Liebherr LTM 1160-5.2 Z68625 Electrics System Carrier Circuit Diagram
Brand: Liebherr
Type of Machine: Telescopic Mobile Crane
Type of Manual: Circuit Diagrams
Model: LTM 1160-5.2 Telescopic Mobile Crane
Serial Number: Z68625 or 068625
Number of Pages: 169 Pages
Ident. Nr.: 98006761
Zeich Nr.: 6201-920.00.01.000-011
INTERFACE: DIESEL ENGINE STUFE 4/TIER 4f+ LICCON2
EXHAUST GAS TREATMENT: SCR(AdBlue)
TRANSMISSION: AS-Tronic
TRANSFER CASE: 2 stufiges VG2750
ENGINE: D946A7
ABV 4-CHANNELABV 6-CHANNEL
ABV CONTROL DEVICE DRIVER'S CAB 4-CHANNEL
ABV CONTROL DEVICE GENERAL LAYOUT 4-CHANNEL
ABV ELECTRICAL SOCKET
AIR CONDITIONING SYSTEM
AIR DRIER
AIR PRESSURE RESERVE
ANTI-THEFT
ANTI-THEFT DEVICE
AUXILIARY HEATER AIRTOP 2000ST
AUXILIARY HEATER AIRTOP EVO 55D
AUXILIARY HEATER PRESELECTOR CLOCK
AUXILIARY HEATER SELECTION
AUXILIARY HEATER THERMO PRO 90
AUXILIARY HEATER THERMO PRO FUNCTIONAL DIAGRAMM
AUXILIARY HEATER THERMO S 230
AUXILIARY HEATER THERMO S 230 FUNCTIONAL DIAGRAMM
BACK UP CAMERA
BATTERIES
BMK-INDEX
BOOM IN RECEPTACLE FRAME (BRAKE POWER REDUCTION)
BRAKE PRESSURE
CAMERA WASHING PUMP
CAN 1 (IES)
CAN 2 (IES)
CAN 3 (IES) VEHICLE
CAN 4 (J1939)
CAN 5 (J1939)
CAN LIDEC (DlESEL ENGINE)
CHANGE OVER DIAPHRAGM RESERVOIR SUSPENSION
CHARGING SET 110V / 230V
CIGARETTE LIGHTER
CIRCUIT DIAGRAM ELECTRICS SYSTEM CARRIER
COOLANT PREHEATING 110V / 230V
COOLING WATER LEVEL
CRANE HYDRAULICS
DESCRIPTION OF SYMBOLS
DIAGNOSIS
DIESEL ENGINE EXHAUST FINISHING TREATMENT SCRF
DIESEL ENGINE ACCELERATOR
DIESEL ENGINE DIAGNOSIS
DIESEL ENGINE ECU SUPPLY
DIESEL ENGINE FAN VALVE
DIESEL ENGINE INJECTOR 1-6
DIESEL ENGINE PRESSURE SENSOR
DIESEL ENGINE RPM SENSOR
DIESEL ENGINE TEMPERATURE SENSOR
DIESEL ENGINE WASTE-GATE
DIFFERENTIAL LOCKS
DIFFERENTIAL LOCKS FUNCTIONAL DIAGRAMM
DISPLAY UNIT DRIVER'S CAB TYPE E
DISPLAY UNIT GENERAL LAYOUT TYPE E
DOLLY OPERATION
DOOR CONTACT SWITCH
EDDY CURRENT BRAKE
ELECTRICAL SOCKET 12V
ELECTRICAL SOCKET DOLLY
EMERGENCY STOP
ENGINE BRAKE
ENGINE CONTROL UNIT GENERAL LAYOUT
ENGINE CONTROL UNIT GENERAL LAYOUT X2 CODE B
ENGINE CONTROL UNIT GENERAL LAYOUT X3 CODE C
ENGINE CONTROL UNIT GENERAL LAYOUT X4 CODE D
ENGINE CONTROL UNIT MOTOR PLUG -X3 / -X4
ENGINE CONTROL UNIT VEHICLE PLUG
ENGINE OIL SENSOR
EXTERNAL FEEDING 110V / 230V
FAN HEATER 110V / 230V
FAN HEATER DRIVER'S CAB -400C
FAN HEATER TRANSMISSION -400C
FIRE EXTINGUISHING SYSTEM
FUEL PREHEATING
FUEL PUMP
FUSE GROUPING
FUSES DRIVER'S CAB
GENERAL LAYOUT CABLE INSTALLATION CARRIER
GENERAL LAYOUT CAN
GENERAL LAYOUT CRANE-EMERGENCY OPERATION
GENERAL LAYOUT EMERGENCY STOP
GENERAL LAYOUT LIGHTING
GENERAL LAYOUT LSB1 / 5
GENERAL LAYOUT SERVICE FLUID LIGHTING
GENERAL LAYOUT SERVICE FLUID SOCKETS
GENERAL LAYOUT VOLTAGE SUPPLY 30er
GENERATOR
HEAT EXCHANGER DRIVER'S CAB
HEAT EXCHANGER DRIVER'S CAB -400C
HEATER FLANGE
HEATING
HOOTER
HYDRAULIC OIL
INCLINATION SENSOR
INTARDER
INTARDER CONTROL DEVICE GENERAL LAYOUT
INTARDER CONTROL DEVICE VEHICLE
KEY BOARD UNIT / DISPLAY UNIT
KEY BOARD UNIT DRIVER'S CAB TYPE C
KEY BOARD UNIT GENERAL LAYOUT TYPE C
KEY OF SYMBOLS
LIGHTING ADDITIONAL PROJECTOR FRONT
LIGHTING BUMPER FRONT
LIGHTING DRIVER'S CAB
LIGHTING LEFT SiDE
LIGHTING REAR
LIGHTING RIGHT SIDE
LIGHTING SLIDING BEAMS
LIGHTING STEERING COLUMN SWITCH
LOOM OF CABLES WL110; WL31
LSB - CONVERTERS DRIVER'S CAB
LSB - CONVERTERS GENERAL LAYOUT
LSB 5
LSB-BTB DRIVER'S CAB
LSB-BTB GENERAL LAYOUT
LSB-BTB VOLTAGE SUPPLY
LSB-I/O-MODULE 1 DRIVER'S CAB
LSB-I/O-MODULE 1 GENERAL LAYOUT
LSB-I/O-MODULE 2 DRIVER'S CAB
LSB-I/O-MODULE 2 GENERAL LAYOUT
LSB-I/O-MODULE 3 DRIVER'S CAB
LSB-I/O-MODULE 3 GENERAL LAYOUT
LSB-I/O-MODULE 4 DRIVER'S CAB
LSB-I/O-MODULE 4 GENERAL LAYOUT
LSBI
MAIN FUSE
MASS DISTRIBUTION
MASS DISTRIBUTION VEHICLE
MIRROR HEATING
MIRRORADJUSTMENT
MODIFICATION SHEET
MONITORING BRAKE PADS
OFF-ROAD GEAR
OIL SENSORS ANGLETRANSMISSION TRANSFER CASE
OUTLINE OF DEVICE
OUTRIGGERS
OUTSIDE TEMPERATURE
PLUG GROUPING GENERAL LAYOUT
POWER TRAIN
POWER TRAIN FUNCTIONAL DIAGRAMM
RADIO
RADIO PREPARATION 24V
RADIO REMOTE CONTROL LOADING STATION
REAR AXLE STEERING
RECOVERY WINCH
ROAD GEAR
SEAT HEATING
SLIDING BEAM MONITOR
SLIDING BEAM MONITOR VARIATiONS
SOCKETS LIGHTING WARNING TAG
SOCKETS TRAILER
SPI
STARTER
STEERING COLUMN SWITCH RIGHT
STEERING PUMP
SUPPORT PRESSURE MONITOR
SUPPORT PRESSURE MONITOR VARIATIONS
SUSPENSION
SUSPENSION EQUALIZATION
TANK
Contents
TELEMETRY FMS-INTERFACE
TRAILER SOCKET 7POL. ADDITIONAL
TRANSFER CASE
TRANSMISSION DIAGNOSIS
TRANSMISSION ECU VOLTAGE SUPPLY
TRANSMISSION INDUCTIVE SENSOR OUTPUT
TRANSMISSIONCONTROL DEVICE GENERAL LAYOUT
TRANSMISSIONCONTROL DEViCE VEHICLE
VENTILATION FLAP
VENTILATOR CENTER CONSOLE
VOLTAGE SUPPLY 12V
VOLTAGE SUPPLY CODING EA-MODULE 1/2/3
VOLTAGE SUPPLY DISPLAY-/KEY BOARD UNiT
VOLTAGE SUPPLY I)O-MODULE 1/2)3i4
VOLTAGE SUPPLY SPECIAL FUNCTIONS
WARNING BEACON
WARNING SIGNAL REVERSING
WINDOW LIFTER
WINDSCREEN WIPER
ZERO POSITION
xi CODE A
