Liebherr Crawler Loaders PR712 to PR752 Service Manual
Brand: Liebherr
Type of Machine: Crawler Loaders
Model: Liebherr
PR 712 F/N xxx-0103→0500
PR 712B F/N xxx-0501→2999
PR 712B F/N xxx-3000→3083
PR 712B F/N xxx-3084→5599
PR 712B F/N xxx-5600→
PR 722 F/N xxx-0103→1000
PR 722B F/N xxx-1001→3000
PR 722B F/N xxx-3001→3170
PR 722B F/N xxx-3171→5599
PR 722B F/N xxx-5600→
PR 732 F/N xxx-2003→2500
PR 732B F/N xxx-2501→2999
PR 732B F/N xxx-3000→3135
PR 732B F/N xxx-3136→5599
PR 732B F/N xxx-5600→
PR 742 F/N xxx-2001→2500
PR 742B F/N xxx-2501→2999
PR 742B F/N xxx-3000→3088
PR 742B F/N xxx-3089→5233
PR 742B F/N xxx-5234→5599
PR 742B F/N xxx-5600→
PR 752 F/N xxx-2002→5599
PR 752 F/N xxx-5600→6199
PR 752 F/N xxx-6200→
Publication Date: 2009
Number of Pages: 1718 Pages
1 General Information
Brand: Liebherr
Model: Liebherr
Foreword and explanation
Safety guidelines
Hand signals
Service items
Table - charts
Code letters + terminal designations
2 Special Tools, Application GuidelinesSpecial tools
Repair welding
Installation guidelines
3 Technical Data - Maintenance GuidelinesTechnical data
Maintenance and inspection guidelines
Maintenance and inspection instructions
Adjustment checklist and quick reference
4 EngineTechnical data LH engine
Power, torque LH engine
Fan and cylinder configuration LH Diesel engine
Remove and Install Engine fan
5 Coupling and Splitter BoxTechnical data couling and splitter box
Coupling
Splitter box
6 Travel HydraulicTechnical data
Description
Function / Schematics
Hydraulic hose routing
Test and adjustment
7 Working HydraulicTechnical data
Description
Test and adjustment
8 Hydraulic ComponentsVariable pump travel hydraulic
Variable motor travel hydraulic
Variable flow pump working hydraulic
Constant pumps and motors
Pilot control valve working hydraulic
Control valve block
Valves
Hydraulic cylinder
9 Electrical SystemCurrent flow diagram
Electrical schematic and wiring
Instrument panel
Location of electrical components
10 Electronic ControlElectrical schematic and wiring
Description of function
Diagnostic test box application
Linkage Electronic engine speed sensing horsepower control system
Pedal control tester application
Travel control joystick
11 Travel GearTechnical data
Construction, function travel gear
Remove and install
11.3.10 Travel gear type A
11.3.11 Travel gear type A
11.3.12 Travel gear type A
11.3.13 Travel gear type C
11.3.14 Travel gear type P
11.3.15 Travel gear type P-D
11.3.16 Travel gear type D
11.3.17 Travel gear type D
11.3.50 Travel gear PR 752
11.3.51 Travel gear PR 752
11.3.52 Travel gear PR 752
12 Track ComponentsTechnical data
Description, function, wear effects
Measuring instructions and evaluation of wear
Appraisal report
Wear chart
Front idler
Track adjuster unit
Track roller
Carrier roller
Track roller frame
Support shaft preassembled
13 Attachments - frontAttachment - straight- / semi-U-blade
Attachment - 6-way-blade
14 Attachments - rearAttachment - ripper
Attachment - cable winch
15 Main Frame - Add On ComponentsCooler / radiator arrangement
Lift cylinder mount
Engine mounts
Equalizer bar
16 Tank Installation'sHydraulic tank
Fuel tank
Battery box
17 Operators Platform, Heater, Air ConditionerHydraulic tilting device
Heater and blower
Engine operation
Air conditioner
18 Special AttachmentsElectrical schematic - canopy
Refueling pump
Electrical schematics - additional lights
Electrical schematics - additional heaters
Operator's seat with air suspension
Hydraulic oil temperature gauge
Reversible fans
19 Miscellaneous InformationsStorage (preservation) guidelines
Material classification
Weight of materials
- Liebherr Diesel Engines 904-926 Service Manual
- Liebherr Software Diagnostic Without Dongle
- LIEBHERR R900 R902 R912 R922 R932 R942 Service Repair Manual
- LIEBHERR excavator A900 , R900 - A944 , R944 service manual
- Liebherr Excavator R952 R952HD R962 R972 R982 Service Manual and Diagram
- Liebherr New Engine CR and PLD Technical Information
- Liebherr Wheel Loader L544 L564 L574 WorkShop Service Manual
- Liebherr R996 Service Manual Hydraulic Excavator
- Liebherr Diesel Engine D846 A7 Maintenance Manual
- Liebherr R944C Hydraulic Excavator Shop Manual
- Liebherr Crawler Dozer PR 776-1296 Service Manual 2015
- Wheel Loader Liebherr L524 - L534 - L538 - Service manual
- Liebherr ZF Transmission Workshop Manual
- Wheel Loader Liebherr L550-L586 2plus2 - Service manual
- Liebherr Mobile Excavator A902 Parts Catalog
