIN CPL.
[1] 2501000 913092208 - CRANE DRIVER'S CABIN,PRE-ASSY.​
[10] 2500009 925303708 - ACCESS COMPL​
[11] 2500007 927761408 - COMPRESSOR​
[125] 2502 913048608 - CONTROL STAND
[1] 774106908 - OPERATOR SEAT​
[9001] 774107008 - OPERATOR SEAT​
[127] 2530 912954008 - CRANE OPERATOR CAB INSTRUMENTS
[3] 2530042 927526408 - DASHBOARD FRONT, PRE-ASSEMBLED​
[4] 2530034 912768308 - MONITOR WITH KEYBOARD 1​
[129] 2531 912758808 - EL.INSTRUMENTS F.CONTROL STAND
[5] 2531003 927068608 - ELECTRIC FOR ARMREST LEFT​
[6] 2531004 927068708 - ELECTRIC FOR ARMREST RIGHT​
[131] 2510 912954208 - TURNTABLE PANELLING
[1] 2510027 927540508 - PANELLING,LEFT​
[2] 2510025 927715608 - FLAP PRE-ASS.​
[133] 2560 913036108 - COUNTERWEIGHT MOUNTING
[1] 2560018 928353808 - BALLASTING RAM PRE-ASS.​
[6] 2560014 927477108 - LOCKING​
[137] 2920 913044808 - ELECTR. SYSTEM F.SLEWING PLATF
[11] 2920013 927876308 - CABLE LIST SLEWING PLATFORM​
[19] 607114208 - WORK LIGHT​
[32] 925844608 - LAMP HOLDER​
[139] 2932 913044908 - SWITCHBOX MOUNTING PARTS
[4] 2932042 927879508 - BASE ASSEMBLY (1/2)​
[4] 2932042 927879508 - BASE ASSEMBLY (2/2)​
[5] 2932035 927793208 - RELAY CONTROL SYSTEM​
[6] 2932502 926975608 - LICCON CONTROL SWITCH BOX​
[141] 2970 913112708 - HYDRAULICS
[2] 511457508 - LOWERING BRAKE VALVE​
[3] 510663008 - PRESSURE FILTER​
[4] 511417608 - PRESSURE LIMITING VALVE​
[5] 510642008 - DIAPHRAGM ACCUMULATOR​
[8] 511465608 - LOWERING BRAKE VALVE​
[10] 510643708 - DIAPHRAGM ACCUMULATOR​
[12] 511459508 - FLOW DIVIDER VALVE​
[13] 511468608 - BASE BLOCK​
[14] 511459808 - CONTROL PLATE​
[15] 511471108 - SLEWING GEAR VALVE​
[17] 9271779 - PILOT CONTROL UNIT​
[19] 511444408 - DIRECTIONAL CONTROL VALVE​
[20] 511444508 - DIRECTIONAL CONTROL VALVE​
[21] 511444608 - DIRECTIONAL CONTROL VALVE​
[24] 2970028 925734908 - CONNECTING PIECE CPL.​
[25] 510643908 - DIAPHRAGM ACCUMULATOR​
[27] 511302208 - DIRECTIONAL CONTROL VALVE​
[30] 921453608 - SCREW COUPLING, CPL​
[31] 96004569 - REPAIR KIT VALVE​
[33] 511444408 - DIRECTIONAL CONTROL VALVE​
[653] 471030708 - FITTING​
[662] 471037508 - FITTING​
[143] 2997 913112808 - HOSE LINES SUPERSTRUCTURE
[145] 2998 912954908 - PIPELINES SUPERSTRUCTURE
[201] 3100 913112908 - TELESCOPIC BOOM CPL.
[1] 3101000 913135508 - PIVOT SECTION, PRE-ASSEMBLED​
[2] 3102000 913126308 - TELESCOPIC SECTION 1 PRE-ASSEM​
[3] 3103000 913126408 - TELESCOPIC SECT.2 PRE-ASSEMBL​
[4] 3104000 913135608 - TELESCOPIC SECT.3 PRE-ASSEMB​
[5] 3105000 912963808 - TELESCOPIC SECT.IV PRE-ASSEMBL​
[6] 3330000 913122208 - MECHANICAL EXTENSION SYSTEM (1/2)​
[6] 3330000 913122208 - MECHANICAL EXTENSION SYSTEM (2/2)​
[203] 3930 912955108 - ELECTR. SYSTEM F. BOOM
[5] 3930249 927060408 - CONNECTOR HOUSING CPL.​
[6] 692502408 - LENGTH/ANGLE INDICATOR [SPF]​
[7] 692100208 - CABLE REEL [SPF]​
[8] 3930250 927621108 - LEAD​
[10] 3930260 927621208 - LEAD​
[301] 1933100 912524908 - MAGNETIC LAMP
[302] 2570 913113008 - ADDITIONAL BALLAST
[1] 2570003 929121608 - COUNTERWEIGHT [SPF]​
[304] 1933 912964308 - EL.COMP. DISPATCH ASSEMBLY
[1] 607138908 - ROTATING BEACON​
[305] 1933200 912716308 - EL.COMP. DISPATCH ASSEMBLY
[306] 1422401 929760308 - TIRE CPL.16.00 R25 [SPF]
[1] 520368808 - TYRE​
[2] 520313908 - DISC WHEEL​
[3] 520190108 - METAL VALVE​
[308] 1770 912961108 - SPARE WHEEL CARRIER
[310] 4027 912227008 - LOAD HOOK CPL. [SPF]
[1] 4099030 925806808 - LOAD HOOK, PRE-ASSEMBLED​
[312] 4065000 913000008 - HOOK BLOCK [SPF]
[2] 4065001 927539008 - TWIN HOOK​
[3] 4099001 924073908 - ROPE PULLEY [SPF]​
[319] 1541 913732008 - ADDITIONAL HEATING
[3] 1780805 912560708 - HEATING TRUMATIC GAS HEATING​
[320] 2541100 913148008 - ADD HEATING SUPERSTRUCTURE
[1] 553095808 - GAS HEATER​
[23] 1780250 912557608 - HEATING ELECTRICAL SYSTEM​
[321] 1663 913036508 - ROPE BOX WITH SUSPENSION
[333] 3500 912999308 - DOUBLE FOLDING JIB CPL.
[1] 3501000 913011808 - DOUBLE FOLDING JIB, PRE-ASSEMB (1/2)​
[1] 3501000 913011808 - DOUBLE FOLDING JIB, PRE-ASSEMB (2/2)​
[3] 3500010 927736008 - MOUNTING CPL.MIDDLE​
[334] 3750 913036608 - TOOLS
[1] 927783108 - ADD-ON UNIT LADDER​
[2000] SK_Z16649 - SERVICE
[10] 96000086 - FILTER PACKAGE​
[20] 96000087 - FILTER PACKAGE​
[110] 96000088 - FILTER PACKAGE​
[120] 96000089 - FILTER PACKAGE​
Manual Preview & Document Quality:
