Liebherr Diesel Engine D856 A7 Repair Manual 9739974
Brand: Liebherr
Type of Machine: Diesel Engine
Type of Manual: Repair Manual
Model: Liebherr D856 A7 Diesel Engine
Part Number: 9739974
Number of Pages: 630 Pages
Repair Manual
Foreword
Explanation of symbols
Warnings
4. Regulations for avoiding injury and environmental contamination
6. Emergency drive programme for units with electronic control units
7. Installation information
Installation of screws/bolts and nuts
Explanation of model plate
Explanation of model designation
Technical data
D856 A7
Engine description
Engine electrics variant A
Engine electrics variant B
Engine electrics variant C
Engine electrics variant D
Engine electrics
Engine electrics (rear left view) remove, install
Coolant manifold remove, install (variant A and B)
Technical data
Coolant manifold remove, install (variant C)
Technical data
Coolant manifold remove, install (variant D)
Technical data
Thermostats remove, install (variant A, B)
Technical data
Thermostats remove, install (variant C)
Technical data
Thermostats remove, install (variant D)
Technical data
Additional work
Thermostat housing remove, install (variant C)
Additional work
Thermostat housing remove, install (variant D)
Additional work
Coolant pump remove, install (variant A, B)
Important information
Install poly-V-belt
Coolant pump remove, install (variant C)
Install poly-V-belt
Coolant pump remove, install (variant D)
Install poly-V-belt
Distributor housing remove, install (variant A, B)
Additional work
Distributor housing remove, install (variant C)
Additional work
Distributor housing remove, install (variant D)
Additional work
Fan hub remove, install (variant A, B)
Technical data
Fan drive remove, install (variant A, B)
Additional work
Add-on units
Air compressor (2-cylinder) remove, install
Technical data
Additional work
Technical data
Special tools
Mount disassembly tool on air compressor
Remove cover
Remove cover
Unscrew drive gear mounting bolt
Remove air compressor drive gear
Remove cylinder head
Remove valve plate
Remove cylinder-head gasket
Remove plates
Remove connecting rod bearing shells
Remove piston
Remove piston pin
Remove piston rings
Remove crankshaft
Assemble air compressor
Install crankshaft
Install piston rings
Install piston pin
Install piston
Mount connecting rod bearing shells
Install plates
Fit cylinder head gasket
Mount valve plate
Tightening sequence, cylinder head
Mount cylinder head
Insert air compressor drive gear
Tighten drive gear mounting bolt
Install cover
Mount cover
Air compressor (2-cylinder with power take-off) remove, install
Technical data
Additional work
Technical data
Special tools
Remove cover
Remove cover
Remove cover
Unscrew drive gear mounting bolts
Remove power take-off drive gear
Remove valve plate
Remove plates
Remove piston
Remove piston pin
Remove piston rings
Remove power take-off shaft
Remove crankshaft
Install crankshaft
Install piston pin
Install piston
Install power take-off shaft
Install plates
Mount valve plate
Mount cylinder head
Insert power take-off drive gear
Tighten drive gear mounting bolts
Mount cover
Install cover
Mount cover
Air compressor (1-cylinder) remove, install
Technical data
Additional work
Technical data
Special tools
Remove cover
Remove valve plate
Remove plates
Remove piston
Remove piston pin
Remove piston rings
Remove crankshaft
Install crankshaft
Install piston pin
Install piston
Mount conrod bearing shell
Install plates
Mount valve plate
Mount cylinder head
Install cover
Starter remove, install
Technical data
Belt drive remove, install
Technical data
Belt drive remove, install (variant C)
Technical data
Alternator remove, install
Technical data
Refrigerant compressor remove, install
Injectors remove, install
Technical data
Rail (common rail) remove, install
Technical data
Fuel service centre remove, install
Fuel service centre dismantle, assemble
Technical data
Special tools
Dismantling the fuel service centre
Allow the fuel service centre (FSC) to drain
Remove heating element
Remove pressure sensor
Remove fuel filter
Remove hand pump housing
Remove support dome
Assemble fuel service centre
Install support dome
Mount hand pump housing
Install fuel filter
Tighten fuel prefilter cover
Tighten fuel filter cover
Install pressure sensor
Install heating element
High-pressure pump remove, install
Additional work
High-pressure pump dismantle, assemble
Additional work
Technical data
Special tools
Dismantle high-pressure pump
Remove metering unit
Remove fuel pump
Remove overflow and flow control valve
Assemble high-pressure pump
Install overflow and flow control valve
Install fuel pump
Install metering unit
High-pressure pump drive remove, install
Additional work
High-pressure pump drive dismantle, assemble
Additional work
Technical data
Dismantle high-pressure pump drive
Remove drive shaft
Remove drive gear
Unscrew plug screw
Assemble high-pressure pump drive
Screw in locking screw
Install drive gear
Install drive shaft
Flame start system remove, install (variant A, B and D)
Technical data
Remove solenoid valve
Install flame start system
Mount solenoid valve
Mount flame glow plug
Flame start system remove, install (variant C)
Technical data
Turbocharging
Charge-air manifold remove, install (variant A, B and D)
Additional work
Charge-air manifold remove, install (variant C)
Additional work
Exhaust turbocharger remove, install (variant A, B and C)
Technical data
Exhaust turbocharger remove, install (variant D)
Technical data
Exhaust system
Exhaust manifold remove, install
Additional work
Cylinder head
Rocker arm mechanism remove, install
Additional work
Dismantle and assemble rocker arm mechanism
Additional work
Cylinder head remove, install
Additional work
Valve clearance check, adjust
Valve stem seals, remove, install
Additional work
Mount cylinder head cover
Valve drive
Camshaft/camshaft bearing remove, installation
Additional work
Check camshaft
Check camshaft radial play
Remove camshaft
Check camshaft bearings
Brand: Liebherr
Repair Manual
Foreword
Warnings
Technical data
D856 A7
Engine description
Engine electrics
Technical data
Technical data
Technical data
Technical data
Technical data
Technical data
Additional work
Additional work
Additional work
Install poly-V-belt
Install poly-V-belt
Install poly-V-belt
Additional work
Additional work
Additional work
Technical data
Additional work
Add-on units
Technical data
Additional work
Technical data
Special tools
Remove cover
Remove cover
Remove valve plate
Remove plates
Remove piston
Remove piston pin
Remove piston rings
Remove crankshaft
Install crankshaft
Install piston pin
Install piston
Install plates
Mount valve plate
Mount cylinder head
Install cover
Mount cover
Technical data
Additional work
Technical data
Special tools
Remove cover
Remove cover
Remove cover
Remove valve plate
Remove plates
Remove piston
Remove piston pin
Remove piston rings
Remove crankshaft
Install crankshaft
Install piston pin
Install piston
Install plates
Mount valve plate
Mount cylinder head
Mount cover
Install cover
Mount cover
Technical data
Additional work
Technical data
Special tools
Remove cover
Remove valve plate
Remove plates
Remove piston
Remove piston pin
Remove piston rings
Remove crankshaft
Install crankshaft
Install piston pin
Install piston
Install plates
Mount valve plate
Mount cylinder head
Install cover
Technical data
Technical data
Technical data
Technical data
Technical data
Technical data
Technical data
Special tools
Remove fuel filter
Remove support dome
Install fuel filter
Additional work
Additional work
Technical data
Special tools
Remove fuel pump
Install fuel pump
Additional work
Additional work
Technical data
Remove drive shaft
Remove drive gear
Unscrew plug screw
Install drive gear
Install drive shaft
Technical data
Technical data
Turbocharging
Additional work
Additional work
Technical data
Technical data
Exhaust system
Additional work
Cylinder head
Additional work
Additional work
Additional work
Additional work
Valve drive
Additional work
Check camshaft
Remove camshaft
- Liebherr Diesel Engines 904-926 Service Manual
- Liebherr Software Diagnostic Without Dongle
- LIEBHERR R900 R902 R912 R922 R932 R942 Service Repair Manual
- LIEBHERR excavator A900 , R900 - A944 , R944 service manual
- Liebherr Excavator R952 R952HD R962 R972 R982 Service Manual and Diagram
- Liebherr New Engine CR and PLD Technical Information
- Liebherr Wheel Loader L544 L564 L574 WorkShop Service Manual
- Liebherr R996 Service Manual Hydraulic Excavator
- Liebherr Diesel Engine D846 A7 Maintenance Manual
- Liebherr R944C Hydraulic Excavator Shop Manual
- Liebherr Crawler Dozer PR 776-1296 Service Manual 2015
- Wheel Loader Liebherr L524 - L534 - L538 - Service manual
- Liebherr ZF Transmission Workshop Manual
- Wheel Loader Liebherr L550-L586 2plus2 - Service manual
- Liebherr Mobile Excavator A902 Parts Catalog
