Liebherr Crane LTM1070-1 Service Manual
Language: English, German
Brand: Liebherr
Type of Manual: Service Manual, Technical Information
Model: Liebherr LTM1070-1 Crane
List of Files:
LTM1070-1 016056 -016061 Carrier Service Manual EN.pdf
Summary of components
Technical data
Hydropneumatic Brake System
Circuit diagram
Functional components
Functional diagram - air supply
Functional description - air supply
Functional diagram - service brake system
Functional description - service brake system
Functional diagram - auxiliary consumers
Functional description - auxiliary consumers
Testing and adjusting
Bleeding the hydraulic brake system
Hydraulic Steering System
Circuit diagram
Functional diagram - semi intergral power steering
Functional description - semi intergral power steering
Functional diagram - servostat steering
Functional description - servostat steering
Testing and adjusting ( hydraulic )
Testing and adjusting ( mechanic )
Hydraulic Supperting System and Rear Wheel Steering
Circuit diagram
Functional diagram - supports
Functional description - support
Functional diagram - rear wheel steering
Functional description — rear wheel steering
Hydropneumatic Suspension
Circuit diagram, hydraulic
Functional diagram
Description of suspension programs
Arrangement - proximity switch
Circuit diagram, electric
Functional description, electric (suspension)
Electrical Installation
Circuit diagram - supporting system
Circuit diagram - undercarriage / superstructure
Key to symbols
LTM1070-1 Carrier Service Manual EN.pdf
Comments on crane type L TM 1070
General arrangement - carrier (fig. 1)
Arrangement - power shift gear (fig. 1.1 )
l. brake system
Position of fig. 2 to 2.7
Description, separator with automatic draw-off valve
-on for cranes of series 0-24 u tooo 16 168
Circuit diagram - air supply and brake system sheet I
Summary of components to sheet 1
Circuit diagram -secondary consumers, carrier / sheet 2
Summary of components to sheet 2
Circuit diagram - secondary consumers, carrier - superstructure / sheet 3
Summary of components to sheet 3
- only for cranes from series 25 ( from 16 200 )
Circuit diagram - secondary consumers, carrier / shæt 2
2. Hydraulic power steering
- only for cranes of series 0-24 up to 00 15 168 )
Position of components, fig. 3
Circuit diagram
Summary of components to circuit diagram
-on for cranes from series 25 from 16 200
Position of components, fig. 4
Circuit diagram
3. Hydraulic outriggers / rear axle steering
Position of components, fig. 5
Circuit diagram
Position of components, fig. 6
Circuit diagram
4. Hydropneumatic suspension
System description with basic diagram
Outline of components - hydraulic rams with proximity switches
- only for cranes of series 0-24 ( up to 00 16 168 )
Position of components, fig. 7
Circuit diagram
Outline of operational control, fig. 7.1
Description of axle suspension programs
Description of functional electrical sequence
- only for cranes from series 25 ( from 00 16 200 )
Position of components, fig. 8
Circuit diagram
Outline of operational control, fig. 8.1
5. Electrical system -vehicle
General comments on el. system
Outline, position of relays ( series 0-24 ), fig. 10
Outline, position of relays ( from series 25 ), fig. 11
Outline, printed circuit board — IJI, fig. 12
Outline, printed circuit board — IJ2, fig. 13
Outline, operational instruments, figures 14 / 15 and 16
Description of display and operational control
Circuit diagram 3230-920.09 (series 0-13 / up to 00 16 088 )
Key to symbols for circuit diagram — version 9
Circuit diagram 3230-920.11 ( series 14-24 / 0016 089 - 16 168 )
Circuit diagram 3230-920.14 ( from series 25 / from 00 16 200 )
Key to symbols for circuit diagram - version 11 and 14
LTM1070-1 Carrier UW Service Manual EN.pdf
UW-01 General
UW-02 General drawing
UW-03 Technical description
UW-04 Drive unit/ Diesel engine
UW-05 Cooling sysm,/Ventilator drive
UW-06 Automatic transmission
UW-07 Transfer case/Cardan shafts
UW-08 Axles with add-on components
UW-09 Air and braking system
UW-10 Steering system
UW-11 Outrigger/rear axle steering
UW-12 Axle-suspension system
UW-13 Electric system
UW-14 Additional units
UW-15 Miscellaneous
LTM1070-1 Service Manual DE.pdf
LTM1070-1 Service Manual EN.pdf
Technical data
Superstructure
Removing and installing components
Diesel engine
Summary Of comiXjnents
Removing and installing, engine
Removing and installing, add-on parts
Gear
Summary of
Removing and installing, gear
Transfer box
Summary of coml.»nents
Removing and installing, transfer
Propeller shafts
Summary of
Removing and installing, axles
Steering
Removing and installing, steering
Supports f Suspension
Summary of cormxments
Removing and installing, sliding arms
Removing and installing, supporting rams / outrigger rams
LTM1070-1 Superstructure OW Service Manual EN.pdf
OW-01 General
OW-02 General drawing
OW-03 Technical description
OW-04 Slewing rim
OW-05 Drive unit/Diesel engine
OW-06 Slewinggear/Slew.ieadthrough
OW-07 Hoist gear
OW-08 Luffing gear/Ballasting
OW-09 Crane hydraulics
0W-1O Crane electrics / LMB
OW-11 Pneumatic system
OW-12 Telescopic boom electric
OW-13 Telescopic boom/Telematik
OW-14 Centralized lubrication
OW-15 Liccon test system
OW-16 Additional units
OW-17 Miscellaneous
LTM1070-1 Superstructure Service Manual EN.pdf
General arrangement - superstructure (fig. 1 )
Position of components ( photographs for summary ) fig. 2 to 14
Crane hydraulics, general
Functional diagram - example ( hoist gear )
Comments on crane operation
Crane hydraulics for cranes from series 0-29.1 ( up to 00 16 219 )
Circuit diagram - complete ( with hoist gear ( HG ) II 3332-970.2.1 (23)
Crane hydraulics at I-winch version
Arrangement — stand
Diagram - supply and pilot control I sheet 1
Functional outline to sheet 1
Diagram - hoist gear I I sheet 2
Functional outline to sheet 2
Diagram - luffing gear I sheet 3
Functional outline to sheet 3
Diagram - telescnping gear I sheet 4
Functional outline to sheet 4
Diagram - slewing gear / sheet 5
Functional outline to sheet 5
Diagram - ballasting ( interlocking device — superstructure ) / sheet 6
Functional outline to sheet 6
Crane hydraulics at 2-winch version
Arrangement - stand
Diagram - hoist gear I at winch selector switch pos. I or II/ sheet 2
Diagram - hoist gear II at winch selector switch position II / sheet 3
Diagram - hoist gear II at winch selector switch Ill / sheet 4
Diagram - luffing gear at winch selector switch I or Ill shæt 5
Diagram - telescopic gear at winch selector switch pos. I or Ill / sheet 6
Diagram - slewing gear / sheet 7
Functional outline to sheet 7
Diagram - ballasting ( interlocking device —superstructure ) / sheet 8
Functional outline to sheet 8
Crane hydraulics for cranes from series 29.2 from m16220
Circuit diagram - complete ( with hoist gear II ) 3332-970.25
Arrangement — stand
Diagram - supply and pilot control / sheet 1
Diagram - hoist gear I / sheet 2
Diagram - telescoping gear I sheet 4
Diagram - ballasting / sheet 6
Arrangement - operator's stand
Functional outline to sheet I
Diagram - hoist gear I at winch selector switch pos. I or II / sheet 2
Diagram - hoist gear II at winch selector switch position Ill I sheet 4
Diagram - luffing gear at winch selector switch pose I or III / sheet 5
Diagram - telescopic gear at winch selector switch pos. I or III / sheet 6
Diagram- ballasting I sheet 8
Crane electric for cranes of series O to 13 u to 00 16 088
Circuit diagram - crane control with 1 hoist gear
Circuit diagram - crane control with 2 hoist gears
Circuit diagram - electrics, superstructure
Key to for circuit diagram
Crane electric for cranes from series 14 ( from 00 16 089 )
Circuit diagram ( with Liccon ) — version for hoist gear I + II
Key to
Summary of subassemblies
Plan of terminals
Arrangement — input board and fuses
Arrangement — switch cabinet
LTM1070-1 Technical Information DE FR.pdf
Brand: Liebherr
List of Files:
Technical data
Circuit diagram
Circuit diagram
Circuit diagram
Functional diagram
Key to symbols
l. brake system
Circuit diagram
Circuit diagram
Circuit diagram
Circuit diagram
Circuit diagram
Circuit diagram
UW-01 General
UW-15 Miscellaneous
Technical data
Superstructure
Diesel engine
Gear
Summary of
Transfer box
Propeller shafts
Summary of
Steering
OW-01 General
OW-04 Slewing rim
OW-07 Hoist gear
OW-17 Miscellaneous
Arrangement — stand
Arrangement - stand
Arrangement — stand
Key to
Plan of terminals
- Liebherr Mobile Crane LTM 1080-1 Liccon Error Code
- Liebherr LTM-1090-4.1 Liccon Error Code
- Liebherr Mobile Crane LTM1090-2 Hydraulic Schematic
- Liebherr Mobile Crane LTM 1050-1 Service Manual
- Liebherr Mobile Crane LTM1200-5.1 Wiring Diagram
- Liebherr Mobile Crane LTM 1090-4.1,1100-4.1,1080-2 Wiring Diagram
- Liebherr LTM 1040-2.1 Service Manual
- Liebherr cranes service manuals
- Liebherr Data Bus and Liccon Computer System Technical Training
- Liebherr Crane LTM 1030-2 Service Manual Hydraulic
- Liebherr Mobile Crane LTM 1050 Diagrams Electrical
- Liebherr Mobile Crane LTM 1090-4.1 Hydraulic Schematic
- Liebherr LTM 1030-2 Service Manual Pneumatic
- Liebherr Mobile Crane LTM 1070-4.1 Spare Parts Catalogue
- Liebherr Mobile Crane LTM 1030-2.1 Wiring Diagram
