mont
21
104
Liebherr Mobile Crane LTC 1055-3.1 Training Documents
Brand: Liebherr
Type of Machine: Mobile Crane
Type of Manual: Training documents
Model: Liebherr LTC 1055-3.1 LTC1055/1 Mobile Crane
Publication Date: 2005
Number of Pages: 82 Pages
Vehicle:
Front view, Lighting, mirror heating, mirror adjustment
View from rear, lighting
Support operating unit, side marker lights, left
Support operating unit, side marker lights, right
Cabine armature:
Monitor LSB-BSE, pedals, steering column switch, tachograph
Master switch, keyboard units, ignition switch
Roof console
Crane cabine:
Wiper motors, washing pumps, voltage transformer
Heating, auxiliary heating
Auxiliary heater
Interior temperature sensor, foot board, arm rest bottom induction sensor
Control cabinet UW:
Relay, fuses
I/O module 5, ABV module
Cabine control cabinet:
Fuses
Relay
Input boards, instrumentation module
LSB UEA 1,2,3,4,5, XNOT-plug
Relay
Diesel engine D 846 Ti A5, P = 338KW:
generator, starter, oil pressure sensor
Needle movement sensor, EGR valve, charge air pressure sensor
Flame starting device, EDC controlling unit, temperature sensor
Engine brake, air filter, cooling water level, fuel preheater
Impulse transmitter, fuel tank sensor
Cooler overview, fan drive
Hydrostatic drive:
Hydraulic motor and pump overview
Double hydraulic motor 165/108 axle 1 and 2
Double hydraulic motor 165/108 axle 3
Compressed air system:
Pressure sensor UW, air dryer
Pressure sensor - cabine, slewing platform locking mechanism
Antiblocking device - axle 1 and 2
Antiblocking device - axle 3
Hydraulic pumps UW (hydraulic shaft):
Steering circuit I and II, AHL, pre-tension pump, auxiliary steering pump, fan pump
Power train:
Cross-differential lock, off-road and road gear axle 1 and 2
Cross-differential lock, off-road and road gear axle 3
Cross-differential lock, pulse generator Tacho, off-road and road gear
Wheel speed sensors
Steering:
Steering gear, deficiency monitor, emergency steering pump
Steering element uncoupling
Active rear axle steering:
Centering cylinder
Angle sensor
Hydraulic pump for rear axle steering
Steering element plate with Bosch CAN valves
AHL block active rear axle steering
Flow indicator, backup supply for centering cylinder
Support:
Supporting valves - left
Supporting valves - right
Supporting pressure indicator, inclination sensor
Axle suspension:
Proximity switch
Axle suspension valves, oil release
Axle suspension, left
Axle suspension, right
Electric slewing platform:
Battery case, main battery switch, external power supply
Terminal box sockets, slewing platform bell, horn
Air conditioning device
Hydraulic slewing platform:
Main control block
Pump pressure sensor
Overview of pumps, superstructure
Solenoid valves - pumps in superstructure, hydraulic brake
Overview of superstructure measuring points
Load sensing changeover valve, hydraulic oil temperature sensor
Winch 1 (hoist gear I)
Winch 2 (hoist gear II)
Ballasting
Central lubrication system, luffing gear
Slewing gear
Direction of boom
Telescopic boom:
Cable drum, boom head angle sensor, hoist limit switch
Working lights, basic frame angle sensor, wind sensor
Length sensors, tele pinning
Tele position
Gripper bolting
Pressure supply unbolting, pressure stage 2 telescope out
Special equipment:
Double folding jib
Camera surveillance, navigation device, multimedia interface
Remote system diagnostics, particle filter
Index_UW
