Hyundai
86
176,834
Liebherr Engine D9512 A7-04 Repair Manual 11387178
Brand: Liebherr
Type of Manual: Repair Manual
Model: Liebherr D9512 A7-04 Engine
From Serial Number 2014-14-0001
Part Number: 11387178
Publication Date: 2015
Number of Pages: 282 Pages
1 Y General information
1.1 Structure of this manual​
1.2 Important notes in this manual​
1.3 Safety instructions​
1.4 Safety instructions for working on the fuel and injection system​
1.5 Safety instructions for working on the exhaust after-treatment system (SCR system)​
1.6 Engine diagrams and engine components​
1.7 Technical data​
1.8 Standard torques and auxiliary materials​
1.9 Fuel diagram​
1.10 Lubricating oil diagram​
1.11 Coolant diagram​
1.12 Assigning the channels in the crankcase and the cylinder head​
1.13 Transport device and fastening parts​
1.14 Tools​
2 Cylinder head, engine control unit and valves
2.1 Removing and installing the cylinder head cover​
2.2 Removing and installing the rocker arm bracket and push rods​
2.3 Removing and installing the valve bridge​
2.4 Removing and installing the cylinder head​
2.5 Removing and installing the valve stem seal, valve springs, valves​
2.6 Removing and installing the roller tappet​
2.7 Removing and installing the camshaft​
2.8 Removing and installing the camshaft bearing​
3 Driving gear
3.1 Removing and installing the piston with connecting rod and piston rings​
3.2 Removing and installing the cylinder liner​
3.3 Removing and installing the crankshaft attachments​
3.4 Removing and installing the front crankshaft seal​
3.5 Removing and installing the unit carrier​
3.6 Removing and installing the intermediate wheel​
3.7 Removing and installing the flywheel​
3.8 Removing and installing the rear crankshaft seal​
3.9 Removing and installing the crankshaft gear wheel​
3.10 Removing and installing the flywheel housing​
3.11 Removing and installing the crankshaft​
4 Fuel and injection system
4.1 Removing and installing the fuel lines​
4.2 Removing and installing the injection line​
4.3 Removing and installing the rail​
4.4 Removing and installing the pressure pipe branch and injector​
4.5 Removing and installing the fuel fine filter module (KSC module)​
4.6 Removing and installing the high pressure pump​
4.7 Removing and installing the high pressure pump drive​
5 Belt drive
5.1 Removing and installing the V-ribbed belt tensioning device alternator​
5.2 Removing and installing the V-ribbed belt tensioning device air conditioning compressor​
6 Charge air and exhaust system
6.1 Removing and installing the exhaust pipe​
6.2 Removing and installing the exhaust manifold​
6.3 Removing and installing the exhaust turbocharger​
6.4 Removing and installing the heat shield​
6.5 Removing and installing the air intake pipe​
6.6 Removing and installing the charge air line​
6.7 Removing and installing the connecting line​
6.8 SCR exhaust after-treatment system​
7 Electrical system
7.1 Removing and installing the heating flange​
7.2 Removing and installing the alternator​
7.3 Removing and installing the starter​
7.4 Removing and installing sensors​
7.5 Removing and installing the engine control unit​
7.6 Removing and installing the engine control unit attachment​
7.7 Replacing the cable harness​
8 Lubrication system
8.1 Removing and installing the end control valve​
8.2 Removing and installing the crankcase ventilation pipeline​
8.3 Removing and installing the crankcase ventilation​
8.4 Removing and installing the oil module​
8.5 Removing and installing the oil cooler​
8.6 Removing and installing the oil pan​
8.7 Removing and installing the lubricating oil pump​
8.8 Removing and installing the piston cooling​
8.9 Initial commissioning of the lubrication system​
9 Cooling system
9.1 Removing and installing the ventilation line​
9.2 Removing and installing the coolant manifold​
9.3 Removing and installing the coolant pump​
9.4 Removing and installing the thermostat housing​
9.5 Removing and installing the thermostats​
9.6 Check the thermostat​
10 Auxiliary output, air conditioning compressor, fan
10.1 Removing and installing the air conditioning compressor​
11 Appendix
11.1 Symbols in this manual​
11.2 Abbreviations used​
