Hyundai
86
176,684
Liebherr Engine D9512 A7 D9512 A7-00 Repair Instruction Manual 11351360
Brand: Liebherr
Type of Manual: Repair Instruction Manual
Model: Liebherr D9512 A7 D9512 A7-00 Engine
From Serial Number 2010-16-0000
Part Number: 11351360
Publication Date: 2020
Number of Pages: 356 Pages
1 General information
1.1 Structure of this manual​
1.2 Important information in this manual​
1.3 Safety instructions​
1.4 Target group​
1.5 Intended use​
1.6 Limitation of liability​
1.7 General safety instructions​
1.8 Preventing personal injuries​
1.9 Personal protective equipment​
1.10 Operating and maintenance areas​
1.11 Preventing property damage​
1.12 Technical data​
1.13 Standard torques​
1.14 Special torques, tightening instructions and instructions for mounting​
1.15 Cleaning agents, locking agents and greases​
1.16 Engine illustrations and engine parts​
1.17 Fuel system​
1.18 Lubrication circuit diagram​
1.19 Coolant diagram​
1.20 Charge air diagram​
1.21 Assignment of the channels in the crankcase and in the cylinder head​
1.22 Transport device and fastening parts​
1.23 Tools​
2 Cylinder head, engine control unit and valves
2.1 Removing, installing the cylinder head cover​
2.2 Removing, installing the rocker arm bracket and push rods​
2.3 Removing, installing the valve bridge​
2.4 Removing, installing the cylinder head​
2.5 Removing, installing the valve stem seals, valve springs, valves​
2.6 Removing, installing the roller plunger​
2.7 Removing, installing the camshaft​
3 Driving gear
3.1 Removing, installing the piston with connecting rod and piston rings​
3.2 Removing, installing the cylinder liner​
3.3 Removing, installing the crankshaft attachments​
3.4 Removing, installing the front crankshaft seal​
3.5 Removing, installing the ancillary support housing​
3.6 Removing, installing the intermediate wheel​
3.7 Removing, installing the flywheel​
3.8 Removing, installing the rear crankshaft seal​
3.9 Removing, installing the crankshaft gear wheel​
3.10 Removing, installing the flywheel housing​
3.11 Removing, installing the crankshaft​
3.12 Removing, installing the crankcase locking parts​
4 Fuel and injection system - Bosch variant
4.1 Safety instructions for working on the fuel and injection system​
4.2 Removing, installing the fuel lines​
4.3 Removing, installing the fuel fine filter module (KSC module)​
4.4 Removing, installing the injection pipe​
4.5 Removing, installing the pressure pipe socket and injector​
4.6 Removing, installing the high pressure pump​
4.7 Removing, installing the drive for the high pressure pump​
5 Fuel and injection system - Liebherr variant
5.1 Safety instructions for working on the fuel and injection system​
5.2 Removing, installing the fuel lines​
5.3 Removing, installing the fuel fine filter module (KSC module)​
5.4 Removing, installing the injection pipe​
5.5 Removing, installing the rail​
5.6 Removing, installing the pressure pipe socket and injector​
5.7 Removing, installing the high pressure pump​
5.8 Removing, installing the drive for the high pressure pump​
6 Belt drive
6.1 Removing, installing the alternator V-ribbed belt tensioning device​
6.2 Removing, installing the air conditioning compressor V-ribbed belt tensioning device​
7 Charge air and exhaust system
7.1 Removing, installing the exhaust pipe​
7.2 Removing, installing the exhaust manifold​
7.3 Removing, installing the exhaust gas turbocharger​
7.4 Removing, installing the heat protection​
7.5 Removing, installing the air intake pipe​
7.6 Removing, installing the charge air pipe​
7.7 Removing, installing the connection line​
7.8 Removing, installing the charging pressure control​
8 Electrical system
8.1 Removing, installing the heating flange​
8.2 Removing, installing the alternator​
8.3 Removing, installing the starter​
8.4 Removing, installing the engine control unit​
8.5 Removing, installing the sensors​
8.6 Replacing the cable harness​
9 Lubricating system
9.1 Removing, installing the end control valve​
9.2 Removing, installing the crankcase breather system pipeline​
9.3 Removing, installing the crankcase breather system​
9.4 Removing, installing the oil module​
9.5 Removing, installing the oil cooler​
9.6 Removing, installing the oil pan​
9.7 Removing, installing the lubricating oil pump​
9.8 Removing, installing the piston cooling​
9.9 Initial commissioning of the lubricating system​
10 Cooling system
10.1 Removing, installing the ventilation line​
10.2 Removing, installing the coolant manifold​
10.3 Removing, installing the coolant pump​
10.4 Removing, installing the thermostat housing​
10.5 Removing, installing the thermostats​
10.6 Checking the thermostat​
10.7 Removing, installing the coolant manifold​
11 Auxiliary output, air conditioning compressor
11.1 Removing, installing the locking parts for auxiliary outputs​
11.2 Removing, installing the air conditioning compressor​
