Hyundai
86
178,785
Liebherr Crawler Crane HS8100 HD 184884 Operating Manual
Brand: Liebherr
Type of Machine: Crawler Crane
Type of Manual: Operating Manual
Model: Liebherr HS8100 HD Crawler Crane
Serial Number: 184884
Publication Date: 2015
Number of Pages: 936 Pages
1 Product description
1.1 Type plate​
1.2 Declaration of conformity​
1.3 Appropriate use​
1.4 Special modes​
1.5 Inappropriate use​
1.6 Use of machine with load moment limiter and hoist limit switches​
1.7 Load chart in dependence on working equipment​
1.8 Machine​
1.9 Basic machine​
1.10 Information about boom designation​
1.11 Main boom overview​
1.12 Main boom 1311.22​
1.13 Fixed jib - overview​
1.14 Fixed jib 0806​
1.15 Auxiliary jib* (25 t (55,115 lb))​
1.16 Mid-point suspensions​
1.17 Rope fixing point​
1.18 Pulley block/hook*​
1.19 Safety barrier*​
1.20 Armrests* for operator's seat​
1.21 Catwalks*​
1.22 Tagline winch* 3 t (6,614 lb)​
1.23 Refueling pump*​
1.24 Uppercarriage railing​
1.25 External power supply*​
1.26 Radio remote control*​
1.27 Hook fixing point *​
1.28 Heating and air-conditioning system*​
1.29 Obstacle warning light*​
1.30 Auxiliary winch *​
1.31 Cable remote control​
1.32 Leak oil return*​
1.33 Ladder* for uppercarriage​
1.34 Reading light* for cabin​
1.35 Emergency control system*​
1.36 Visual motion warning device*​
1.37 Rope reeving winch* 17.5 kN (3,930 lbf)​
1.38 Falling object protection* for cab​
1.39 Video surveillance system*​
1.40 Central lubrication*​
1.41 Auxiliary floodlights*​
2 Safety instructions
2.1 Technical condition of the machine​
2.2 Areas of responsibility​
2.3 Requirements to personnel​
2.4 Personal protective equipment​
2.5 Work area​
2.6 Danger zone​
2.8 Safety signs on the machine​
2.9 Meaning of the safety signs​
2.10 Meaning of machine-specific signs​
2.11 Hazards​
2.12 What to do in dangerous situations​
2.13 Working at heights​
2.14 Application on floating devices​
2.15 Use at low temperatures​
2.16 Hand signals​
3 Control and operating elements
3.1 Operating elements on the undercarriage​
3.2 Operating elements on the uppercarriage​
3.3 Cabin​
3.4 Left multi-directional control lever​
3.5 Right double T-lever​
3.6 Foot pedals and hand levers​
3.7 Control panel X11​
3.8 Control panel X12​
3.9 Control panel X22​
3.10 Control panel X23​
3.11 Control panel X25​
3.12 Monitor​
3.13 Screen Start​
3.14 Mode screen​
3.15 Aggregate screen​
3.16 Operating hours screen​
3.17 Setup screen​
3.18 Screen Working range limitation​
3.19 Screen Access control​
3.20 Mode screen​
3.21 Settings screen​
3.22 Error messages screen​
3.23 Radio remote control*​
3.24 Emergency control system*​
3.25 Auxiliary heating*​
3.26 Video monitoring system*​
4 Operation
4.1 Checks before start up​
4.2 Start-up​
4.3 Control panels​
4.4 Operator's seat​
4.5 Lighting​
4.6 Windscreen wiper system​
4.7 Ventilation, heating and air-conditioning system*​
4.8 Auxiliary heating*​
4.9 Additional cab equipment​
4.10 Central lubrication*​
4.11 Mode​
4.12 Programming the setup​
4.13 Load moment limiter (LML)​
4.14 Calculating load charts online​
4.15 Set the load capacity display to zero (taring)​
4.16 Crawler​
4.17 Swing​
4.18 Main boom​
4.19 Winch1/winch2​
4.20 Free-fall mode*​
4.21 Winch synchronization*​
4.22 Grab mode*​
4.23 Hammer mode​
4.24 Interlock control​
4.25 Piling control*​
4.26 Vibrator mode*​
4.27 Lowering control​
4.28 Casing oscillator*​
4.29 Working range limitation for main boom and jib​
4.30 Rope reeving winch​
4.31 Tagline winch*​
4.32 Radio remote control*​
4.33 Constant pull winch1 and winch2​
4.34 Filling machine with fuel​
4.35 Inclination display​
4.36 Rope measuring system*​
4.37 Emergency stop​
4.38 Shutdown​
4.39 Emergency control system*​
5 Operational faults, diagnosis
5.1 Malfunctions​
5.2 Litronic testing system​
5.3 Fuses​
6 Operational planning
6.1 Tools required​
6.2 Positioning the hook or pulley block​
6.3 Restrictions due to wind​
6.4 Rigging equipment and/or sling gear​
7 Assembly and dismantling
7.1 Explanation of symbols used​
7.2 Implementation instructions for assembly and disassembly​
7.3 Locking elements - overview​
7.4 Assembling the basic machine​
7.5 Main boom 1313.24​
7.6 Main boom 1311.22​
7.7 Assembling the main boom​
7.8 Fixed jib 0806​
7.9 Assembling the fixed jib​
7.10 Adjusting the track​
7.11 Break-in protection*​
7.12 Assembling the machine without a self-assembly system​
7.13 Disassembling the main boom​
7.14 Disassembling the basic machine​
8 Transport
8.1 Loading the basic machine with an assist crane​
8.2 Transporting the basic machine with crawler side frame with a transport vehicle​
8.3 Transporting the basic machine with crawler side frame with a transport vehicle​
8.4 Transporting the basic machine without crawler side frame with a transport vehicle​
8.5 Transporting the boom sections​
9 Maintenance
9.1 Maintenance and inspection schedule​
9.2 Lubricants and consumables​
9.3 Implementation instructions for the maintenance​
9.4 Air filter system​
9.5 Distribution gearbox​
9.6 Swing​
9.7 Swing connection​
9.8 Winch 1/Winch 2​
9.9 Boom luffing winches​
9.10 Rope reeving winch​
9.11 Tagline winch​
9.12 Crawler​
9.13 Lifting device​
9.14 Hook/pulley block​
9.15 Hydraulic system​
9.16 Hydraulic oil tank​
9.17 Hydraulic oil filter​
9.18 Hydraulic cylinders​
9.19 Bypass filter system​
9.20 Electrical system​
9.21 Batteries​
9.22 Lighting​
9.23 Limit switches​
9.24 Mechanical inclinometer​
9.25 Emergency stop​
9.26 Fire extinguishers​
9.27 Personal protective equipment​
9.28 Safety signs​
9.29 Steel structure​
9.30 Main boom​
9.31 Jib​
9.32 A-frame1​
9.33 Carbon-fibre pendant straps​
9.34 Counterweight​
9.35 Lubrication system​
9.36 Ropes​
9.37 rope drive​
9.38 Rope pulleys​
9.39 Rope suspension and rope fixation​
9.40 Cab​
9.41 Operator`s seat​
9.42 Heating/ventilation/air conditioning/auxiliary heating system​
9.43 Auxiliary heating*​
9.44 Hoses, cables​
9.45 Gab rope guide​
9.46 Vibrator cooling​
9.47 Compressor*​
9.48 Machine care​
