Liebherr Crawler Dozer PR776-1296 Service Manual
- Download this document, you need 8625 Gallons
Brand: Liebherr
Type of Machine: Bulldozer
Type of Document: Service Manual, Electric and Hydraulic Diagrams
Model: Liebherr PR776-1296
Order Number: 12254329
Date: 2023
Number of Pages: 908 Pages
010 Introduction
Brand: Liebherr
Date: 2023
010 Introduction
010.1 Safety instructions
010.2 Special tools for maintenance and repair work
010.3 Standards and specifications
010.4 Conservation guidelines
010.5 Repair welding
010.6 Hydraulic symbols
010.7 Electrical symbols
010.8 Material weights
020 Technical data020.1 Complete machine
020.2 Drive group
020.3 Cooling system
020.4 Working hydraulics
020.5 Travel hydraulics
020.6 Hydraulic components
020.7 Electrical system
020.8 Travel gearbox
020.9 Travel gear, axles, tyres, drive shafts
020.10 Working attachment
030 Maintenance030.1 Maintenance and inspection schedule
030.2 Fill quantities and lubrication chart
030.3 Lubricants and fuels
030.4 Maintenance tasks
030.5 Adjustment checklist
030.6 Adjustment procedure
040 Drive group040.1 Diesel engine
040.2 Clutch
040.3 Splitter box
050 Cooling system050.1 Complete cooling system
050.2 Cooler arrangement
050.3 Hydraulic
050.4 Cooling system - Full overview
060 Working hydraulics060.1 Working hydraulics - Full overview
060.2 Regulating pump
060.3 Proportional control valve block
060.4 Working hydraulic pilot control unit
060.5 Hydraulic cylinder
070 Travel hydraulics070.1 Complete travel hydraulics
070.2 Travel hydraulics - Full overview
070.3 Regulating pump
070.4 Variable displacement pump
070.5 Variable displacement motors
070.6 Distributor block
080 Hydraulic components080.1 Hydraulic cylinder
080.2 Valves
080.3 Hydraulic tank
100 Brake system100.1 Inching brake pedal
110 Electrical system110.1 Electrical system - Full overview
110.2 Lighting system
110.3 Circuit diagrams
110.4 Electrical components of operator's cab
110.5 Electrical components - Heatable exterior mirror (option)
110.6 Electrical components - Diesel engine
110.7 Diesel engine electrical components
110.8 Electrical components - Main frame
110.9 Electrical components - Main frame
110.10 Electrical components Compartments
110.11 Display unit
110.12 Electrical components LiDAT (option)
110.13 Electrical components LiTU3 (option)
110.14 Electrical components - Incline alarm (option)
110.15 Electrical components - Data interface (option)
110.16 Electrical components - Input module A240 (option)
110.17 Electrical components - Output module A135 (option)
110.18 Electrical components - Travel hydraulics pressure cut-off
110.19 Electrical components - Acoustic reversing warning device (option)
110.20 Electrical components - Disengageable reversing warning device (option)
110.21 Electrical components - Optical reversing warning device (option)
110.22 Electrical components - Engine after-run
110.23 Electrical components - Access ladder
110.24 Electrical components - Warm water heating device (option)
110.25 Electrical components - Jump-start (option)
110.26 Electrical components - Reversible fan drive (option)
110.27 Electrical components - Working hydraulics cutting angle adjustment (option)
110.28 Electrical components - 3-point belt with warning sound (option)
110.29 Electrical components - Supply box for external users (option)
110.30 Electrical components - Coolant level check (option)
110.31 Electrical components - External operating hour meter (option)
110.32 Electrical components - Generator disconnecting switch (option)
110.33 Electrical components - Ripper headlight (option)
120 Travel gearbox120.1 Travel gear, overall
120.2 Brake system
120.3 Duo cone slipring seal
120.4 External oil supply
130 Travel gear, axles, tyres, drive shafts130.1 Undercarriage frame
130.2 Idler
130.3 Tension unit
130.4 Track roller
130.5 Carrier roller (Optional)
130.6 Function, wear and evaluation
140 Steel components Basic machine140.1 Lift cylinder suspension
140.2 Oscillating axle frame
140.3 Push frame
150 Working attachment150.1 Semi U-blade
150.2 Hydraulic cutting angle adjustment
150.3 Ripper
150.4 Cutting angle adjustment - Ripper
160 Operator's cab, heating and air conditioning160.1 Operator’s platform
160.2 Operator's cab
160.3 Heater and ventilation
160.4 Heating, ventilation, air conditioning
190 Options190.1 Reversible fan drive
200 Service codes, diagnosis200.1 Test and adjustment software
- Liebherr Diesel Engines 904-926 Service Manual
- Liebherr Software Diagnostic Without Dongle
- LIEBHERR R900 R902 R912 R922 R932 R942 Service Repair Manual
- LIEBHERR excavator A900 , R900 - A944 , R944 service manual
- Liebherr Excavator R952 R952HD R962 R972 R982 Service Manual and Diagram
- Liebherr New Engine CR and PLD Technical Information
- Liebherr Wheel Loader L544 L564 L574 WorkShop Service Manual
- Liebherr R996 Service Manual Hydraulic Excavator
- Liebherr Diesel Engine D846 A7 Maintenance Manual
- Liebherr R944C Hydraulic Excavator Shop Manual
- Liebherr Crawler Dozer PR 776-1296 Service Manual 2015
- Wheel Loader Liebherr L524 - L534 - L538 - Service manual
- Liebherr ZF Transmission Workshop Manual
- Wheel Loader Liebherr L550-L586 2plus2 - Service manual
- Liebherr Mobile Excavator A902 Parts Catalog
