Hyundai
86
176,834
Liebherr Crawler Tractor PR724-PR764 Service Manual
Brand: Liebherr
Type of Machine: Crawler Tractor
Model: Liebherr
PR 724 L - F/N 753-6600 ->
PR 724 XL - F/N 754-6600 ->
PR 724 LGP - F/N 755-6600 ->
PR 734 L - F/N 724-8219 ->
PR 734 XL - F/N 725-8219 ->
PR 734 LGP - F/N 726-8219 ->
PR 744 L - F/N 940-7356 ->
PR 744 LGP - F/N 942-7356 ->
PR 754
PR 764
Number of Pages: 3057 Pages
01 General Information
Foreword and explanation​
Safety guidelines​
Service Items​
Table - charts​
Conservation guidelines​
Weight of materials​
02 Special Tools, Application Guidelines
Special tools​
Repair welding​
Installation instructions​
03 Technical Data, Maintenance Guidelines
Technical data​
Maintenance- and Inspection Guidelines​
Maintenance and inspection instructions​
Quick reference for machine adjustment​
Adjustment checklist​
04 Engine
Technical data​
Fan and cylinder configuration​
Installation kit – Diesel particle filter​
Installation and test list for Diesel particle filter​
05 Coupling, Splitter Box
Technical data​
Coupling​
Splitter box​
Couplings pump drive​
06 Travel Hydraulic
Technical data​
Description​
Function / Schematics​
Test and Adjustment​
Location of components​
07 Working Hydraulic
Technical data​
Description​
08 Hydraulic Components
Variable pump​
Variable motor​
Variable flow pumps and motors​
Constant pumps and motors​
Pilot control valve Working Hydraulic​
Control valve block​
Valves​
Hydraulic cylinder​
09 Electrical System - Plans and Components
Code letter explanations​
Functions​
Fuses, panel points, notes​
Current flow diagram​
Instrument panel​
Travel control devices​
10 Electrical System - Descriptions
Application software - travel drive​
Software PDL – Diesel particle filter​
Service Code List​
11 Final Drive
Technical data​
Description and function​
Sectional view​
12 Track Components
Technical data​
Design, Function, Wear and Evaluation​
Appraisal report and wear charts​
Track roller frame and idler unit​
Track roller​
Carrier roller​
Tension unit​
13 Attachments - front
Straight blade​
6 way blade​
Hydraulic cutting angle adjustment​
14 Attachments - rear
Ripper​
15 Main Frame - Add On Components
Cooler / radiator arrangement​
Lift cylinder mount​
Equalizer bar​
Engine Mounts​
16 Tank Installation's
Hydraulic tank​
Fuel tank​
Battery box​
17 Operators Platform, Heater, Air Conditioner
Operator's platform​
Heater and Blower​
Air conditioner​
Operator’s seat​
Throttle control​
18 Special Attachments
Refueling pump​
Reversible fan​
Cable winch​
Pressure cut off – Travel hydraulic​
19 Additional Documentation
Travel Hydraulic​
Working Hydraulic​
