Hyundai
86
176,834
Liebherr Crawler Loaders LR622 LR622B LR632B LR632 Service Manual
Brand: Liebherr
Type of Machine: Crawler Loaders
Model: Liebherr
LR 622 F/N 392-2030→2287
LR 622 F/N 392-2288→5599
LR 622 F/N 392-5600→6199
LR 622B F/N 392-6200→
LR 632 F/N 393-2003→2197
LR 632 F/N 393-2198→5599
LR 632 F/N 393-5600→6199
LR 632B F/N 393-6200→
Number of Pages: 978 Pages
1 General Information
Foreword and explanation​
Safety guidelines​
Hand signals​
Service items​
Table - charts​
Code letters + terminal designations​
2 Special Tools, Application Guidelines
Special tools​
Repair welding​
Installation guidelines​
3 Technical Data - Maintenance Guidelines
Technical data​
Maintenance and inspection guidelines​
Maintenance and inspection instructions​
Adjustment checklist and quick reference​
4 Engine
Technical data LH engine​
Power, torque LH engine​
Fan and cylinder configuration LH Diesel engine​
5 Coupling and Splitter Box
Technical data couling and splitter box​
Coupling​
Splitter box​
6 Travel Hydraulic
Technical data​
Description​
Function / Schematics​
Hydraulic hose routing​
Test and adjustment​
7 Working Hydraulic
Technical data​
Description​
8 Hydraulic Components
Variable pump travel hydraulic​
Variable motor travel hydraulic​
Variable flow pump working hydraulic​
Constant pumps and motors​
Pilot control valve working hydraulic​
Control valve block​
Valves​
Hydraulic cylinder​
9 Electrical System
Current flow diagram​
Electrical schematic and wiring​
Instrument panel​
10 Electronic Control
Description of function​
Diagnostic test box application​
Pedal control tester application​
Travel control joystick​
11 Travel Gear
Technical data​
Construction, function travel gear​
Remove and install​
11.3.20 Travel gear type P​
11.3.21 Travel gear type P-D​
11.3.22 Travel gear type D​
12 Track Components
Technical data​
Description, function, wear effects​
Measuring instructions and evaluation of wear​
Appraisal report​
Wear chart​
Front idler​
Track adjuster unit​
Track roller​
Carrier roller​
Track roller frame​
Support shaft preassembled​
13 Attachments - front
Mechanical end stops - bucket attachment​
Attachment - multi purpose bucket​
14 Attachments - rear
Attachment - ripper​
15 Main Frame - Add On Components
Cooler / radiator arrangement​
Equalizer bar​
16 Tank Installation's
Hydraulic tank​
Fuel tank​
Battery box​
17 Operators Platform, Heater, Air Conditioner
Hydraulic tilting device​
Heater and blower​
Engine operation​
Air conditioner​
18 Special Attachments
Refueling pump​
Arrangement - additional lights​
Operator's seat with air suspension​
Windshield wiper - interval switch​
Hydraulic oil temperature gauge​
19 Miscellaneous Informations
Storage (preservation) guidelines​
Material classification​
Weight of materials​
