Hyundai
86
176,684
Liebherr Crawler Dozer PR766-1421 Service Manual 12216964
Brand: Liebherr
Type of Machine: Crawler Dozer
Model: Liebherr PR766-1421 Crawler Dozer
Order Number: 12216964
Publication Date: 2021
Number of Pages: 827 Pages
010 Introduction
010.1 Safety instructions​
010.2 Special tools for maintenance and repair work​
010.3 Standards and specifications​
010.4 Conservation guidelines​
010.5 Repair welding​
010.6 Hydraulic symbols​
010.7 Electrical symbols​
010.8 Material weights​
020 Technical data
020.1 Complete machine​
020.2 Drive group​
020.3 Cooling system​
020.4 Working hydraulics​
020.5 Travel hydraulics​
020.6 Hydraulic components​
020.7 Electrical system​
020.8 Travel gearbox​
020.9 Travel gear, axles, tyres, drive shafts​
020.10 Working attachment​
030 Maintenance
030.1 Maintenance and inspection schedule​
030.2 Fill quantities and lubrication chart​
030.3 Lubricants and fuels​
030.4 Maintenance tasks​
030.5 Adjustment checklist​
030.6 Adjustment procedure​
040 Drive group
040.1 Diesel engine​
040.2 Clutch​
040.3 Splitter box​
040.4 Couplings - Pump output​
050 Cooling system
050.1 Complete cooling system​
050.2 Cooler arrangement​
050.3 Hydraulic​
060 Working hydraulics
060.1 Working hydraulics - full overview​
060.2 Regulating pump​
060.3 Proportional control valve block​
060.4 Working hydraulic pilot control unit​
060.5 Hydraulic cylinder​
070 Travel hydraulics
070.1 Travel hydraulics overview​
070.2 Double gear pump - replenishing​
070.3 Variable displacement pump​
070.4 Variable displacement motors​
070.5 Distributor block​
080 Hydraulic components
080.1 Double gear pump replenishing​
080.2 Hydraulic cylinder​
080.3 Valves​
080.4 Hydraulic tank​
100 Brake system
100.1 Inching brake pedal​
110 Electrical system
110.1 Electrical system - full overview​
110.2 Lighting system​
110.3 Circuit diagrams​
110.4 Electrical components of operator's cab​
110.5 Electrical components - Heatable exterior mirror (option)​
110.6 Electrical components - Diesel engine​
110.7 Electrical components - main frame​
110.8 Electrical components Compartments​
110.9 Display unit​
110.10 Electrical components LiTU2 (option)​
110.11 Electrical components LiTU3 (option)​
120 Travel gearbox
120.1 Travel gearbox, overall​
120.2 Brake system​
120.3 Duo cone slipring seal​
120.4 External oil supply​
130 Travel gear, axles, tyres, drive shafts
130.1 Undercarriage frame​
130.2 Idler​
130.3 Tension unit​
130.4 Tension unit – removal​
130.5 Tension unit - installation​
130.6 Track roller​
130.7 Carrier roller (option)​
130.8 Function, wear and evaluation​
140 Steel components Basic machine
140.1 Lift cylinder suspension​
140.2 Equaliser bar​
140.3 Push frame (outside)​
150 Working attachment
150.1 Straight blade​
150.2 Hydraulic cutting angle adjustment​
150.3 Ripper​
150.4 Cutting angle adjustment - Ripper​
160 Operator's cab, heating and air conditioning
160.1 Operator’s platform​
160.2 Operator's cab​
160.3 Heating, ventilation, air conditioning​
190 Options
190.1 Reversible fan drive​
200 Service codes, diagnosis
200.2 Test and adjustment software​
