Liebherr LTM 1200-5.1 Z69503 Superstructure Circuit Diagram
Brand: Liebherr
Type of Machine: Telescopic Mobile Crane
Type of Manual: Circuit Diagram
Model: LTM 1200-5.1 Superstructure
Serial Number: Z69503 or 069503
Number of Pages: 187 Pages
Ident-Nr.: 984509708
Zeich-Nr.: 3381-93200.001001-001
Hoist Gear I or Hoist Gear I + II Engine with Abgasemission III / Tier III
ACCELERATOR SUPERSTRUCTURE, C00LING WATER LEVEL, ENGINE ECU
ACKNOWLEDGEMENT SAFETY CHAIN, ENGINE EXCESS PRESSURE, CHARGE CONTROL EXCESS PRESSURE
ACUSTICAL WARNING, ENGINE MONITORING LICCON
ADAPTOR - ...CHANNEL WITH ENGINE STOP, TANK SENSOR
AIR CONDITIONING ENGINE SUPERSTRUCTURE, PREHEAT, EXTERNAL FEEDING V
ANGLE TRANSMITTER TELESC. SECTION PULLEY HEAD FAN CABIN, HEAT EXCHANGER, HEATING
ANGLE TRANSMITTER, EXTERNAL FEEDING V, VENTILATOR V CABIN
AUXILIARY CONSUMERS, TELE DISMANTLING, FLASHING LIGHT
BALLASTING, FLIGHT WARNING LAMP ( OPTION )
BATTERY BOX, CHARGING SET, FUEL PREHEATING
CAB INSTALLATION, FUSE GROUPING
CAB INSTALLATION, WORKING PROJECTOR, FUSE GROUPING
CAN BUS : ENGINE - ECU- l/O-MODULE FUSES B
CENTRAL GREASING FUSES
CENTRAL UNIT ( VOLTAGE SUPPLY ), FUSES
CENTRAL UNIT ( VOLTAGE SUPPLY ), GENERAL OUTLAY HOISTING LIMIT SWITCH
CENTRAL UNIT GENERAL OUTLAY
CENTRAL UNIT GENERAL OUTLAY B00M —
CENTRAL UNIT GENERAL OUTLAY ENGINE
CENTRAL UNIT GENERAL OUTLAY HOISTING LIMIT SWITCH
CENTRAL UNIT GENERAL OUTLAY HYDRAULICS :
CENTRAL UNITO FUSES
CENTRAL UNITO FUSES ( F- F ) BATTERY BOX
CHARGING SET, READING LAMP, SOCKETS V, GENERAL OUTLAY HYDRAULICS : c
CIRCUIT DIAGRAM SUPERSTRUCTURE I GENERAL OUTLAY HYDRAULICS :
CONNECTION PLAN GENERAL OUTLAY HYDRAULICS :
CONNECTION PLAN GENERAL OUTLAY HYDRAULICS : BALLASTING /
CONTROLS AND FITTING CONTROL STAND HW+, GENERAL OUTLAY l/O-MODULE
CONTROLS AND FITTING CONTROL STAND HW, GENERAL OUTLAY HYDRAULICS : TELESCOPING /
CONTROLS AND FITTING R00F, GENERAL OUTLAY LSB
CONTROLS AND FITTING, MONITOR, GENERAL OUTLAY HYDRAULICS : FOLDING JIB LUFFING
C00LER DRIVE DIESEL ENGINE, GENERAL OUTLAY LSB
C00LING WATERTEMPERATURE, FUEL TEMPERATURE, GENERAL OUTLAY LSB
CUT OFF DIAGRAM GENERAL OUTLAY LSB
CUT OFF DIAGRAM GENERAL OUTLAY SUPERSTRUCTURE
CUT OFF DIAGRAM GENERAL OUTLAY SUPERSTRUCTURE / EXCESS PRESSURE t
CUT OFF DIAGRAM GENERAL OUTLAY SWITCH CABINET +S
CYLINDER INTERLOCKED / UNLOCKED, GENERAL OUTLAY WIRING B00M
CYLINDER UNBOLTING, TELESC. SECTION UNBOLTING, GENERATOR, STARTER
DESCRIPTION OF SYMBOLS HEADLIGHT FOR WINCH, REAR MIRROR HEATING
DESCRIPTION OF SYMBOLS HEATING
DESCRIPTION OF SYMBOLS HEATING THERMO ST ( OPTION )
DESCRIPTION OF SYMBOLS HEATING THERMO ST, COMPLEMENTARY HEATING
DESCRIPTION OF SYMBOLS HEATING, GENERAL OUTLAY HEATING —
DESCRIPTION OF SYMBOLS HOIST GEAR , FEEDING PRESSURE WINCH
DESCRIPTION OF SYMBOLS HOIST GEAR , WORKING HOUR METER HOIST GEAR
DISPOSITION MASTER SWITCH HW+, HOIST GEAR , WINCH
DISPOSITION MASTER SWITCH HW, HOIST GEAR , FEEDING PRESSURE WINCH
DOLLY OPERATION HOSE DRUM DRIVE (ASSEMBLY) F
EMERGENCY OPERATION WITHOUT LICCON l/O-MODULE
EMERGENCY OPERATION WITHOUT LICCON l/O-MODULE DISPOSITION
ENGINE - ECU, ENGINE - DIAGNOSIS, INJECTION PUMP CYLINDER, SOLENOID VALVE CYLINDER
ENGINE - ECU, ENGINE RUNS (D+), HEATER FLANGE, INPUT BOARD EP
ENGINE - ELECTRONICS ECU INPUT BOARD EP (-A)
ENGINE -ECU, INCLINING CAB, FOLDING JIB SWIVEL
INPUT BOARD EP
INPUT BOARD EP (-A)
INPUT BOARD EP / LSB
INPUT BOARD EPO / EP / EP / EP
KEY OF SYMBOLS
LEVELLING
LIGHTING, WARNING BEACON
LUFFING, LOWERING BRAKE LOWERING B00M
LUFFING, TELESCOPING
MASS DISTRIBUTION
MASTER SWITCH LEFT
MASTER SWITCH LEFT / RIGHT
MASTER SWITCH RIGHT
MASTER SWITCH, DEAD MAN
MONITOR
OIL PRESSURE, CHARGE AIR PRESSURE, CHARGE AIR TEMPERATURE
OPERATING EQUIPMENT
OUTLINE OF DEVICE
OUTRIGGERS
PLUG GROUPING
POWER PACK
PRESSURE SENSOR LUFFING CYLINDER
RADIATOR I
RADIO, SOCKET V ( OPTION )
REGISTER OF SHEETS
RESERVE
SEAT SPRINGING,
SLEWING GEAR, FREE-WHEEL SLEWING GEAR, CIRCULATION
SLEWING GEAR, SPEED TRANSDUCER SLEWING GEAR
SLEWING PLATFORM ADJUSTMENT
SLI, CUTOFF SLI, OVERLOAD, BUZZER SLI
SPEED, SPEED INDEX, DIESEL ENGINE SPEED
SUPPORTING PRESSURE INDICATOR
TELEDIAGNOSIS GSM WITH TC Terminal
TELESC. SECT. INTERLOCK ( MANUAL OPERATION )
TELESC. SECT. INTERLOCK,
TELESCOPING, INITIAL TENSION RING AREA
TELESCOPING, LUFFING, FOLDING JIB LUFFING
TOP OF LIFT
TOP OF LIFT, HOISTING LIMIT SWITCH TELESC. SECTION
VENTILATOR LICCON
VERSION
VOLTAGE SUPPLY EXCESS PRESSURE
WIND WARNING
WIND WARNING, FLASHING LIGHT
WORKING PROJECTOR W BASE SECTION
WORKING PROJECTOR W B00M HEAD
WORKING PROJECTOR XW BASE SECTION
